Dear Turris users,
the Turris OS 3.8.2 had been released few seconds ago.
The main thing of this release are repairs of DNS handling mistakes due to changes in unbound and dnsmasq and there is also a number of security fixes!
Take a look:
knot-resolver: automatically, temporally turn off IPv6 if it doesn’t work
mac80211: few fixes from LEDE
nethist: fixed crash when too many interfaces are present on the router
dnsmasq and swconfig: fix broken dhcp and switch after Turris Omnia update from factory
nextcloud-install: better database handling
new kernel for better security
new OpenVPN for better security
possible fix for Turris 1.x random reboots based on few logs we got from testers. Worked for us too
Stay secure and online!
We are looking forward to reading your feedback!
I have the same issue after update to 3.8.2, no internet, no wifi, no disks. But 3.8.2 RC had no problem with internet, wifi or disks.
I have Turris 1.1, btrfs filesystem on SD card.
Rolled back to 3.8.1, I’ll do it again tonight and send logs to the tech support, now I need a functional router.
same problems in here … very quick overview what I have noticed: no mount of extrenal flash -> possible module error, no internet -> no iptables running -> kernel version/module error ??? more details at evening when I am home
I have the same issue on my router Turris 1.x (with BTRFS on microSD card).
Router has the internet connection, but LAN no. Wifi is off. No disks are mounted (only tmpfs and /)
The question is, who is responsible for testing on old hardware - Turris 1.x . We had many fails in history, but this one is really huge. Pls answer, Turris team.
