For someone can be easier to buy something like TINYCONTROL TP29 Chytrá Wi-Fi zásuvka s měřením energie, TASMOTA - SUNTECH Computer , upload esphome.io firmware and write some script switching relay off and on
Yes on HBL reboots works, but I assume, we have test reboot also after some longer uptime…
It works consistently for me for several weeks, with reboots every 2-5 days.
Nice fun project. I got all parts and tools here. I can 3D-print the enclose. What about the script? Do you have an example script?
@pepe, can you confirm it with your internal tests?
Let me say what our politics like to say: "I can not confirm it or deny it, " but what works on one unit does not mean it will work on others. We don’t have simply sufficient data to confirm if the behavior is somehow improved. On the other hand, the kernel version is not so often updated in OpenWrt 21.02, but that will change.
No sorry, no ready to use script.
But a search for script trigger when leaving runleve 3 or similar would get you started.
And perhaps a hw timer to flip back the relay, 555?
Cool with a enclosure.
Looking forward tto a New topic in the mox hw tweaks where we can follow your work
Thanks anyway for the answer. When TOS 6 is in HBK, I’ll update my MOXes.
Hi, for my Mox worked fine workaround reboot-issue-workaround-v4 · Turris / MOX boot-builder · GitLab
https://www.profiservis.info/wp-content/uploads/2022/02/mox-1024x553.png
How many TOS updates with restart has successful?
Tryied 3 times. All worked fine after reboot command.
The problem is workaround v4 does not work for everyone.
Last week mine hanged during update to 5.4.1 - exactly when I left for vacation, so was 1 week without my nextcloud sync. So - no, 5.3.10 didn’t seem to fix that.
Do you have Turris MOX?
yes, mox hbk. never had such problems with my omnia though.
MOX have long time unresolved reboot issue. Try workaround (for me problem persist) and/or TOS 6 (HBL).
If by workaround you mean modified uboot/atf - tried that with no changes. I was on HBL but switched to HBK as it updates with less frequency hence is available for longer period. I.e. hbl I find hanging every now and then while with hbk I have at least a month span but ok i got that this thread is about software bug, was just mis-directed here from some closed mox reboot hang topic, sorry for that.
Then I recommend contacting support. They will try to work with you to find a mutually acceptable solution.
HBL - Turris OS 6 and the latest workaround work for me.
