Turris 1.0 nebootuje po obnově z SD karty
Zdravím, pokouším se provést obnovu z SD kart u svého Turrisu 1.0. Obnova probíhá tak, jak je popsáno v návodu, po rebootu ale Turris nenaběhne, nemůže namountovat ubifs.
Dělám toto:
  • s přepínači v poloze 011 010 a s kartou s sdcard.img zasunutou ve slotu nabootuji Turris:
U-Boot 2013.10-rc2-00039-g73346b1-dirty (Jul 02 2015 - 13:47:57)
CPU0:  P2020E, Version: 2.1, (0x80ea0021)
Core:  e500, Version: 5.1, (0x80211051)
Clock Configuration:
       CPU0:1200 MHz, CPU1:1200 MHz,
       CCB:600  MHz,
       DDR:400  MHz (800 MT/s data rate) (Asynchronous), LBC:37.500 MHz
L1:    D-cache 32 KiB enabled
       I-cache 32 KiB enabled
Board: TURRIS1 CPLD: V4.1 PCBA: V4.0
Error, wrong i2c adapter 2 max 2 possible
rom_loc: nor upper bank
SD/MMC : 4-bit Mode
eSPI : Enabled
I2C:   Error, wrong i2c adapter 2 max 2 possible
ready
SPI:   ready
DRAM:  Detected UDIMM 9905428-181.A00LF
2 GiB (DDR3, 64-bit, CL=6, ECC off)
Flash: 16 MiB
L2:    512 KiB enabled
NAND:  256 MiB
MMC:  FSL_SDHC: 0
*** Warning - bad CRC, using default environment
PCIe1: Root Complex of mini PCIe SLOT, no link, regs @ 0xffe0a000
PCIe1: Bus 00 - 00
PCIe2: Root Complex of PCIe SLOT, x1, regs @ 0xffe09000
  02:00.0     - 168c:0030 - Network controller
PCIe2: Bus 01 - 02
PCIe3: Root Complex of PCIe SLOT, no link, regs @ 0xffe08000
PCIe3: Bus 03 - 03
In:    serial
Out:   serial
Err:   serial
MAC Addresses:
CRC doesn't match.
try: 2 delay: 360000
MAC0 D8:58:D7:00:09:78
MAC1 D8:58:D7:00:09:79
MAC2 D8:58:D7:00:09:7A
Net:   Phy not found
PHY reset timed out
eTSEC1, eTSEC2, eTSEC3 [PRIME]
Hit any key to stop autoboot:  0
=> nand scrub.chip -y
NAND scrub.chip: device 0 whole chip
Erasing at 0xffe0000 -- 100% complete.
OK
  • stisknu resetovací tlačítko a Turris začne zase bootovat:
       CCB:600  MHz,
SD/MMC : 4-bit Mode
eSPI : Enabled
ready
SPI:   ready
Flash: 16 MiB
L2:    512 KiB enabled
NAND:  256 MiB
MMC:  FSL_SDHC: 0
PCIe1: Bus 00 - 00
PCIe2: Bus 01 - 02
PCIe3: Bus 03 - 03
In:    serial
Out:   serial
Err:   serial
MAC Addresses:
CRC doesn't match.
Net:   Phy not found
PHY reset timed out
MMC read: dev # 0, block # 2048, count 32768 ... 32768 blocks read: OK
Un-Protect Flash Bank # 1
Erase Flash Bank # 1
...................................................................................................................e
Copy to Flash... 9....8....7....6....5....4....3....2....1....done
HOTOVO
  • vypnu napájení, přepnu přepínače do polohy 110 010 a znovu připojím napájení:
U-Boot 2015.04-04654-gbcfb33e-dirty (Jun 26 2015 - 12:50:49)
       CCB:600  MHz,
wdt status 00000005 reset
       Watchdog enabled
Board: TURRIS CPLD: V4.1 PCBA: V4.0
in: 56
out: 0
io_config: 255
SD/MMC : 4-bit Mode
eSPI : Enabled
ready
SPI:   ready
DRAM:  Error, wrong i2c adapter 2 max 2 possible
Flash: 16 MiB
L2:    512 KiB enabled
NAND:  256 MiB
MMC:   FSL_SDHC: 0
PCIe1: Bus 00 - 00
PCIe2: Root Complex of PCIe SLOT, x1 gen1, regs @ 0xffe09000
PCIe2: Bus 01 - 02
PCIe3: Bus 03 - 03
In:    serial
Out:   serial
Err:   serial
Net:   Phy 5 not found
PHY reset timed out
eTSEC1
Error: eTSEC1 address not set.
, eTSEC2
Error: eTSEC2 address not set.
, eTSEC3 [PRIME]
Error: eTSEC3 address not set.
BOOT NAND
wdt status 00000003
UBI: attaching mtd2 to ubi0
UBI: scanning is finished
UBI: empty MTD device detected
UBI: attached mtd2 (name "mtd=0", size 256 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 2044, bad PEBs: 4, corrupted PEBs: 0
UBI: user volume: 0, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 0
UBI: available PEBs: 2004, total reserved PEBs: 40, PEBs reserved for bad PEB handling: 36
Error reading superblock on volume 'ubi0:rootfs' errno=-19!
ubifsmount - mount UBIFS volume
Usage:
ubifsmount <volume-name>
    - mount 'volume-name' volume
UBIFS not mounted, use ubifs mount to mount volume first!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
    - load file 'filename' to address 'addr'
Usage:
WARNING: adjusting available memory to 30000000
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Dělám něco špatně? Používám obraz z http://repo.turris.cz/turris/sdcard-rescue/sdcard.img , nemyslím, že by se poškodil při stahování nebo zapisování na SD kartu. Je možné, že není kompatibilní s mým Turrisem?
Díky za každou radu!
Vařím z vody, nevidím podle kterého návodu jsi to dělal.
Použil jsi obnovení továrního nastavení ?
Podržet tlačítko reset cca 6 vteřin?
Co tě k obnově z sd vedlo? Již nějaký čas se paměť v nor aktualizuje sama…
Úvodem možná … jaký byl prvotní důvod zvoleného postupu?
Proč jste se do obnovy z SD karty pouštěl?
Co jsem si tak připomněl ze starých návodů … platných pro hodně starou verzi TurrisOS 3.x (která ale byla kdysi poplatná pro Turris 1.x) … bude třeba ještě provést reset do továrního nastavení …
https://wiki.turris.cz/cs/troubleshooting/start#obnoveni_tovarniho_nastaveni
Takhle máte přehrán akorát záchranný systém v NOR paměti, ale operační paměť NAND, ze které TurrisOS 3.0 bootuje, je po aplikaci příkazu "nand scrub.chip -y" krásně vyčištěná.
Proto nejspíš i ta hláška:
"UBIFS not mounted, use ubifs mount to mount volume first!"
Výborně jsi dokázal shrnout jeden příspěvek do dvou. Gratuluji
Několikrát jsem zopakoval postup popsaný tady a nakonec to zafungovalo. Nevím přesně proč, možná pomohlo, že jsem použil měnší kartu (128MB), každopárně Turris nabootoval do OS verze 3. Systém moc nefungoval, webové rozhraní místo některých stránek zobrazovalo vyjímky (ale LuCi celkem fungovalo), ssh nefugovalo (chyběla binárka sshd daemona), DNS sice beželo, ale nerezolvovalo atd.
Nicméně změnil jsem /etc/resolv.conf, aby ukazoval na jiný DNS v mojí síti, povedlo se mi stáhnout a nainstalovat nové certifikáty a tím rozchodit opkg a podle tohoto návodu zmigrovat na btrfs.
Pak jsem stáhnul nejnovejší medikit a pomocí něj nainstaloval nejnovější OS 5. Takže můj Turris je teď plně funkční.
Díky!
Měl jsem ten samý problém, postupoval jsem podle tohoto přehledného TL;DR návodu. a Turris už opět jede na verzi 7.1.3 :slightly_smiling_face:
