root@omnia:~# ls -lh /tmp/kresd/data.mdb
-rw-r----- 1 kresd kresd 2.0M Jul 30 19:17 /tmp/kresd/data.mdb
Ram usage still increasing, now kresd uses 551 MB.
Here is the log:
Jul 8 10:36:10 omnia kresd[26398]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 10:37:03 omnia kresd[27014]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 10:37:04 omnia kresd[27151]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 10:37:13 omnia kresd[28987]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 10:37:34 omnia kresd[29339]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 10:37:42 omnia kresd[29339]: [timesk] cannot resolve '.' NS
Jul 8 10:37:51 omnia kresd[29339]: [taupd ] active refresh failed for . with rcode: 2
Jul 8 10:37:51 omnia kresd[29699]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:08:50 omnia kresd[10721]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:26:49 omnia kresd[16497]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:26:50 omnia kresd[16642]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:27:16 omnia kresd[17755]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:32:33 omnia kresd[19810]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 13:32:34 omnia kresd[19810]: [cache ] Warning: real cache size is 104857600 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 14:46:50 omnia kresd[9279]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 14:46:50 omnia kresd[9279]: [cache ] Warning: real cache size is 104857600 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:00:53 omnia kresd[20982]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:00:54 omnia kresd[20982]: [cache ] Warning: real cache size is 104857600 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:05:15 omnia kresd[22428]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:16 omnia kresd[22428]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:05:21 omnia kresd[22503]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:21 omnia kresd[22503]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:05:26 omnia kresd[22525]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:26 omnia kresd[22525]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:05:31 omnia kresd[22547]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:31 omnia kresd[22547]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:05:36 omnia kresd[22567]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:36 omnia kresd[22567]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:05:41 omnia kresd[22589]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:05:41 omnia kresd[22589]: [system] error while loading config: /tmp/kresd.config:30: unexpected symbol near '#' (workdir '/tmp/kresd')
Jul 8 21:06:04 omnia kresd[22826]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:06:04 omnia kresd[22826]: [cache ] Warning: real cache size is 104857600 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:09:24 omnia kresd[24005]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:09:25 omnia kresd[24005]: [cache ] Warning: real cache size is 104857600 instead of the requested 10485760 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:18:05 omnia kresd[26662]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:18:05 omnia kresd[26662]: [cache ] Warning: real cache size is 104857600 instead of the requested 10485760 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:26:13 omnia kresd[29149]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:26:13 omnia kresd[29149]: [cache ] Warning: real cache size is 104857600 instead of the requested 10485760 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:27:01 omnia kresd[29594]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:27:01 omnia kresd[29594]: [cache ] Warning: real cache size is 104857600 instead of the requested 5242880 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:35:59 omnia kresd[32301]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:35:59 omnia kresd[32301]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:36:04 omnia kresd[32371]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:36:04 omnia kresd[32371]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:36:09 omnia kresd[32392]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:36:09 omnia kresd[32392]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:36:14 omnia kresd[32414]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:36:14 omnia kresd[32414]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:36:19 omnia kresd[32434]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:36:19 omnia kresd[32434]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:36:24 omnia kresd[32498]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:36:24 omnia kresd[32498]: [system] error while loading config: /tmp/kresd.config:29: '=' expected near '-' (workdir '/tmp/kresd')
Jul 8 21:38:45 omnia kresd[865]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:38:45 omnia kresd[865]: [cache ] Warning: real cache size is 104857600 instead of the requested 5242880 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 8 21:42:12 omnia kresd[2032]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 8 21:42:12 omnia kresd[2032]: [cache ] Warning: real cache size is 104857600 instead of the requested 2097152 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 9 07:41:15 omnia kresd[8751]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 9 07:41:15 omnia kresd[8751]: [cache ] Warning: real cache size is 104857600 instead of the requested 2097152 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 9 08:54:29 omnia kresd[32169]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 9 08:54:29 omnia kresd[32169]: [cache ] Warning: real cache size is 104857600 instead of the requested 2097152 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 9 09:35:50 omnia kresd[11611]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 9 09:36:34 omnia kresd[12002]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 16 12:26:53 omnia kresd[12002]: [hint ] [ ]/tmp/dhcp.leases.dynamic:30: invalid syntax
Jul 17 16:56:34 omnia kresd[12002]: [hint ] [ ]/tmp/dhcp.leases.dynamic:30: invalid syntax
Jul 24 07:59:53 omnia kresd[12002]: [hint ] [ ]/tmp/dhcp.leases.dynamic:30: invalid syntax
Jul 28 13:58:10 omnia kresd[12002]: [hint ] [ ]/tmp/dhcp.leases.dynamic:29: invalid syntax
Jul 29 17:58:24 omnia kresd[1749]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:24 omnia kresd[1749]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:24 omnia kresd[1749]: stack traceback:
Jul 29 17:58:24 omnia kresd[1749]: [C]: in function 'open'
Jul 29 17:58:24 omnia kresd[1749]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:24 omnia kresd[1749]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:58:29 omnia kresd[1822]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:29 omnia kresd[1822]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:29 omnia kresd[1822]: stack traceback:
Jul 29 17:58:29 omnia kresd[1822]: [C]: in function 'open'
Jul 29 17:58:29 omnia kresd[1822]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:29 omnia kresd[1822]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:58:34 omnia kresd[1855]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:34 omnia kresd[1855]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:34 omnia kresd[1855]: stack traceback:
Jul 29 17:58:34 omnia kresd[1855]: [C]: in function 'open'
Jul 29 17:58:34 omnia kresd[1855]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:34 omnia kresd[1855]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:58:39 omnia kresd[1880]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:39 omnia kresd[1880]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:39 omnia kresd[1880]: stack traceback:
Jul 29 17:58:39 omnia kresd[1880]: [C]: in function 'open'
Jul 29 17:58:39 omnia kresd[1880]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:39 omnia kresd[1880]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:58:44 omnia kresd[1897]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:44 omnia kresd[1897]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:44 omnia kresd[1897]: stack traceback:
Jul 29 17:58:44 omnia kresd[1897]: [C]: in function 'open'
Jul 29 17:58:44 omnia kresd[1897]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:44 omnia kresd[1897]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:58:49 omnia kresd[1923]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:58:49 omnia kresd[1923]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:58:49 omnia kresd[1923]: stack traceback:
Jul 29 17:58:49 omnia kresd[1923]: [C]: in function 'open'
Jul 29 17:58:49 omnia kresd[1923]: /tmp/kresd.config:17: in main chunk
Jul 29 17:58:49 omnia kresd[1923]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:59:44 omnia kresd[2319]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:59:44 omnia kresd[2319]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:59:44 omnia kresd[2319]: stack traceback:
Jul 29 17:59:44 omnia kresd[2319]: [C]: in function 'open'
Jul 29 17:59:44 omnia kresd[2319]: /tmp/kresd.config:17: in main chunk
Jul 29 17:59:44 omnia kresd[2319]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:59:49 omnia kresd[2388]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:59:49 omnia kresd[2388]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:59:49 omnia kresd[2388]: stack traceback:
Jul 29 17:59:49 omnia kresd[2388]: [C]: in function 'open'
Jul 29 17:59:49 omnia kresd[2388]: /tmp/kresd.config:17: in main chunk
Jul 29 17:59:49 omnia kresd[2388]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:59:54 omnia kresd[2410]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:59:54 omnia kresd[2410]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:59:54 omnia kresd[2410]: stack traceback:
Jul 29 17:59:54 omnia kresd[2410]: [C]: in function 'open'
Jul 29 17:59:54 omnia kresd[2410]: /tmp/kresd.config:17: in main chunk
Jul 29 17:59:54 omnia kresd[2410]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 17:59:59 omnia kresd[2430]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 17:59:59 omnia kresd[2430]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 17:59:59 omnia kresd[2430]: stack traceback:
Jul 29 17:59:59 omnia kresd[2430]: [C]: in function 'open'
Jul 29 17:59:59 omnia kresd[2430]: /tmp/kresd.config:17: in main chunk
Jul 29 17:59:59 omnia kresd[2430]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 18:00:04 omnia kresd[2508]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 18:00:04 omnia kresd[2508]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 18:00:04 omnia kresd[2508]: stack traceback:
Jul 29 18:00:04 omnia kresd[2508]: [C]: in function 'open'
Jul 29 18:00:04 omnia kresd[2508]: /tmp/kresd.config:17: in main chunk
Jul 29 18:00:04 omnia kresd[2508]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 18:00:09 omnia kresd[2529]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 18:00:09 omnia kresd[2529]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 18:00:09 omnia kresd[2529]: stack traceback:
Jul 29 18:00:09 omnia kresd[2529]: [C]: in function 'open'
Jul 29 18:00:09 omnia kresd[2529]: /tmp/kresd.config:17: in main chunk
Jul 29 18:00:09 omnia kresd[2529]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 18:00:13 omnia kresd[2731]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 18:00:13 omnia kresd[2731]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:58:41 omnia kresd[21729]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:58:41 omnia kresd[21729]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:58:41 omnia kresd[21729]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:58:41 omnia kresd[21729]: stack traceback:
Jul 29 20:58:41 omnia kresd[21729]: [C]: in function 'max_ttl'
Jul 29 20:58:41 omnia kresd[21729]: /tmp/kresd.config:28: in main chunk
Jul 29 20:58:41 omnia kresd[21729]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:58:46 omnia kresd[21799]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:58:46 omnia kresd[21799]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:58:46 omnia kresd[21799]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:58:46 omnia kresd[21799]: stack traceback:
Jul 29 20:58:46 omnia kresd[21799]: [C]: in function 'max_ttl'
Jul 29 20:58:46 omnia kresd[21799]: /tmp/kresd.config:28: in main chunk
Jul 29 20:58:46 omnia kresd[21799]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:58:51 omnia kresd[21819]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:58:51 omnia kresd[21819]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:58:51 omnia kresd[21819]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:58:51 omnia kresd[21819]: stack traceback:
Jul 29 20:58:51 omnia kresd[21819]: [C]: in function 'max_ttl'
Jul 29 20:58:51 omnia kresd[21819]: /tmp/kresd.config:28: in main chunk
Jul 29 20:58:51 omnia kresd[21819]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:58:56 omnia kresd[21842]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:58:56 omnia kresd[21842]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:58:56 omnia kresd[21842]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:58:56 omnia kresd[21842]: stack traceback:
Jul 29 20:58:56 omnia kresd[21842]: [C]: in function 'max_ttl'
Jul 29 20:58:56 omnia kresd[21842]: /tmp/kresd.config:28: in main chunk
Jul 29 20:58:56 omnia kresd[21842]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:59:02 omnia kresd[21862]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:59:02 omnia kresd[21862]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:59:02 omnia kresd[21862]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:59:02 omnia kresd[21862]: stack traceback:
Jul 29 20:59:02 omnia kresd[21862]: [C]: in function 'max_ttl'
Jul 29 20:59:02 omnia kresd[21862]: /tmp/kresd.config:28: in main chunk
Jul 29 20:59:02 omnia kresd[21862]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:59:07 omnia kresd[21884]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:59:07 omnia kresd[21884]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 20:59:07 omnia kresd[21884]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 20:59:07 omnia kresd[21884]: stack traceback:
Jul 29 20:59:07 omnia kresd[21884]: [C]: in function 'max_ttl'
Jul 29 20:59:07 omnia kresd[21884]: /tmp/kresd.config:28: in main chunk
Jul 29 20:59:07 omnia kresd[21884]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 20:59:19 omnia kresd[22131]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 20:59:19 omnia kresd[22131]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:22:55 omnia kresd[22131]: [contrl] > e[A
Jul 29 21:22:55 omnia kresd[22131]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: (binary): cannot load incompatible bytecode
Jul 29 21:22:59 omnia kresd[22131]: [contrl] > e[A
Jul 29 21:22:59 omnia kresd[22131]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: (binary): cannot load incompatible bytecode
Jul 29 21:25:13 omnia kresd[29593]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:25:13 omnia kresd[29593]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:04 omnia kresd[30012]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:04 omnia kresd[30012]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:33 omnia kresd[30340]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:33 omnia kresd[30340]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:33 omnia kresd[30340]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:33 omnia kresd[30340]: stack traceback:
Jul 29 21:26:33 omnia kresd[30340]: [C]: in function 'max_ttl'
Jul 29 21:26:33 omnia kresd[30340]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:33 omnia kresd[30340]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:26:38 omnia kresd[30389]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:38 omnia kresd[30389]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:38 omnia kresd[30389]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:38 omnia kresd[30389]: stack traceback:
Jul 29 21:26:38 omnia kresd[30389]: [C]: in function 'max_ttl'
Jul 29 21:26:38 omnia kresd[30389]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:38 omnia kresd[30389]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:26:43 omnia kresd[30416]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:43 omnia kresd[30416]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:43 omnia kresd[30416]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:43 omnia kresd[30416]: stack traceback:
Jul 29 21:26:43 omnia kresd[30416]: [C]: in function 'max_ttl'
Jul 29 21:26:43 omnia kresd[30416]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:43 omnia kresd[30416]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:26:48 omnia kresd[30433]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:48 omnia kresd[30433]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:48 omnia kresd[30433]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:48 omnia kresd[30433]: stack traceback:
Jul 29 21:26:48 omnia kresd[30433]: [C]: in function 'max_ttl'
Jul 29 21:26:48 omnia kresd[30433]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:48 omnia kresd[30433]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:26:52 omnia kresd[30592]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:52 omnia kresd[30592]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:52 omnia kresd[30592]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:52 omnia kresd[30592]: stack traceback:
Jul 29 21:26:52 omnia kresd[30592]: [C]: in function 'max_ttl'
Jul 29 21:26:52 omnia kresd[30592]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:52 omnia kresd[30592]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:26:57 omnia kresd[30667]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:26:57 omnia kresd[30667]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:26:57 omnia kresd[30667]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:26:57 omnia kresd[30667]: stack traceback:
Jul 29 21:26:57 omnia kresd[30667]: [C]: in function 'max_ttl'
Jul 29 21:26:57 omnia kresd[30667]: /tmp/kresd.config:28: in main chunk
Jul 29 21:26:57 omnia kresd[30667]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:02 omnia kresd[30706]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:02 omnia kresd[30706]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:02 omnia kresd[30706]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:02 omnia kresd[30706]: stack traceback:
Jul 29 21:27:02 omnia kresd[30706]: [C]: in function 'max_ttl'
Jul 29 21:27:02 omnia kresd[30706]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:02 omnia kresd[30706]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:07 omnia kresd[30732]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:07 omnia kresd[30732]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:07 omnia kresd[30732]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:07 omnia kresd[30732]: stack traceback:
Jul 29 21:27:07 omnia kresd[30732]: [C]: in function 'max_ttl'
Jul 29 21:27:07 omnia kresd[30732]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:07 omnia kresd[30732]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:08 omnia kresd[30875]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:08 omnia kresd[30875]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:08 omnia kresd[30875]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:08 omnia kresd[30875]: stack traceback:
Jul 29 21:27:08 omnia kresd[30875]: [C]: in function 'max_ttl'
Jul 29 21:27:08 omnia kresd[30875]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:08 omnia kresd[30875]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:13 omnia kresd[30991]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:13 omnia kresd[30991]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:13 omnia kresd[30991]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:13 omnia kresd[30991]: stack traceback:
Jul 29 21:27:13 omnia kresd[30991]: [C]: in function 'max_ttl'
Jul 29 21:27:13 omnia kresd[30991]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:13 omnia kresd[30991]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:18 omnia kresd[31010]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:18 omnia kresd[31010]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:18 omnia kresd[31010]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:18 omnia kresd[31010]: stack traceback:
Jul 29 21:27:18 omnia kresd[31010]: [C]: in function 'max_ttl'
Jul 29 21:27:18 omnia kresd[31010]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:18 omnia kresd[31010]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:23 omnia kresd[31035]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:23 omnia kresd[31035]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:23 omnia kresd[31035]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:23 omnia kresd[31035]: stack traceback:
Jul 29 21:27:23 omnia kresd[31035]: [C]: in function 'max_ttl'
Jul 29 21:27:23 omnia kresd[31035]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:23 omnia kresd[31035]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:26 omnia kresd[31186]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:26 omnia kresd[31186]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:26 omnia kresd[31186]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:26 omnia kresd[31186]: stack traceback:
Jul 29 21:27:26 omnia kresd[31186]: [C]: in function 'max_ttl'
Jul 29 21:27:26 omnia kresd[31186]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:26 omnia kresd[31186]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:31 omnia kresd[31260]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:31 omnia kresd[31260]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:31 omnia kresd[31260]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:31 omnia kresd[31260]: stack traceback:
Jul 29 21:27:31 omnia kresd[31260]: [C]: in function 'max_ttl'
Jul 29 21:27:31 omnia kresd[31260]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:31 omnia kresd[31260]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:36 omnia kresd[31279]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:36 omnia kresd[31279]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:36 omnia kresd[31279]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:36 omnia kresd[31279]: stack traceback:
Jul 29 21:27:36 omnia kresd[31279]: [C]: in function 'max_ttl'
Jul 29 21:27:36 omnia kresd[31279]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:36 omnia kresd[31279]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:41 omnia kresd[31304]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:41 omnia kresd[31304]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:27:41 omnia kresd[31304]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:27:41 omnia kresd[31304]: stack traceback:
Jul 29 21:27:41 omnia kresd[31304]: [C]: in function 'max_ttl'
Jul 29 21:27:41 omnia kresd[31304]: /tmp/kresd.config:28: in main chunk
Jul 29 21:27:41 omnia kresd[31304]: ERROR: max_ttl must be larger than minimum TTL, and in range <1, ((1u << 31) - 1)>' (workdir '/tmp/kresd')
Jul 29 21:27:44 omnia kresd[31455]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:27:44 omnia kresd[31455]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:28:07 omnia kresd[31901]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:28:07 omnia kresd[31901]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:30:11 omnia kresd[319]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:30:11 omnia kresd[319]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:31:11 omnia kresd[830]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:31:11 omnia kresd[830]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:36:19 omnia kresd[830]: [contrl] > cache.size
Jul 29 21:36:19 omnia kresd[830]: [contrl] error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:36:19 omnia kresd[830]: stack traceback:
Jul 29 21:36:19 omnia kresd[830]: [C]: in function 'get'
Jul 29 21:36:19 omnia kresd[830]: /usr/lib/knot-resolver/sandbox.lua:454: in function '__index'
Jul 29 21:36:19 omnia kresd[830]: [string "return table_print(cache.size)"]:1: in main chunk
Jul 29 21:36:19 omnia kresd[830]: ERROR: Function not implemented
Jul 29 21:36:23 omnia kresd[830]: [contrl] > cache.size()
Jul 29 21:36:23 omnia kresd[830]: [contrl] error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:36:23 omnia kresd[830]: stack traceback:
Jul 29 21:36:23 omnia kresd[830]: [C]: in function 'get'
Jul 29 21:36:23 omnia kresd[830]: /usr/lib/knot-resolver/sandbox.lua:454: in function '__index'
Jul 29 21:36:23 omnia kresd[830]: [string "return table_print(cache.size())"]:1: in main chunk
Jul 29 21:36:23 omnia kresd[830]: ERROR: Function not implemented
Jul 29 21:36:36 omnia kresd[830]: 1048576
Jul 29 21:36:41 omnia kresd[830]: 1048576
Jul 29 21:36:48 omnia kresd[830]: [contrl] > print(cache.current_storage)
Jul 29 21:36:48 omnia kresd[830]: [contrl] error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:36:48 omnia kresd[830]: stack traceback:
Jul 29 21:36:48 omnia kresd[830]: [C]: in function 'get'
Jul 29 21:36:48 omnia kresd[830]: /usr/lib/knot-resolver/sandbox.lua:454: in function '__index'
Jul 29 21:36:48 omnia kresd[830]: [string "return table_print(print(cache.current_storage))"]:1: in main chunk
Jul 29 21:36:48 omnia kresd[830]: ERROR: Function not implemented
Jul 29 21:38:22 omnia kresd[3036]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:22 omnia kresd[3036]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:22 omnia kresd[3036]: stack traceback:
Jul 29 21:38:22 omnia kresd[3036]: [C]: in function 'open'
Jul 29 21:38:22 omnia kresd[3036]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:22 omnia kresd[3036]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:27 omnia kresd[3111]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:27 omnia kresd[3111]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:27 omnia kresd[3111]: stack traceback:
Jul 29 21:38:27 omnia kresd[3111]: [C]: in function 'open'
Jul 29 21:38:27 omnia kresd[3111]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:27 omnia kresd[3111]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:32 omnia kresd[3131]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:32 omnia kresd[3131]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:32 omnia kresd[3131]: stack traceback:
Jul 29 21:38:32 omnia kresd[3131]: [C]: in function 'open'
Jul 29 21:38:32 omnia kresd[3131]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:32 omnia kresd[3131]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:37 omnia kresd[3156]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:37 omnia kresd[3156]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:37 omnia kresd[3156]: stack traceback:
Jul 29 21:38:37 omnia kresd[3156]: [C]: in function 'open'
Jul 29 21:38:37 omnia kresd[3156]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:37 omnia kresd[3156]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:42 omnia kresd[3173]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:42 omnia kresd[3173]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:42 omnia kresd[3173]: stack traceback:
Jul 29 21:38:42 omnia kresd[3173]: [C]: in function 'open'
Jul 29 21:38:42 omnia kresd[3173]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:42 omnia kresd[3173]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:47 omnia kresd[3199]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:47 omnia kresd[3199]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:47 omnia kresd[3199]: stack traceback:
Jul 29 21:38:47 omnia kresd[3199]: [C]: in function 'open'
Jul 29 21:38:47 omnia kresd[3199]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:47 omnia kresd[3199]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:38:59 omnia kresd[3394]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:38:59 omnia kresd[3394]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:38:59 omnia kresd[3394]: stack traceback:
Jul 29 21:38:59 omnia kresd[3394]: [C]: in function 'open'
Jul 29 21:38:59 omnia kresd[3394]: /tmp/kresd.config:17: in main chunk
Jul 29 21:38:59 omnia kresd[3394]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:04 omnia kresd[3466]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:04 omnia kresd[3466]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:04 omnia kresd[3466]: stack traceback:
Jul 29 21:39:04 omnia kresd[3466]: [C]: in function 'open'
Jul 29 21:39:04 omnia kresd[3466]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:04 omnia kresd[3466]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:09 omnia kresd[3541]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:09 omnia kresd[3541]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:09 omnia kresd[3541]: stack traceback:
Jul 29 21:39:09 omnia kresd[3541]: [C]: in function 'open'
Jul 29 21:39:09 omnia kresd[3541]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:09 omnia kresd[3541]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:14 omnia kresd[3571]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:14 omnia kresd[3571]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:14 omnia kresd[3571]: stack traceback:
Jul 29 21:39:14 omnia kresd[3571]: [C]: in function 'open'
Jul 29 21:39:14 omnia kresd[3571]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:14 omnia kresd[3571]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:19 omnia kresd[3614]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:20 omnia kresd[3614]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:20 omnia kresd[3614]: stack traceback:
Jul 29 21:39:20 omnia kresd[3614]: [C]: in function 'open'
Jul 29 21:39:20 omnia kresd[3614]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:20 omnia kresd[3614]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:22 omnia kresd[3765]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:22 omnia kresd[3765]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:22 omnia kresd[3765]: stack traceback:
Jul 29 21:39:22 omnia kresd[3765]: [C]: in function 'open'
Jul 29 21:39:22 omnia kresd[3765]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:22 omnia kresd[3765]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:27 omnia kresd[3836]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:27 omnia kresd[3836]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:27 omnia kresd[3836]: stack traceback:
Jul 29 21:39:27 omnia kresd[3836]: [C]: in function 'open'
Jul 29 21:39:27 omnia kresd[3836]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:27 omnia kresd[3836]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:32 omnia kresd[3859]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:32 omnia kresd[3859]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:32 omnia kresd[3859]: stack traceback:
Jul 29 21:39:32 omnia kresd[3859]: [C]: in function 'open'
Jul 29 21:39:32 omnia kresd[3859]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:32 omnia kresd[3859]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:37 omnia kresd[3879]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:37 omnia kresd[3879]: [system] error while loading config: error occurred here (config filename:lineno is at the bottom, if config is involved):
Jul 29 21:39:37 omnia kresd[3879]: stack traceback:
Jul 29 21:39:37 omnia kresd[3879]: [C]: in function 'open'
Jul 29 21:39:37 omnia kresd[3879]: /tmp/kresd.config:17: in main chunk
Jul 29 21:39:37 omnia kresd[3879]: ERROR: invalid cache size specified, it must be in range <8192, (0xffffffffu)> (workdir '/tmp/kresd')
Jul 29 21:39:40 omnia kresd[4035]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:39:40 omnia kresd[4035]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:40:58 omnia kresd[4817]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:40:58 omnia kresd[4817]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:54:15 omnia kresd[8856]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 29 21:54:15 omnia kresd[8856]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 29 21:54:56 omnia kresd[8856]: [contrl] > e[A
Jul 29 21:54:56 omnia kresd[8856]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: (binary): cannot load incompatible bytecode
Jul 30 05:47:08 omnia kresd[12916]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 05:47:08 omnia kresd[12916]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 11:25:54 omnia kresd[13076]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 11:25:54 omnia kresd[13076]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 15:54:31 omnia kresd[23477]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 15:54:31 omnia kresd[23477]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 15:55:10 omnia kresd[24388]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 15:55:10 omnia kresd[24388]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 16:53:21 omnia kresd[10279]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 16:53:21 omnia kresd[10279]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 17:16:45 omnia kresd[10279]: [contrl] > 83.135.2.235
Jul 30 17:16:45 omnia kresd[10279]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: [string " 83.135.2.235"]:1: malformed number near '83.135.2.235'
Jul 30 17:17:32 omnia kresd[17656]: [system] warning: hard limit for number of file-descriptors is only 4096 but recommended value is 524288
Jul 30 17:17:32 omnia kresd[17656]: [cache ] Warning: real cache size is 2097152 instead of the requested 1048576 bytes. To reduce the size you need to remove the file '/tmp/kresd/data.mdb' by hand.
Jul 30 17:18:16 omnia kresd[17656]: [contrl] > > cache.clear()
Jul 30 17:18:16 omnia kresd[17656]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: [string "> cache.clear()"]:1: unexpected symbol near '>'
Jul 30 17:18:16 omnia kresd[17656]: [contrl] > {
Jul 30 17:18:16 omnia kresd[17656]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: [string "{"]:1: unexpected symbol near '{'
Jul 30 17:18:16 omnia kresd[17656]: [contrl] > ['count'] = 511,
Jul 30 17:18:16 omnia kresd[17656]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: [string " ['count'] = 511,"]:1: unexpected symbol near '['
Jul 30 17:18:23 omnia kresd[17656]: [contrl] > }cache.clear()
Jul 30 17:18:23 omnia kresd[17656]: [contrl] /usr/lib/knot-resolver/sandbox.lua:540: [string "}cache.clear()"]:1: unexpected symbol near '}'
