Thanks for your effort @peci1
I tried to check HW and all seems fine. I also reseated wifi modules inside, just to be sure.
Output is:
root@Yurris:/tmp/log# cat messages|grep -i btrfs
Sep 28 19:13:19 Yurris kernel: [ 0.000000] Kernel command line: earlyprintk rootwait console=ttyS0,115200 rootfstype=btrfs root=PARTUUID=00000000-01 rootflags=commit=5,subvol=@ rw cfg80211.freg=**
Sep 28 19:13:19 Yurris kernel: [ 0.000000] Unknown kernel command line parameters "earlyprintk mangled_fs=btrfs", will be passed to user space.
Sep 28 19:13:19 Yurris kernel: [ 2.202569] Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no
Sep 28 19:13:19 Yurris kernel: [ 3.847835] BTRFS: device fsid d3cd672d-ea8c-4b98-9099-117a07f334d6 devid 1 transid 12987 /dev/root scanned by swapper/0 (1)
Sep 28 19:13:19 Yurris kernel: [ 3.860420] BTRFS info (device mmcblk0p1): using crc32c (crc32c-generic) checksum algorithm
Sep 28 19:13:19 Yurris kernel: [ 3.868844] BTRFS info (device mmcblk0p1): disk space caching is enabled
Sep 28 19:13:19 Yurris kernel: [ 3.875562] BTRFS info (device mmcblk0p1): has skinny extents
Sep 28 19:13:19 Yurris kernel: [ 3.893240] BTRFS info (device mmcblk0p1): enabling ssd optimizations
Sep 28 19:13:19 Yurris kernel: [ 3.907755] VFS: Mounted root (btrfs filesystem) on device 0:14.
Sep 28 19:13:19 Yurris kernel: [ 3.941217] mangled_fs=btrfs
Sep 28 19:13:19 Yurris kernel: [ 6.645947] BTRFS info: devid 1 device path /dev/root changed to /dev/mmcblk0p1 scanned by mount (698)
I will monitor after the card reseat and if problems occur again I will switch drivers.
But weird thing is that everything was forking for 2 years with no problem. Just recently I have these issues
