When I try running pkgupdate in the command line, I get:
root@turris:~# pkgupdate line not found line not found line not found ERROR: unreachable: https://repo.turris.cz/omnia/lists/base.lua: Operation timed out after 30000 milliseconds with 0 out of 0 bytes received line not found line not found line not found ERROR: unreachable: https://repo.turris.cz/omnia/lists/base.lua: Operation timed out after 30000 milliseconds with 0 out of 0 bytes received root@turris:~#
The last few lines in /usr/share/updater/updater-log:
what turris version do you have currently? Check it by: cat /etc/turris-version
I have: 3.11.3, but I am on RC channel and this is the latest, but It think it has just been released to stable as well.
You got simple timeout message, so the reason is that you cannot reach the repo server. If it was just down at the very moment you tried, it should just work now.
Can you ping the ping repo.turris.cz host? If you cannot you have some network issue.
Check if you can resolve the hostname, if you can reach any other host beyond this?
it is interesting and you say you can really ping repo.turris.cz from your router? Are you sure you did that from your router and not from your machine?
You can install wget, if you dont have it yet. opkg install wget
you can also try both commands thereafter:
i run the wget from the router itself. Could it have to do with ipv6 vs ipv4 host resolving? maybe wget did fallback on ipv4 after ipv6 timed out and the updater does not do so?
(just an idea, because wget took so long)
apparently the ipv6 of the host repo.turris.cz is not reachable from my host.
ipv4 fails also, but possibly because of webserver configuration when i try to access using the ip:
wget http://217.31.192.69/omnia/lists/base.lua
–2019-03-31 22:29:22-- http://217.31.192.69/omnia/lists/base.lua
Connecting to 217.31.192.69:80… connected.
HTTP request sent, awaiting response… 404 Not Found
2019-03-31 22:29:22 ERROR 404: Not Found.
