root@turris:~# pkgupdate -e DBG
DEBUG:src/lib/events.c:586 (run_util_init):Dumping busybox to: /tmp/updater-busybox-dMPkCD/busybox
DEBUG:src/lib/locks.c:45 (lua_acquire):Trying to get a lock at /var/lock/opkg.lock
DEBUG:backend.lua:358 (status_parse):Parsing status file /usr/lib/opkg/status
DEBUG:src/lib/interpreter.c:323 (lua_run_generic):Command: /usr/bin/atsha204cmd serial-number
DEBUG:requests.lua:441 (func):Running script file:////etc/updater/conf.d/base.lua
DEBUG:requests.lua:441 (func):Running script https://repo.turris.cz/omnia/lists/base.lua
DEBUG:src/lib/events.c:823 (download):Downloading https://repo.turris.cz/omnia/lists/base.lua.sig
DEBUG:src/lib/events.c:727 (download_check_info):Download failed, trying again 1 (https://repo.turris.cz/omnia/lists/base.lua.sig): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/events.c:727 (download_check_info):Download failed, trying again 1 (https://repo.turris.cz/omnia/lists/base.lua): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/events.c:727 (download_check_info):Download failed, trying again 2 (https://repo.turris.cz/omnia/lists/base.lua.sig): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/events.c:727 (download_check_info):Download failed, trying again 2 (https://repo.turris.cz/omnia/lists/base.lua): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/events.c:735 (download_check_info):Download failed (https://repo.turris.cz/omnia/lists/base.lua.sig): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/events.c:735 (download_check_info):Download failed (https://repo.turris.cz/omnia/lists/base.lua): Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
line not found
line not found
line not found
ERROR:src/pkgupdate/main.c:255 (main):
unreachable: https://repo.turris.cz/omnia/lists/base.lua: Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
DEBUG:src/lib/locks.c:82 (lua_lock_release):Released lock at /var/lock/opkg.lock
DEBUG:src/lib/events.c:604 (run_util_clean):Removing temporally busybox from: /tmp/updater-busybox-dMPkCD/busybox
root@turris:~#
