root@kukuzi:~# pkgupdate
WARN:Requested package luci-i18n-ddns-en that is missing, ignoring
as requested.
WARN:Request not satisfied to install package: luci-app-hd-idle
WARN:Request not satisfied to install package: luci-i18n-hd-idle-en
WARN:Request not satisfied to install package: luci-app-transmissio
n
WARN:Request not satisfied to install package: luci-app-upnp
WARN:Request not satisfied to install package: luci-i18n-transmissi
on-en
WARN:Request not satisfied to install package: luci-i18n-upnp-en
line not found
line not found
line not found
line not found
line not found
ERROR:
inconsistent: Requested package foris-client that is not available.
root@kukuzi:~#
I can understand your feelings, however Turris OS 3.11 was in RC since 30th October, I can understand that we can not test all setups, which are possible. They’re so many packages, which we don’t use. That’s why we appreciate every user, who help us with testing. This issue isn’t mentioned there. When we don’t know about it, we cannot look at it and fix it.
All the reports should be reported directly to us. The best way is to send us an email to tech.support@turris.cz or if you’re acknowledged enough, you can create an issue on our Gitlab.
I don’t like to see bugs reported here, because it many posts, it can be lost, however, I and my colleagues are trying to catch them as many as we can.
Unfortunately, if things go well, we don’t usually hear feedback about it. That’s known issue and that’s cannot be changed. If yes, I’d be naive.
But back to your issue:
It would help me to know something more about your network (ISP) and if you can send me diagnostics, which you can generate in Foris. We need to gather as much as possible details about it, so we can look at it.
Because the value “0” what you have linked the thread is there by default and we didn’t change it.
That’s can be found here:
##### Error notifications #####
Updater selhal:
[string "transaction"]:323: [string "transaction"]:149: Collisions:
• /lib/modules/4.4.165-4a7a81f8db0ad743e54c68e1845c60b6-1/xt_LED.ko: kmod-ipt-led (new-file), kmod-ledtrig-netfilter (new-file)
##### Update notifications #####
• Installed version 20180409-2 of package ca-bundle
• Installed version 7.62.0-2 of package libcurl
• Installed version 60.4.6-3.6-2 of package updater-ng
In the past I did some experiments with LED triggering using iptables, but those packages are now uninstalled. However running pkgupdate still fails. What to do?
Didn’t you install package foris-client manually? It should be just a dummy package with dependencies.
What you need are foris-client-bin, foris-controller-app. So you can remove the foris-client by opkg or you can remove the row from /etc/updater/conf.d/opkg-auto.lua.
And this package should be back in the next release.
Your approval is required to apply pending updates.You can grant it in the Foris administrative interface in the 'Updater' menu.
• Install ca-bundle 20180409-2
• Install libcurl 7.62.0-2
• Install updater-ng 60.4.6-3.6-2
after remove binutils with command opkg remove binutils I run pkgupdate
This is log from updater
root@omnia:/tmp/lock# pkgupdate
WARN:Script file:///usr/share/updater/localrepo/localrepo.lua not found, but ignoring its absence as requested
WARN:Request not satisfied to install package: luci-i18n-base-pl
WARN:Request not satisfied to install package: luci-i18n-commands-pl
WARN:Request not satisfied to install package: luci-i18n-ddns-pl
WARN:Request not satisfied to install package: luci-app-minidlna
WARN:Request not satisfied to install package: luci-i18n-minidlna-en
WARN:Request not satisfied to install package: luci-i18n-hd-idle-pl
WARN:Request not satisfied to install package: luci-i18n-minidlna-pl
WARN:Request not satisfied to install package: luci-i18n-samba-pl
WARN:Request not satisfied to install package: luci-app-ahcp
WARN:Request not satisfied to install package: luci-app-mjpg-streamer
WARN:Request not satisfied to install package: luci-app-tinyproxy
WARN:Request not satisfied to install package: luci-app-transmission
WARN:Request not satisfied to install package: luci-i18n-ahcp-en
WARN:Request not satisfied to install package: luci-i18n-tinyproxy-en
WARN:Request not satisfied to install package: luci-i18n-transmission-en
WARN:Request not satisfied to install package: luci-i18n-ahcp-pl
WARN:Request not satisfied to install package: luci-i18n-firewall-pl
WARN:Request not satisfied to install package: luci-i18n-statistics-pl
WARN:Request not satisfied to install package: luci-i18n-tinyproxy-pl
WARN:Request not satisfied to install package: luci-i18n-transmission-pl
WARN:Request not satisfied to install package: luci-i18n-upnp-pl
WARN:Request not satisfied to install package: luci-i18n-wol-pl
WARN:Request not satisfied to uninstall package: libnl-tiny
INFO:Queue install of l10n_supported/turris/1.3-2
INFO:Queue install of userlists/turris/11.6
INFO:Queue install of python3-base/turris/3.6.0-3.6-3
INFO:Queue install of python3-light/turris/3.6.0-3.6-3
INFO:Queue install of python3-uci/turris/0.3-3.6-1
INFO:Queue install of updater-ng-supervisor/turris/60.4.6-3.6-2
INFO:Queue install of base-files/turris/195-r47055
INFO:Queue install of busybox/turris/1.29.3-1
INFO:Queue install of create_notification/turris/58
INFO:Queue install of kernel/turris/4.4.165-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-ipt/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-conntrack/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-nat/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-nathelper/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-base/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-uhci/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb3/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-cfg80211/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-mac80211/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ath/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ath10k/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ath9k-common/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ath9k/turris/4.4.165+2017-01-31-4-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-libphy/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-swconfig/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-switch-mvsw61xx/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-i2c-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-i2c-mv64xxx/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-serial/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-serial-wwan/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-serial-qualcomm/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-hwmon-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-thermal/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-thermal-armada/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-mmc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-mvsdio/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-wdt-orion/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-default-on/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-gpio/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-heartbeat/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-morse/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-netdev/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-netfilter/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-oneshot/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-timer/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-transient/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ledtrig-usbdev/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of resolver-conf/turris/0.0.1-27
INFO:Queue install of knot-libzscanner/turris/2.7.3-1
INFO:Queue install of knot-libs/turris/2.7.3-1
INFO:Queue install of knot-resolver/turris/3.1.0-1
INFO:Queue install of libunbound/turris/1.8.1-2
INFO:Queue install of kmod-ipt-nat/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-conntrack/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of firewall/turris/2018-06-13
INFO:Queue install of kmod-llc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-stp/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-bridge/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ebtables/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of switch-branch/turris/1.6-1
INFO:Queue install of curl/turris/7.62.0-2
INFO:Queue install of opkg/turris/6
INFO:Queue install of kmod-lib-crc-ccitt/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-slhc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ppp/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-pppox/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-pppoe/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of cznic-repo-keys/turris/4.1
INFO:Queue install of cznic-repo-keys-test/turris/4.1
INFO:Queue install of updater-ng-localrepo/turris/60.4.6-3.6-2
INFO:Queue install of updater-ng-opkg/turris/60.4.6-3.6-2
INFO:Queue install of kmod-nf-conntrack6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-ipt6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ip6tables/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of openssh-client/turris/7.9p1-1
INFO:Queue install of openssh-keygen/turris/7.9p1-1
INFO:Queue install of openssh-client-utils/turris/7.9p1-1
INFO:Queue install of openssh-moduli/turris/7.9p1-1
INFO:Queue install of openssh-server/turris/7.9p1-1
INFO:Queue install of openssh-sftp-client/turris/7.9p1-1
INFO:Queue install of openssh-sftp-server/turris/7.9p1-1
INFO:Queue install of bind-libs/turris/9.11.5-2
INFO:Queue install of bind-client/turris/9.11.5-2
INFO:Queue install of bind-dig/turris/9.11.5-2
INFO:Queue install of libhavege/turris/1.9.4-1
INFO:Queue install of haveged/turris/1.9.4-1
INFO:Queue install of oneshot/turris/26
INFO:Queue install of libatsha204/turris/28-3.6-1
INFO:Queue install of user-notify/turris/58
INFO:Queue install of libintl-full/turris/0.19.4-6
INFO:Queue install of gettext/turris/0.19.4-6
INFO:Queue install of user-notify-l10n-pl/turris/1.0.7-1
INFO:Queue install of schnapps/turris/1.6-1
INFO:Queue install of luci-proto-ipv6/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-ppp/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-app-firewall/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-theme-bootstrap/turris/git-18.328.59464-9636605-1
INFO:Queue install of lighttpd/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-setenv/turris/1.4.50-3
INFO:Queue install of luci-lib-jsonc/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-lib-ip/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-lib-nixio/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-base/turris/git-18.328.59464-9636605-10
INFO:Queue install of luci-mod-admin-full/turris/git-18.328.59464-9636605-3
INFO:Queue install of lighttpd-mod-cgi/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-alias/turris/1.4.50-3
INFO:Queue install of luci/turris/git-18.328.59464-9636605-1
INFO:Queue install of python3-xml/turris/3.6.0-3.6-3
INFO:Queue install of python3-unittest/turris/3.6.0-3.6-3
INFO:Queue install of python3-sqlite3/turris/3.6.0-3.6-3
INFO:Queue install of python3-pydoc/turris/3.6.0-3.6-3
INFO:Queue install of python3-openssl/turris/3.6.0-3.6-3
INFO:Queue install of python3-ncurses/turris/3.6.0-3.6-3
INFO:Queue install of python3-multiprocessing/turris/3.6.0-3.6-3
INFO:Queue install of python3-lzma/turris/3.6.0-3.6-3
INFO:Queue install of python3-logging/turris/3.6.0-3.6-3
INFO:Queue install of python3-gdbm/turris/3.6.0-3.6-3
INFO:Queue install of python3-email/turris/3.6.0-3.6-3
INFO:Queue install of python3-distutils/turris/3.6.0-3.6-3
INFO:Queue install of python3-decimal/turris/3.6.0-3.6-3
INFO:Queue install of python3-dbm/turris/3.6.0-3.6-3
INFO:Queue install of python3-ctypes/turris/3.6.0-3.6-3
INFO:Queue install of python3-codecs/turris/3.6.0-3.6-3
INFO:Queue install of python3-asyncio/turris/3.6.0-3.6-3
INFO:Queue install of python3/turris/3.6.0-3.6-3
INFO:Queue install of python3-lib2to3/turris/3.6.0-3.6-3
INFO:Queue install of python3-dev/turris/3.6.0-3.6-3
INFO:Queue install of python3-setuptools/turris/22.0.5-3.6-2
INFO:Queue install of python3-ubus/turris/0.1-3.6-1
INFO:Queue install of foris-client-python3/turris/0.8-3.6-1
INFO:Queue install of lighttpd-mod-proxy/turris/1.4.50-3
INFO:Queue install of python3-prctl/turris/1.6.1-3.6-1
INFO:Queue install of python3-websocket-server/turris/0.4-3.6-6
INFO:Queue install of foris-ws/turris/0.2-3.6-1
INFO:Queue install of lighttpd-mod-redirect/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-fastcgi/turris/1.4.50-3
INFO:Queue install of python3-markupsafe/turris/1.0-3.6-1
INFO:Queue install of python3-jinja2/turris/2.10-3.6-1
INFO:Queue install of python3-flup/turris/1.0.3-3.6-1
INFO:Queue install of python3-bottle/turris/0.12.13-3.6-1
INFO:Queue install of python3-bottle-i18n/turris/0.1.5-3.6-3
INFO:Queue install of foris-common/turris/98.17-3.6-1
INFO:Queue install of foris-config/turris/98.17-3.6-1
INFO:Queue install of foris/turris/98.17-3.6-1
INFO:Queue install of kmod-ipt-conntrack-extra/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-ipopt/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ifb/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-sched-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-sched/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of turris-maintain/turris/3-4
INFO:Queue install of python3-turrishw/turris/0.4-3.6-1
INFO:Queue install of python3-jsonschema/turris/2.6.0-3.6-1
INFO:Queue install of foris-schema-python3/turris/0.7.1-3.6-1
INFO:Queue install of python3-pbkdf2/turris/1.3-3.6-3
INFO:Queue install of foris-controller/turris/0.10.12-3.6-1
INFO:Queue install of foris-controller-diagnostics-module/turris/0.4-3.6-1
INFO:Queue install of foris-diagnostics-plugin/turris/10.4-3.6-1
INFO:Queue install of turris-webapps/turris/1-5
INFO:Queue install of foris-l10n-pl/turris/98.17-3.6-1
INFO:Queue install of foris-diagnostics-plugin-l10n-pl/turris/10.4-3.6-1
INFO:Queue install of userlists-l10n-pl/turris/1.0.7-1
INFO:Queue install of nuci/turris/161-1
INFO:Queue install of nuci-nethist/turris/161-1
INFO:Queue install of turris-version/turris/3.11
INFO:Queue install of lighttpd-mod-openssl/turris/1.4.50-3
INFO:Queue install of kmod-nfnetlink/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-conntrack-netlink/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of vim-full/turris/8.1-1
INFO:Queue install of luci-app-commands/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-base-en/turris/git-18.328.59464-9636605-10
INFO:Queue install of luci-i18n-commands-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-nfnetlink-log/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-nflog/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nfnetlink-nfacct/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-ipset/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of ucollect-lib/turris/127
INFO:Queue install of kmod-nf-nat6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-nat6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-tproxy/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of ucollect-config/turris/127
INFO:Queue install of ucollect-prog/turris/127
INFO:Queue install of python3-libatsha204/turris/28-3.6-1
INFO:Queue install of nikola/turris/43-3.6-2
INFO:Queue install of kmod-tun/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of foris-controller-openvpn-module/turris/0.5-3.6-1
INFO:Queue install of foris-openvpn-plugin/turris/16.3-3.6-1
INFO:Queue install of foris-openvpn-plugin-l10n-pl/turris/16.3-3.6-1
INFO:Queue install of kmod-atm/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-pppoa/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-pcompress/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-hash/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-null/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-aead/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-manager/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-ecb/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-sha1/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-mppe/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-iptunnel/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-gre/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-iptunnel6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ip6-tunnel/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-iptunnel4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-sit/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-textsearch/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nf-nathelper-extra/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-mii/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-net/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-net-cdc-ether/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-net-rndis/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-wdm/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-net-qmi-wwan/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-serial-option/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of ddns-scripts/turris/2.7.8-7
INFO:Queue install of luci-proto-3g/turris/git-18.328.59464-9636605-1
INFO:Queue install of python3-cachetools/turris/2.0.1-3.6-2
INFO:Queue install of kmod-nfnetlink-queue/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ipt-nfqueue/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of pakon/turris/1.2-16
INFO:Queue install of foris-controller-pakon-module/turris/0.2-3.6-1
INFO:Queue install of foris-pakon-plugin/turris/2.4.4-3.6-0
INFO:Queue install of foris-controller-data_collect-module/turris/1.0-3.6-3
INFO:Queue install of foris-data_collect-plugin/turris/1.1-3.6-1
INFO:Queue install of foris-client-bin/turris/0.8-3.6-1
INFO:Queue install of gnupg/turris/1.4.23-1
INFO:Queue install of ssbackups/turris/2.0-3.6-1
INFO:Queue install of foris-controller-ssbackups-module/turris/0.5-3.6-1
INFO:Queue install of foris-ssbackups-plugin/turris/8.3.1-3.6-2
INFO:Queue install of foris-ssbackups-plugin-l10n-pl/turris/8.3.1-3.6-2
INFO:Queue install of nuci-tls/turris/161-1
INFO:Queue install of kmod-scsi-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ata-core/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ata-ahci/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-fscache/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-dnsresolver/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-fcrypt/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-pcbc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-rxrpc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-afs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-autofs4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-xor/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-raid6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-zlib/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-lzo/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-crc32c/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-crc32c/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-btrfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-sha256/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-des/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-md4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-md5/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-hmac/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-cifs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-configfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-cramfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-exfat/turris/4.4.165+git-20151121-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-exportfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-crc16/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-ext4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-f2fs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-hfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-utf8/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-hfsplus/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-isofs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-jfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-minix/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-vfat/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-msdos/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-nfs-common/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-nfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-oid-registry/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-nfs-common-v4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-nfsd/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-ntfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-lib-crc-itu-t/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-udf/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-fs-xfs/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp1250/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp1251/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp437/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp775/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp850/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp852/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp862/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp864/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp866/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-cp932/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-1/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-13/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-15/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-2/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-6/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-iso8859-8/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-nls-koi8r/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-mod/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-linear/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-multipath/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-raid0/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-raid1/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-raid10/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-md-raid456/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-storage/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-storage-extras/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb2/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-storage-uas/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ata-ahci-platform/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-ata-mvebu-ahci/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-marvell-cesa/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of libcomerr/turris/1.44.3-1
INFO:Queue install of libss/turris/1.44.3-1
INFO:Queue install of libext2fs/turris/1.44.3-1
INFO:Queue install of e2fsprogs/turris/1.44.3-1
INFO:Queue install of resize2fs/turris/1.44.3-1
INFO:Queue install of foris-controller-storage-module/turris/0.2.3-3.6-0
INFO:Queue install of foris-storage-plugin/turris/1.2-3.6-2
INFO:Queue install of kmod-dm/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of mdadm/turris/4.0-4
INFO:Queue install of kmod-fuse/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of libfuse/turris/2.9.8-1
INFO:Queue install of fuse-utils/turris/2.9.8-1
INFO:Queue install of badblocks/turris/1.44.3-1
INFO:Queue install of luci-app-samba/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-samba-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of kmod-crypto-authenc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-cryptodev/turris/4.4.165+1.8-mvebu-2
INFO:Queue install of kmod-crypto-user/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-cbc/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-wq/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-rng/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-iv/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-seqiv/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-ctr/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-gf128/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-xts/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-cmac/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-sha512/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-ccm/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-crypto-deflate/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-veth/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of gnupg-utils/turris/1.4.23-1
INFO:Queue install of python3-pyserial/turris/2.7-3.6-2
INFO:Queue install of netmetr/turris/1.4-3.6-2
INFO:Queue install of foris-controller-netmetr-module/turris/0.4.1-3.6-1
INFO:Queue install of foris-netmetr-plugin/turris/4.4.1-3.6-1
INFO:Queue install of foris-netmetr-plugin-l10n-pl/turris/4.4.1-3.6-1
INFO:Queue install of luci-app-statistics/turris/git-18.328.59464-9636605-4
INFO:Queue install of luci-app-wol/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-openconnect/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-proto-relay/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-firewall-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of luci-i18n-statistics-en/turris/git-18.328.59464-9636605-4
INFO:Queue install of luci-i18n-wol-en/turris/git-18.328.59464-9636605-1
INFO:Queue install of bind-host/turris/9.11.5-2
INFO:Queue install of git/turris/2.19.1-1
INFO:Queue install of kmod-ata-marvell-sata/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-usb-serial-ch341/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-loop/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of lighttpd-mod-access/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-accesslog/turris/1.4.50-3
INFO:Queue install of lighttpd-mod-extforward/turris/1.4.50-3
INFO:Queue install of tune2fs/turris/1.44.3-1
INFO:Queue install of kmod-lib-lz4/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of kmod-zram/turris/4.4.165+1-1-4a7a81f8db0ad743e54c68e1845c60b6-1
INFO:Queue install of git-http/turris/2.19.1-1
INFO:Queue removal of python-libatsha204
INFO:Queue removal of python-pyserial
INFO:Queue removal of user_notify_locales
INFO:Queue removal of foris-tls-plugin-l10n-pl
INFO:Queue removal of ar
INFO:Queue removal of foris-wizard
INFO:Queue removal of python-bottle-i18n
INFO:Queue removal of python-flup
INFO:Queue removal of python-ncclient
INFO:Queue removal of python-websocket-server
INFO:Queue removal of foris-client
INFO:Queue removal of python-ubus
INFO:Queue removal of python-prctl
INFO:Queue removal of python-pbkdf2
INFO:Queue removal of foris-schema
INFO:Queue removal of python-jsonschema
INFO:Queue removal of objdump
INFO:Queue removal of libopcodes
INFO:Queue removal of libbfd
INFO:Queue removal of python-functools32
INFO:Queue removal of updater-ng-py2-supervisor
INFO:Queue removal of python-uci
Press return to continue, CTRL+C to abort
INFO:Executing preupdate hooks...
INFO:Subprogram output: /etc/updater/hook_preupdate/05_schnapps.sh:
Snapshot number 229 created
INFO:End of subprogram output
INFO:Unpacking download packages
INFO:Checking for file collisions between packages
INFO:Running pre-install scripts and merging packages to root file system
WARN:Config file /etc/passwd modified by the user. Backing up the new one into /etc/passwd-opkg
WARN:Config file /etc/hosts modified by the user. Backing up the new one into /etc/hosts-opkg
WARN:Config file /etc/config/system modified by the user. Backing up the new one into /etc/config/system-opkg
WARN:Config file /etc/shadow modified by the user. Backing up the new one into /etc/shadow-opkg
WARN:Config file /etc/profile modified by the user. Backing up the new one into /etc/profile-opkg
WARN:Config file /etc/shells modified by the user. Backing up the new one into /etc/shells-opkg
WARN:Config file /etc/banner modified by the user. Backing up the new one into /etc/banner-opkg
WARN:Config file /etc/sysctl.conf modified by the user. Backing up the new one into /etc/sysctl.conf-opkg
WARN:Config file /etc/rc.local modified by the user. Backing up the new one into /etc/rc.local-opkg
WARN:Config file /etc/group modified by the user. Backing up the new one into /etc/group-opkg
WARN:Config file /etc/config/resolver modified by the user. Backing up the new one into /etc/config/resolver-opkg
WARN:Config file /etc/config/firewall modified by the user. Backing up the new one into /etc/config/firewall-opkg
WARN:Config file /etc/firewall.user modified by the user. Backing up the new one into /etc/firewall.user-opkg
WARN:Config file /etc/config/sshd modified by the user. Backing up the new one into /etc/config/sshd-opkg
WARN:Config file /etc/config/user_notify modified by the user. Backing up the new one into /etc/config/user_notify-opkg
WARN:Config file /etc/lighttpd/lighttpd.conf modified by the user. Backing up the new one into /etc/lighttpd/lighttpd.conf-opkg
WARN:Collision with existing path. Moving /etc/config/ucitrack to /usr/share/updater/collided/etc/config
WARN:Config file /etc/config/luci modified by the user. Backing up the new one into /etc/config/luci-opkg
WARN:Config file /etc/config/foris-ws modified by the user. Backing up the new one into /etc/config/foris-ws-opkg
WARN:Config file /etc/config/foris modified by the user. Backing up the new one into /etc/config/foris-opkg
WARN:Config file /etc/config/backups modified by the user. Backing up the new one into /etc/config/backups-opkg
WARN:Config file /etc/config/foris-controller modified by the user. Backing up the new one into /etc/config/foris-controller-opkg
Output from ucollect-config.preinst:
cat: can't open '2': No such file or directory
WARN:Config file /etc/config/ddns modified by the user. Backing up the new one into /etc/config/ddns-opkg
WARN:Config file /etc/config/pakon modified by the user. Backing up the new one into /etc/config/pakon-opkg
WARN:Config file /etc/config/ssbackups modified by the user. Backing up the new one into /etc/config/ssbackups-opkg
WARN:Config file /etc/config/storage modified by the user. Backing up the new one into /etc/config/storage-opkg
WARN:Config file /etc/config/netmetr modified by the user. Backing up the new one into /etc/config/netmetr-opkg
WARN:Config file /etc/config/luci_statistics modified by the user. Backing up the new one into /etc/config/luci_statistics-opkg
INFO:Running post-install and post-rm scripts
Output from resolver-conf.postinst:
chown: unknown user/group kresd:kresd
Output from knot-resolver.postinst:
+ '[' -z ]
+ /etc/init.d/dnsmasq restart
udhcpc: started, v1.29.3
udhcpc: sending discover
udhcpc: no lease, failing
+ sleep 2
+ /etc/kresd/kresd.postinst.sh
+ uci -q get resolver.kresd.static_domains
+ stat_dom=
+ '[' '!' -z ]
+ /etc/init.d/resolver restart
+ rm /etc/kresd/kresd.postinst.sh
+ /etc/kresd/convert_config.sh
+ rm /etc/kresd/convert_config.sh
+ uci -q get resolver.common.prefered_resolver
+ '[' kresd '=' kresd ]
+ egrep -q '(1|yes|true|enabled|on)'
+ uci -q get resolver.common.forward_upstream
Output from firewall.postinst:
Warning: Section 'miniupnpd' must specify a path
* Flushing IPv4 filter table
* Flushing IPv4 nat table
* Flushing IPv4 mangle table
* Flushing IPv4 raw table
* Flushing IPv6 filter table
* Flushing IPv6 nat table
* Flushing IPv6 mangle table
* Flushing IPv6 raw table
* Flushing conntrack table ...
* Populating IPv4 filter table
* Rule 'Allow-DHCP-Renew'
* Rule 'Allow-Ping'
* Rule 'Allow-IGMP'
* Rule #7
* Rule #8
* Rule 'ssh-honeypot'
* Rule 'ssh'
* Rule 'http'
* Rule 'https'
* Rule 'netconf'
* Rule 'snmp'
* Rule 'iperf'
* Rule 'torrent'
* Rule 'vpn_turris_rule'
* Rule 'guest dns rule'
* Rule 'guest dhcp rule'
* Redirect 'ssh-honeypot'
* Redirect 'ssh'
* Redirect 'wr710n-ssh'
* Redirect 'ubuntu-ssh'
* Redirect 'debian-ssh'
* Redirect 'hpe-ssh'
* Redirect 'ilo-ssh'
* Forward 'lan' -> 'vpn_turris'
* Forward 'lan' -> 'wan'
* Forward 'vpn_turris' -> 'lan'
* Forward 'lan' -> 'lan2'
* Forward 'vpn_turris' -> 'lan2'
* Forward 'vpn_turris' -> 'wan'
* Forward 'lan2' -> 'lan'
* Forward 'lan2' -> 'vpn_turris'
* Forward 'lan2' -> 'wan'
* Forward 'guest_turris' -> 'wan'
* Forward 'lan3' -> 'wan'
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Zone 'guest_turris'
* Populating IPv4 nat table
* Redirect 'ssh'
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv4 mangle table
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv4 raw table
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 filter table
* Rule 'Allow-DHCPv6'
* Rule 'Allow-MLD'
* Rule 'Allow-ICMPv6-Input'
* Rule 'Allow-ICMPv6-Forward'
* Rule #7
* Rule #8
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 nat table
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan2_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan2_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_lan3_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_lan3_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_wan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_wan_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_vpn_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_vpn_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_guest_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_guest_turris_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'prerouting_rule'
Warning: fw3_ipt_rule_append(): Can't find target 'postrouting_rule'
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 mangle table
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Populating IPv6 raw table
* Zone 'lan'
* Zone 'lan2'
* Zone 'lan3'
* Zone 'wan'
* Zone 'vpn_turris'
* Set tcp_ecn to off
* Set tcp_syncookies to on
* Set tcp_window_scaling to on
* Running script '/etc/firewall.user'
* Running script '/usr/share/firewall/turris'
* Running script '/etc/firewall.d/with_reload/firewall.include.sh'
iptables: No chain/target/match by that name.
ip6tables: No chain/target/match by that name.
* Running script '/etc/firewall.d/without_reload/firewall.include.sh'
Output from switch-branch.postinst:
+ '[' deploy '=' deploy ]
+ VBRANCH=
+ sed -i '/\(turris\|omnia\)_nightly_/d;s#\(https://repo\.turris\.cz/\(turris\|omnia\)\)[^/]*/#\1/#' /etc/opkg/distfeeds.conf
+ uci set 'updater.override=override'
+ VBRANCH=
+ uci set 'updater.override.branch='
+ uci commit updater.override.branch
+ true
+ exit 0
Output from opkg.postinst:
+ VBRANCH=
+ VBRANCH=
+ true
+ exit 0
Output from updater-ng-opkg.postinst:
+ '[' -f /etc/updater/conf.d/opkg-auto.lua ]
+ UPDATER_CONFIG=/etc/updater/conf.d/opkg-auto.lua
+ sed -n 's/^Package.*content *= *"file:\/\/\([^"]*\)".*/\1/p' /etc/updater/conf.d/opkg-auto.lua
+ read PKG
+ localrepo clean --repo auto
+ sed -i '/^Package.*content/d' /etc/updater/conf.d/opkg-auto.lua
+ rm -rf /usr/share/updater/local-pkgs
Output from haveged.postinst:
haveged: listening socket at 3
Output from oneshot.postinst:
+ SCRIPT_DIR=/usr/share/oneshot/scripts
+ COMPLETED_DIR=/usr/share/oneshot/completed
+ mkdir -p /usr/share/oneshot/completed
+ ls /usr/share/oneshot/scripts
+ sort
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0000-opkg-uri ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0001-opkg-no-testing ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0002-opkg-https ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0003-reset-updater-pkgs ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0004-set-root-passwd ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0005-slash-opkg ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0006-samba-norestart ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0007-ssh-enable ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0008-lighttpd-start-sooner ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0009-fix-old-banner ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0009-samba-norestart-again ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0010-disable-old-feed ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0011-no-directories-in-opkg-list ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0011-stable-new-removal ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0013-unbound-dont-enable-dnsmasq ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0014-turris-btrfs ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0015-wifi-path-fix ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0016-dhcpv6-unicast-disable ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0017-lighttpd-conf-fix ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/0018-datacollect-userlist ]
+ read SCRIPT
+ '[' '!' -f /usr/share/oneshot/completed/012-omnia-wan-led ]
+ read SCRIPT
Output from foris-ws.postinst:
+ '[' -n ]
+ /etc/init.d/foris-ws enable
ln: /etc/rc.d/K1foris-ws: File exists
+ /etc/init.d/foris-ws restart
Output from foris-common.postinst:
+ '[' -n ]
+ /etc/init.d/lighttpd enable
+ /etc/init.d/lighttpd restart
Output from foris-config.postinst:
+ '[' -n ]
Output from foris-controller.postinst:
+ '[' -n ]
+ /etc/init.d/foris-controller enable
+ /etc/init.d/foris-controller restart
Output from foris-controller-diagnostics-module.postinst:
+ '[' -n ]
Output from foris-diagnostics-plugin.postinst:
+ '[' -n ]
Output from turris-webapps.postinst:
+ '[' -n ]
Output from foris-l10n-pl.postinst:
+ '[' -n ]
Output from foris-diagnostics-plugin-l10n-pl.postinst:
+ '[' -n ]
grep: /proc/6014/cmdline: No such file or directory
Output from nuci.postinst:
100 65 100 65 0 0 422 0 --:--:-- --:--:-- --:--:-- 436
Output from turris-version.postinst:
df: /srv/lxc/debian/rootfs: can't find mount point
df: /srv/lxc/ubuntu/rootfs: can't find mount point
Output from foris-controller-openvpn-module.postinst:
+ '[' -n ]
Output from foris-openvpn-plugin.postinst:
+ '[' -n ]
grep: /proc/7116/cmdline: No such file or directory
Output from foris-openvpn-plugin-l10n-pl.postinst:
+ '[' -n ]
Statistics page was mangled again after the update after quite a few updates where it wasn’t.
I haven’t heard about it for a while, however, we haven’t updated LuCi for a while.
I have created the issue for it, so we can check it and fix it for the next time. https://gitlab.labs.nic.cz/turris/openwrt/issues/227
I also encountered a scary error message on the first refresh after reboot that went away after I reloaded the page. I captured a PDF of the page, but I’m not sure it’s worth posting since it went away right away.
It’s not necessary. I see, for this issue, there are already 2 tickets opened by users for it, so we will look into it!
Is there any way to keep it from automatically going to the Foris page after 5 seconds?
The time is increasing itself when you add more webapps.
Right after the update (before restarting), I see these issues:
DDNS stopped updating with these errors spit out in the log every minute (fixed after restart):
18:19:00 err ddns-scripts[8548]: myddns_ipv4: BusyBox nslookup error: 127
18:19:00 warning ddns-scripts[8548]: myddns_ipv4: Get registered/public IP for xxx.ddns.net failed - retry 63/0 in 60 seconds
mosquitto service was stopped and not started again when updater finished (fixed after restart)
pip3-installed package paho.mqtt got uninstalled
luci statistics are working
I think the fact that ddns stopped working before restart should be considered a bug, because somebody might rely on ddns updates to remotely connect to his router before the restart.
What should I do for my pip packages to survive the update?
Output from luci-i18n-base-en.postinst:
/usr/lib/opkg/info//luci-i18n-base-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-base-en': No such file or directory
Output from luci-i18n-commands-en.postinst:
/usr/lib/opkg/info//luci-i18n-commands-en.postinst: .: line 2: can't open '/etc/uci-defaults/luci-i18n-commands-en': No such file or directory
+ '[' -n ]
+ '[' -n ]
after that, nothing happens. reboot breaks the router. =(
