JFYI, in france the provider named “free” is going all ipv6 soon. So maybe, handling this can be good for some french users.
No, this is not a Turris problem. This is an ISP problem. As long as Free.fr and all the transit providers between them and Turris.cz are working properly, going all IPv6 will not be an issue.
In my case, it’s because the AT&T DHCPv6 server distributes an address to the router (IA_NA) from a different address pool than the delegated prefix (IA_PD) for the local network (2001:506:6000::/35
vs 2600:1700::/28
). The packets from the IA_NA address are able to reach American servers, but they’re filtered out at AT&T’s interfaces to the rest of the world.
When I was experiencing this issue back in April, I fixed it by changing my DNS provider in Turris, however the same problem has come back again. I am on AT&T (Los Angeles, CA) and have tried all 5 DNS forwarding options and the updater fails on all 5 options. Tired disabling DNS forwarding and DNSSEC and updater still fails. Not sure what I can do at this point?
I am at a loss on how to fix this now.
Had the same issue here in france with the free isp
Hi. Just installed a brand new Omnia. All works, but after I setup ipv6 tunnel from HE, I got this error
root@turris:~# wget https://repo.turris.cz/omnia/lists/base.lua
--2019-06-09 20:21:18-- https://repo.turris.cz/omnia/lists/base.lua
Resolving repo.turris.cz... 2001:1488:ac15:ff80::69, 217.31.192.69
Connecting to repo.turris.cz|2001:1488:ac15:ff80::69|:443... failed: Operation timed out.
Connecting to repo.turris.cz|217.31.192.69|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 9237 (9.0K)
Saving to: 'base.lua'
base.lua 100%[================================================================================================================>] 9.02K --.-KB/s in 0s
2019-06-09 20:23:25 (118 MB/s) - 'base.lua' saved [9237/9237]
It worked correctly on my old Turris 1.1.
I’ve switched off dns forwarding - no change. Any Idea? Is it my ISP or HE issue?
root@RTCN:~# wget https://repo.turris.cz/omnia/lists/base.lua
Resolving repo.turris.cz… 2001:1488:ac15:ff80::69, 217.31.192.69
Connecting to repo.turris.cz|2001:1488:ac15:ff80::69|:443… failed: Operation timed out.
Connecting to repo.turris.cz|217.31.192.69|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 9237 (9.0K)
Saving to: ‘base.lua’
base.lua 100%[==================================================================================>] 9.02K --.-KB/s in 0s
2019-06-09 21:07:26 (111 MB/s) - ‘base.lua’ saved [9237/9237]
root@RTCN:~# pkgupdate
line not found
line not found
line not found
ERROR:
unreachable: https://repo.turris.cz/omnia/lists/base.lua: Operation timed out after 30000 milliseconds with 0 out of 0 bytes received
Without IPV6
Package list
|nstall |luci-i18n-ddns-ca |2.4.8-1 |1681 |Translation for luci-app-ddns - Català (Catalan)|
|Install |luci-i18n-ddns-cs |2.4.8-1 |1712 |Translation for luci-app-ddns - Čeština (Czech)|
|Install |luci-i18n-ddns-de |2.4.8-1 |8071 |Translation for luci-app-ddns - Deutsch (German)|
|Install |luci-i18n-ddns-el |2.4.8-1 |1831 |Translation for luci-app-ddns - Ελληνικά (Greek)|
|Install |luci-i18n-ddns-es |2.4.8-1 |1684 |Translation for luci-app-ddns - Español (Spanish)|
|Install |luci-i18n-ddns-fr |2.4.8-1 |1663 |Translation for luci-app-ddns - Français (French)|
|Install |luci-i18n-ddns-he |2.4.8-1 |1725 |Translation for luci-app-ddns - עִבְרִית (Hebrew)|
|Install |luci-i18n-ddns-hu |2.4.8-1 |1709 |Translation for luci-app-ddns - Magyar (Hungarian)|
Well, from various posts on the forum over time, I think pkgupdate
doesn’t work well when you have IPv6 that appears OK (in some way) but doesn’t really work.
Well. One thing is a workaround - switch to ipv4.
Second thing is this ipv6 issue. I’m not expert on network, so I have no idea, how to analyze the problem.
@xba are you using native ipv6 or tunnel?
Hmm, have you tried the WAN connection test button in Foris? (Though I can not say I’m really good at debugging these.)
Try “okpg update” beforehand
Thanks for hint. I’ll test it after my return from business trip. Unfortunately, I’ve some troubles with VPN as well, so can’t test it remotely.
works on this node with native ipv6 via dhcp pd and ipv4 via ds-lite.
Connecting to repo.turris.cz|2001:1488:ac15:ff80::69|:443… connected.
Length: 9237 (9.0K)
However, this one does not work wget https://raw.githubusercontent.com/stangri/openwrt-repo/master/Packages.gz
and stops/hangs
Resolving raw.githubusercontent.com… 64:ff9b::9765:2485, 151.101.36.133
Connecting to raw.githubusercontent.com|64:ff9b::9765:2485|:443… failed: Operation timed out.
Connecting to raw.githubusercontent.com|151.101.36.133|:443… connected.
Unable to establish SSL connection.
Turning off ipv6 solves the matter and for my part I am convinced thus being a routing issue with ipv6 somehow, though not clear whether it is caused by the ISP’s ipv6 routing or the TO.
Another indication seems that with ipv6 via dhcp pd and ipv4 via ds-lite enabled android apps that support only ipv4 connectivity fail to connect as well.
It is difficult to debug since the traceoute
package is castrate of -T
and tcptraceroute
not available in the repo.
Usually routing issues are on IP level already, in which case it shouldn’t be significant which method you use (UDP is default IIRC). Otherwise I was testing such stuff from some other machine behind Omnia, or one could surely use a container on Omnia, too.
I am wondering whether this potentially caused by openssl
and/or netifd
because the result on the TO differs from one of its client
On the TO
Whilst on the TO client
Resolving raw.githubusercontent.com (raw.githubusercontent.com)… 64:ff9b::9765:c85, 151.101.36.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|64:ff9b::9765:c85|:443… failed: Connection timed out.
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.36.133|:443… connected.
Length: 3241 (3.2K) [application/octet-stream]
So far i did not face this issue at all, this week it occurs twice. After remote-restart, all fine. Aside “backup” service was complaining as well. Updater was complaining also. So from my point of view, just some “network” glitch. Is there something i can “check/change” ?
coincided with Outage of some of our services ?
very possibly , yes … thanks for link
I know this will not solve the issue of the OP, respectively the thread’s topic but I thought to share at least my findings.
For my case the culprit is vpn-policy-routing
. Having enabled the connectivity issue with raw.githubusercontent.com is present, disabling it the issue is not present.
It seems that that package introduces some NAT64 behaviour by embedding ipv4 addresses into ipv6 addresses.
Since yesterday I have the same issue:
pkgupdate
line not found
line not found
line not found
ERROR:
Turris OS Version 3.11.4
Kernelversion 4.4.178-7bc33afbb1b35f5830b2b1b42c9cd8a0-0
