Really tomorrow???
Right. I should rather say āRelease for Turris Omnia will follow soon or in next daysā. Next time, I wonāt give an exact release day.
I wanted to release it today as I said, but it didnāt work. My bad. Package ānetdataā failed to build and we decided not to release it to RC to avoid potential issues which could appear as some users could have it installed in RC. Iāve triggered it once again right now. It takes a few hours as it compiles all the packages.
Today, we are releasing a new RC for both routers - Turris 1.x and Turris Omnia.
Changelog:
- sentinel-certgen: update to version 6.1.3.
Today, tomorrow ⦠thx
Omnia 2GB Ok (OpenVPN server, 3x LXC, SATA card, SSD + HW raid BOX)
Turris 1.0 Ok (OpenVPN client)
I thought this would be handled automatically by opkg upgrade scripts. Will it be there in the released version?
I personally believe scripts shouldnāt (automatically) touch user-written configuration.
Itās not generally even possible, as Knot Resolver configuration is a Turing-complete language, and you could have anything in there. Of course, we are trying to keep incompatible changes to minimum and concentrate them into moments when the major number changes (3.x -> 4.x in this case), and we have them in a separate section in NEWS.
Yes, itās true. Upgrade scripts donāt overwrite user-modified configuration files. They create *-opkg
files instead.
Yes in general, but for Knot Resolver there even isnāt any installed configuration file so far, I believe. (All of that is generated into /tmp/kresd.config
by the init script, including composition with the user-supplied config if thatās specified.)
If we detect if you have some incompatible changes in your user-modified file for Knot Resolver, you will receive a notification.
We released another RC4 version for both routers Turris 1.x and Turris Omnia.
Changelog:
- netboot: minor fixes and serial numbers are now displayed in decimal.
- node-mozilla-iot-gateway: fixed compile issue, which means that you can now install it.
- kernel: update to version 4.4.187
So this is no longer true?
it is conditionally true - only if specified as conffiles
in the package Makefile those files will not be overwritten.
I canāt remember any example of configuration files which are not specified in conffiles and thus they are overwritten.
This been one example
Everything still works for me. Iām online with this latest rc
Thanks! May I ask if you are having Turris 1.x or Turris Omnia?
I have a Turris Omnia
I have Turris 1.0 and the last RC4 version of TurrisOS 3.11.6 works well too.
TO, nas, smb and tm. Everything seems to work fine.
Update from 3.11.5 ok
Pairing MOX Power Wi-Fi in CLI now works.
Pairing in Firefox worked.
Safari shows MANAGED DEVICES.
Wi-Fi shows count of Devices 2 and only one channel at a time. Which is fine.
Canāt ping MOX AP by myname.lan but serial.lan:
Changed in Luci:
luci > Network > Hostnames > Hostname: myname
8/9/19 MOX Wi-Fi went down tonight. Reset of MOX, reconnecting in Firefox helped.
