The Turris MOX does not keep time when mains power is removed despite having an RTC battery. The time is always reset to 2001-01-01. What is the purpose of the battery then?
Edit 5 years later:
Turns out my Turris MOX has no RTC battery inside it, which explains the behavior Turris MOX, no RTC battery?
I believe RTC is exactly the purpose of the battery and thus something is wrong in your particular case, but I’m personally not confident about these HW details.
