(I don’t have more than 4 devices in my LAN currently to test the full 10 gigabit throughput)
also the omnia delivers if running iperf against it full gigabit, only if it has to do routing i see this waveing
may still be happing, or may not at all, it is just not possible to discern without some information on that transceiver’s feature (implementation).
if that be the case than other nodes with GiB connectivity should exhibit a similar issue, but as @ChrisDeath demonstrated it does not happen on that user’s node (with SFP).
It would be interesting to see test results from any other forum user with GiB upstream connectivity provided through an external modem over the TO’s copper port.
is the subscriber line ds-lite or native dual-stack and is the modem in bridge mode and the client dialling up to the ISP, assuming PPPoE, or the modem in control?
It is native Dualstack and DOCSIS does no PPPoE here, it outputs a public IP and a Prefix on it’s ethernet port.
But i think I found the issue.
Doing iperf3 directly connected to the modem i get 0 retransmits
makes only sense for dial-up connectivity, e.g. PPPoE, but not on DHCP with the external modem.
Not sure whether it makes sense in DHCP with the modem or creates a double NAT, perhaps depends on whether the modem’s subnet is the same as the TO’s subnet.
If i disable that i have no internet connection anymore, which makes sense i guess because i try in that case to route private IPs in the internet which can’t work.
beside that, no dropped packets according to the firewall log for the iperf3 test, only some broadcast from time to time that are not related to this.
