There is an LED fix? Is there a post you got that from that has more information?
I know it is a little bit late to let you know about it, but we yesterday, we pushed a small update related to Turris OS 6.0 at 21:45 (CEST), where we fixed:
- Turris 1.x issues with mismatch kernel
- Fixed firewall issue in some occasional situations.
Thanks for the patch, I didn’t get around to fix it yet so I’ll shamelessly copy it from you.
EDIT: proper fix (copied over from 5.4):
If you are working from home or need to have remote control of the Turris router you should change your update settings to " Update approval needed ".
That way you get notified of the updates and can apply them at a time to suit your needs.
not sure what this should solve, but i still have to start the sentinel fw logs manually?
luci>system>startup restart
But, if i check the sentinel fw url, with my device, it does send data apperantly? might be a reforis thingie?
I had delayed reboots enabled to not be distrubed by updates. I kind of thought the updates wouldn’t be applied and couldn’t break anything until that reboot. This is the first time in years that an automatic update broke something important right away (before the reboot) and needed immediate attention. So that was obviously a wrong assumption on my part.
Thanks, that helped restore my Turris 1.0 to working order. Of course, with Wi-Fi down and with not having any ethernet-enabled device at the location, doing so was a little challenging…
Hello everyone who is dealing with the new version, I found that MINIDLNA sharing works again on Turris 1.x routers. So it might be added to the list of fixed bugs. Thanks
Thanks for your reply anyway.
I don’t use ntfs on the USB devices I plugged on my Mox. And, even if I did, the block device should be detected anyway (before trying to mount any filesystem).
My problem is that USB mass storage devices are simply not detected on my Mox (including the one that was working flawlessly on it before the Turris OS upgrade).
3 posts were merged into an existing topic: Turris Mox USB (from module A) not working any more (for mass storage) after TOS 6.0 upgrade
I also had a problem with lighttpd and not being able to access the portal on my Turris.
In the log file this was mentioned:
turris procd: Instance lighttpd::instance1 s in a crash loop 6 crashes, 0 seconds since last crash
Apparently in the 30-rrdtool.conf it was crashing of missing the home_dir:
`## Path to the rrdtool database. You can override this in conditionals.’
rrdtool.db-name = home_dir + “/lighttpd.rrd”’
Resolved by ## out the line rrd.db-name. Manually started lighttpd and things seem to be working again.
Turris Omnia [my system is on mSATA SSD] (Adblock, RIPE Atlas, Statistics) update from 5.4.4 to 6.x.x … LED fine (setting and color), internet available, terminal working, but reForis and Luci not working despite 3 reboots …
Web **192.168.2.1** refused to connect.
#### Try:
* Check the connection
* Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
rollback and repeated update to 6.x.x with the same result … broken reForis and Luci
=== EDIT /var/log/lighttpd/error.log
2022-10-21 19:04:05: (../src/server.c.1588) server started (lighttpd/1.4.67)
2022-10-21 19:04:41: (../src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:41,113] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:04:41: (../src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:41,116] ERROR in app: Exception on / [GET]
2022-10-21 19:04:41: (../src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:04:41: (../src/mod_fastcgi.c.450) FastCGI-stderr: File "/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py", line 358, in send
Souhrn
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:04:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:46,122] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:04:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:50,774] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:50,776] ERROR in app: Exception on / [GET]
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:04:50: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:04:55,782] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:04:54: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:05:16,856] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:05:16,857] ERROR in app: Exception on / [GET]
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:05:16: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:05:21,862] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:05:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:11:03: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 19:11:26: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:11:34,629] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:11:34,632] ERROR in app: Exception on /login [GET]
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:11:34: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:11:39,636] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:11:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:13:15,780] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:13:15,782] ERROR in app: Exception on /login [GET]
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:13:15: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:13:20,786] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:13:20: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:20:23: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 19:20:33: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:20:41,262] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:20:41,264] ERROR in app: Exception on /login [GET]
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:20:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:20:46,269] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:20:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:25:41: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 19:25:51: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:25:59,271] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:25:59,274] ERROR in app: Exception on /login [GET]
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:25:59: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:26:04,279] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:26:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:28:25,967] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:28:25,968] ERROR in app: Exception on /login [GET]
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:28:25: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:28:30,972] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:28:30: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:29:46,766] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:29:46,767] ERROR in app: Exception on /login [GET]
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:29:46: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:29:51,772] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:29:51: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:36:38: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 19:36:57: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:37:05,170] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:37:05,173] ERROR in app: Exception on /login [GET]
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:37:05: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:37:10,178] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:37:10: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 19:53:44: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 19:53:56: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:54:04,496] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:54:04,499] ERROR in app: Exception on /login [GET]
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:54:04: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 19:54:09,504] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 19:54:09: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 20:49:16: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 20:50:27: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 20:50:36,037] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 20:50:36,040] ERROR in app: Exception on /login [GET]
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 20:50:36: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 20:50:41,045] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 20:50:41: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-21 22:39:01: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-21 22:40:25: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 22:40:33,696] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 22:40:33,699] ERROR in app: Exception on /login [GET]
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 22:40:33: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-21 22:40:38,704] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-21 22:40:38: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-22 08:13:53: (…/src/gw_backend.c.528) connect /tmp/fastcgi.turris_auth.socket-0: Connection refused
2022-10-22 08:14:13: (…/src/gw_backend.c.528) connect /tmp/fastcgi.reforis.socket-0: Connection refused
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:21,781] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:21,784] ERROR in app: Exception on / [GET]
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-22 08:14:21: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:26,788] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-22 08:14:26: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:40,731] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:40,732] ERROR in app: Exception on / [GET]
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-22 08:14:39: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr:[2022-10-22 08:14:45,737] ERROR in backend: Exception occurred during the communication with backend. (Connection to controller 0000000B00006219 is lost.)
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr:Traceback (most recent call last):
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 358, in send
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/queue.py”, line 179, in get
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr:_queue.Empty
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr:During handling of the above exception, another exception occurred:
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2070, in wsgi_app
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1515, in full_dispatch_request
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1511, in full_dispatch_request
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1857, in preprocess_request
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/views.py”, line 31, in guide_redirect
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 74, in perform
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 56, in perform
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/backend.py”, line 128, in _send
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 360, in send
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/foris_client/buses/mqtt.py”, line 334, in check_controllers
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr:foris_client.buses.base.ControllerMissing: Connection to controller 0000000B00006219 is lost.
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 576, in run
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flup/server/fcgi_base.py”, line 1175, in handler
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/main.py”, line 31, in call
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2088, in call
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 2073, in wsgi_app
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 1437, in handle_exception
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 113, in internal_error
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/templating.py”, line 146, in render_template
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask/app.py”, line 756, in update_template_context
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 183, in add_translations_catalog_to_ctx
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/flask_babel/init.py”, line 226, in get_locale
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 178, in get_locale
2022-10-22 08:14:45: (…/src/mod_fastcgi.c.450) FastCGI-stderr: File “/usr/lib/python3.9/site-packages/reforis/init.py”, line 189, in _get_locale_from_backend
A summary of issues that I found with this upgrade with my Omnia:
- Wi-Fi networks no longer reachable. Fixed by reboot.
- Upstream connection no longer working (the Omnia runs an OpenVPN client). Fixed by reboot.
- The TLS certificate of the web UIs changed.
- The SSH certificate changed. Well, actually not: the upgrade just disabled the ECDSA key, my client resorted to the Ed25519 key (but none of Omnia’s SSH keys actually changed).
- DNS resolving stopped working. Turned out to be dnsmasq still serving DNS, thus Knot/kresd failing to start. Fixed with " What to do if it’s too late" instructions in Knot resolver over dnsmasq.
Finally, even if there were some wrinkles, I’d like to thank the Turris team for keeping on supporting their products!
My update to Turris OS drove me to some random reboots. Surprisingly, my SDIO Wifi worked as expected.
I genuinely don’t know why the Mox reboots on its own whether I use it or no.
I had to rollback and thanks to the Turris team, it worked ! I’ll waiting for a fix. Good luck guys !
The snapshot is taken after you confirmed the update! You need to role back one more step to prevent it updating again automatically. Had this on 5.x as well.
My Mox also reboots every few hours, for no apparent reason.
I created a separate thread for that issue: Mox reboots randomly after TOS 6.0 upgrade
Any official steps what to do with Mox? It’s a brick now and I do not want to waste my time to rolling back just for fun. Should I wait for a patch or do the factory reset?
Upgrade went OK but lighttpd didn’t work
(Upgrade took a long time, lots of moving stuff from /srv to /usr - I have an SSD in the Omnia):
turris procd: /etc/rc.d/S85updater-journal-recover: WARN:Collision with existing path. Moving /srv/www/nextcloud/apps/logreader/l10n/hr.json to /usr/share/updater/collided/srv/www/nextcloud/apps/logreader/l10n
root@turris:/www# /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Undefined config variable: var.home_dir
2022-10-20 12:12:51: (…/src/configfile.c.2162) source: /etc/lighttpd/conf.d/30-rrdtool.conf line: 18 pos: 39 parser failed somehow near here: +
2022-10-20 12:12:51: (…/src/configfile.c.2162) source: /etc/lighttpd/lighttpd.conf line: 35 pos: 0 parser failed somehow near here: (EOL)
Line 18 of 30-rrdtool.conf has
rrdtool.db-name = home_dir + “/lighttpd.rrd”
If I
mv /etc/lighttpd/conf.d/30-rrdtool.conf /etc/lighttpd/conf.d/30-rrdtool.conf.bak
lighttpd starts…
HTH someone
Well, surprisingly, on Turris 1.0, everything went smoothly and it looks like everything is working fine so far.
Unfortunately on MOX (updating from 5.4.4), it failed during update.
Log
Error notifications
Updater failed: Failed to fork command /tmp/updater-busybox-nEooNK/busybox: Out of memory
Update notifications
• Installed version 8.4.0-3 of package libgcc
• Installed version 1.1.24-3 of package libc
• Installed version 2021-05-16-b14c4688-2 of package libubox
• Installed version 0.15-2 of package libjson-c
• Installed version 2021-05-16-b14c4688-2 of package libblobmsg-json
• Installed version 2021-05-16-b14c4688-2 of package jshn
• Installed version 2021-06-30-4fc532c8-2 of package ubusd
• Installed version 2021-06-30-4fc532c8-2 of package libubus
• Installed version 2020-08-05-c291088f-2 of package libnl-tiny
• Installed version 2021-04-14-4b3db117-5 of package libuci
• Installed version 2021-10-30-8f82742c-1 of package netifd
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kernel
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-hwmon-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-i2c-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-regmap-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-regmap-i2c
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-rtc-ds1307
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ikconfig
• Installed version 5.15.74-3-68d5cb97f389f2b1d7c118599a176f24 of package kmod-gpio-button-hotplug
• Installed version 2020-06-08-5a8b3662-41 of package hostapd-common
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-hash
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-null
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-gf128
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-ghash
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-sha256
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-aead
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-manager
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-hmac
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-rng
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-seqiv
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-ctr
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-gcm
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-ccm
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-cmac
• Installed version 2022.08.12-1 of package wireless-regdb
• Installed version 2022-04-26-dc6847eb-1 of package libiwinfo-data
• Installed version 2022-04-26-dc6847eb-1 of package iwinfo
• Installed version 5.9-8fab0c9e-3 of package iw
• Installed version 5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-cfg80211
• Installed version 5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mac80211
• Installed version 5.15.74+2020-02-06-a2fd00bb-3-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mwlwifi
• Installed version 20211216-1 of package mwifiex-sdio-firmware
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mmc
• Installed version 5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mwifiex-sdio
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nls-base
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-scsi-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb-storage
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb-storage-extras
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-conntrack
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-nat
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-nathelper
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb-storage-uas
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-log
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-ipt
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-reject
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-br-netfilter
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb-ehci
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-usb2
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-flow
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-kpp
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-ecdh
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-input-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-input-evdev
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-hid
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-crc16
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-ecb
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-bluetooth
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-btmrvl
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24-5 of package mox-dtb
• Installed version 26 of package mtd
• Installed version 2.3.0-48 of package mox-generic-support
• Installed version 2.3.0-48 of package mox-support
• Installed version 1.4.0-1 of package libprotobuf-c
• Installed version 0.6.0-1 of package libfstrm
• Installed version 20210119-1 of package ca-bundle
• Installed version 1.1.24-3 of package libpthread
• Installed version 1.1.24-3 of package librt
• Installed version 2.36.1-2 of package libuuid
• Installed version 1.0.8-1 of package libbz2
• Installed version 3.3-2 of package libffi
• Installed version 1.2.11-6 of package zlib
• Installed version 3.9.14-3.9-1 of package libpython3
• Installed version 3.9.14-3.9-1 of package python3-base
• Installed version 3.9.14-3.9-1 of package python3-light
• Installed version 3.9.14-3.9-1 of package python3-logging
• Installed version 3.9.14-3.9-1 of package python3-multiprocessing
• Installed version 0.0.4-42 of package resolver-conf
• Installed version 2.1.0-beta3-8 of package luajit
• Installed version 0.9.28-1 of package lmdb
• Installed version 1.40.0-3 of package libuv
• Installed version 8.4.0-3 of package libstdcpp
• Installed version 1.43.0-1 of package libnghttp2
• Installed version 3.2.1-1 of package knot-libzscanner
• Installed version 8.4.0-3 of package libatomic
• Installed version 6.2.1-1 of package libgmp
• Installed version 3.6-1 of package libnettle
• Installed version 3.7.1-2 of package libgnutls
• Installed version 3.2.1-1 of package knot-libs
• Installed version 0.0.2-12 of package dnssec-rootkey
• Installed version 5.5.3-1 of package knot-resolver
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-nat
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-nf-conntrack6
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-conntrack
• Installed version 1.8.7-1 of package libxtables
• Installed version 1.8.7-1 of package libip6tc
• Installed version 1.8.7-1 of package libip4tc
• Installed version 2022-02-17-4cd7d4f3-4 of package firewall
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-acompress
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-zstd
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-xor
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-raid6
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-zlib-deflate
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-zlib-inflate
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-lzo
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-crypto-crc32c
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-lib-crc32c
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-fs-btrfs
• Installed version 2.10-4 of package liblzo
• Installed version 2.36.1-2 of package libblkid
• Installed version 2.36.1-2 of package libmount
• Installed version 2.4.48-2 of package libattr
• Installed version 5.11-1 of package btrfs-progs
• Installed version 2.36.1-2 of package libsmartcols
• Installed version 2.36.1-2 of package mount-utils
• Installed version 14-8 of package cert-backup-btrfs
• Installed version 4.2-5 of package cznic-repo-keys
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-libphy
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-fixed-phy
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-of-mdio
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-dsa
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-dsa-mv88e6xxx
• Installed version 2021-04-14-4b3db117-5 of package uci
• Installed version 2020-10-25-9ef88681-2 of package ubox
• Installed version 2021-05-16-b14c4688-2 of package libjson-script
• Installed version 2021-03-08-2cfc26f8-2 of package procd
• Installed version 2.1.2-1 of package ubi-utils
• Installed version 2021-01-04-c53b1882-1 of package fstools
• Installed version 1.1.1q-1 of package libopenssl
• Installed version 7.83.1-4.1 of package libcurl
• Installed version 7.83.1-4.1 of package curl
• Installed version 1.5.7-3 of package cronie
• Installed version 0.23.0-3.9-3 of package python3-crontab
• Installed version 3.9.14-3.9-1 of package python3-email
• Installed version 3.9.14-3.9-1 of package python3-distutils
• Installed version 1.16.0-3.9-1 of package python3-six
• Installed version 2.4.7-3.9-2 of package python3-pyparsing
• Installed version 20.4-3.9-1 of package python3-packaging
• Installed version 1.5.0-3.9-3 of package python3-distro
• Installed version 0.9.0-3.9-1 of package python3-uci
• Installed version 1.4.0-9 of package l10n-supported
• Installed version 5.1.5-9 of package liblua
• Installed version 2021-04-14-4b3db117-5 of package libuci-lua
• Installed version 5.1.5-9 of package lua
• Installed version 2019-04-21-733af884-1 of package luasocket
• Installed version 0.9.54-1 of package json4lua
• Installed version 20210119-1 of package ca-certificates
• Installed version 0.2.1-4 of package base64c
• Installed version 2.2.10-2 of package libexpat
• Installed version 5.2.5-3 of package liblzma
• Installed version 3.5.1-1 of package libarchive
• Installed version 0.9.6-2 of package liburiparser
• Installed version 2.1.12-1 of package libevent2
• Installed version 70.0.0-2 of package updater-ng
• Installed version 1.8.0-42 of package pkglists
• Installed version 1.5.3-3.9-3 of package updater-supervisor
• Installed version 2021-05-14-6a6011df-1 of package libuclient
• Installed version 2021-05-14-6a6011df-1 of package uclient-fetch
• Installed version 2021-06-13-1bf042dd-1 of package opkg
• Installed version 8.32-6 of package coreutils
• Installed version 8.32-6 of package coreutils-sort
• Installed version 2.7.0-28 of package switch-branch
• Installed version 2019-11-12-8f7fe925-1 of package fwtool
• Installed version 2021-02-20-49283916-2 of package openwrt-keyring
• Installed version 2020-05-23-f1f65026-1 of package usign
• Installed version 2018-02-04-c7e938d6-1 of package jsonfilter
• Installed version 1458-6.0-r16691+127-060aa0021f of package base-files
• Installed version 1.33.2-3 of package busybox
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-offload
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-i2c-pxa
• Installed version 5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ath
• Installed version 5.15.74+2021-11-28-dc350bbf-2-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ath10k-ct
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-thermal
• Installed version 5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mt76-core
• Installed version 5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mt76-connac
• Installed version 5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mt7615-common
• Installed version 5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24 of package kmod-mt7915e
• Installed version 5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ath9k-common
• Installed version 6.2-3 of package terminfo
• Installed version 6.2-3 of package libncurses
• Installed version 6.4-1 of package nano
• Installed version 1.09-5 of package etherwake
• Installed version git-21.163.62608-7d7df07 of package luci-app-wol
• Installed version 1-57 of package fix-updater-v65.0-alternatives-update
• Installed version 1-57 of package fix-firewall-zone-limit
• Installed version 10.36-1 of package libpcre2
• Installed version 1.4.67-3 of package lighttpd
• Installed version 1-57 of package fix-lighttpd-sync-with-upstream
• Installed version 1-57 of package fix-network-devices
• Installed version 1-57 of package fix-firewall-check-reboot
• Installed version 0.3.1-3.9-1 of package mox-otp
• Installed version 0.4.1-2 of package crypto-wrapper
• Installed version 3.9.14-3.9-1 of package python3-urllib
• Installed version 3.9.14-3.9-1 of package python3-xml
• Installed version 3.9.14-3.9-1 of package python3-unittest
• Installed version 3330000-1 of package libsqlite3
• Installed version 3.9.14-3.9-1 of package python3-sqlite3
• Installed version 8.1-1 of package libreadline
• Installed version 3.9.14-3.9-1 of package python3-readline
• Installed version 3.9.14-3.9-1 of package python3-pydoc
• Installed version 3.9.14-3.9-1 of package python3-openssl
• Installed version 3.9.14-3.9-1 of package python3-ncurses
• Installed version 3.9.14-3.9-1 of package python3-lzma
• Installed version 1.18.1-2 of package libgdbm
• Installed version 3.9.14-3.9-1 of package python3-gdbm
• Installed version 3.9.14-3.9-1 of package python3-decimal
• Installed version 4.7.25.4.NC-6 of package libdb47
• Installed version 3.9.14-3.9-1 of package python3-dbm
• Installed version 3.9.14-3.9-1 of package python3-ctypes
• Installed version 3.9.14-3.9-1 of package python3-codecs
• Installed version 3.9.14-3.9-1 of package python3-cgi
• Installed version 3.9.14-3.9-1 of package python3-cgitb
• Installed version 3.9.14-3.9-1 of package python3-asyncio
• Installed version 58.1.0-1 of package python3-pkg-resources
• Installed version 58.1.0-1 of package python3-setuptools
• Installed version 0.1.2-3.9-3 of package python3-ubus
• Installed version 0.2.1-3.9-5 of package turris-timezone
• Installed version 1.3-3.9-2 of package python3-text-unidecode
• Installed version 4.0.1-3.9-1 of package python3-slugify
• Installed version 1.1.1q-1 of package libopenssl-conf
• Installed version 1.1.1q-1 of package openssl-util
• Installed version 6-4 of package turris-cagen
• Installed version 1.5.1-3.9-1 of package python3-paho-mqtt
• Installed version 1.17.2-1 of package libcares
• Installed version 2.0.15-1 of package libmosquitto-ssl
• Installed version 1.7.15-3 of package cJSON
• Installed version 2.0.15-1 of package mosquitto-client-ssl
• Installed version 2.43-1 of package libcap
• Installed version 3.1.0-2 of package libwebsockets-openssl
• Installed version 2.0.15-1 of package mosquitto-ssl
• Installed version 22.1-13 of package fosquitto
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-sched-core
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-sched-cake
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-raw
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-conntrack-extra
• Installed version 1.8.7-1 of package iptables
• Installed version 1.8.7-1 of package iptables-mod-conntrack-extra
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ipt-ipopt
• Installed version 1.8.7-1 of package iptables-mod-ipopt
• Installed version 5.15.74-1-68d5cb97f389f2b1d7c118599a176f24 of package kmod-ifb
• Installed version 1.0.4-2 of package libmnl
• Installed version 0.19.8.1-2 of package libintl-full
• Installed version 0.180-1 of package libelf
• Installed version 5.10.10-2 of package libbpf
• Installed version 5.11.0-3 of package tc-mod-iptables
• Installed version 5.11.0-3 of package tc-full
• Installed version 1.5.1-1 of package sqm-scripts
• Installed version 0.19.8.1-2 of package gettext-tools
• Installed version 61.5.1-1 of package create_notification
• Installed version 3.11-3.9-2 of package python3-ply
• Installed version 2.20-3.9-5 of package python3-pycparser
• Installed version 1.14.6-3.9-1 of package python3-cffi
• Installed version 3.4.8-3.9-2 of package python3-cryptography
Then:
Log
Error notifications
Updater failed: pkgupdate: unrecognized option `--state-log'
Try `pkgupdate --help' or `pkgupdate --usage' for more information.
Exit code: 64
So I rollbacked, rebooted (and replugged power because my MOX doesn’t boot up after reboot) and tried to pkgupdate over SSH, which (with a lot of errors) worked:
Log
root@turris-mox:~# pkgupdate
INFO:Target Turris OS: 6.0
INFO:Queue upgrade of libgcc/core/8.4.0-3[7.5.0-2]
INFO:Queue upgrade of libc/core/1.1.24-3[1.1.24-2]
INFO:Queue upgrade of libubox/base/2021-05-16-b14c4688-2[2020-05-25-66195aee-1]
INFO:Queue upgrade of libjson-c/base/0.15-2[0.12.1-3.1]
INFO:Queue upgrade of libblobmsg-json/base/2021-05-16-b14c4688-2[2020-05-25-66195aee-1]
INFO:Queue upgrade of jshn/base/2021-05-16-b14c4688-2[2020-05-25-66195aee-1]
INFO:Queue downgrade of ubusd/base/2021-06-30-4fc532c8-2[2022-02-21-b32a0e17-1]
INFO:Queue downgrade of libubus/base/2021-06-30-4fc532c8-2[2022-02-21-b32a0e17-1]
INFO:Queue downgrade of ubus/base/2021-06-30-4fc532c8-2[2022-02-21-b32a0e17-1]
INFO:Queue upgrade of libnl-tiny/base/2020-08-05-c291088f-2[0.1-5]
INFO:Queue upgrade of libuci/base/2021-04-14-4b3db117-5[2019-09-01-415f9e48-4]
INFO:Queue upgrade of netifd/base/2021-10-30-8f82742c-1[2021-01-09-753c351b-2]
INFO:Queue upgrade of kernel/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-hwmon-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-i2c-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-regmap-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-regmap-i2c/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-rtc-ds1307/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ikconfig/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-gpio-button-hotplug/core/5.15.74-3-68d5cb97f389f2b1d7c118599a176f24[4.14.294-3-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of hostapd-common/base/2020-06-08-5a8b3662-41[2019-08-08-ca8c2bd2-9]
INFO:Queue upgrade of kmod-crypto-hash/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-crypto-null/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-crypto-gf128/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-ghash/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-sha256/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-crypto-aead/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-crypto-manager/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-crypto-hmac/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-rng/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-seqiv/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-ctr/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-gcm/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-crypto-ccm/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-crypto-cmac/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of wireless-regdb/base/2022.08.12-1[2021.08.28-1]
INFO:Queue install of libiwinfo-data/base/2022-04-26-dc6847eb-1
INFO:Queue upgrade of libiwinfo/base/2022-04-26-dc6847eb-1[2019-10-16-07315b6f-3]
INFO:Queue upgrade of iwinfo/base/2022-04-26-dc6847eb-1[2019-10-16-07315b6f-3]
INFO:Queue upgrade of iw/base/5.9-8fab0c9e-3[5.0.1-1]
INFO:Queue upgrade of kmod-cfg80211/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-mac80211/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-mwlwifi/core/5.15.74+2020-02-06-a2fd00bb-3-68d5cb97f389f2b1d7c118599a176f24[4.14.294+2019-03-02-31d93860-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of mwifiex-sdio-firmware/base/20211216-1[20190416-1]
INFO:Queue upgrade of kmod-mmc/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-mwifiex-sdio/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nls-base/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-scsi-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb-storage/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb-storage-extras/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-conntrack/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-nat/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-nathelper/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb-storage-uas/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-nf-log/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-nf-ipt/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-reject/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ipt-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-br-netfilter/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb-ehci/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-usb2/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-flow/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-crypto-kpp/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-crypto-ecdh/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-input-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-input-evdev/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-hid/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-lib-crc16/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-crypto-ecb/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-bluetooth/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-btmrvl/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of mox-dtb/turrispackages/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24-5[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd-1]
INFO:Queue upgrade of mtd/core/26[24]
INFO:Queue upgrade of mox-generic-support/turrispackages/2.3.0-48[2.3.0-4]
INFO:Queue upgrade of mox-support/turrispackages/2.3.0-48[2.3.0-4]
INFO:Queue install of libprotobuf-c/packages/1.4.0-1
INFO:Queue install of libfstrm/packages/0.6.0-1
INFO:Queue upgrade of ca-bundle/base/20210119-1[20200601-1]
INFO:Queue upgrade of libpthread/core/1.1.24-3[1.1.24-2]
INFO:Queue upgrade of librt/core/1.1.24-3[1.1.24-2]
INFO:Queue upgrade of libuuid/base/2.36.1-2[2.34-1]
INFO:Queue reinstall of libbz2/base/1.0.8-1
INFO:Queue reinstall of libffi/packages/3.3-2
INFO:Queue downgrade of zlib/base/1.2.11-6[1.2.12]
INFO:Queue install of libpython3/packages/3.9.14-3.9-1
INFO:Queue upgrade of python3-base/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-light/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-logging/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-multiprocessing/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of resolver-conf/turrispackages/0.0.4-42[0.0.4-1]
INFO:Queue reinstall of luajit/packages/2.1.0-beta3-8
INFO:Queue upgrade of lmdb/packages/0.9.28-1[0.9.24-2]
INFO:Queue upgrade of libuv/packages/1.40.0-3[1.40.0-2]
INFO:Queue upgrade of libstdcpp/core/8.4.0-3[7.5.0-2]
INFO:Queue upgrade of libnghttp2/packages/1.43.0-1[1.41.0-1]
INFO:Queue upgrade of knot-libzscanner/packages/3.2.1-1[3.1.7-1]
INFO:Queue upgrade of libatomic/core/8.4.0-3[7.5.0-2]
INFO:Queue upgrade of libgmp/base/6.2.1-1[6.1.2-2]
INFO:Queue upgrade of libnettle/base/3.6-1[3.5.1-1]
INFO:Queue upgrade of libgnutls/packages/3.7.1-2[3.6.15-2]
INFO:Queue upgrade of knot-libs/packages/3.2.1-1[3.1.7-1]
INFO:Queue upgrade of dnssec-rootkey/turrispackages/0.0.2-12[0.0.2-1]
INFO:Queue reinstall of knot-resolver/turrispackages/5.5.3-1
INFO:Queue upgrade of kmod-ipt-nat/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-conntrack6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ipt-conntrack/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of libxtables/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of libip6tc/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of libip4tc/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of firewall/base/2022-02-17-4cd7d4f3-4[2019-11-22-8174814a-3]
INFO:Queue upgrade of kmod-crypto-acompress/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-lib-zstd/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-lib-xor/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-lib-raid6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-lib-zlib-deflate/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-lib-zlib-inflate/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-lib-lzo/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-crypto-crc32c/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-lib-crc32c/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-fs-btrfs/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of liblzo/packages/2.10-4[2.10-2]
INFO:Queue upgrade of libblkid/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of libmount/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of libattr/packages/2.4.48-2[2.4.48-1]
INFO:Queue upgrade of btrfs-progs/packages/5.11-1[5.7-1]
INFO:Queue upgrade of libsmartcols/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of mount-utils/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of cert-backup-btrfs/turrispackages/14-8[14-2]
INFO:Queue upgrade of cert-backup/turrispackages/14-8[14-2]
INFO:Queue upgrade of cznic-repo-keys/turrispackages/4.2-5[4.2-1]
INFO:Queue install of kmod-libphy/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-fixed-phy/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-of-mdio/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-dsa/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-dsa-mv88e6xxx/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of uci/base/2021-04-14-4b3db117-5[2019-09-01-415f9e48-4]
INFO:Queue upgrade of ubox/base/2020-10-25-9ef88681-2[2019-06-16-4df34a4d-4]
INFO:Queue upgrade of libjson-script/base/2021-05-16-b14c4688-2[2020-05-25-66195aee-1]
INFO:Queue upgrade of procd/base/2021-03-08-2cfc26f8-2[2020-03-07-09b9bd82-1]
INFO:Queue upgrade of ubi-utils/core/2.1.2-1[2.1.1-1]
INFO:Queue upgrade of fstools/core/2021-01-04-c53b1882-1[2020-05-12-84269037-1]
INFO:Queue reinstall of libopenssl/base/1.1.1q-1
INFO:Queue upgrade of libcurl/packages/7.83.1-4.1[7.66.0-3]
INFO:Queue upgrade of curl/packages/7.83.1-4.1[7.66.0-3]
INFO:Queue upgrade of cronie/turrispackages/1.5.7-3[1.5.7-2]
INFO:Queue install of python3-crontab/turrispackages/0.23.0-3.9-3
INFO:Queue upgrade of python3-email/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-distutils/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-six/packages/1.16.0-3.9-1[1.13.0-3.7-1]
INFO:Queue install of python3-pyparsing/packages/2.4.7-3.9-2
INFO:Queue install of python3-packaging/packages/20.4-3.9-1
INFO:Queue upgrade of python3-distro/packages/1.5.0-3.9-3[1.5.0-3.7-1]
INFO:Queue upgrade of python3-uci/packages/0.9.0-3.9-1[0.8.1-3.7-1]
INFO:Queue upgrade of l10n-supported/turrispackages/1.4.0-9[1.3.1-1]
INFO:Queue upgrade of liblua/base/5.1.5-9[5.1.5-3]
INFO:Queue upgrade of libuci-lua/base/2021-04-14-4b3db117-5[2019-09-01-415f9e48-4]
INFO:Queue upgrade of lua/base/5.1.5-9[5.1.5-3]
INFO:Queue upgrade of luasocket/packages/2019-04-21-733af884-1[3.0-rc1-20130909-5]
INFO:Queue reinstall of json4lua/packages/0.9.54-1
INFO:Queue upgrade of ca-certificates/base/20210119-1[20200601-1]
INFO:Queue upgrade of base64c/turrispackages/0.2.1-4[0.2.1-1]
INFO:Queue reinstall of libexpat/packages/2.2.10-2
INFO:Queue upgrade of liblzma/packages/5.2.5-3[5.2.5-1]
INFO:Queue upgrade of libarchive/packages/3.5.1-1[3.4.2-1]
INFO:Queue upgrade of liburiparser/turrispackages/0.9.6-2[0.9.6-1]
INFO:Queue upgrade of libevent2/base/2.1.12-1[2.1.11-1]
INFO:Queue upgrade of updater-ng/turrispackages/70.0.0-2[69.1.3-2]
INFO:Queue upgrade of pkglists/turrispackages/1.8.0-42[1.7.1-1]
INFO:Queue upgrade of updater-supervisor/turrispackages/1.5.3-3.9-3[1.4.3-3.7-2]
INFO:Queue upgrade of libuclient/base/2021-05-14-6a6011df-1[2020-06-17-51e16ebf-1]
INFO:Queue upgrade of uclient-fetch/base/2021-05-14-6a6011df-1[2020-06-17-51e16ebf-1]
INFO:Queue upgrade of opkg/base/2021-06-13-1bf042dd-1[2021-01-31-c5dccea9-1]
INFO:Queue upgrade of coreutils/packages/8.32-6[8.30-2]
INFO:Queue upgrade of coreutils-sort/packages/8.32-6[8.30-2]
INFO:Queue upgrade of switch-branch/turrispackages/2.7.0-28[2.7.0-1]
INFO:Queue upgrade of fwtool/core/2019-11-12-8f7fe925-1[2]
INFO:Queue reinstall of openwrt-keyring/base/2021-02-20-49283916-2
INFO:Queue reinstall of usign/base/2020-05-23-f1f65026-1
INFO:Queue reinstall of jsonfilter/base/2018-02-04-c7e938d6-1
INFO:Queue upgrade of base-files/core/1458-6.0-r16691+127-060aa0021f[204.4-5.4.4-r11431+100-83b0e20711]
INFO:Queue upgrade of busybox/base/1.33.2-3[1.30.1-9]
INFO:Queue upgrade of kmod-ipt-offload/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-i2c-pxa/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-ath/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ath10k-ct/core/5.15.74+2021-11-28-dc350bbf-2-68d5cb97f389f2b1d7c118599a176f24[4.14.294+2021-06-03-b44cd7b2-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue install of kmod-thermal/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-mt76-core/core/5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-mt76-connac/core/5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-mt7615-common/core/5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of kmod-mt7915e/core/5.15.74+2022-10-01-72b87836-4-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-ath9k-common/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ath9k/core/5.15.74+5.15.58-1-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+4.19.237-1-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of terminfo/base/6.2-3[6.1-5]
INFO:Queue upgrade of libncurses/base/6.2-3[6.1-5]
INFO:Queue upgrade of nano/packages/6.4-1[6.2-1]
INFO:Queue upgrade of etherwake/packages/1.09-5[1.09-4]
INFO:Queue downgrade of luci-app-wol/luci/git-21.163.62608-7d7df07[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of fix-updater-v65.0-alternatives-update/turrispackages/1-57[1-1]
INFO:Queue install of fix-firewall-zone-limit/turrispackages/1-57
INFO:Queue install of libpcre2/packages/10.36-1
INFO:Queue upgrade of lighttpd/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue install of fix-lighttpd-sync-with-upstream/turrispackages/1-57
INFO:Queue install of fix-network-devices/turrispackages/1-57
INFO:Queue install of fix-firewall-check-reboot/turrispackages/1-57
INFO:Queue upgrade of mox-otp/turrispackages/0.3.1-3.9-1[0.3-3.7-1]
INFO:Queue upgrade of crypto-wrapper/turrispackages/0.4.1-2[0.4-2]
INFO:Queue upgrade of python3-urllib/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-xml/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-unittest/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of libsqlite3/packages/3330000-1[3310100-1]
INFO:Queue upgrade of python3-sqlite3/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of libreadline/base/8.1-1[8.0-1]
INFO:Queue install of python3-readline/packages/3.9.14-3.9-1
INFO:Queue upgrade of python3-pydoc/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-openssl/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-ncurses/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-lzma/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of libgdbm/packages/1.18.1-2[1.11-1]
INFO:Queue upgrade of python3-gdbm/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-decimal/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue reinstall of libdb47/packages/4.7.25.4.NC-6
INFO:Queue upgrade of python3-dbm/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-ctypes/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-codecs/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-cgi/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-cgitb/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-asyncio/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3/packages/3.9.14-3.9-1[3.7.13-3.7-1]
INFO:Queue upgrade of python3-pkg-resources/packages/58.1.0-1[47.1.0-1]
INFO:Queue upgrade of python3-setuptools/packages/58.1.0-1[47.1.0-1]
INFO:Queue upgrade of python3-ubus/turrispackages/0.1.2-3.9-3[0.1-3.7-2]
INFO:Queue install of turris-timezone/turrispackages/0.2.1-3.9-5
INFO:Queue upgrade of python3-text-unidecode/packages/1.3-3.9-2[1.2-3.7-1]
INFO:Queue upgrade of python3-slugify/packages/4.0.1-3.9-1[3.0.3-3.7-1]
INFO:Queue reinstall of libopenssl-conf/base/1.1.1q-1
INFO:Queue reinstall of openssl-util/base/1.1.1q-1
INFO:Queue upgrade of turris-cagen/turrispackages/6-4[6-1]
INFO:Queue upgrade of python3-paho-mqtt/packages/1.5.1-3.9-1[1.5.1-3.7-1]
INFO:Queue upgrade of libcares/packages/1.17.2-1[1.15.0-5]
INFO:Queue upgrade of libmosquitto-ssl/packages/2.0.15-1[1.6.15-1]
INFO:Queue install of cJSON/packages/1.7.15-3
INFO:Queue upgrade of mosquitto-client-ssl/packages/2.0.15-1[1.6.15-1]
INFO:Queue upgrade of libcap/packages/2.43-1[2.27-1]
INFO:Queue upgrade of libwebsockets-openssl/packages/3.1.0-2[3.1.0-1]
INFO:Queue upgrade of mosquitto-ssl/packages/2.0.15-1[1.6.15-1]
INFO:Queue upgrade of fosquitto/turrispackages/22.1-13[22-1]
INFO:Queue upgrade of kmod-sched-core/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-sched-cake/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294+2019-03-12-057c7388-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ipt-raw/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ipt-conntrack-extra/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of iptables/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of iptables-mod-conntrack-extra/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of kmod-ipt-ipopt/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of iptables-mod-ipopt/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of kmod-ifb/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue reinstall of libmnl/base/1.0.4-2
INFO:Queue reinstall of libintl-full/base/0.19.8.1-2
INFO:Queue upgrade of libelf/base/0.180-1[0.177-1]
INFO:Queue install of libbpf/base/5.10.10-2
INFO:Queue install of tc-mod-iptables/base/5.11.0-3
INFO:Queue install of tc-full/base/5.11.0-3
INFO:Queue upgrade of sqm-scripts/packages/1.5.1-1[1.4.0-2]
INFO:Queue reinstall of gettext-tools/base/0.19.8.1-2
INFO:Queue upgrade of create_notification/turrispackages/61.5.1-1[61.5-2]
INFO:Queue upgrade of python3-ply/packages/3.11-3.9-2[3.11-3.7-1]
INFO:Queue upgrade of python3-pycparser/packages/2.20-3.9-5[2.20-3.7-1]
INFO:Queue upgrade of python3-cffi/packages/1.14.6-3.9-1[1.13.2-3.7-1]
INFO:Queue upgrade of python3-cryptography/packages/3.4.8-3.9-2[2.8-3.7-1]
INFO:Queue upgrade of python3-certifi/packages/2021.5.30-3.9-1[2019.11.28-3.7-1]
INFO:Queue upgrade of python3-urllib3/packages/1.25.11-3.9-1[1.25.10-3.7-1]
INFO:Queue upgrade of python3-idna/packages/3.2-3.9-1[2.9-3.7-1]
INFO:Queue upgrade of python3-chardet/packages/4.0.0-3.9-1[3.0.4-3.7-2]
INFO:Queue upgrade of python3-requests/packages/2.25.1-3.9-2[2.23.0-3.7-1]
INFO:Queue upgrade of sentinel-certgen/turrispackages/6.2-3.9-13[6.2-3.7-1]
INFO:Queue reinstall of msmtp/packages/1.8.19-1
INFO:Queue upgrade of at/packages/3.2.1-1[3.1.23-2]
INFO:Queue upgrade of user-notify/turrispackages/61.5.1-1[61.5-2]
INFO:Queue reinstall of bzip2/base/1.0.8-1
INFO:Queue upgrade of coreutils-base64/packages/8.32-6[8.30-2]
INFO:Queue install of turris-restart/turrispackages/14-1
INFO:Queue reinstall of libacl/packages/2.2.53-1
INFO:Queue upgrade of xz-utils/packages/5.2.5-3[5.2.5-1]
INFO:Queue upgrade of xz/packages/5.2.5-3[5.2.5-1]
INFO:Queue upgrade of tar/packages/1.32-3[1.32-2]
INFO:Queue install of turris-backup/turrispackages/14-1
INFO:Queue upgrade of turris-maintain/turrispackages/14-1[12-1]
INFO:Queue upgrade of turrishw/turrispackages/0.9.0-3.9-1[0.5.3-3.7-1]
INFO:Queue upgrade of python3-pyrsistent/packages/0.16.0-3.9-1[0.15.3-3.7-1]
INFO:Queue upgrade of python3-attrs/packages/21.2.0-3.9-1[19.3.0-3.7-1]
INFO:Queue upgrade of python3-jsonschema/packages/3.2.0-3.9-5[3.2.0-3.7-2]
INFO:Queue upgrade of foris-schema/turrispackages/0.8.0-3.9-3[0.8.0-3.7-1]
INFO:Queue upgrade of python3-ifaddr/packages/0.1.7-3.9-1[0.1.7-3.7-1]
INFO:Queue upgrade of python3-zeroconf/packages/0.29.0-3.9-1[0.28.0-3.7-1]
INFO:Queue upgrade of python3-pbkdf2/turrispackages/1.3-3.9-5[1.3-3.7-4]
INFO:Queue upgrade of python3-prctl/turrispackages/1.8.1-3.9-3[1.7-3.7-2]
INFO:Queue upgrade of foris-controller-app/turrispackages/5.2.0-3.9-3[2.1.3-3.7-1]
INFO:Queue upgrade of foris-client/turrispackages/1.0.4-3.9-3[1.0.3-3.7-4]
INFO:Queue upgrade of foris-controller-hotplug/turrispackages/5.2.0-3.9-3[2.1.3-3.7-1]
INFO:Queue upgrade of foris-controller/turrispackages/5.2.0-3.9-3[2.1.3-3.7-1]
INFO:Queue install of fix-remote-access-ca-permissions/turrispackages/1-57
INFO:Queue install of fix-firewall-doublesafe/turrispackages/1-57
INFO:Queue upgrade of zoneinfo-africa/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-asia/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-europe/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-australia-nz/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-northamerica/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-india/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-atlantic/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-southamerica/packages/2021a-1[2020c-1]
INFO:Queue upgrade of watchdog_adjust/turrispackages/6-2[6-1]
INFO:Queue upgrade of zoneinfo-simple/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-pacific/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-poles/packages/2021a-1[2020c-1]
INFO:Queue upgrade of zoneinfo-core/packages/2021a-1[2020c-1]
INFO:Queue install of flock/base/2.36.1-2
INFO:Queue install of rainbow-animator/turrispackages/0.1.1-3
INFO:Queue install of kmod-ledtrig-activity/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue install of mox-rainbow-backend/turrispackages/0.1.1-2
INFO:Queue install of rainbow/turrispackages/0.1.1-3
INFO:Queue reinstall of wireless-tools/base/29-6
INFO:Queue upgrade of wpad-openssl/base/2020-06-08-5a8b3662-41[2019-08-08-ca8c2bd2-9]
INFO:Queue upgrade of rpcd/base/2022-02-19-8d26a1ba-1[2020-05-26-67c8a3fd-1]
INFO:Queue reinstall of rpcd-mod-rrdns/luci/20170710
INFO:Queue downgrade of luci-proto-ipv6/luci/git-21.148.49484-14511e5[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of libiwinfo-lua/base/2022-04-26-dc6847eb-1[2019-10-16-07315b6f-3]
INFO:Queue downgrade of luci-proto-ppp/luci/git-21.163.64918-6c6559a[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-app-opkg/luci/git-22.273.29015-e01e38c[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-app-firewall/luci/git-22.089.67741-3856d50[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-theme-bootstrap/luci/git-22.288.45155-afd0012[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of rpcd-mod-iwinfo/base/2022-02-19-8d26a1ba-1[2020-05-26-67c8a3fd-1]
INFO:Queue reinstall of cgi-io/packages/2022-08-10-901b0f04-21
INFO:Queue upgrade of rpcd-mod-luci/luci/20210614[20201107]
INFO:Queue upgrade of rpcd-mod-file/base/2022-02-19-8d26a1ba-1[2020-05-26-67c8a3fd-1]
INFO:Queue upgrade of liblucihttp/luci/2021-06-11-3dc89af4-1[2019-07-05-a34a17d5-1]
INFO:Queue upgrade of liblucihttp-lua/luci/2021-06-11-3dc89af4-1[2019-07-05-a34a17d5-1]
INFO:Queue downgrade of luci-lib-jsonc/luci/git-22.097.61937-bc85ba5[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-lib-ip/luci/git-20.250.76529-62505bd[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-lib-nixio/luci/git-20.234.06894-c4a4e43[git-22.264.46202-f25285a-1]
INFO:Queue install of luci-lib-base/luci/git-20.232.39649-1f6dc29
INFO:Queue downgrade of libubus-lua/base/2021-06-30-4fc532c8-2[2022-02-21-b32a0e17-1]
INFO:Queue upgrade of luci-base/luci/git-22.288.45155-afd0012[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-mod-network/luci/git-22.244.54918-77c916e[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-mod-system/luci/git-22.264.46189-30ba277[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-mod-status/luci/git-22.089.70019-d4f0b06[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-mod-admin-full/luci/git-19.253.48496-3f93650[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci/luci/git-20.074.84698-ead5e81[git-22.264.46202-f25285a-1]
INFO:Queue install of ath10k-board-qca988x/base/20211216-1
INFO:Queue upgrade of ath10k-firmware-qca988x-ct/base/2020-11-08-1[2020-07-02-1]
INFO:Queue install of libmagic/packages/5.39-1
INFO:Queue install of file/packages/5.39-1
INFO:Queue upgrade of socat/packages/1.7.3.4-2[1.7.3.3-1]
INFO:Queue install of hwinfo/packages/21.71-3
INFO:Queue upgrade of lsblk/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of turris-diagnostics/turrispackages/16.0.0-4[14.0.0-2]
INFO:Queue upgrade of schnapps/turrispackages/2.10.1-2[2.8.0-2]
INFO:Queue install of libpam/packages/1.5.1-1
INFO:Queue install of lighttpd-mod-auth/turrispackages/1.4.67-3
INFO:Queue install of lighttpd-mod-authn_pam/turrispackages/1.4.67-3
INFO:Queue upgrade of lighttpd-mod-alias/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of lighttpd-mod-fastcgi/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue install of turris-bootstrap-theme/turrispackages/0.3.2-2
INFO:Queue install of turris-diagnostics-web/turrispackages/16.0.0-4
INFO:Queue upgrade of kmod-tun/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of openvpn-openssl/packages/2.5.3-4[2.4.11-1]
INFO:Queue install of luci-mod-dashboard/luci/git-21.020.38173-d3280e6
INFO:Queue upgrade of diffutils/packages/3.7-3[3.7-2]
INFO:Queue upgrade of htop/packages/3.2.1-1[3.0.5-1]
INFO:Queue upgrade of procps-ng/packages/3.3.16-3[3.3.15-2]
INFO:Queue upgrade of procps-ng-top/packages/3.3.16-3[3.3.15-2]
INFO:Queue upgrade of psmisc/packages/23.4-2[23.3-1]
INFO:Queue upgrade of turris-utils/turrispackages/2.1-6[2.1-1]
INFO:Queue upgrade of python3-flup/packages/1.0.3-3.9-4[1.0.3-3.7-3]
INFO:Queue upgrade of python3-werkzeug/packages/2.0.2-3.9-1[0.16.0-3.7-1]
INFO:Queue upgrade of python3-markupsafe/packages/2.1.0-3.9-1[1.1.1-3.7-1]
INFO:Queue upgrade of python3-jinja2/packages/3.0.3-3.9-1[2.10.1-3.7-1]
INFO:Queue upgrade of python3-itsdangerous/packages/2.0.1-3.9-1[1.1.0-3.7-1]
INFO:Queue upgrade of python3-click/packages/8.0.3-3.9-1[7.0-3.7-1]
INFO:Queue upgrade of python3-flask/packages/2.0.1-3.9-1[1.1.2-3.7-1]
INFO:Queue upgrade of python3-flask-seasurf/packages/0.3.0-3.9-1[0.3.0-3.7-1]
INFO:Queue upgrade of python3-pytz/packages/2021.3-3.9-1[2019.3-3.7-1]
INFO:Queue upgrade of python3-babel/packages/2.9.1-3.9-1[2.9.1-3.7-1]
INFO:Queue upgrade of python3-flask-babel/packages/2.0.0-3.9-1[2.0.0-3.7-1]
INFO:Queue install of turris-auth/turrispackages/0.4.2-3.9-1
INFO:Queue upgrade of lighttpd-mod-setenv/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of lighttpd-mod-redirect/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of python3-cachelib/packages/0.1-3.9-2[0.1-3.7-1]
INFO:Queue upgrade of lighttpd-mod-proxy/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of python3-websockets/packages/10.3-3.9-1[9.1-3.7-1]
INFO:Queue upgrade of foris-ws/turrispackages/1.6.2-3.9-5[1.6.1-3.7-5]
INFO:Queue upgrade of reforis/turrispackages/1.3.1-3.9-6.1[1.1.2-3.7-3]
INFO:Queue upgrade of vim-full/packages/8.2-3[8.1-6]
INFO:Queue upgrade of blkid/base/2.36.1-2[2.34-1]
INFO:Queue upgrade of partx-utils/base/2.36.1-2[2.34-1]
INFO:Queue reinstall of libiconv-full/base/1.16-1
INFO:Queue reinstall of libpopt/base/1.16-2
INFO:Queue upgrade of rsync/packages/3.2.3-3[3.1.3-2]
INFO:Queue upgrade of coreutils-stat/packages/8.32-6[8.30-2]
INFO:Queue upgrade of foris-controller-storage-module/turrispackages/0.10.0-3.9-5[0.10.0-3.7-2]
INFO:Queue upgrade of reforis-storage-plugin/turrispackages/0.2.2-3.9-4[0.2.2-3.7-1]
INFO:Queue upgrade of bash/packages/5.1-2[5.0-4]
INFO:Queue upgrade of turris-motd/turrispackages/0.1.0-2[0.1.0-1]
INFO:Queue upgrade of openssh-sftp-client/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of procps-ng-ps/packages/3.3.16-3[3.3.15-2]
INFO:Queue upgrade of libpcre/base/8.44-3[8.43-1]
INFO:Queue install of wget-ssl/packages/1.21.1-1
INFO:Queue downgrade of logrotate/packages/3.17.0-1[3.17.0-2]
INFO:Queue upgrade of libdbi/packages/0.9.0-5[0.9.0-4]
INFO:Queue upgrade of glib2/packages/2.66.4-1[2.58.3-5]
INFO:Queue reinstall of syslog-ng/packages/3.38.1-1
INFO:Queue downgrade of luci-compat/luci/git-22.046.85744-f08a0f6[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-app-Commands/luci/git-21.099.45423-3fff72a[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of resolver-debug/turrispackages/0.0.3-17[0.0.3-1]
INFO:Queue upgrade of openssh-keygen/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of openssh-client/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of openssh-client-utils/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of libpcap/base/1.9.1-3.1[1.9.1-2.1]
INFO:Queue upgrade of tcpdump/base/4.9.3-4[4.9.3-3]
INFO:Queue upgrade of start-indicator/turrispackages/1.0-9[1.0-1]
INFO:Queue upgrade of iputils-tracepath/packages/20210202-1[20101006-1]
INFO:Queue reinstall of libsysfs/base/2.1.0-3
INFO:Queue reinstall of sysfsutils/base/2.1.0-3
INFO:Queue upgrade of libsensors/packages/3.6.0-1[3.5.0-4]
INFO:Queue upgrade of lm-sensors/packages/3.6.0-1[3.5.0-4]
INFO:Queue upgrade of turris-defaults/turrispackages/0.1.2-6[0.1.2-2]
INFO:Queue downgrade of odhcp6c/base/2021-01-09-53f07e90-16[2021-01-09-64e1b4e7-16]
INFO:Queue upgrade of getrandom/base/2020-10-25-9ef88681-2[2019-06-16-4df34a4d-4]
INFO:Queue upgrade of urandom-seed/base/3[1.0-1]
INFO:Queue upgrade of odhcpd/base/2021-07-18-bc9d317f-3[2020-05-03-49e4949c-3]
INFO:Queue reinstall of resolveip/base/2
INFO:Queue upgrade of kmod-iptunnel6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ip6-tunnel/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of ds-lite/base/8[7-4]
INFO:Queue upgrade of kmod-lib-crc-ccitt/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-slhc/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ppp/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-pppox/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-pppoe/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of ppp-mod-pppoe/base/2.4.8.git-2020-10-03-3[2.4.7.git-2019-05-25-5]
INFO:Queue upgrade of ppp/base/2.4.8.git-2020-10-03-3[2.4.7.git-2019-05-25-5]
INFO:Queue upgrade of kmod-iptunnel4/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-iptunnel/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-sit/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of 6in4/base/26[25-1]
INFO:Queue upgrade of kmod-nfnetlink/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-conntrack-netlink/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of libnfnetlink/base/1.0.1-4[1.0.1-3]
INFO:Queue downgrade of libnetfilter-conntrack/base/1.0.8-1[2018-05-01-3ccae9f5-2]
INFO:Queue upgrade of kmod-ipt-ipset/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of dnsmasq-full/base/2.86-2[2.80-16.3]
INFO:Queue upgrade of kmod-zram/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of zram-swap/base/8[1.1-3]
INFO:Queue upgrade of sentinel-firewall/turrispackages/0.1.2-15[0.1.2-1]
INFO:Queue upgrade of libipset/base/7.6-1[7.3-1]
INFO:Queue upgrade of ipset/base/7.6-1[7.3-1]
INFO:Queue upgrade of python3-msgpack/packages/1.0.2-3.9-1[1.0.0-3.7-1]
INFO:Queue upgrade of libsodium/packages/1.0.18-4[1.0.18-1]
INFO:Queue upgrade of libzmq-curve/packages/4.3.4-1[4.3.3-2]
INFO:Queue upgrade of python3-zmq/turrispackages/22.3.0-3.9-3[19.0.1-3.7-1]
INFO:Queue upgrade of sentinel-dynfw-client/turrispackages/1.4.0-17[1.4.0-2]
INFO:Queue upgrade of sentinel-eula/turrispackages/1.1-6[1.1-1]
INFO:Queue upgrade of msgpack-c/packages/4.0.0-1[3.3.0-1]
INFO:Queue upgrade of libconfig/packages/1.7.2-3[1.7.2-2]
INFO:Queue upgrade of libpaho-mqtt-c/turrispackages/1.3.9-2[1.3.9-1]
INFO:Queue upgrade of liblz4/packages/1.9.3-1[1.9.2-4]
INFO:Queue upgrade of libmicrohttpd-no-ssl/packages/0.9.71-1[0.9.62-3]
INFO:Queue downgrade of czmq/packages/4.2.1-1[4.2.1-2]
INFO:Queue upgrade of sentinel-proxy/turrispackages/1.4-2[1.4-1]
INFO:Queue upgrade of kmod-nfnetlink-log/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ipt-nflog/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of iptables-mod-nflog/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of libnetfilter-log/packages/1.0.2-1[1.0.1-2]
INFO:Queue upgrade of logc/turrispackages/0.4.0-5[0.4.0-1]
INFO:Queue upgrade of logc-czmq/turrispackages/0.1.0-2[0.1.0-1]
INFO:Queue upgrade of logc-argp/turrispackages/0.4.0-5[0.4.0-1]
INFO:Queue upgrade of sentinel-fwlogs/turrispackages/0.3.0-2[0.3.0-1]
INFO:Queue upgrade of turris-survey/turrispackages/0.4-3.9-3[0.4-3.7-1]
INFO:Queue upgrade of rmbt-client/turrispackages/1.1-2[1.1-1]
INFO:Queue upgrade of python3-pyserial/packages/3.4-3.9-2[3.4-3.7-1]
INFO:Queue upgrade of netmetr/turrispackages/2.0.2-3.9-4[1.6.0-3.7-1]
INFO:Queue upgrade of kmod-ebtables/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue reinstall of ebtables/base/2018-06-27-48cff25d-1
INFO:Queue upgrade of logc-libevent/turrispackages/0.1.0-2[0.1.0-1]
INFO:Queue upgrade of sentinel-minipot/turrispackages/2.3.0-4[2.3.0-1]
INFO:Queue upgrade of updater-drivers/turrispackages/0.1.2-8[0.1.2-1]
INFO:Queue upgrade of sshpass/packages/1.09-1[1.06-1]
INFO:Queue upgrade of python3-pyasn1/packages/0.4.8-3.9-2[0.4.8-3.7-1]
INFO:Queue upgrade of python3-pyasn1-modules/packages/0.2.8-3.9-2[0.2.8-3.7-1]
INFO:Queue upgrade of python3-service-identity/packages/18.1.0-3.9-2[18.1.0-3.7-1]
INFO:Queue install of python3-cryptodome/packages/3.9.7-3.9-3
INFO:Queue upgrade of python3-zope-interface/packages/5.4.0-3.9-1[4.7.2-3.7-1]
INFO:Queue install of python3-typing-extensions/packages/3.7.4.3-3.9-1
INFO:Queue install of python3-pyopenssl/packages/20.0.1-3.9-1
INFO:Queue upgrade of python3-hyperlink/packages/21.0.0-3.9-1[19.0.0-3.7-1]
INFO:Queue upgrade of python3-incremental/packages/21.3.0-3.9-1[17.5.0-3.7-1]
INFO:Queue upgrade of python3-constantly/packages/15.1.0-3.9-2[15.1.0-3.7-1]
INFO:Queue upgrade of python3-bcrypt/packages/3.1.7-3.9-4[3.1.7-3.7-1]
INFO:Queue upgrade of python3-automat/packages/20.2.0-3.9-2[0.8.0-3.7-1]
INFO:Queue install of python3-appdirs/packages/1.4.4-3.9-1
INFO:Queue upgrade of python3-twisted/packages/22.2.0-3.9-1[19.10.0-3.7-2]
INFO:Queue upgrade of python3-cachetools/packages/3.1.1-3.9-2[3.1.1-3.7-1]
INFO:Queue upgrade of haas-proxy/turrispackages/2.0.2-3.9-6[2.0.2-3.7-2]
INFO:Queue upgrade of localrepo/turrispackages/0.2.1-17[0.2.1-2]
INFO:Queue upgrade of updater-opkg-wrapper/turrispackages/0.2.0-9[0.2.0-2]
INFO:Queue upgrade of turris-version/base/6.0[5.4.4]
INFO:Queue upgrade of 6rd/base/10[9-4]
INFO:Queue install of libevdev/packages/1.13.0-1
INFO:Queue install of libudev-zero/packages/1.0.1-1
INFO:Queue install of libcbor/packages/0.8.0-1
INFO:Queue install of libfido2/packages/1.6.0-1
INFO:Queue upgrade of openssh-server/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of openssh-sftp-server/packages/8.4p1-4[8.0p1-1]
INFO:Queue upgrade of libi2c/packages/4.3-3.9-1[4.1-3.7-3]
INFO:Queue upgrade of i2c-tools/packages/4.3-3.9-1[4.1-3.7-3]
INFO:Queue upgrade of shadow-utils/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of uboot-envtools/core/2021.01-5[2018.03-5]
INFO:Queue upgrade of shadow-common/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-vipw/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-usermod/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-userdel/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-useradd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-su/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-pwunconv/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-pwconv/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-pwck/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-passwd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-nologin/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-newusers/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-newuidmap/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-newgrp/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-newgidmap/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-logoutd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-login/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-lastlog/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-grpunconv/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-grpconv/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-grpck/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-groups/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-groupmod/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-groupmems/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-groupdel/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-groupadd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-gpasswd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-faillog/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-expiry/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-chsh/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-chpasswd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-chgpasswd/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-chfn/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow-chage/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of shadow/packages/4.8.1-3[4.8.1-1]
INFO:Queue upgrade of openssh-moduli/packages/8.4p1-4[8.0p1-1]
INFO:Queue install of pciids/packages/0.359-1
INFO:Queue upgrade of libpci/packages/3.8.0-2[3.6.2-3]
INFO:Queue upgrade of libkmod/packages/27-2[20-2]
INFO:Queue upgrade of pciutils/packages/3.8.0-2[3.6.2-3]
INFO:Queue upgrade of lighttpd-mod-cgi/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of turris-webapps/turrispackages/3.7.1-5[3.7-1]
INFO:Queue upgrade of libtirpc/packages/1.3.2-1[1.2.6-2]
INFO:Queue upgrade of lsof/packages/4.94.0-1[4.91-1]
INFO:Queue install of usbids/packages/0.359-1
INFO:Queue upgrade of libusb-1.0/base/1.0.24-4[1.0.22-2]
INFO:Queue upgrade of usbutils/packages/013-2[007-11]
INFO:Queue upgrade of ip-full/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of umdns/base/2021-01-26-78aa36b0-3[2020-04-25-cdac0460-2]
INFO:Queue upgrade of bind-libs/packages/9.18.7-1[9.16.33-1]
INFO:Queue upgrade of bind-client/packages/9.18.7-1[9.16.33-1]
INFO:Queue upgrade of nstat/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of devlink/base/5.11.0-3[5.0.0-2.1]
INFO:Queue install of kmod-netlink-diag/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of ss/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of genl/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of ip-bridge/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of bind-dig/packages/9.18.7-1[9.16.33-1]
INFO:Queue upgrade of rdma/base/5.11.0-3[5.0.0-2.1]
INFO:Queue upgrade of lighttpd-mod-openssl/turrispackages/1.4.67-3[1.4.63-2]
INFO:Queue upgrade of lighttpd-https-cert/turrispackages/6.0-3[6.0-1]
INFO:Queue downgrade of libnetfilter-queue/packages/1.0.5-4[2017-06-27-601abd1c-2]
INFO:Queue reinstall of libnetfilter-cthelper/packages/1.0.0-2
INFO:Queue reinstall of libnetfilter-cttimeout/packages/1.0.0-2
INFO:Queue downgrade of conntrack/packages/1.4.6-3[2018-05-01-88610abe-1]
INFO:Queue install of kmod-crypto-md5/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of iputils-ping/packages/20210202-1[20101006-1]
INFO:Queue install of kmod-nf-log6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24
INFO:Queue upgrade of kmod-nf-ipt6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-nf-reject6/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of kmod-ip6tables/core/5.15.74-1-68d5cb97f389f2b1d7c118599a176f24[4.14.294-1-28a6284edbf84ab22e01f492fbad32dd]
INFO:Queue upgrade of ip6tables/core/1.8.7-1[1.8.3-1]
INFO:Queue upgrade of libustream-openssl/base/2022-01-16-868fd881-2[2020-03-13-40b563b1-2]
INFO:Queue upgrade of foris-controller-schnapps-module/turrispackages/0.5-3.9-4[0.5-3.7-1]
INFO:Queue upgrade of reforis-snapshots-plugin/turrispackages/1.2.1-3.9-4[1.2.1-3.7-1]
INFO:Queue upgrade of foris-controller-openvpn_client-module/turrispackages/0.6.0-3.9-9[0.5.1-3.7-1]
INFO:Queue upgrade of foris-controller-openvpn-module/turrispackages/0.8.0-3.9-4[0.7.0-3.7-1]
INFO:Queue upgrade of reforis-openvpn-plugin/turrispackages/1.5.0-3.9-4[1.5.0-3.7-1]
INFO:Queue upgrade of foris-controller-haas-module/turrispackages/0.1.1-3.9-3[0.1.1-3.7-1]
INFO:Queue upgrade of foris-controller-sentinel-module/turrispackages/0.3.0-3.9-3[0.3.0-3.7-1]
INFO:Queue upgrade of reforis-data-collection-plugin/turrispackages/0.4.0-3.9-5[0.4.0-3.7-1]
INFO:Queue upgrade of reforis-haas-plugin/turrispackages/0.1.4-3.9-1[0.1.3-3.7-1]
INFO:Queue upgrade of foris-controller-diagnostics-module/turrispackages/1.0.5-3.9-4[1.0.5-3.7-1]
INFO:Queue upgrade of reforis-diagnostics-plugin/turrispackages/2.5.1-3.9-4[2.5.1-3.7-1]
INFO:Queue upgrade of turris-webapps-luci/turrispackages/1.1-7[1.1-1]
INFO:Queue upgrade of foris-controller-netmetr-module/turrispackages/0.4.2-3.9-10[0.4.2-3.7-4]
INFO:Queue upgrade of reforis-netmetr-plugin/turrispackages/0.3.0-3.9-5[0.3.0-3.7-1]
INFO:Queue upgrade of openvpn-hotplug/turrispackages/0.2-2[0.2-1]
INFO:Queue upgrade of luci-i18n-base-en/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-i18n-wol-cs/luci/git-22.240.58472-bdaec14[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-i18n-opkg-cs/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-i18n-base-cs/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of reforis-l10n-cs/turrispackages/1.3.1-3.9-6.1[1.1.2-3.7-3]
INFO:Queue upgrade of reforis-haas-plugin-l10n-cs/turrispackages/0.1.4-3.9-1[0.1.3-3.7-1]
INFO:Queue upgrade of reforis-diagnostics-plugin-l10n-cs/turrispackages/2.5.1-3.9-4[2.5.1-3.7-1]
INFO:Queue upgrade of reforis-data-collection-plugin-l10n-cs/turrispackages/0.4.0-3.9-5[0.4.0-3.7-1]
INFO:Queue upgrade of reforis-netmetr-plugin-l10n-cs/turrispackages/0.3.0-3.9-5[0.3.0-3.7-1]
INFO:Queue upgrade of user-notify-l10n-cs/turrispackages/1.6.0-2[1.4.1-1]
INFO:Queue install of turris-diagnostics-l10n-cs/turrispackages/16.0.0-4
INFO:Queue upgrade of reforis-openvpn-plugin-l10n-cs/turrispackages/1.5.0-3.9-4[1.5.0-3.7-1]
INFO:Queue upgrade of pkglists-l10n-cs/turrispackages/1.6.0-2[1.4.1-1]
INFO:Queue upgrade of reforis-snapshots-plugin-l10n-cs/turrispackages/1.2.1-3.9-4[1.2.1-3.7-1]
INFO:Queue upgrade of luci-i18n-firewall-en/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-i18n-Commands-en/luci/git-22.240.58472-bdaec14[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-i18n-opkg-en/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue upgrade of luci-i18n-firewall-cs/luci/git-22.277.72334-3923199[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-i18n-wol-en/luci/git-22.240.58472-bdaec14[git-22.264.46202-f25285a-1]
INFO:Queue downgrade of luci-i18n-Commands-cs/luci/git-22.240.58472-bdaec14[git-22.264.46202-f25285a-1]
INFO:Queue removal of python3-python
INFO:Queue removal of kmod-crypto-pcompress
INFO:Queue removal of wget
INFO:Queue removal of iputils-traceroute6
INFO:Queue removal of kmod-ledtrig-heartbeat
INFO:Queue removal of python3-crypto
INFO:Queue removal of python3-importlib-metadata
INFO:Queue removal of iputils-ping6
INFO:Queue removal of python3-zipp
INFO:Queue removal of python3-more-itertools
INFO:Queue removal of python3-simplejson
INFO:Queue removal of kmod-lib-lz4
INFO:Queue removal of iputils-tracepath6
INFO:Queue removal of tc
Press return to continue, CTRL+C to abort
INFO:Downloading packages
INFO:Executing preupdate hook: 05_schnapps.sh
Snapshot number 104 created
INFO:Unpacking download packages
INFO:Checking for file collisions between packages
INFO:Running pre-install and pre-rm scripts and merging packages to root file system
WARN:Config file /etc/config/resolver modified by the user. Backing up the new one into /etc/config/resolver-opkg
WARN:Config file /etc/config/firewall modified by the user. Backing up the new one into /etc/config/firewall-opkg
WARN:Config file /etc/config/updater modified by the user. Backing up the new one into /etc/config/updater-opkg
WARN:Config file /etc/config/pkglists modified by the user. Backing up the new one into /etc/config/pkglists-opkg
WARN:Config file /etc/passwd modified by the user. Backing up the new one into /etc/passwd-opkg
WARN:Config file /etc/shadow modified by the user. Backing up the new one into /etc/shadow-opkg
WARN:Config file /etc/shells modified by the user. Backing up the new one into /etc/shells-opkg
WARN:Config file /etc/group modified by the user. Backing up the new one into /etc/group-opkg
WARN:Collision with existing path. Moving //sbin/tc to /usr/share/updater/collided/sbin
WARN:Config file /etc/config/user_notify modified by the user. Backing up the new one into /etc/config/user_notify-opkg
WARN:Config file /etc/config/foris modified by the user. Backing up the new one into /etc/config/foris-opkg
WARN:Config file /etc/config/luci modified by the user. Backing up the new one into /etc/config/luci-opkg
WARN:Config file /etc/config/openvpn modified by the user. Backing up the new one into /etc/config/openvpn-opkg
WARN:Config file /etc/config/dhcp modified by the user. Backing up the new one into /etc/config/dhcp-opkg
WARN:Config file /etc/config/sentinel modified by the user. Backing up the new one into /etc/config/sentinel-opkg
WARN:Config file /etc/config/netmetr modified by the user. Backing up the new one into /etc/config/netmetr-opkg
WARN:Config file /etc/config/haas modified by the user. Backing up the new one into /etc/config/haas-opkg
INFO:Running prerm of python3-python
INFO:Running prerm of kmod-crypto-pcompress
INFO:Running prerm of wget
INFO:Running prerm of iputils-traceroute6
INFO:Running prerm of kmod-ledtrig-heartbeat
INFO:Running prerm of python3-crypto
INFO:Running prerm of python3-importlib-metadata
INFO:Running prerm of iputils-ping6
INFO:Running prerm of python3-zipp
INFO:Running prerm of python3-more-itertools
INFO:Running prerm of python3-simplejson
INFO:Running prerm of kmod-lib-lz4
INFO:Running prerm of iputils-tracepath6
INFO:Running prerm of tc
INFO:Removing packages and leftover files
INFO:Running post-install and post-rm scripts
INFO:Running postinst of libgcc
INFO:Running postinst of libc
INFO:Running postinst of libubox
INFO:Running postinst of libjson-c
INFO:Running postinst of libblobmsg-json
INFO:Running postinst of jshn
INFO:Running postinst of ubusd
INFO:Running postinst of libubus
INFO:Running postinst of libnl-tiny
INFO:Running postinst of libuci
INFO:Running postinst of netifd
Failed to connect to ubus
Command failed: Not found
INFO:Running postinst of kernel
INFO:Running postinst of kmod-hwmon-core
INFO:Running postinst of kmod-i2c-core
INFO:Running postinst of kmod-regmap-core
INFO:Running postinst of kmod-regmap-i2c
INFO:Running postinst of kmod-rtc-ds1307
INFO:Running postinst of kmod-ikconfig
INFO:Running postinst of kmod-gpio-button-hotplug
INFO:Running postinst of hostapd-common
INFO:Running postinst of kmod-crypto-hash
INFO:Running postinst of kmod-crypto-null
INFO:Running postinst of kmod-crypto-gf128
INFO:Running postinst of kmod-crypto-ghash
INFO:Running postinst of kmod-crypto-sha256
INFO:Running postinst of kmod-crypto-aead
INFO:Running postinst of kmod-crypto-manager
INFO:Running postinst of kmod-crypto-hmac
INFO:Running postinst of kmod-crypto-rng
INFO:Running postinst of kmod-crypto-seqiv
INFO:Running postinst of kmod-crypto-ctr
INFO:Running postinst of kmod-crypto-gcm
INFO:Running postinst of kmod-crypto-ccm
INFO:Running postinst of kmod-crypto-cmac
INFO:Running postinst of wireless-regdb
INFO:Running postinst of libiwinfo-data
INFO:Running postinst of iwinfo
INFO:Running postinst of kmod-cfg80211
INFO:Running postinst of kmod-mac80211
INFO:Running postinst of kmod-mwlwifi
INFO:Running postinst of mwifiex-sdio-firmware
INFO:Running postinst of kmod-mmc
INFO:Running postinst of kmod-mwifiex-sdio
INFO:Running postinst of kmod-nls-base
INFO:Running postinst of kmod-usb-core
INFO:Running postinst of kmod-scsi-core
INFO:Running postinst of kmod-usb-storage
INFO:Running postinst of kmod-usb-storage-extras
INFO:Running postinst of kmod-nf-conntrack
INFO:Running postinst of kmod-nf-nat
INFO:Running postinst of kmod-nf-nathelper
INFO:Running postinst of kmod-usb-storage-uas
INFO:Running postinst of kmod-nf-log
INFO:Running postinst of kmod-nf-ipt
INFO:Running postinst of kmod-nf-reject
INFO:Running postinst of kmod-ipt-core
INFO:Running postinst of kmod-br-netfilter
INFO:Running postinst of kmod-usb-ehci
INFO:Running postinst of kmod-usb2
INFO:Running postinst of kmod-nf-flow
INFO:Running postinst of kmod-crypto-kpp
INFO:Running postinst of kmod-crypto-ecdh
INFO:Running postinst of kmod-input-core
INFO:Running postinst of kmod-input-evdev
INFO:Running postinst of kmod-hid
INFO:Running postinst of kmod-lib-crc16
INFO:Running postinst of kmod-crypto-ecb
INFO:Running postinst of kmod-bluetooth
INFO:Running postinst of kmod-btmrvl
INFO:Running postinst of mox-dtb
INFO:Running postinst of mtd
INFO:Running postinst of mox-generic-support
INFO:Running postinst of mox-support
INFO:Running postinst of libprotobuf-c
INFO:Running postinst of libfstrm
INFO:Running postinst of ca-bundle
INFO:Running postinst of libpthread
INFO:Running postinst of librt
INFO:Running postinst of libuuid
INFO:Running postinst of libbz2
INFO:Running postinst of libffi
INFO:Running postinst of zlib
INFO:Running postinst of libpython3
INFO:Running postinst of python3-base
INFO:Running postinst of python3-light
INFO:Running postinst of python3-logging
INFO:Running postinst of python3-multiprocessing
INFO:Running postinst of resolver-conf
Preferred resolver=kresd
Convert kresd/unbound configuration to /etc/config/resolver
Converting kresd configuration
Converting unbound configuration
nothing done
Called /etc/init.d/kresd stop
set dhcp script
job 27 at Thu Oct 20 13:18:00 2022
Called /etc/init.d/kresd start
set dhcp script
Called /etc/resolver/dhcp_host_domain_ng.py
uci: Entry not found
INFO:Running postinst of luajit
INFO:Running postinst of lmdb
INFO:Running postinst of libuv
INFO:Running postinst of libstdcpp
INFO:Running postinst of libnghttp2
INFO:Running postinst of knot-libzscanner
INFO:Running postinst of libatomic
INFO:Running postinst of libgmp
INFO:Running postinst of libnettle
INFO:Running postinst of libgnutls
INFO:Running postinst of knot-libs
INFO:Running postinst of dnssec-rootkey
/etc/root.keys already stored, skipping
+ '[' -n ]
+ /usr/sbin/cert-backup /etc/root.keys
INFO:Running postinst of knot-resolver
set dhcp script
job 28 at Thu Oct 20 13:18:00 2022
set dhcp script
resolver.kresd.hostname_config was already converted to list
+ '[' -z ]
+ /etc/init.d/dnsmasq restart
+ sleep 2
+ /etc/kresd/kresd.postinst.sh
+ uci -q get resolver.kresd.static_domains
+ stat_dom=
+ '[' '!' -z ]
+ /etc/init.d/resolver restart
+ rm /etc/kresd/kresd.postinst.sh
+ /etc/kresd/convert_config.sh
+ rm /etc/kresd/convert_config.sh
+ uci -q get resolver.common.prefered_resolver
+ '[' kresd '=' kresd ]
+ + uci -q get resolver.common.forward_upstream
egrep -q '(1|yes|true|enabled|on)'
+ ping -c 1 repo.turris.cz
INFO:Running postinst of kmod-ipt-nat
INFO:Running postinst of kmod-nf-conntrack6
INFO:Running postinst of kmod-ipt-conntrack
INFO:Running postinst of libxtables
INFO:Running postinst of libip6tc
INFO:Running postinst of libip4tc
INFO:Running postinst of firewall
Warning: Failed to connect to ubus
Warning: Section @zone[0] (lan) cannot resolve device of network 'lan'
Warning: Section @zone[1] (xxxxxxx) cannot resolve device of network 'xxxxxxx'
Warning: Section @zone[2] (yyyyyy) cannot resolve device of network yyyyyyyy
Warning: Option @zone[3].sentinel_dynfw is unknown
Warning: Option @zone[3].sentinel_fwlogs is unknown
Warning: Option @zone[3].sentinel_minipot is unknown
Warning: Option @zone[3].haas_proxy is unknown
Warning: Section @zone[3] (wan) cannot resolve device of network 'wan'
Warning: Section @zone[3] (wan) cannot resolve device of network 'wan6'
Warning: Section 'guest_turris' must not have a name longer than 11 characters
Warning: Section 'turris_vpn_client' has no device, network, subnet or extra options
Warning: Section 'vpn_turris' cannot resolve device of network 'vpn_turris'
Warning: Section 'guest_turris_dns_rule' refers to not existing zone 'guest_turris'
Warning: Section 'guest_turris_dhcp_rule' refers to not existing zone 'guest_turris'
Warning: Section 'guest_turris_Allow_DHCPv6' refers to not existing zone 'guest_turris'
Warning: Section 'guest_turris_Allow_MLD' refers to not existing zone 'guest_turris'
Warning: Section 'guest_turris_Allow_ICMPv6_Input' refers to not existing zone 'guest_turris'
Warning: Section @rule[20] (Allow VPN secondary subnet to yyyyyy) does not specify a protocol, assuming TCP+UDP
Warning: Section @rule[21] (Block VPN secondary subnet to LAN) does not specify a protocol, assuming TCP+UDP
Warning: Section @redirect[0] (yyyyxxxx.cz) does not specify a protocol, assuming TCP+UDP
Warning: Section @redirect[2] (xxxxxxxx.cz) does not specify a protocol, assuming TCP+UDP
Warning: Section 'guest_turris_forward_wan' refers to not existing zone 'guest_turris'
Warning: Section @zone[4] (guest_turris) must not have a name longer than 11 characters
Warning: Section @zone[5] (tr_vpn_xx) has no device, network, subnet or extra options
* Flushing IPv4 filter table
* Flushing IPv4 nat table
* Flushing IPv4 mangle table
* Flushing IPv4 raw table
* Flushing IPv6 filter table
* Flushing IPv6 mangle table
* Flushing conntrack table ...
* Populating IPv4 filter table
* Rule 'Allow-DHCP-Renew'
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Rule 'Allow-IPSec-ESP'
* Rule 'Allow-ISAKMP'
* Rule 'vpn_turris_rule'
* Rule 'Allow VPN secondary subnet to yyyyyy'
* Rule 'Block VPN secondary subnet to LAN'
* Redirect 'yyyyxxxx.cz'
* Redirect 'xxxxxxxx.cz'
* Forward 'lan' -> 'wan'
* Forward 'lan' -> 'tr_vpn_xx'
* Forward 'vpn_turris' -> 'lan'
* Forward 'lan' -> 'vpn_turris'
* Forward yyyyyyyy -> 'wan'
* Forward 'xxxxxxx' -> 'wan'
* Forward 'lan' -> yyyyyyyy
* Forward 'lan' -> 'xxxxxxx'
* Forward 'vpn_turris' -> yyyyyyyy
* Forward yyyyyyyy -> 'vpn_turris'
* Forward yyyyyyyy -> 'lan'
* Forward 'vpn_turris' -> 'xxxxxxx'
* Forward 'xxxxxxx' -> 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Populating IPv4 nat table
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Populating IPv4 mangle table
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Populating IPv4 raw table
* Zone 'lan'
- Using automatic conntrack helper attachment
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Populating IPv6 filter table
* Rule 'Allow-DHCPv6'
* Rule 'Allow-MLD'
* Rule 'Allow-ICMPv6-Input'
* Rule 'Allow-ICMPv6-Forward'
! Skipping due to different family of ip address
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Populating IPv6 mangle table
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Set tcp_ecn to off
* Set tcp_syncookies to on
* Set tcp_window_scaling to on
* Running script '/etc/firewall.user'
* Running script '/usr/libexec/sentinel/firewall.sh'
* Dynamic blocking on zone 'wan'
- input
- forward
* Logging of zone 'wan'
- DROP
- REJECT
* HaaS proxy on zone 'wan' (22 -> 2525)
* Minipot FTP on zone 'wan' (21 -> 2133)
* Minipot HTTP on zone 'wan' (80 -> 8033)
* Minipot SMTP on zone 'wan' (25 -> 5873)
* Minipot SMTP submission on zone 'wan' (587 -> 5873)
* Minipot Telnet on zone 'wan' (23 -> 2333)
INFO:Running postinst of kmod-crypto-acompress
INFO:Running postinst of kmod-lib-zstd
INFO:Running postinst of kmod-lib-xor
INFO:Running postinst of kmod-lib-raid6
INFO:Running postinst of kmod-lib-zlib-deflate
INFO:Running postinst of kmod-lib-zlib-inflate
INFO:Running postinst of kmod-lib-lzo
INFO:Running postinst of kmod-crypto-crc32c
INFO:Running postinst of kmod-lib-crc32c
INFO:Running postinst of kmod-fs-btrfs
INFO:Running postinst of liblzo
INFO:Running postinst of libblkid
INFO:Running postinst of libmount
INFO:Running postinst of libattr
INFO:Running postinst of btrfs-progs
INFO:Running postinst of libsmartcols
INFO:Running postinst of mount-utils
INFO:Running postinst of cert-backup-btrfs
INFO:Running postinst of cznic-repo-keys
/etc/updater/keys/release.pub already stored, skipping
/etc/updater/keys/standby.pub already stored, skipping
INFO:Running postinst of kmod-libphy
INFO:Running postinst of kmod-fixed-phy
INFO:Running postinst of kmod-of-mdio
INFO:Running postinst of kmod-dsa
INFO:Running postinst of kmod-dsa-mv88e6xxx
INFO:Running postinst of uci
INFO:Running postinst of ubox
INFO:Running postinst of libjson-script
INFO:Running postinst of procd
INFO:Running postinst of ubi-utils
INFO:Running postinst of fstools
INFO:Running postinst of libopenssl
INFO:Running postinst of libcurl
INFO:Running postinst of curl
INFO:Running postinst of cronie
INFO:Running postinst of python3-crontab
INFO:Running postinst of python3-email
INFO:Running postinst of python3-distutils
INFO:Running postinst of python3-six
INFO:Running postinst of python3-pyparsing
INFO:Running postinst of python3-packaging
INFO:Running postinst of python3-distro
INFO:Running postinst of python3-uci
INFO:Running postinst of l10n-supported
l10n
INFO:Running postinst of liblua
INFO:Running postinst of libuci-lua
INFO:Running postinst of luasocket
INFO:Running postinst of json4lua
INFO:Running postinst of ca-certificates
INFO:Running postinst of base64c
INFO:Running postinst of libexpat
INFO:Running postinst of liblzma
INFO:Running postinst of libarchive
INFO:Running postinst of liburiparser
INFO:Running postinst of libevent2
INFO:Running postinst of updater-ng
INFO:Running postinst of pkglists
INFO:Running postinst of updater-supervisor
INFO:Running postinst of libuclient
INFO:Running postinst of uclient-fetch
INFO:Running postinst of opkg
INFO:Running postinst of coreutils
INFO:Running postinst of coreutils-sort
INFO:Running postinst of switch-branch
+ uci set 'updater.turris=turris'
+ uci set 'updater.turris.mode=branch'
+ uci set 'updater.turris.branch=hbs'
+ sed -i 's|https://repo\.turris\.cz/.*/\([^/]*\)/packages/|https://repo\.turris\.cz/hbs/\1/packages/|' /etc/opkg/distfeeds.conf
+ uci commit updater.turris
+ set +x
INFO:Running postinst of fwtool
INFO:Running postinst of openwrt-keyring
INFO:Running postinst of usign
INFO:Running postinst of jsonfilter
INFO:Running postinst of base-files
+ set +x
INFO:Running postinst of busybox
Failed to parse json data: unexpected end of data
INFO:Running postinst of kmod-ipt-offload
INFO:Running postinst of kmod-i2c-pxa
INFO:Running postinst of kmod-ath
INFO:Running postinst of kmod-ath10k-ct
INFO:Running postinst of kmod-thermal
INFO:Running postinst of kmod-mt76-core
INFO:Running postinst of kmod-mt76-connac
INFO:Running postinst of kmod-mt7615-common
INFO:Running postinst of kmod-mt7915e
INFO:Running postinst of kmod-ath9k-common
INFO:Running postinst of terminfo
INFO:Running postinst of libncurses
INFO:Running postinst of nano
INFO:Running postinst of etherwake
INFO:Running postinst of luci-app-wol
INFO:Running postinst of fix-updater-v65.0-alternatives-update
INFO:Running postinst of fix-firewall-zone-limit
INFO:Running postinst of libpcre2
INFO:Running postinst of lighttpd
INFO:Running postinst of fix-lighttpd-sync-with-upstream
INFO:Running postinst of fix-network-devices
INFO:Running postinst of fix-firewall-check-reboot
warning: Commands will be executed using /bin/sh
job 29 at Thu Oct 20 13:21:00 2022
INFO:Running postinst of mox-otp
INFO:Running postinst of crypto-wrapper
INFO:Running postinst of python3-urllib
INFO:Running postinst of python3-xml
INFO:Running postinst of python3-unittest
INFO:Running postinst of libsqlite3
INFO:Running postinst of python3-sqlite3
INFO:Running postinst of libreadline
INFO:Running postinst of python3-readline
INFO:Running postinst of python3-pydoc
INFO:Running postinst of python3-openssl
INFO:Running postinst of python3-ncurses
INFO:Running postinst of python3-lzma
INFO:Running postinst of libgdbm
INFO:Running postinst of python3-gdbm
INFO:Running postinst of python3-decimal
INFO:Running postinst of libdb47
INFO:Running postinst of python3-dbm
INFO:Running postinst of python3-ctypes
INFO:Running postinst of python3-codecs
INFO:Running postinst of python3-cgi
INFO:Running postinst of python3-cgitb
INFO:Running postinst of python3-asyncio
INFO:Running postinst of python3-pkg-resources
INFO:Running postinst of python3-setuptools
INFO:Running postinst of python3-ubus
INFO:Running postinst of turris-timezone
INFO:Running postinst of python3-text-unidecode
INFO:Running postinst of python3-slugify
INFO:Running postinst of libopenssl-conf
INFO:Running postinst of openssl-util
INFO:Running postinst of turris-cagen
INFO:Running postinst of python3-paho-mqtt
INFO:Running postinst of libcares
INFO:Running postinst of libmosquitto-ssl
INFO:Running postinst of cJSON
INFO:Running postinst of mosquitto-client-ssl
INFO:Running postinst of libcap
INFO:Running postinst of libwebsockets-openssl
INFO:Running postinst of mosquitto-ssl
INFO:Running postinst of fosquitto
Generating fosquitto config file in /var/etc/fosquitto.generated.conf
INFO:Running postinst of kmod-sched-core
INFO:Running postinst of kmod-sched-cake
INFO:Running postinst of kmod-ipt-raw
INFO:Running postinst of kmod-ipt-conntrack-extra
INFO:Running postinst of iptables
INFO:Running postinst of iptables-mod-conntrack-extra
INFO:Running postinst of kmod-ipt-ipopt
INFO:Running postinst of iptables-mod-ipopt
INFO:Running postinst of kmod-ifb
INFO:Running postinst of libmnl
INFO:Running postinst of libintl-full
INFO:Running postinst of libelf
INFO:Running postinst of libbpf
INFO:Running postinst of tc-mod-iptables
INFO:Running postinst of tc-full
INFO:Running postinst of sqm-scripts
INFO:Running postinst of gettext-tools
INFO:Running postinst of create_notification
INFO:Running postinst of python3-ply
INFO:Running postinst of python3-pycparser
INFO:Running postinst of python3-cffi
INFO:Running postinst of python3-cryptography
INFO:Running postinst of python3-certifi
INFO:Running postinst of python3-urllib3
INFO:Running postinst of python3-idna
INFO:Running postinst of python3-chardet
INFO:Running postinst of python3-requests
INFO:Running postinst of sentinel-certgen
INFO:Running postinst of msmtp
INFO:Running postinst of at
INFO:Running postinst of user-notify
INFO:Running postinst of bzip2
INFO:Running postinst of coreutils-base64
INFO:Running postinst of turris-restart
INFO:Running postinst of libacl
INFO:Running postinst of xz-utils
INFO:Running postinst of tar
INFO:Running postinst of turris-backup
INFO:Running postinst of turris-maintain
INFO:Running postinst of turrishw
INFO:Running postinst of python3-pyrsistent
INFO:Running postinst of python3-attrs
INFO:Running postinst of python3-jsonschema
INFO:Running postinst of foris-schema
INFO:Running postinst of python3-ifaddr
INFO:Running postinst of python3-zeroconf
INFO:Running postinst of python3-pbkdf2
INFO:Running postinst of python3-prctl
INFO:Running postinst of foris-controller-app
INFO:Running postinst of foris-client
INFO:Running postinst of foris-controller-hotplug
INFO:Running postinst of fix-remote-access-ca-permissions
INFO:Running postinst of fix-firewall-doublesafe
Warning: Section 'guest_turris' cannot resolve device of network 'guest_turris'
Warning: Section @zone[0] (lan) has no device, network, subnet or extra options
Warning: Section @zone[1] (xxxxxxx) has no device, network, subnet or extra options
Warning: Section @zone[2] (yyyyyy) has no device, network, subnet or extra options
Warning: Section @zone[3] (wan) has no device, network, subnet or extra options
Warning: Section @zone[4] (tr_vpn_xx) has no device, network, subnet or extra options
Warning: Section @zone[5] (vpn_turris) has no device, network, subnet or extra options
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Rule 'guest dns rule'
* Rule 'guest dhcp rule'
* Forward 'tr_guest' -> 'wan'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of zoneinfo-africa
INFO:Running postinst of zoneinfo-asia
INFO:Running postinst of zoneinfo-europe
INFO:Running postinst of zoneinfo-australia-nz
INFO:Running postinst of zoneinfo-northamerica
INFO:Running postinst of zoneinfo-india
INFO:Running postinst of zoneinfo-atlantic
INFO:Running postinst of zoneinfo-southamerica
INFO:Running postinst of watchdog_adjust
INFO:Running postinst of zoneinfo-simple
INFO:Running postinst of zoneinfo-pacific
INFO:Running postinst of zoneinfo-poles
INFO:Running postinst of zoneinfo-core
INFO:Running postinst of flock
INFO:Running postinst of rainbow-animator
INFO:Running postinst of kmod-ledtrig-activity
INFO:Running postinst of mox-rainbow-backend
/usr/libexec/rainbow/uci.sh: line 67: type: led_defaults: not found
/usr/libexec/rainbow/led_activity.sh: line 141: /sys/class/leds/mox:red:activity/trigger: No such file or directory
grep: /sys/class/leds/mox:red:activity/trigger: No such file or directory
/usr/libexec/rainbow/led_activity.sh: line 144: /sys/class/leds/mox:red:activity/invert: No such file or directory
Warning: activity setup failed for: activity
INFO:Running postinst of wireless-tools
INFO:Running postinst of wpad-openssl
INFO:Running postinst of rpcd
INFO:Running postinst of rpcd-mod-rrdns
INFO:Running postinst of luci-proto-ipv6
INFO:Running postinst of libiwinfo-lua
INFO:Running postinst of luci-proto-ppp
INFO:Running postinst of luci-app-opkg
INFO:Running postinst of luci-app-firewall
INFO:Running postinst of luci-theme-bootstrap
/luci-static/bootstrap
INFO:Running postinst of rpcd-mod-iwinfo
INFO:Running postinst of cgi-io
INFO:Running postinst of rpcd-mod-luci
INFO:Running postinst of rpcd-mod-file
INFO:Running postinst of liblucihttp
INFO:Running postinst of liblucihttp-lua
INFO:Running postinst of luci-lib-jsonc
INFO:Running postinst of luci-lib-ip
INFO:Running postinst of luci-lib-nixio
INFO:Running postinst of luci-lib-base
INFO:Running postinst of libubus-lua
INFO:Running postinst of luci-base
INFO:Running postinst of luci-mod-network
INFO:Running postinst of luci-mod-system
INFO:Running postinst of luci-mod-status
INFO:Running postinst of luci-mod-admin-full
INFO:Running postinst of ath10k-board-qca988x
INFO:Running postinst of ath10k-firmware-qca988x-ct
INFO:Running postinst of libmagic
INFO:Running postinst of file
INFO:Running postinst of socat
INFO:Running postinst of hwinfo
INFO:Running postinst of lsblk
INFO:Running postinst of turris-diagnostics
INFO:Running postinst of schnapps
INFO:Running postinst of libpam
INFO:Running postinst of lighttpd-mod-auth
INFO:Running postinst of lighttpd-mod-authn_pam
INFO:Running postinst of lighttpd-mod-alias
INFO:Running postinst of lighttpd-mod-fastcgi
INFO:Running postinst of turris-bootstrap-theme
INFO:Running postinst of turris-diagnostics-web
INFO:Running postinst of kmod-tun
INFO:Running postinst of openvpn-openssl
INFO:Running postinst of luci-mod-dashboard
INFO:Running postinst of diffutils
INFO:Running postinst of htop
INFO:Running postinst of procps-ng
INFO:Running postinst of procps-ng-top
INFO:Running postinst of psmisc
INFO:Running postinst of turris-utils
INFO:Running postinst of python3-flup
INFO:Running postinst of python3-werkzeug
INFO:Running postinst of python3-markupsafe
INFO:Running postinst of python3-jinja2
INFO:Running postinst of python3-itsdangerous
INFO:Running postinst of python3-click
INFO:Running postinst of python3-flask
INFO:Running postinst of python3-flask-seasurf
INFO:Running postinst of python3-pytz
INFO:Running postinst of python3-babel
INFO:Running postinst of python3-flask-babel
INFO:Running postinst of turris-auth
INFO:Running postinst of lighttpd-mod-setenv
INFO:Running postinst of lighttpd-mod-redirect
INFO:Running postinst of python3-cachelib
INFO:Running postinst of lighttpd-mod-proxy
INFO:Running postinst of python3-websockets
INFO:Running postinst of foris-ws
INFO:Running postinst of reforis
INFO:Running postinst of vim-full
INFO:Running postinst of blkid
INFO:Running postinst of partx-utils
INFO:Running postinst of libiconv-full
INFO:Running postinst of libpopt
INFO:Running postinst of rsync
INFO:Running postinst of coreutils-stat
INFO:Running postinst of foris-controller-storage-module
INFO:Running postinst of reforis-storage-plugin
INFO:Running postinst of bash
INFO:Running postinst of turris-motd
INFO:Running postinst of openssh-sftp-client
INFO:Running postinst of procps-ng-ps
INFO:Running postinst of wget-ssl
INFO:Running postinst of logrotate
INFO:Running postinst of libdbi
INFO:Running postinst of glib2
INFO:Running postinst of syslog-ng
INFO:Running postinst of luci-compat
INFO:Running postinst of luci-app-Commands
INFO:Running postinst of resolver-debug
Remove buttons in LuCI's Custom Commands
Add debug buttons in LuCI's Custom Commands
Config reload successful
INFO:Running postinst of openssh-keygen
INFO:Running postinst of openssh-client
INFO:Running postinst of openssh-client-utils
INFO:Running postinst of libpcap
INFO:Running postinst of tcpdump
INFO:Running postinst of start-indicator
INFO:Running postinst of iputils-tracepath
INFO:Running postinst of libsysfs
INFO:Running postinst of sysfsutils
INFO:Running postinst of libsensors
INFO:Running postinst of lm-sensors
INFO:Running postinst of turris-defaults
Europe/Prague
CZ
INFO:Running postinst of odhcp6c
INFO:Running postinst of getrandom
INFO:Running postinst of urandom-seed
INFO:Running postinst of odhcpd
odhcpd
INFO:Running postinst of resolveip
INFO:Running postinst of kmod-iptunnel6
INFO:Running postinst of kmod-ip6-tunnel
INFO:Running postinst of ds-lite
INFO:Running postinst of kmod-lib-crc-ccitt
INFO:Running postinst of kmod-slhc
INFO:Running postinst of kmod-ppp
INFO:Running postinst of kmod-pppox
INFO:Running postinst of kmod-pppoe
INFO:Running postinst of ppp-mod-pppoe
INFO:Running postinst of kmod-iptunnel4
INFO:Running postinst of kmod-sit
INFO:Running postinst of 6in4
INFO:Running postinst of kmod-nfnetlink
INFO:Running postinst of kmod-nf-conntrack-netlink
INFO:Running postinst of libnfnetlink
INFO:Running postinst of libnetfilter-conntrack
INFO:Running postinst of kmod-ipt-ipset
INFO:Running postinst of dnsmasq-full
touch: /tmp/resolv.conf.d/resolv.conf.auto: No such file or directory
INFO:Running postinst of kmod-zram
INFO:Running postinst of zram-swap
Setting up swapspace version 1, size = 253751296 bytes
zram_stop: deactivate swap /dev/zram0
zram_reset: claiming memory back via /sys/block/zram0/reset
zram_start: activating '/dev/zram0' for swapping (242 MegaBytes)
zram_reset: enforcing defaults via /sys/block/zram0/reset
zram_comp_algo: Set compression algorithm 'lzo' for zram '/dev/zram0'
INFO:Running postinst of sentinel-firewall
Warning: Section @zone[4] (tr_guest) has no device, network, subnet or extra options
Warning: Section @zone[6] (vpn_turris) has no device, network, subnet or extra options
* Clearing IPv4 filter table
* Clearing IPv4 nat table
* Clearing IPv4 mangle table
* Clearing IPv4 raw table
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Clearing IPv6 filter table
* Clearing IPv6 mangle table
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of libipset
INFO:Running postinst of ipset
INFO:Running postinst of python3-msgpack
INFO:Running postinst of libsodium
INFO:Running postinst of libzmq-curve
INFO:Running postinst of python3-zmq
INFO:Running postinst of sentinel-dynfw-client
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of sentinel-eula
INFO:Running postinst of msgpack-c
INFO:Running postinst of libconfig
INFO:Running postinst of libpaho-mqtt-c
INFO:Running postinst of liblz4
INFO:Running postinst of libmicrohttpd-no-ssl
INFO:Running postinst of czmq
INFO:Running postinst of sentinel-proxy
INFO:Running postinst of kmod-nfnetlink-log
INFO:Running postinst of kmod-ipt-nflog
INFO:Running postinst of iptables-mod-nflog
INFO:Running postinst of libnetfilter-log
INFO:Running postinst of logc
INFO:Running postinst of logc-czmq
INFO:Running postinst of logc-argp
INFO:Running postinst of sentinel-fwlogs
Warning: Section @redirect[0] (yyyy.xxxx.cz) does not specify a protocol, assuming TCP+UDP
Warning: Section @redirect[2] (yyyy.xxxx.cz) does not specify a protocol, assuming TCP+UDP
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of turris-survey
INFO:Running postinst of rmbt-client
INFO:Running postinst of python3-pyserial
INFO:Running postinst of netmetr
INFO:Running postinst of kmod-ebtables
INFO:Running postinst of ebtables
INFO:Running postinst of logc-libevent
INFO:Running postinst of sentinel-minipot
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of updater-drivers
INFO:Running postinst of sshpass
INFO:Running postinst of python3-pyasn1
INFO:Running postinst of python3-pyasn1-modules
INFO:Running postinst of python3-service-identity
INFO:Running postinst of python3-cryptodome
INFO:Running postinst of python3-zope-interface
INFO:Running postinst of python3-typing-extensions
INFO:Running postinst of python3-pyopenssl
INFO:Running postinst of python3-hyperlink
INFO:Running postinst of python3-incremental
INFO:Running postinst of python3-constantly
INFO:Running postinst of python3-bcrypt
INFO:Running postinst of python3-automat
INFO:Running postinst of python3-appdirs
INFO:Running postinst of python3-twisted
INFO:Running postinst of python3-cachetools
INFO:Running postinst of haas-proxy
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Rule 'Allow-MLD'
* Rule #11
* Rule #12
* Rule #13
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
* Zone 'lan'
* Zone 'xxxxxxx'
* Zone yyyyyyyy
* Zone 'wan'
* Zone 'tr_guest'
* Zone 'tr_vpn_xx'
* Zone 'vpn_turris'
- input
- forward
- DROP
- REJECT
INFO:Running postinst of localrepo
Local repository seems to be consistent.
INFO:Running postinst of updater-opkg-wrapper
INFO:Running postinst of turris-version
INFO:Running postinst of 6rd
INFO:Running postinst of libevdev
INFO:Running postinst of libudev-zero
INFO:Running postinst of libcbor
INFO:Running postinst of libfido2
INFO:Running postinst of openssh-server
INFO:Running postinst of openssh-sftp-server
INFO:Running postinst of libi2c
INFO:Running postinst of i2c-tools
INFO:Running postinst of shadow-utils
INFO:Running postinst of uboot-envtools
INFO:Running postinst of shadow-common
INFO:Running postinst of shadow-vipw
INFO:Running postinst of shadow-usermod
INFO:Running postinst of shadow-userdel
INFO:Running postinst of shadow-useradd
INFO:Running postinst of shadow-su
INFO:Running postinst of shadow-pwunconv
INFO:Running postinst of shadow-pwconv
INFO:Running postinst of shadow-pwck
INFO:Running postinst of shadow-passwd
INFO:Running postinst of shadow-nologin
INFO:Running postinst of shadow-newusers
INFO:Running postinst of shadow-newuidmap
INFO:Running postinst of shadow-newgrp
INFO:Running postinst of shadow-newgidmap
INFO:Running postinst of shadow-logoutd
INFO:Running postinst of shadow-login
INFO:Running postinst of shadow-lastlog
INFO:Running postinst of shadow-grpunconv
INFO:Running postinst of shadow-grpconv
INFO:Running postinst of shadow-grpck
INFO:Running postinst of shadow-groups
INFO:Running postinst of shadow-groupmod
INFO:Running postinst of shadow-groupmems
INFO:Running postinst of shadow-groupdel
INFO:Running postinst of shadow-groupadd
INFO:Running postinst of shadow-gpasswd
INFO:Running postinst of shadow-faillog
INFO:Running postinst of shadow-expiry
INFO:Running postinst of shadow-chsh
INFO:Running postinst of shadow-chpasswd
INFO:Running postinst of shadow-chgpasswd
INFO:Running postinst of shadow-chfn
INFO:Running postinst of shadow-chage
INFO:Running postinst of openssh-moduli
INFO:Running postinst of pciids
INFO:Running postinst of libpci
INFO:Running postinst of libkmod
INFO:Running postinst of pciutils
INFO:Running postinst of lighttpd-mod-cgi
INFO:Running postinst of turris-webapps
INFO:Running postinst of libtirpc
INFO:Running postinst of lsof
INFO:Running postinst of usbids
INFO:Running postinst of libusb-1.0
INFO:Running postinst of usbutils
INFO:Running postinst of ip-full
INFO:Running postinst of umdns
Command failed: Request timed out
INFO:Running postinst of bind-libs
INFO:Running postinst of bind-client
INFO:Running postinst of nstat
INFO:Running postinst of devlink
INFO:Running postinst of kmod-netlink-diag
INFO:Running postinst of genl
INFO:Running postinst of ip-bridge
INFO:Running postinst of bind-dig
INFO:Running postinst of rdma
INFO:Running postinst of lighttpd-mod-openssl
INFO:Running postinst of lighttpd-https-cert
INFO:Running postinst of libnetfilter-queue
INFO:Running postinst of libnetfilter-cthelper
INFO:Running postinst of libnetfilter-cttimeout
INFO:Running postinst of conntrack
INFO:Running postinst of kmod-crypto-md5
INFO:Running postinst of iputils-ping
INFO:Running postinst of kmod-nf-log6
INFO:Running postinst of kmod-nf-ipt6
INFO:Running postinst of kmod-nf-reject6
INFO:Running postinst of kmod-ip6tables
INFO:Running postinst of ip6tables
INFO:Running postinst of libustream-openssl
INFO:Running postinst of foris-controller-schnapps-module
INFO:Running postinst of reforis-snapshots-plugin
INFO:Running postinst of foris-controller-openvpn_client-module
INFO:Running postinst of foris-controller-openvpn-module
INFO:Running postinst of reforis-openvpn-plugin
INFO:Running postinst of foris-controller-haas-module
INFO:Running postinst of foris-controller-sentinel-module
INFO:Running postinst of reforis-data-collection-plugin
INFO:Running postinst of reforis-haas-plugin
INFO:Running postinst of foris-controller-diagnostics-module
INFO:Running postinst of reforis-diagnostics-plugin
INFO:Running postinst of turris-webapps-luci
INFO:Running postinst of foris-controller-netmetr-module
INFO:Running postinst of reforis-netmetr-plugin
INFO:Running postinst of openvpn-hotplug
INFO:Running postinst of luci-i18n-base-en
INFO:Running postinst of luci-i18n-wol-cs
INFO:Running postinst of luci-i18n-opkg-cs
INFO:Running postinst of luci-i18n-base-cs
INFO:Running postinst of reforis-l10n-cs
INFO:Running postinst of reforis-haas-plugin-l10n-cs
INFO:Running postinst of reforis-diagnostics-plugin-l10n-cs
INFO:Running postinst of reforis-data-collection-plugin-l10n-cs
INFO:Running postinst of reforis-netmetr-plugin-l10n-cs
INFO:Running postinst of user-notify-l10n-cs
INFO:Running postinst of turris-diagnostics-l10n-cs
INFO:Running postinst of reforis-openvpn-plugin-l10n-cs
INFO:Running postinst of pkglists-l10n-cs
INFO:Running postinst of reforis-snapshots-plugin-l10n-cs
INFO:Running postinst of luci-i18n-firewall-en
INFO:Running postinst of luci-i18n-Commands-en
INFO:Running postinst of luci-i18n-opkg-en
INFO:Running postinst of luci-i18n-firewall-cs
INFO:Running postinst of luci-i18n-wol-en
INFO:Running postinst of luci-i18n-Commands-cs
INFO:Cleaning up control files
WARN:Restart your device to apply all changes.
INFO:Executing reboot_required hook: 50-create-notification.sh
INFO:Target Turris OS: 6.0
INFO:Queue removal of fix-lighttpd-sync-with-upstream
Connection to 192.168.0.1 closed by remote host.
Connection to 192.168.0.1 closed.
Unfortunately the WAN and LAN speed performance remains unchanged (or maybe even worse, only around 550 Mb/s when using NetMetr and 400 Mb/s on LAN).
Just rebooted and again got new IPv6 addresses on my pppoe-wan interface. Seems the interface identifier is changing. How to fix this?
