I try t get an small Kingston 30GB SMS200S3 mSATA ssd to work
in my omina route. Used the free slot above the sim adapter but the
there is no new partition shown in /proc/partitions also nothing shows
up in dmesg. Do I have to use one of the other two slots currently
occupied by the wlan moduls?
All the ahci modules are loading. Compared dmesg output with and without the ssd installed and there is no difference. Ordered an USB3 adapter for the mSATA to verify the ssd is working. Will post results here.
I think it is the wrong slot. mSATA should be the slot at the cpu. Schematic says CN7A and the one with the SIM is labelled CN62 on the pictures and in the schematic.
Good catch, it works in that slot. Abit laborious because thats where the small wifi card is mounted and there are screws at the backside of the board so the mainboard must be dismantled. Due to the cable lents between cards and antennas the small card must move to the outher lost above the sim card adapter.
Seeing an sda device now and three wireless networks. Thank you for the tip the labels on the mainboard are barely readable with an magnifier.
achim71 & adminX: thank you very much for posting this important information. I plan to use a mSATA card as NAS (Samsung SSD 850EVO 1TB) too.
Does this dual-purpose slot auto-detect whether there is an mPCIe or mSATA card inserted? Or must it be configured in some config file of the OS.
Does the OS auto-detect when the 2.4GHz wifi card get’s moved to the mCPIe slot above the SIM card adapter?
Also, could you briefly describe the steps, how to get the mSATA drive working after it is detected. The Turris documentation regarding NAS installation is not yet translated to English.
Dual-purpose slot should detect mPCIe/mSATA and OS will detect your card at new slot. But it probably will not recognize it as a same card, so you will have to redo all the configuration. Or modify the existing one to point to the right card.
Does that mean that one would have to replace the WiFi cards in order to place an mSATA?
I’m getting a bit nervous that I have bought a device that I will break in 2 weeks…
(I’m a software guy, hardware tweaks scare me…).
P.S. This guy is fixing his laptop as I would (not really, I’m prolly above average with hardware… but it still scares me, as it takes time that I do not have…):
The small wifi card must be moved from the slot next to the cpu to the outer slot. Because it is an short card a few holdings must be adjusted. Abit more effort than to put the msata card in the free slot but it’s just a dozend screws, not difficult.
Yeah, quite disappointed…this should have been mentioned somewhere among provided documentation. Or even better, the wifi cards should have been placed at rights slots right away. Would save me a solid 45 minutes of disassembling, assembling, trying, and repeating
After placing the mSata (Crucial MX200 250GB) to the 3rd slot (next to the CPU), the disk recognized as /dev/sda according to dmesg.
Well, there is no right position. The setup router comes with suits good for the installation of LTE expansion pack. It’s actually good that the mSATA slot is not shared with the SIM slot so one can use SSD and LTE modem at the same time.
could you share what exactly is needed to modify? I assume only name of the device?.. It isnt mentioned on video tutorial (HW part looks easy enough).
If you don’t mind losing your wireless config, the simplest method is to remove /etc/config/wireless and run wifi detect > /etc/config/wireless (or reboot the router), then re-configure the WiFi again. Alternatively you can just change the wireless.radioN.path for the wireless cards. There are multiple ways how to get the paths, I prefer renaming the wireless config and running wifi detect, then renaming the config back and adjusting the paths.
Well, just pay attention to the physical pcie address and adjust the other attributes accordingly.
My config follows (wifi names/passwords anonymized )
I wish the video had mentioned the need to manually update the PCIe addresses. I had my router apart a couple of times shuffling cards back and forth trying to figure out why I lost 2.4 GHz Wifi after installing an mSATA drive.
