On my iPhone I was forced to reset my cookies and other web settings to be able to login via safari.
I had no problem logging in after update on my mac using safari.
When I open web administration after OS update, I have to use username and password. I tried root admin etc…but it didn’t work. When I try restart lighttpd I got this:
root@turris:/# /etc/init.d/lighttpd restart
Syntax OK
/usr/lib/lighttpd/mod_alias.so
/usr/lib/lighttpd/mod_cgi.so
2016-12-09 11:54:14: (plugin.c.187) Cannot load plugin mod_auth more than once, please fix your config (lighttpd may not accept such configs in future releases)
2016-12-09 11:54:14: (plugin.c.227) dlopen() failed for: /usr/lib/lighttpd/mod_authn_file.so File not found
2016-12-09 11:54:14: (server.c.912) loading plugins finally failed
I had the same error message “can’t load library 'libpcre.so.0” when I was trying to use grep (full version, not from busybox). Because of that other services also failed, like unbound and postfix. Updating grep solved it.
Luci and Basic web-admin pages are not accessible by me too - only sometime and a short time (< 20 sec). I either wait or I tried also https and then there worked.
Similar failure here
Since the recent (2016/12/16) automatic system update the web admin interface does not work anymore.
As I was able to use SSH at least I found the lighthttpd refuses to load screaming it requires a rrd binary to be set. Why did not the updater take care of that? What the … … … … … … (lots of 4-letter words), what’s wrong with collecting some statistics enabled by built-in means???
I’m not a openwrt/Linux guru, I used LuCi (now unavailable) to confugure the box.
Btw, my MC was broken by the update as well – furtunately deleting its (not too precious) history helped (as found here, thanks).
Any idea other than RTFM (i.e. spending a year reading The Linux Bible and trying zillions of googled-out links which may or may not work)? TIA…
Being a T-O owner does not necessarily qualify one as an expert in this area. Contrary, additionally to performing its primary networking-related tasks the T-O represents a neat platform for learning and playing which may eventually bring the expertise some day.
H.
PS: Dear SW maintainers, are you learning from a well known company which releases regular upgrades often breaking things that used to work? Don’t do that, please.
Yet, according to the referred post (which I used to cure my instance) it seems MC failure having something common with updates – NONES’s last post in the original thread in Czech in the old forum (“…I should take care of MC update myself…”)
Nevertheless, it is not the key issue.
No, that’s why I asked the community for help. To make it clear I approximately did the following:
tried another browser (Chrome → Edge)
did some googling to no avail (like “omnia turris luci cannot login”)
fired the PuTTY
got stuck with MC
resolved MC issue with info found in the forum
after a while spent searching I found this thread
attempted to restart lighttpd to no avail
ran updater.sh (it has never went silently and has been reporting some warnings and other issues since the router was first brought up, I don’t remember exactly the messages seen in the web UI)
attempted to restart httpd, still broken
found the httpd log stating:
2016-12-18 02:43:59: (log.c.217) server started
2016-12-18 02:43:59: (mod_rrdtool.c.391) rrdtool.binary has to be set
2016-12-18 02:43:59: (server.c.1270) Configuration of plugins failed. Going down.
got upset and tired of the the world being augmented with another imperfect tool (a row of euphemisms) that let me down
asked the forum
went finally (almost 3am) to my bed feeling diappointed
Where are the days of NetWare 3.12/4.x which could run for months without a reboot (even if it was patched several times during its up period) and with patches that never brought it to its knees? (At least this is my personal experinece when I was baby-sitting a few of them – I usually almost didn’t know we had them.)
I have not touched the collection or rrd stuff in Omnia so I don’t know the correct configuration for it but the error message indicates mod_rrdtool plugin for lighttpd (probably coming from package lighttpd-mod-rrdtool) doesn’t find its configuration.
You can try to remove lighttpd-mod-rrdtool package in case you don’t need it or if you have reinstalled it and the web admin still doesn’t work you could try something like this as a workaround:
Unfortunately
2016-12-18 11:06:27: (server.c.1296) WARNING: unknown config-key: rrdtool.binary (ignored)
Removing the new local,conf.
Nevertheless, I found some info on lighttpd config in the meantime and renamed the rrd load which brought my LuCi to life again,
Now I’ve been trying to reinstall the rrd/collecd stuff (must be removed first even if it was uninstalled through opkg). I guess I have to delve into /etc/config/updater and other conf docs stuff anyways.
Have a nice and really sunny Sunday (no Sun here shining outside neither down on my Turris).
