My MOX keeps trying to upgrade to 6.0, despite the fact it has SDIO card. Luckily, it fails on wireguard
package.
Why? It was supposed not to upgrade to 6.x.
package.
Could you send diagnostics through the support channel, please? We will look into it.
I got the same problem, did you fix that?
In [CZ] im trying to describe this situation. Seems mox cant detect right branch and switch to hbs-sdio
added logs for my upgrade boot loop issue here
Thanks for solving the problem with lighttpd, (reForis ??) and Luci. It was really enough to edit /etc/lighttpd/conf.d/30-rrdtool.conf
by deactivating the line
## rrdtool.db-name = home_dir + "lighttpd.rrd
⌠and then restart ⌠/etc/init.d/lighttpd restart
(Confirming the CPU temperature drop from 62 to 52 degrees Celsius in Statistics ⌠but i think it must be a function of the sensor, because the CPU has the same load)
In my case Luci is working and reForis reports an error even after another router restart
A problem occurred in a Python script. Here is the sequence of function calls leading up to the error, in the order they occurred.
/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py in run(self=<flup.server.fcgi_base.Request object>)
/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py in handler(self=<flup.server.fcgi.WSGIServer object>, req=<flup.server.fcgi_base.Request object>)
/usr/lib/python3.9/site-packages/reforis/__main__.py in __call__(self=
<reforis.main.AppWrapper object>, environ={âCONTENT_LENGTHâ: â0â, âDOCUMENT_ROOTâ: â/www/turris-webapps/â, âGATEWAY_INTERFACEâ: âCGI/1.1â, âHTTPSâ: âonâ, âHTTP_ACCEPTâ: âtext/html,application/xhtml+xml,application/xml;âŚ,/;q=0.8,application/signed-exchange;v=b3;q=0.9â, âHTTP_ACCEPT_ENCODINGâ: âgzip, deflate, brâ, âHTTP_ACCEPT_LANGUAGEâ: âcs,en-GB;q=0.9,en;q=0.8â, âHTTP_CACHE_CONTROLâ: âmax-age=0â, âHTTP_COOKIEâ: â_csrf_token=21dacf1f36a94a281f14f6623bd4a17014f2âŚqpoyzkp; sysauth=c7fbc69260906ebe035e41349b4e59daâ, âHTTP_DNTâ: â1â, âŚ}, start_response=<function BaseFCGIServer.handler..start_response>)
/usr/lib/python3.9/site-packages/flask/app.py in call(self=<Flask âreforisâ>, environ={âCONTENT_LENGTHâ: â0â, âDOCUMENT_ROOTâ: â/www/turris-webapps/â, âGATEWAY_INTERFACEâ: âCGI/1.1â, âHTTPSâ: âonâ, âHTTP_ACCEPTâ: âtext/html,application/xhtml+xml,application/xml;âŚ,/;q=0.8,application/signed-exchange;v=b3;q=0.9â, âHTTP_ACCEPT_ENCODINGâ: âgzip, deflate, brâ, âHTTP_ACCEPT_LANGUAGEâ: âcs,en-GB;q=0.9,en;q=0.8â, âHTTP_CACHE_CONTROLâ: âmax-age=0â, âHTTP_COOKIEâ: â_csrf_token=21dacf1f36a94a281f14f6623bd4a17014f2âŚqpoyzkp; sysauth=c7fbc69260906ebe035e41349b4e59daâ, âHTTP_DNTâ: â1â, âŚ}, start_response=<function BaseFCGIServer.handler..start_response>)
/usr/lib/python3.9/site-packages/flask/app.py in wsgi_app(self=<Flask âreforisâ>, environ={âCONTENT_LENGTHâ: â0â, âDOCUMENT_ROOTâ: â/www/turris-webapps/â, âGATEWAY_INTERFACEâ: âCGI/1.1â, âHTTPSâ: âonâ, âHTTP_ACCEPTâ: âtext/html,application/xhtml+xml,application/xml;âŚ,/;q=0.8,application/signed-exchange;v=b3;q=0.9â, âHTTP_ACCEPT_ENCODINGâ: âgzip, deflate, brâ, âHTTP_ACCEPT_LANGUAGEâ: âcs,en-GB;q=0.9,en;q=0.8â, âHTTP_CACHE_CONTROLâ: âmax-age=0â, âHTTP_COOKIEâ: â_csrf_token=21dacf1f36a94a281f14f6623bd4a17014f2âŚqpoyzkp; sysauth=c7fbc69260906ebe035e41349b4e59daâ, âHTTP_DNTâ: â1â, âŚ}, start_response=<function BaseFCGIServer.handler..start_response>)
/usr/lib/python3.9/site-packages/flask/app.py in handle_exception(self=<Flask âreforisâ>, e=ControllerMissing(âConnection to controller 0000000B00006219 is lost.â))
/usr/lib/python3.9/site-packages/reforis/init.py in internal_error(error=<InternalServerError â500: Internal Server Errorâ>)
/usr/lib/python3.9/site-packages/flask/templating.py in render_template(template_name_or_list=âerrors/500.htmlâ, **context={âerrorâ: <InternalServerError â500: Internal Server Errorâ>, âgâ: <flask.ctx._AppCtxGlobals object>, ârequestâ: <Request âhttps://192.168.2.1/reforis/â [GET]>, âsessionâ: <FileSystemSession {â_permanentâ: True}>})
/usr/lib/python3.9/site-packages/flask/app.py in update_template_context(self=<Flask âreforisâ>, context={âerrorâ: <InternalServerError â500: Internal Server Errorâ>, âgâ: <flask.ctx._AppCtxGlobals object>, ârequestâ: <Request âhttps://192.168.2.1/reforis/â [GET]>, âsessionâ: <FileSystemSession {â_permanentâ: True}>})
/usr/lib/python3.9/site-packages/reforis/init.py in add_translations_catalog_to_ctx()
/usr/lib/python3.9/site-packages/flask_babel/init.py in get_locale()
/usr/lib/python3.9/site-packages/reforis/init.py in get_locale()
/usr/lib/python3.9/site-packages/reforis/init.py in _get_locale_from_backend(app=<Flask âreforisâ>)
/usr/lib/python3.9/site-packages/reforis/backend.py in perform(self=MqttSender, module=âwebâ, action=âget_dataâ, data=None, raise_exception_on_failure=True, controller_id=None)
/usr/lib/python3.9/site-packages/reforis/backend.py in _send(self=MqttSender, module=âwebâ, action=âget_dataâ, data=None, controller_id=None)
/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py in send(self=<foris_client.buses.mqtt.MqttSender object>, module=âwebâ, action=âget_dataâ, data=None, timeout=30.0, controller_id=â0000000B00006219â)
/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py in check_controllers()
ControllerMissing: Connection to controller 0000000B00006219 is lost.
args = (âConnection to controller 0000000B00006219 is lost.â,)
device_id = â0000000B00006219â
with_traceback =
I have just asked about this, can you check if this caused the problem?
âNext time, when we will be releasing Turris OS 7.0, it will contain just a migration to a newer OpenWrt and no other new features.â
Quoted from the thread:
I fully agree with that first release pure major upgrade and then release new Turris OS specific features.
Major release with such specific changes is a big challenge.
âPaKon moved to a separate pageâ - to which page? Where can I find more details?
Itâs now a separate webapp, so if you install it, it will show up in the overview where you can choose between reForis, LuCI, Nextcloud, etc.
Since upgrade this happens:
Every 60 seconds. Is this normal? Should I worry? Never seen this behavior before the upgrade.
@Pepe saw this also, failed sentinel firewall logs in reForis. will file a support report
Iâve had the same problem, but no rrdtool config anywhere I could comment out.
luckily error message in /var/log/lighttpd/error.log was at least a bit helpful:
2022-10-21 07:31:31: (../src/server.c.1588) server started (lighttpd/1.4.67)
2022-10-21 07:31:31: (../src/mod_alias.c.70) url.alias: `/bandwidthd/' will never match as `/' matched first
2022-10-21 07:31:31: (../src/server.c.1592) Configuration of plugins failed. Going down.
so I renamed /etc/lighttpd/conf.d/bandwidthd.conf to 00-bandwidthd.conf
and lighthttpd started correctly.
this kind of error should not cause lighthttpd to crash but this is not problem of turris I guess
Yes. I replied to origin comment with link.
Like @dadall , I had to do a rollback of my Mox to 5.4.4 for now.
Here is how I did it (please tell me if I did something wrong, that other should not reproduce):
The Mox seems to be stable. USB works.
Yeah, last week Iâm just rolling back. But the last update in HBT looks OK, except the ethernet on MOX C - the br-lan is empty on my MOX, the lan1-4 unassinged after upgrade - the /etc/config/network looks kind of OK, had no time to compare it yet, when I tried to add it using reforis, the status of lan1-4 is DOWN. In Luci I noticed the empty br-lan, so tried to set it up again, but the lan1-4 still claims no connection. So when I set it up, I lost wi-fi lan as well. Will try to look deeper once Iâll have more time and the will to suffer
I did not check this at the time when the issue appeared (just added the new key).
I can see now that /etc/ssh/sshd_config
was modified at the time of the OS update (the first one).
But the line referencing HostKey
is not commented.
I did the update on my blue Turris Omnia 1GB with internal SSD. It was impossible to do the update via WIFI so I had to do it via ethernet and I chose ssh login and pkgupdate
to do so I could see some feedback on how it advances.
As mentioned before by 0W0 in post #96 I manually had to interfere to get mysqld
working angain for Nextcloud
lighttpd
was or better is not working properly. I have to say I use letsencrypt
and when I tried to start lighttpd
it refused to start and I found the following in `/var/log/lighttpd/error.log:
After renaming /etc/lighttpd/conf.d/letsencrypt.conf
to /etc/lighttpd/conf.d/letsencrypt.conf.bak
I was able to start lighttpd
and access ReForis
, Luci
and Nextcloud
therefore I got new log entries in /var/log/lighttpd/error.log
Content of /etc/lighttpd/conf.d/letsencrypt.conf
is
I was not able to check any further despite lxc
works as well as my DDNS and openvpn server
As I think lighttpd
and especially itâs configuration needs some overdoing.
Edit:I just realized Firewall logs
in section Sentinel
in ReForis
failed. Disabling and enabling in ReForis
again solved the fail.
Anyway thank you for 6.0 and now is the time to show community can also contribute â hopefully constructive input â to maintainers.
Is Pakon installed on your machine ? ?
Rather double-check this. If you restart the firewall logs collector, it has a green check for a few seconds, but then goes red again. At least for me.
