Turris Omnia - VLAN on TOS 4.x/5.x
On TO 3.x.x I had set some VLAN on my Turris Omnias (by following instructions in documentation), but after fresh installation to 4.x and later to 5.x, there is no possibility to set VLAN in LuCI and there is no instruction how to proceed.
My question is, it is possible just to edit network, dhcp and firewall according to files from 3.x.x to enable VLAN on TOS 4.x/5.x?
My network config files are (almost default):
network TOS 3.x.x
config interface 'loopback'
	option ifname 'lo'
	option proto 'static'
	option ipaddr '127.0.0.1'
	option netmask '255.0.0.0'
config globals 'globals'
	option ula_prefix 'fd2a:c5a2:11ed::/48'
config interface 'lan'
	option ifname 'eth0 eth2'
	option force_link '1'
	option type 'bridge'
	option ipaddr '192.168.1.1'
	option ip6assign '60'
config interface 'wan'
	option ifname 'eth1'
	option proto 'dhcp'
config interface 'wan6'
	option ifname '@wan'
	option proto 'dhcpv6'
	option noserverunicast '1'
config switch
	option name 'switch0'
	option reset '1'
	option enable_vlan '1'
config switch_vlan
	option device 'switch0'
	option vlan '1'
	option vid '1'
	option ports '0 1 2 3 5'
config switch_vlan
	option vlan '2'
	option ports '4 6'
	option vid '2'
	option enabled '1'
	option ifname 'guest_turris_0 guest_turris_1'
	option ipaddr '10.111.222.1'
	option bridge_empty '1'
network TOS 5.x How I should edit this config file?
	option ifname 'lo'
	option ula_prefix 'fde4:1bc5:f8d1::/48'
	list ifname 'lan0'
	list ifname 'lan1'
	list ifname 'lan2'
	list ifname 'lan3'
	list ifname 'lan4'
	option ifname 'eth2'
	option proto 'dhcp'
	option hostname 'Router'
	option ipv6 '0'
	option enabled '1'
	option proto 'none'
Further I would like to set connection on one of LAN ports with some proxy, to be able watching videos from abroad right on TV (e.g. watching TV archives from Czech in Slovakia) - just by swiching cable between these ports. But I don´t know if this will be possible.
For guidance and explanations have a look here: DSA and 802.1Q tagging - SW tweaks - Turris forum
That is for sure possible - if you use the guide above.
There’s unfortunately nothing left in that post - it’s been edited into oblivion.
You’re right, didn’t check that before posting. Sry.
So, nobody with some basic example of working vlan on TOS 4.x/5.x? :confused:
Did you search in this forum for „dsa“? I myself posted mupliple replies on this topic here, so there should be plenty of information…
Even though some kind of documentation would be much appreciated as this topic comes up way too often… :slight_smile:
Well maybe I have not understand it. What I want, is some simple example, how should new network, dhcp and firewall config files look like. There is no such example (at least I have not found it) in this forum.
I am just asking how to edit config switch , config switch_vlan and other parts of files (which were working in TOS3.x) to get working simple vlan (in TOS4.x/5.x), but nobody could answer this (maybe simple) question yet. So, if you know how to do it, please, write here some tutorial.
Thanks
There is no Config Switch anymore. Furthermore, in your TOS3 example I don’t see any VLAN used on user side [beside of the default split ports 0 - 3 and port 4].
In my case, I use tagged VLAN2 on lan0 port, and separate network on lan1 port [no need to create VLAN since TOS4]. You can remove IPv6 related stuff if not using it.
network file:
	option ifname 'lan0 lan2 lan3 lan4'
config interface 'dev'
	option ipaddr '192.168.222.222'
	option netmask '255.255.255.248'
	option ifname 'lan1'
	option ip6assign '64'
	option ip6hint '88'
config interface 'virt'
	option ipaddr '10.1.1.1'
	option ifname 'lan0.2'
	option ip6hint 'ff'
dhcp file:
config dhcp 'lan'
	option interface 'lan'
	option start '100'
	option limit '100'
	option leasetime '1d'
	list dhcp_option '6,1.1.1.1,8.8.8.8'
config dhcp 'probe'
	option interface 'dev'
	option start '1'
	option limit '2'
config dhcp 'virt'
	option interface 'virt'
	option start '100'
	option limit '100'
	option ra 'server'
	option dhcpv6 'server'
	option ra_management '2'
	list dns '2606:4700:4700::1111'
	list dns '2001:4860:4860::8888'
firewall file:
config zone
	option name 'lan'
	option input 'ACCEPT'
	option output 'ACCEPT'
	option forward 'ACCEPT'
	option network 'lan virt dev'
Thank you!
I have edited/added these into my config files according to yours:
network
	list ifname 'lan0'
	list ifname 'lan1'
	list ifname 'lan2'
	list ifname 'lan4'
config interface 'vlan'
	option ipaddr '192.168.4.1'
	list ifname 'lan3'
dhcp
config dhcp 'vlan'
	option interface 'vlan'
	option start '100'
	option limit '150'
	option leasetime '12h'
	option ra 'server'
	list dhcp_option '6,192.168.4.1'
firewall
config zone
	option name 'vlan'
	list network 'vlan'
But device connected to separated network (vlan) cannot reach internet. It obtains IP from correct range, but I think, I have bad firewall rule or there is missing something…
firewall - add
config forwarding
	option src 'vlan'
	option dest 'wan'
or place VLAN to the same zone as LAN (like I have)
if you do not use IPv6, remove following:
option ra 'server'
Hi!
I have been reading the entire message to try to understand how to reconfigure the turris omnia router in TOS 4.x / 5.x versions. unable to use swconfig.
I have seen that the Vlan are now controlled with the DSA switch, but I do not see enough information about it to understand it. How can I transfer this configuration to Dsa Switch?
This is my configuration for Turris Omnia that I have been using for 2-3 years Turris OS version 3.xx with 15.05 (Chaos Calmer), with Lan eth0.1, Iptv eth1.2 (incoming tv traffic), Voip eth1.3, Tvlan eth0.4 (isolated tv so it doesn’t flood traffic with mcproxy), wan eth1.6:
option ifname 'lo'
option ula_prefix 'fda7: 8045: b9e8 :: / 48'
config switch
option reset '1'
config switch_vlan
option vlan '1'
option vid '1'
option ports '1 2 3 5t 6'
config switch_vlan
option vlan '2'
option vid '2'
option ports '4t'
config switch_vlan
option vlan '3'
option vid '3'
option ports '4t'
config switch_vlan
option vlan '4'
option vid '4'
option ports '0 5t'
config switch_vlan
option vlan '6'
option vid '6'
option ports '4t'
option ifname 'eth0.1'
option igmp_snooping '1'
config interface 'iptv'
option ifname 'eth1.2'
option ipaddr '10 .133.155.92 '
option netmask '255.128.0.0'
option gateway '10 .128.0.1 '
option defaultroute '0'
option peerdns '0'
config interface 'tvlan'
option ifname 'eth0.4'
option ipaddr '192.168.2.1'
config route
option interface 'iptv'
option target '172.16.0.0'
option netmask '255.240.0.0'
config route
option interface 'voip'
option target '10 .31.255.128 '
option gateway '10 .22.64.1 '
option netmask '255.255.255.224'
config interface 'voip'
option ifname 'eth1.3'
option proto 'dhcp'
option peerdns '0'
option ifname 'eth1.6'
option proto 'pppoe'
option username 'adslppp @ telefonicanetpa'
option password 'adslppp'
option ipv6 '1'
option mtu '1492'
option ifname 'wan'
config interface 'vpn_turris'
option ifname 'tun_turris'
option proto 'none'
option auto '1'
option enabled '1'
Thanks
I´d like to have networks separated.
Tomorrow I will try to add forward rule and let know if it works. Thank you.
Well, it goes bit beyond my knowledge. I can say, you will create VLAN only by assigning a physical network interface with .x, such as lan0.1. Therefore if you set it is lan0 it goes out untagged, when lan0.1 then it goes out tagged as VLAN1
How does this work? Is you TV set able to work with VLAN tagged packets?
This VLAN config works. There are a lot of interface in differt VLANS. Now you can set the client to use a particular VLAN and it get an IP and works just fine.
Where I am stuck is how can I say VLAN3 interface lan10.3 is tagged and hands hands dhacp instead of LAN10. On interface LAN10 I always get dhcp from VLAN0. How can I change that ?
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix ‘fd11:2a2f:dc25::/48’
config interface ‘wan’
option ifname ‘eth0’
option proto ‘dhcp’
option ipv6 ‘1’
config interface ‘lan’
option type ‘bridge’
option ipaddr ‘192.168.1.1’
option _turris_mode ‘managed’
option ip6assign ‘60’
option bridge_empty ‘1’
option ifname ‘lan1 lan10 lan11 lan12 lan13 lan14 lan15 lan16 lan2 lan3 lan4 lan5 lan6 lan7 lan8 lan9’
config interface ‘guest_turris’
option enabled ‘1’
option ipaddr ‘10.111.222.1’
config interface ‘wan6’
option ifname ‘@wan
option proto ‘dhcpv6’
config interface ‘LAN3’
option ipaddr ‘192.168.3.1’
option dns ‘192.168.3.1’
option ifname ‘lan1.3 lan10.3 lan11.3 lan12.3 lan13.3 lan14.3 lan15.3 lan16.3 lan2.3 lan3.3 lan4.3 lan5.3 lan6.3 lan7.3 lan8.3 lan9.3’
config interface ‘LAN8_DMZ’
option ipaddr ‘192.168.8.1’
option ifname ‘lan1.8 lan10.8 lan11.8 lan12.8 lan2.8 lan3.8 lan4.8 lan5.8 lan6.8 lan7.8 lan8.8 lan9.8’
config interface ‘LAN2_IOT’
option ifname ‘lan1.2 lan2.2 lan3.2 lan4.2’
option ipaddr ‘192.168.2.1’
The DHCP Service needs to get an idea of the networks structure. The OpenWrt DHCP Service enables for the definition of multiple subnets AND to bind them to a specific network interface.
See “DHCP pools” within DNS and DHCP configuration
And have a look at the samples here: OpenWrt DNS and DHCP conf. samples
Taking this and your configuration details, your /etc/config/dhcp should roughly contain something like
config dhcp ‘LAN3’
option interface ‘LAN3’ # the interface
option start ‘100’ # address pool start inclusive
option limit ‘150’ # address pool end inclusive
list dhcp_option ‘6,192.168.3.1’ # the default router
config dhcp ‘LAN8_DMZ’
option interface ‘LAN8_DMZ’ # the interface
list dhcp_option ‘6,192.168.8.1’ # the default router
config dhcp ‘LAN2_IOT’
option interface ‘LAN2_IOT’ # the interface
list dhcp_option ‘6,192.168.2.1’ # the default router
best regards
N.
Thank you ,
DHCP is working if you set the client to the desired vlan, client side tagging.
All interfaces default to VLAN1 (tagged) all the other VLANS are not tagged. What I like to do is to move the interface tag from lan1 to lan1.8 for example.
That is your default or you mean that being the default by the OS? For the latter all DSA ports are in untag state, check with bridge v, e.g. prints
port    vlan ids
lan0     1 PVID Egress Untagged
  • untag state (one VID per each port only)
    bridge v a dev lan1 vid 8 pvid untagged
  • tag state
    bridge v a dev lan1 vid 8 tagged, or
    bridge v a dev lan1 vid 8 pvid tagged
similar operation for a bridge port exchange the device name, e.g. dev lan1 with dev br-LAN2_IOT.
So, I have added this rule and it seems that internet is working finally. :slight_smile: Sorry for that, " my tomorrow " lasted for 27 days… Thank you again!
So, the right way for very simple vlan configuration in my case is (all with unused ipv6):
network
	list ifname 'lan0'
	list ifname 'lan1'
	list ifname 'lan2'
	list ifname 'lan4'
	list ifname 'lan3'
	list dns '192.168.4.1'
dhcp
config dhcp 'vlan'
	option start '100'
	option limit '150'
	option ra 'server'
	option ra_management '1'
firewall
config zone
	option name 'vlan'
	list network 'vlan'
config forwarding
	option src 'vlan'
	option dest 'wan'
