LED, LAN and wi-fi working after reboot?
strings /dev/mtd1 | grep U-Boot
returns no result. However on mtd0 there is a result:
% strings /dev/mtd0 | grep U-Boot
U-Boot SPL 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000
LED, LAN and WI-FI are working as far as I can tell. One network connection must work anyway, as I am sending this through the router. But I also tested WI-FI briefly and it connects. I am still only using the 2.4 GHz one I think, though. Also internal 1 TB mSATA SSD still works
Apparently I did not succeed in bricking my device.
Final edit: found a thread with pretty much my problem (was in Czech), and some mentions on the RC thread in English (where, unless I understood it wrongly, it was claimed that this exact problem was fixed?!).
Leaving this here for now, for non-Czech speaking users whom might get hit by this on the final 6.5.
â
The rescue update broke the flash for me (Turris Omnia, purchased in March 2017 on alzashop.cz I think), 2GB model.
Had to use kwboot
to get to an usable bootenv, and flashed it to uboot-devel
(from HBS omnia-uboot_2023.01-5) and omnia-initramfs-zimage
* (from the nor_fw location) to get back to an usable system. Found the instructions here.
_ * see PS#2
That allowed me to boot, and I was able to run nor-update
(per this page - thanks @jada4p above for the the link); I was kinda surprised to see it actually change stuff,
root@router:/# nor-update
Verifying /dev/mtd0 against uboot ...
95ee7fbfc670b2655937271b428555c5 - /dev/mtd0
a3a04aa6143fe437e00b96fbcc8cd20f - uboot
Failed
Warning: Bad CRC, using default environment
Unlocking /dev/mtd0 ...
Erasing /dev/mtd0 ...
Writing from uboot to /dev/mtd0 ...
Verifying /dev/mtd1 against rescue ...
6c453ee022850e0caca0163898ac3ad2 - /dev/mtd1
550b8eb1766f9348fe928ebcbbd3aa49 - rescue
Failed
Unlocking /dev/mtd1 ...
Erasing /dev/mtd1 ...
Writing from rescue to /dev/mtd1 ...
root@router:/# reboot
but whatever. After a reboot, everything seemed to work and be as expected
a3a04aa6143fe437e00b96fbcc8cd20f - /dev/mtd0
Success
550b8eb1766f9348fe928ebcbbd3aa49 - /dev/mtd1
Success
root@router:/# schnapps factory-version
6.5.0
Iâve no idea why I had ended with with different checksums, but fine, seems solved now.
Hereâs the relevant portion of my boot log (after the fix), in case it could help devs figure out what the issue was:
BootROM - 1.73
Booting from SPI flash
U-Boot SPL 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
High speed PHY - Version: 2.0
MiniPCIe/mSATA card detection... MiniPCIe
WWAN slot configuration... PCIe+USB2.0
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 5 | PCIe0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
mv_ddr: completed successfully
Trying to boot from SPI
U-Boot 2022.10-rc4-OpenWrt-r16653+119-44ce70f0e2 (Sep 15 2022 - 18:21:35 +0000)
SoC: MV88F6820-A0 at 1600 MHz
DRAM: 2 GiB (800 MHz, 32-bit, 2T, ECC not enabled)
Core: 71 devices, 24 uclasses, devicetree: separate
WDT: Started watchdog@20300 with servicing (60s timeout)
MMC: mv_sdh: 0
Loading Environment from SPIFlash... SF: Detected s25fl164k with page size 256 Bytes, erase size 4 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
Model: Turris Omnia
MCU type: STM32
MCU version: b5a8a24e007eb72be16aeb3fff6f03ec647023e4/67eddc9540526d0a9d9660f7a7867af9a28a68d6
RAM size: 2048 MiB
Serial Number: 0000000B0001500F
Disabling MCU watchdog... disabled
Regdomain set to **
pcie0.0: Link up
pcie1.0: Link up
pcie2.0: Link down
Net: eth0: ethernet@70000, eth1: ethernet@30000, eth2: ethernet@34000 [PRIME]
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1199 bytes read in 35 ms (33.2 KiB/s)
## Executing script at 01800000
gpio: pin gpio@71_4 (gpio 68) value is 1
21434 bytes read in 39 ms (536.1 KiB/s)
4328320 bytes read in 285 ms (14.5 MiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x420b80 ]
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 0fff7000, end 0ffff3b9 ... OK
Starting kernel ...
Anyway. While I appreciate the fact that the rescue image updating support was optional and not selected by default, Iâm not sure it shouldâve been offered at this point in time - I was lucky enough to have the knowledge I needed to fix it (and the bits I wasnât sure about, I found in the forums and docs), but really guys.
Just because somebody gets an Omnia, you canât assume theyâd be able to do this.
It also helped tremendously that I had the foresight to equip the router with a USB serial port in advance (just in case) - I imagine this wouldâve been a fair bit less convenient if I had had to open the thing up and hook up the wires of an FTDI cable (if anybody else wants to do this - I drilled a USB-C-shaped hole in the front of the case, and got through it the USB header off a CH340E which I had sticky-taped to the top the case internally, and had connected RX/TX/GND to the Omnia board header).
Anyway, posting this long rant here so somebody in the same situation would hopefully find everything they needed to recover their router promptly, in one place.
And FWIW, Iâm not complaining. I understood the risk, took it, had to recover, and I did.
But still, guys. Seems kinda dangerous to make this kind of options available to potentially less geeky customers.
PS. The initial failure looked like this:
| 0 | 5 | PCIe0 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
ERROR: Invalid data checksum in kwbimage
Trying to boot from BOOTROM
Returning to BootROM (return address 0xffff05c4)...
BootROM: Image checksum verification FAILED
BootROM: Bad header at offset D4200000
BootROM: Bad header at offset D4400000
BootROM: Bad header at offset D4600000
BootROM - 1.73
| 0 | 5 | PCIe0 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
mv_ddr: 14.0.0
DDR3 Training Sequence - 2nd boot - Skip
(and then nothing, until the watchdog kicked in and rebooted the thing)
However, the SPI flash is clearly still good (or it wouldnât have worked a second time, I expect), and - this is the bad bit - I received no warning/error of any kind about flashing the NOR having failed. And yes, I did wait after the update until htop showed me that the writing to /dev/mtd1
had finished.
PS#2. Might be time to update the nor_fw folder; also, a note that youâre supposed to use image.fit .lzma from rescue-image_3.6.1-35 would be nice as well - I initially tried image.fit and panicked about having a too old, with too small NOR, router, for the current firmware I had to
strings $(which nor-update) | grep rescue
to figure I was attempting to flash the wrong file - not that itâd matter, if you just provided the right file as omnia-initramfs-zimage
in the nor_fw
folder
Seems I got really lucky then. Thanks.
Running nor-update
again shows the same checksums and success messages as in your post.
Same issue here with postfix too.
I cannot acces my Omnia with NAS perk via SSH after update. reForis and LuCI seems to be accessible, Transmission too, but SSH says Session not connected. LXC running on that Omnia is accessible via SSH.
Reboot didnât helpedâŚ
Also the same with my main Omnia, which was updated, but still not restartedâŚ
Edit:
Syslog message:
Jan 23 19:02:43 Pivnicka_NAS sshd[7602]: Unable to negotiate with 192.168.1.177 port 40952: no matching host key type found. Their offer: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521 [preauth]
Jan 23 19:07:53 turris sshd[12168]: Unable to negotiate with 192.168.1.177 port 57460: no matching host key type found. Their offer: ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521 [preauth]
I am using Snowflake SSH client, but I am unable to connect from terminal too. Any advice?
Turris Omnia, never updated the firmware. 6.5.0 installation successful, and nor-update successful:
root@turris:/tmp/log# nor-update
02ac2a52595476d095a4a8157bd401ca - /dev/mtd0
Failed
d4a7af8e7a2799252d6b555a0a6a2e08 - /dev/mtd1
Failed
root@turris:/tmp/log# reboot
Success
Success
After upgrade I have problem with OpenVPN connection between two Turris routers. Anybody else?
Nope, running fine here?
Turris Omnia (RTROM01), update from 6.4.4 to 6.5.0. RIPE + LXC installed. No issues observed.
Thank you for the update!
Try newer ssh client/newer configuration, some obsolete ciphers were disabled by OpenSSH update.
Postfix is currently not building due to some dependencies issues, we will look into that.
Completely unrelated topic from my previous post.
fw_printenv
complains about a bad CRC; this was previously reported on the RC thread, but it seems 6.5 final hasnât fixed it either (by providing the correct contents for /etc/fw_env.config
And yes, I did do a saveenv
in U-Boot - so U-Boot itself no longer complains about the CRC error causing it to load the default environment.
My current fw_env.config
is
/dev/mtd0 0xc0000 0x10000 0x40000
In my view, the hook script that installs u-boot should update this file as well. Might be something worth doing for 6.5.1 or whenever.
Edit (before I got to hit âReplyâ :>): Iâve looked in the 6.5.0 medkit, and it seems thereâs no /etc/fw_env.config
in it at all?!
Edit #2 (also before I got to hit âReplyâ): a look at the device tree (specifically at /sys/devices/platform/soc/f1010600.spi/of_node/spi-nor@0/partitions/partition@f0000/reg
) made me find out that the following /etc/fw_env.config
contents work (at least with fw_printenv
/dev/mtd2 0x0 0x10000 0x10000
that said, while it looks correct, Iâd like somebody to confirm it actually is, before me - or anyone else - tries to run fw_setenv
âŚ
Edit #3: After digging through nor-update
, it seems thereâs some fw_printenv stuff being done as part of uboot_preupdate()
âŚ
This might not be unrelated to my previous post after all
The fact that my old uboot had environment on /dev/mtd0
, not /dev/mtd2
, at 0xc0000, means that the old uboot image was necessarily smaller than 0xc0000; the new one is 0xe8f00. So attempting to write the new one would necessarily thrash my existing environment (which wouldnât be so bad), but begs to question whether /dev/mtd0
wasnât somehow smaller than 0xe8f00⌠(FWIW, I last installed cleanly 3.11.2 in Feb.2019; itâs been all upgrades since, and I keep a snapshot for every upgrade).
'cause the way I see it, if you attempted to write a 931KB image over a partition smaller than that could only go two ways: either only part of the image would be written (because thereâs no room), leaving you with a partial update and missing code, or mtd
could simply refuse to flash to a too-small partition.
- in the first case, itâs possible nothing was wrong with DDR training - instead, that simply happened to be the last thing printed before uboot jumped to code that simply hadnât been written to flash
- in the second, if the new uboot was required for the updated rescue system image (because the rescue partition,
/dev/mtd1
, was clearly large enough to be flashed correctly), itâs only natural that the system couldnât boot.
Now, I have no proof of this, but I could swear I saw a 2015 uboot header when I connected the serial right after it first failed to boot, before I went serial booting and flashing the NOR. (I only remember this because I went, âjaysus, they updated all that code but wouldnât update the bloody version stringâ before getting back to the task at hand).
Anyway. If any of those two failure scenarios were the real issue, then I think the problem is that nor-update
doesnât check proprly what itâs attempting to write to.
Iâd strongly suggest changing the check logic in uboot_preupdate()
to first and foremost check /proc/mtd
for the expected partition layout, and refuse to update either uboot or the rescue system unless it looked ok (specifically, unless the mtd partition map looked exactly as expected). Ideally, doing something to mitigate that, like enlarging /dev/mtd0
and ideally relocating the uboot environment for the next boot (not really necessary since we know we can boot just fine with a broken environment, and anyone whom had to modify their bootenv knows pretty well how to fix things for himself in 5mins or less).
My 2 cents. Hopefully the Turris team can do something with the insights above.
IIRC, /dev/mtd2 is only an âaliasâ of some space in /dev/mtd0. These two just overlap and are meant to. So it doesnât necessarily mean that the old image had to end before mtd2 start.
Turris Omnia, installed 6.5.0 and updated firmware with nor-update. Result: multiple spontaneous reboots in the 18 hours that has passed since. How can I debug this in the best way?
Iâm not sure thatâs correct as stated. If you mean that several might be located on the same flash device (in this case), youâre correct, but that doesnât mean they overlap; indeed, they shouldnât, and with the current firmware, they donât (check sysfs).
I honestly have no idea what the old ubootâs device tree looked like, nor do I know whether that gets merged into the kernel DT or the kernel simply provides its own description of the same stuff (I suspect the former), but from what I found in fw_env.config
, I strongly suspect there was no /dev/mtd2
with the old uboot.
And hereâs the second bit. uboot_preupdate()
in nor-update
attempts to dump the environment (suceeding), and uboot_postupdate()
attempts to restore it. However, unless you reboot inbetween (so you get the updated mtd table from uboot) or update fw_env.config, the DT hasnât changed, so if you environment was on /dev/mtd0
at 0xc0000, it will be written back in the exact same location (no /dev/mtd2
exists yet FWIW). And if you just wrote wrote 0xe8f000 bytes to /dev/mtd0
at 0, and then another donât-care-how-many to /dev/mtd0
at 0xc0000⌠There you go, instant uboot code corruption.
My talk at 2am local about mtd0 being too small doesnât hold much water now at half 9, true (mustâve been at least 0x100000, since the environment was included at the end of mtd0). But the âcheck the damn /proc/mtd
â bit still makes sense IMO.
The only thing that nags me is that I could swear I saw a 2015-something uboot header on after the presumed update. But itâs not impossible that happened not during the failure, but rather when I was messing around with kwboot, attempting to resurrect my main router (I wonder whether thatâs what you get on the turris server at nor_fwâŚ)
I think that is correct. Look here:
And here:
And here as well:
With new U-Boot there is u-boot-env added. But this was known 1 year ago and there is still no config for fw_printenv
in medkit⌠And the fix is simple as to add one file and its done. Two Issues solvedâŚ
Thatâs a good point; if I understand it correctly, and my reasoning is correct, then,
- no system that lacks an
/etc/fw_env.config
would be broken, since saving/restoring fw_env isnât going to happen duringnor_update
- a system that has an
/etc/fw_env.config
that actually matches the uboot2022 config will have no trouble updating - a system that has an
/etc/fw_env.config
that has the old layout (mtd0+0xc0000) will be broken like mine was, because the uboot_postupdatefw_setenv -s
will overwrite part of the uboot code
Edit: On the bright side, (particularly since I expect /etc/fw_env.config is not present on most omnias), this means that the number of affected people will be fairly low.
Probably the simplest possible solution in order not to break anything would be to not restore the boot environment if fw_env.config is present and has the old layout.
The better but more complicated solution would be to back up the old environment
dd if=/dev/mtd0 bs=0x10000 of=/usr/share/nor-update/ubootenv skip=12 count=1
as part of pre-update) and somehow write it to the new location; no simple solution comes to mind - but what can be done could be something like preparing a mtd0 image that included the old environment, to be flashed before the kernel starts using the new mtd layout:
# in pre-update
dd if=/dev/mtd0 bs=$((0x10000)) skip=$((0xC)) count=1 > /tmp/uboot-env
# prepare update image by assembling the uboot, padding, and the old environment
ubootfile=/usr/share/nor-update/uboot
ubootbinsz=$(ls -l $ubootfile|awk '{print $5}')
if [ $ubootbinsz > $((0xf0000)) ]; then
echo uboot image too large\; aborting...
exit
fi
cat $ubootfile > /tmp/uboot-with-env
dd if=/dev/zero count=$((0xf0000-ubootbinsz)) bs=1 >> /tmp/uboot-with-env
cat /tmp/uboot-env >> /tmp/uboot-with-env
# write the created partition image to the current mtd0 (that'll show up as mtd0+mtd after the uboot changes)
dd if=/tmp/uboot-with-env of=/dev/mtd0 bs=$((0x10000))
Edit #2: ok, Iâm stupid. If we have the old layout in /etc/fw_env.config
, itâs enough to replace the condition of calling fw_env-config-init.sh
, which will do exactly what needs to be done.
However. fw_env-config-init.sh
sets the config to /dev/mtd0 0xf0000 0x10000 0x10000
only if
U-Boot 2015.10-rc2
is not found in /dev/mtd0 - so calling in before updating uboot is the wrong place.
If however it was called in postupdate (after uboot was flashed) but before fw_setenv -s
was called, I expect itâll do whatâs actually intended.
As far as Iâm concerned, case solved.
Could you post the new default IPv6 settings please? I would like to consider using them, but I donât want to reinstall my router.
Hello there, here a âenthusiast amateurâ aka nOOb. Whats the verdict for someone with a standard indy omnia ( 2015 U boot version me think) at this stage?
