Omnia 3.10 disappeared Wi-Fi
After 3.10 upgrade I noticed that Foris is only showing one Wi-Fi card anymore. I tried the new “Reset Wi-Fi” button, but that didn’t help and even this looks suspicious to me:
# lspci
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
01:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
I’m not certain if this happened at this point, but both of them were showing up not long ago and I certainly haven’t touched the HW since.
Missing 5g probably won’t noticeably impede me, due to lack of supporting devices, but if you have an idea what’s wrong…
Can you please post output from dmesg immediately after reboot (dmesg should not contain any sensitive information but optionally you can send it to me directly). I think that it’s once again problem with PCI. If so then it should be visible in dmesg that system failed to identify card or load firmware to it. Common fix is either move 5GHz wifi to left most slot or to let us swap some capacitors on board.
Just for anyone else reading this. Problem with pci card initialization should be happening only with boards from initial series (those primarily shipped to contributors from Indiegogo). And it’s not problem with board but rather with Qualcomm card it self.
Serial number starts with 4 (talked with Pepe in the meantime); that’s probably related to being a 1GiB RAM variant (no longer manufactured). The only suspicious part I see is a kernel backtrace. I tried two reboots and it seems the same.
2018-05-13 20:24:56 notice syslog-ng[3376]: syslog-ng starting up; version='3.10.1'
2018-05-13 20:24:56 info kernel[]: [    7.740640] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
2018-05-13 20:24:56 info kernel[]: [    7.748253] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
2018-05-13 20:24:56 info kernel[]: [    7.756823] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
2018-05-13 20:24:56 info kernel[]: [    7.762837] hub 2-0:1.0: USB hub found
2018-05-13 20:24:56 info kernel[]: [    7.766606] hub 2-0:1.0: 1 port detected
2018-05-13 20:24:56 info kernel[]: [    7.770628] xhci-hcd f10f0000.usb3: xHCI Host Controller
2018-05-13 20:24:56 info kernel[]: [    7.775969] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
2018-05-13 20:24:56 info kernel[]: [    7.783521] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
2018-05-13 20:24:56 info kernel[]: [    7.791842] hub 3-0:1.0: USB hub found
2018-05-13 20:24:56 info kernel[]: [    7.795610] hub 3-0:1.0: 1 port detected
2018-05-13 20:24:56 info ucollect[3553]: Reconnecting to api.turris.cz:5679 now
2018-05-13 20:24:56 info ucollect[3553]: Socat started
2018-05-13 20:24:57 info kernel[]: [    7.799678] xhci-hcd f10f8000.usb3: xHCI Host Controller
2018-05-13 20:24:57 info kernel[]: [    7.805025] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
2018-05-13 20:24:57 info kernel[]: [    7.812621] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
2018-05-13 20:24:57 info kernel[]: [    7.821190] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
2018-05-13 20:24:57 info kernel[]: [    7.827186] hub 4-0:1.0: USB hub found
2018-05-13 20:24:57 info kernel[]: [    7.830966] hub 4-0:1.0: 1 port detected
2018-05-13 20:24:57 info kernel[]: [    7.834983] xhci-hcd f10f8000.usb3: xHCI Host Controller
2018-05-13 20:24:57 info kernel[]: [    7.840310] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
2018-05-13 20:24:57 info kernel[]: [    7.847849] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
2018-05-13 20:24:57 info kernel[]: [    7.856166] hub 5-0:1.0: USB hub found
2018-05-13 20:24:57 info kernel[]: [    7.859933] hub 5-0:1.0: 1 port detected
2018-05-13 20:24:57 info kernel[]: [    7.865107] usbcore: registered new interface driver usb-storage
2018-05-13 20:24:57 info kernel[]:    8.157944] init: - preinit -
2018-05-13 20:24:57 notice kernel[]:   11.208549] mount_root: mounting /dev/root
2018-05-13 20:24:57 info kernel[]: [   11.518110] BTRFS info (device mmcblk0p1): disk space caching is enabled
2018-05-13 20:24:57 info kernel[]:   11.524982] mount_root: loading kmods from internal overlay
2018-05-13 20:24:57 info kernel[]:   11.736988] block: attempting to load /etc/config/fstab
2018-05-13 20:24:57 info kernel[]:   11.743355] block: extroot: not configured
2018-05-13 20:24:57 info kernel[]:   11.749899] procd: - early -
2018-05-13 20:24:57 info kernel[]:   11.752820] procd: - watchdog -
2018-05-13 20:24:57 notice kernel[]: [   11.853579] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   11.880259] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   11.915728] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   11.940076] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   11.975614] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   11.999876] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   12.035126] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   12.059576] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   12.094929] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 notice kernel[]: [   12.119171] random: jshn: uninitialized urandom read (4 bytes read, 43 bits of entropy available)
2018-05-13 20:24:57 info kernel[]:   12.323885] procd: - ubus -
2018-05-13 20:24:57 info kernel[]:   13.331881] procd: - init -
2018-05-13 20:24:57 info kernel[]: [   13.402167] marvell-cesa f1090000.crypto: CESA device successfully registered
2018-05-13 20:24:57 info kernel[]: [   13.414623] NET: Registered protocol family 38
2018-05-13 20:24:57 info kernel[]: [   13.427711] Netfilter messages via NETLINK v0.30.
2018-05-13 20:24:57 info kernel[]: [   13.438228] md: linear personality registered for level -1
2018-05-13 20:24:57 info kernel[]: [   13.444367] md: raid0 personality registered for level 0
2018-05-13 20:24:57 info kernel[]: [   13.450370] md: raid1 personality registered for level 1
2018-05-13 20:24:57 info kernel[]: [   13.456576] md: raid10 personality registered for level 10
2018-05-13 20:24:57 info kernel[]: [   13.462512] async_tx: api initialized (async)
2018-05-13 20:24:57 info kernel[]: [   13.469834] md: raid6 personality registered for level 6
2018-05-13 20:24:57 info kernel[]: [   13.475182] md: raid5 personality registered for level 5
2018-05-13 20:24:57 info kernel[]: [   13.480505] md: raid4 personality registered for level 4
2018-05-13 20:24:57 notice kernel[]: [   13.487711] FS-Cache: Loaded
2018-05-13 20:24:57 info kernel[]: [   13.491073] md: multipath personality registered for level -4
2018-05-13 20:24:57 info kernel[]: [   13.498013] NET: Registered protocol family 8
2018-05-13 20:24:57 info kernel[]: [   13.502397] NET: Registered protocol family 20
2018-05-13 20:24:57 info kernel[]: [   13.511642] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
2018-05-13 20:24:57 notice kernel[]: [   13.522514] Key type dns_resolver registered
2018-05-13 20:24:57 info kernel[]: [   13.529636] NET: Registered protocol family 33
2018-05-13 20:24:57 notice kernel[]: [   13.534119] Key type rxrpc registered
2018-05-13 20:24:57 notice kernel[]: [   13.537790] Key type rxrpc_s registered
2018-05-13 20:24:57 info kernel[]: [   13.544794] kAFS: Red Hat AFS client v0.1 registering.
2018-05-13 20:24:57 notice kernel[]: [   13.549982] FS-Cache: Netfs 'afs' registered for caching
2018-05-13 20:24:57 info kernel[]: [   13.584640] RPC: Registered named UNIX socket transport module.
2018-05-13 20:24:57 info kernel[]: [   13.590578] RPC: Registered udp transport module.
2018-05-13 20:24:57 info kernel[]: [   13.595305] RPC: Registered tcp transport module.
2018-05-13 20:24:57 info kernel[]: [   13.600019] RPC: Registered tcp NFSv4.1 backchannel transport module.
2018-05-13 20:24:57 notice kernel[]: [   13.624506] NFS: Registering the id_resolver key type
2018-05-13 20:24:57 notice kernel[]: [   13.629590] Key type id_resolver registered
2018-05-13 20:24:57 notice kernel[]: [   13.633815] Key type id_legacy registered
2018-05-13 20:24:57 info kernel[]: [   13.638459] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
2018-05-13 20:24:57 info kernel[]: [   13.647664] ntfs: driver 2.1.32 [Flags: R/O MODULE].
2018-05-13 20:24:57 notice kernel[]: [   13.657479] RxRPC: Registered security type 2 'rxkad'
2018-05-13 20:24:57 info kernel[]: [   13.674299] tun: Universal TUN/TAP device driver, 1.6
2018-05-13 20:24:57 info kernel[]: [   13.679366] tun: (C) 1999-2004 Max Krasnyansky
2018-05-13 20:24:57 info kernel[]: [   13.689505] sit: IPv6 over IPv4 tunneling driver
2018-05-13 20:24:57 info kernel[]: [   13.696332] gre: GRE over IPv4 demultiplexor driver
2018-05-13 20:24:57 info kernel[]: [   13.701827] ip_gre: GRE over IPv4 tunneling driver
2018-05-13 20:24:57 info kernel[]: [   13.721465] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
2018-05-13 20:24:57 info kernel[]: [   13.729884] PPP generic driver version 2.4.2
2018-05-13 20:24:57 info kernel[]: [   13.736278] ip6_tables: (C) 2000-2006 Netfilter Core Team
2018-05-13 20:24:57 info kernel[]: [   13.749576] nf_conntrack version 0.5.0 (16109 buckets, 64436 max)
2018-05-13 20:24:57 info kernel[]: [   14.663012] ip_set: protocol 6
2018-05-13 20:24:57 info kernel[]: [   18.521997] cryptodev: driver 1.8 loaded.
2018-05-13 20:24:57 info kernel[]: [   20.172254] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
2018-05-13 20:24:57 info kernel[]: [   20.180282] Backport generated by backports.git backports-20160324-13-g24da7d3c
2018-05-13 20:24:57 info kernel[]: [   22.371170] u32 classifier
2018-05-13 20:24:57 info kernel[]: [   22.373887]     input device check on
2018-05-13 20:24:57 info kernel[]: [   22.377554]     Actions configured
2018-05-13 20:24:57 info kernel[]: [   22.821120] Mirror/redirect action on
2018-05-13 20:24:57 info kernel[]: [   23.741100] GACT probability on
2018-05-13 20:24:57 info kernel[]: [   27.491165] netem: version 1.3
2018-05-13 20:24:57 info kernel[]: [   28.944026] fuse init (API version 7.23)
2018-05-13 20:24:57 info kernel[]: [   29.152392] usbcore: registered new interface driver cdc_wdm
2018-05-13 20:24:57 info kernel[]: [   29.161857] Ebtables v2.0 registered
2018-05-13 20:24:57 info kernel[]: [   29.167420] ip_tables: (C) 2000-2006 Netfilter Core Team
2018-05-13 20:24:57 info kernel[]: [   29.244569] ctnetlink v0.93: registering with nfnetlink.
2018-05-13 20:24:57 info kernel[]: [   29.484689] nfnl_acct: registering with nfnetlink.
2018-05-13 20:24:57 info kernel[]: [   29.490377] PPP MPPE Compression module registered
2018-05-13 20:24:57 info kernel[]: [   29.495749] NET: Registered protocol family 24
2018-05-13 20:24:57 info kernel[]: [   29.503984] usbcore: registered new interface driver ums-alauda
2018-05-13 20:24:57 info kernel[]: [   29.510744] usbcore: registered new interface driver ums-cypress
2018-05-13 20:24:57 info kernel[]: [   29.517775] usbcore: registered new interface driver ums-datafab
2018-05-13 20:24:57 info kernel[]: [   29.524678] usbcore: registered new interface driver ums-freecom
2018-05-13 20:24:57 info kernel[]: [   29.531651] usbcore: registered new interface driver ums-isd200
2018-05-13 20:24:57 info kernel[]: [   29.538616] usbcore: registered new interface driver ums-jumpshot
2018-05-13 20:24:57 info kernel[]: [   29.545605] usbcore: registered new interface driver ums-karma
2018-05-13 20:24:57 info kernel[]: [   29.552755] usbcore: registered new interface driver ums-sddr09
2018-05-13 20:24:57 info kernel[]: [   29.559653] usbcore: registered new interface driver ums-sddr55
2018-05-13 20:24:57 info kernel[]: [   29.566786] usbcore: registered new interface driver ums-usbat
2018-05-13 20:24:57 info kernel[]: [   29.579054] usbcore: registered new interface driver usbserial
2018-05-13 20:24:57 info kernel[]: [   29.584953] usbcore: registered new interface driver usbserial_generic
2018-05-13 20:24:57 info kernel[]: [   29.591529] usbserial: USB Serial support registered for generic
2018-05-13 20:24:57 info kernel[]: [   29.610009] xt_time: kernel timezone is -0000
2018-05-13 20:24:57 info kernel[]: [   29.632352] usbcore: registered new interface driver cdc_ether
2018-05-13 20:24:57 info kernel[]: [   29.647297] usbcore: registered new interface driver qmi_wwan
2018-05-13 20:24:57 info kernel[]: [   29.654234] usbcore: registered new interface driver rndis_host
2018-05-13 20:24:57 warning kernel[]: [   29.664257] vmap allocation for size 102400 failed: use vmalloc= to increase size.
2018-05-13 20:24:57 warning kernel[]: [   29.672401] vmalloc: allocation failure: 95849 bytes
2018-05-13 20:24:57 warning kernel[]: [   29.677377] kmodloader: page allocation failure: order:0, mode:0x24000c0
2018-05-13 20:24:57 warning kernel[]: [   29.684107] CPU: 1 PID: 883 Comm: kmodloader Not tainted 4.4.131-a2dbf3bef3d0c1f725e0a5f0801935a1-2 #1
2018-05-13 20:24:57 warning kernel[]: [   29.693433] Hardware name: Marvell Armada 380/385 (Device Tree)
2018-05-13 20:24:57 warning kernel[]: [   29.699365] Backtrace:
2018-05-13 20:24:57 warning kernel[]: [   29.701832] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
2018-05-13 20:24:57 warning kernel[]: [   29.709416]  r6:00000000 r5:60000013 r4:c0730428 r3:00000000
2018-05-13 20:24:57 warning kernel[]: [   29.715132] [] (show_stack) from [] (dump_stack+0x98/0xac)
2018-05-13 20:24:57 warning kernel[]: [   29.722375] [] (dump_stack) from [] (warn_alloc_failed+0xec/0x120)
2018-05-13 20:24:57 warning kernel[]: [   29.730307]  r6:00000001 r5:00000000 r4:024000c0 r3:c0728e74
2018-05-13 20:24:57 warning kernel[]: [   29.736024] [] (warn_alloc_failed) from [] (__vmalloc_node_range+0x170/0x214)
2018-05-13 20:24:57 warning kernel[]: [   29.744914]  r3:00017669 r2:c0620450
2018-05-13 20:24:57 warning kernel[]: [   29.748515]  r6:c008cc4c r5:00000000 r4:00017669
2018-05-13 20:24:57 warning kernel[]: [   29.753173] [] (__vmalloc_node_range) from [] (module_alloc+0x5c/0xbc)
2018-05-13 20:24:57 warning kernel[]: [   29.761454]  r10:f09914c0 r9:f097c000 r8:00017669 r7:ffffffff r6:c008cc4c r5:024000c0
2018-05-13 20:24:57 warning kernel[]: [   29.769353]  r4:c074a11c
2018-05-13 20:24:57 warning kernel[]: [   29.771903] [] (module_alloc) from [] (load_module+0x7b4/0x1d1c)
2018-05-13 20:24:57 warning kernel[]: [   29.779661]  r8:00017669 r7:00000aa0 r6:f0991ba4 r5:000002ea r4:ede2bf34
2018-05-13 20:24:57 warning kernel[]: [   29.786431] [] (load_module) from [] (SyS_init_module+0xdc/0x14c)
2018-05-13 20:24:57 warning kernel[]: [   29.794277]  r10:00000051 r9:0001223f r8:ede2a000 r7:f099c0a4 r6:b67070b4 r5:00000000
2018-05-13 20:24:57 warning kernel[]: [   29.802176]  r4:000000a4
2018-05-13 20:24:57 warning kernel[]: [   29.804725] [] (SyS_init_module) from [] (ret_fast_syscall+0x0/0x48)
2018-05-13 20:24:57 warning kernel[]: [   29.812831]  r10:00000000 r9:ede2a000 r8:c0009ec4 r7:00000080 r6:00000000 r5:00000000
2018-05-13 20:24:57 warning kernel[]: [   29.820730]  r4:00000000
2018-05-13 20:24:57 warning kernel[]: [   29.823283] Mem-Info:
2018-05-13 20:24:57 warning kernel[]: [   29.825565] active_anon:141 inactive_anon:2 isolated_anon:0
2018-05-13 20:24:57 warning kernel[]: [   29.825565]  active_file:3066 inactive_file:937 isolated_file:0
2018-05-13 20:24:57 warning kernel[]: [   29.825565]  unevictable:0 dirty:0 writeback:0 unstable:0
2018-05-13 20:24:57 warning kernel[]: [   29.825565]  slab_reclaimable:461 slab_unreclaimable:1542
2018-05-13 20:24:57 warning kernel[]: [   29.825565]  mapped:1845 shmem:2 pagetables:22 bounce:0
2018-05-13 20:24:57 warning kernel[]: [   29.825565]  free:247186 free_pcp:394 free_cma:0
2018-05-13 20:24:57 warning kernel[]: [   29.857723] Normal free:732444kB min:3504kB low:4380kB high:5256kB active_anon:388kB inactive_anon:8kB active_file:9668kB inactive_file:3072kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:786432kB managed:768840kB mlocked:0kB dirty:0kB writeback:0kB mapped:5448kB shmem:8kB slab_reclaimable:1844kB slab_unreclaimable:6168kB kernel_stack:1184kB pagetables:88kB unstable:0kB bounce:0kB free_pcp:920kB local_pcp:384kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
2018-05-13 20:24:57 warning kernel[]: [   29.901699] lowmem_reserve[]: 0 2048 2048
2018-05-13 20:24:57 warning kernel[]: [   29.905764] HighMem free:256300kB min:256kB low:552kB high:852kB active_anon:176kB inactive_anon:0kB active_file:2596kB inactive_file:676kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:262144kB managed:262144kB mlocked:0kB dirty:0kB writeback:0kB mapped:1932kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:656kB local_pcp:352kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
2018-05-13 20:24:57 warning kernel[]: [   29.948607] lowmem_reserve[]: 0 0 0
2018-05-13 20:24:57 warning kernel[]: [   29.952147] Normal: 1*4kB (E) 7*8kB (U) 2*16kB (U) 4*32kB (UME) 3*64kB (UME) 1*128kB (E) 1*256kB (E) 1*512kB (E) 2*1024kB (ME) 0*2048kB 178*4096kB (M) = 732444kB
2018-05-13 20:24:57 warning kernel[]: [   29.966844] HighMem: 5*4kB (UM) 2*8kB (M) 2*16kB (M) 8*32kB (UM) 0*64kB 2*128kB (UM) 1*256kB (U) 1*512kB (U) 1*1024kB (U) 0*2048kB 62*4096kB (M) = 256324kB
2018-05-13 20:24:57 warning kernel[]: [   29.981012] 4006 total pagecache pages
2018-05-13 20:24:57 warning kernel[]: [   29.984769] 0 pages in swap cache
2018-05-13 20:24:57 warning kernel[]: [   29.988088] Swap cache stats: add 0, delete 0, find 0/0
2018-05-13 20:24:57 warning kernel[]: [   29.993330] Free swap  = 0kB
2018-05-13 20:24:57 warning kernel[]: [   29.996214] Total swap = 0kB
2018-05-13 20:24:57 warning kernel[]: [   29.999098] 262144 pages RAM
2018-05-13 20:24:57 warning kernel[]: [   30.001990] 65536 pages HighMem/MovableOnly
2018-05-13 20:24:57 warning kernel[]: [   30.006180] 4398 pages reserved
2018-05-13 20:24:57 info kernel[]: [   30.013578] pci 0000:00:01.0: enabling device (0140 -> 0142)
2018-05-13 20:24:57 debug kernel[]: [   30.105851] ath: EEPROM regdomain: 0x0
2018-05-13 20:24:57 debug kernel[]: [   30.105857] ath: EEPROM indicates default country code should be used
2018-05-13 20:24:57 debug kernel[]: [   30.105859] ath: doing EEPROM country->regdmn map search
2018-05-13 20:24:57 debug kernel[]: [   30.105863] ath: country maps to regdmn code: 0x3a
2018-05-13 20:24:57 debug kernel[]: [   30.105866] ath: Country alpha2 being used: US
2018-05-13 20:24:57 debug kernel[]: [   30.105869] ath: Regpair used: 0x3a
2018-05-13 20:24:57 debug kernel[]: [   30.117691] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
2018-05-13 20:24:57 info kernel[]: [   30.119079] ieee80211 phy0: Atheros AR9287 Rev:2 mem=0xf09a0000, irq=108
2018-05-13 20:24:57 info kernel[]: [   30.128042] usbcore: registered new interface driver option
2018-05-13 20:24:57 info kernel[]: [   30.133697] usbserial: USB Serial support registered for GSM modem (1-port)
2018-05-13 20:24:57 info kernel[]: [   30.141310] usbcore: registered new interface driver qcserial
2018-05-13 20:24:57 info kernel[]: [   30.147102] usbserial: USB Serial support registered for Qualcomm USB modem
2018-05-13 20:24:57 notice kernel[]: [   32.569762] random: nonblocking pool is initialized
2018-05-13 20:24:57 info kernel[]: [   35.424988] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
2018-05-13 20:24:57 info kernel[]: [   35.502526] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2018-05-13 20:24:57 info kernel[]: [   35.506002] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
2018-05-13 20:24:57 info kernel[]: [   37.420915] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2018-05-13 20:24:57 info kernel[]: [   37.420974] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
2018-05-13 20:24:57 info kernel[]: [   37.500902] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
2018-05-13 20:24:57 info kernel[]: [   37.500923] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
2018-05-13 20:24:57 info kernel[]: [   38.472717] device eth0 entered promiscuous mode
2018-05-13 20:24:57 info kernel[]: [   38.473704] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
2018-05-13 20:24:57 info kernel[]: [   38.500958] device eth2 entered promiscuous mode
2018-05-13 20:24:57 info kernel[]: [   38.500996] br-lan: port 2(eth2) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   38.501014] br-lan: port 2(eth2) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   38.501041] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
2018-05-13 20:24:57 info kernel[]: [   38.582229] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2018-05-13 20:24:57 debug kernel[]: [   38.762086] ath: EEPROM regdomain: 0x80cb
2018-05-13 20:24:57 debug kernel[]: [   38.762093] ath: EEPROM indicates we should expect a country code
2018-05-13 20:24:57 debug kernel[]: [   38.762096] ath: doing EEPROM country->regdmn map search
2018-05-13 20:24:57 debug kernel[]: [   38.762099] ath: country maps to regdmn code: 0x36
2018-05-13 20:24:57 debug kernel[]: [   38.762102] ath: Country alpha2 being used: CZ
2018-05-13 20:24:57 debug kernel[]: [   38.762105] ath: Regpair used: 0x36
2018-05-13 20:24:57 debug kernel[]: [   38.762108] ath: regdomain 0x80cb dynamically updated by user
2018-05-13 20:24:57 info kernel[]: [   39.462557] br-lan: port 2(eth2) entered disabled state
2018-05-13 20:24:57 info kernel[]: [   39.868784] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
2018-05-13 20:24:57 info kernel[]: [   39.870144] device wlan0 entered promiscuous mode
2018-05-13 20:24:57 info kernel[]: [   39.870184] br-lan: port 3(wlan0) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   39.870204] br-lan: port 3(wlan0) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   40.461112] br-lan: port 3(wlan0) entered disabled state
2018-05-13 20:24:57 info kernel[]: [   40.470903] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
2018-05-13 20:24:57 info kernel[]: [   40.470979] br-lan: port 1(eth0) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   40.471006] br-lan: port 1(eth0) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   40.490907] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
2018-05-13 20:24:57 info kernel[]: [   40.490973] br-lan: port 2(eth2) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   40.491003] br-lan: port 2(eth2) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   41.581258] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
2018-05-13 20:24:57 info kernel[]: [   41.581275] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
2018-05-13 20:24:57 info kernel[]: [   42.471202] br-lan: port 1(eth0) entered forwarding state
2018-05-13 20:24:57 info kernel[]: [   42.490862] br-lan: port 2(eth2) entered forwarding state
2018-05-13 20:24:57 warning ucollect[3553]: epoll_wait on 4 interrupted, retry
2018-05-13 20:24:57 info ucollect[3553]: Reconfiguring
2018-05-13 20:24:57 info ucollect[3553]: Loading plugin library libpluglib_ucollect_diffstore_1.2.so
2018-05-13 20:24:57 info ucollect[3376]: Last message 'Loading plugin libra' repeated 1 times, suppressed by syslog-ng on turris
2018-05-13 20:24:57 info ucollect[3553]: Sending login credentials disabled
2018-05-13 20:24:57 info ucollect[3376]: Last message 'Sending login creden' repeated 5 times, suppressed by syslog-ng on turris
2018-05-13 20:24:57 info ucollect[3553]: Unloading plugin library
2018-05-13 20:24:59 info ucollect[3376]: Last message 'Unloading plugin lib' repeated 1 times, suppressed by syslog-ng on turris
2018-05-13 20:24:59 notice firewall[]: Reloading firewall due to ifup of wan (eth1)
2018-05-13 20:24:59 info turris-firewall-rules[]: (v63) IPv4 WAN interface used - 'eth1'
2018-05-13 20:24:59 info turris-firewall-rules[]: (v63) IPv6 WAN interface used - 'lo'
2018-05-13 20:24:59 notice netifd[]: radio0 (3124): wlan0: ACS-COMPLETED freq=2447 channel=8
2018-05-13 20:24:59 notice netifd[]: radio0 (3124): Using interface wlan0 with hwaddr 04:f0:21:23:2f:0d and ssid "Sdruzeni"
2018-05-13 20:24:59 info kernel[]: [   47.243333] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
2018-05-13 20:24:59 info kernel[]: [   47.243405] br-lan: port 3(wlan0) entered forwarding state
2018-05-13 20:24:59 info kernel[]: [   47.243433] br-lan: port 3(wlan0) entered forwarding state
2018-05-13 20:24:59 info sshd[5236]: Accepted publickey for root from 192.168.8.66 port 42772 ssh2: RSA SHA256:MuWD+xqeqYM9aU0A+5uXZRhmBPreXw4dLnNz4KMj5EQ
2018-05-13 20:24:59 notice netifd[]: radio0 (3124): wlan0: interface state ACS->ENABLED
2018-05-13 20:24:59 notice netifd[]: radio0 (3124): wlan0: AP-ENABLED
2018-05-13 20:24:59 notice netifd[]: Network device 'wlan0' link is up
2018-05-13 20:25:00 err ntpdate[3560]: no server suitable for synchronization found
2018-05-13 20:25:00 info dnsmasq[4448]: started, version 2.78 DNS disabled
2018-05-13 20:25:00 warning dnsmasq[4448]: overflow: 4 log entries lost
You have to use dmesg for real. Syslog-ng is not configured to read pre-startup kernel messages (it only stores messages generated after its startup). That meas that in time it starts up most of the hardware initialization is done and because of that it won’t show up in logs. PCI is initialized pretty early during boot process.
Ah, yes, there is something about firmware failing to load.
[   13.518072] Key type dns_resolver registered
[   13.525231] NET: Registered protocol family 33
[   13.529689] Key type rxrpc registered
[   13.533373] Key type rxrpc_s registered
[   13.540336] kAFS: Red Hat AFS client v0.1 registering.
[   13.545538] FS-Cache: Netfs 'afs' registered for caching
[   13.580174] RPC: Registered named UNIX socket transport module.
[   13.586126] RPC: Registered udp transport module.
[   13.590839] RPC: Registered tcp transport module.
[   13.595559] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.619897] NFS: Registering the id_resolver key type
[   13.625017] Key type id_resolver registered
[   13.629209] Key type id_legacy registered
[   13.633900] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   13.643109] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   13.652924] RxRPC: Registered security type 2 'rxkad'
[   13.669621] tun: Universal TUN/TAP device driver, 1.6
[   13.674709] tun: (C) 1999-2004 Max Krasnyansky
[   13.684891] sit: IPv6 over IPv4 tunneling driver
[   13.691785] gre: GRE over IPv4 demultiplexor driver
[   13.697256] ip_gre: GRE over IPv4 tunneling driver
[   13.716728] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   13.725319] PPP generic driver version 2.4.2
[   13.731607] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   13.744856] nf_conntrack version 0.5.0 (16109 buckets, 64436 max)
[   14.473106] ip_set: protocol 6
[   17.562129] cryptodev: driver 1.8 loaded.
[   18.832326] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[   18.840351] Backport generated by backports.git backports-20160324-13-g24da7d3c
[   19.272260] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   19.277950] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
[   19.284416] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   19.463600] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   19.474338] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.484045] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   19.493173] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   19.503570] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.513089] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   19.530391] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   19.539673] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   19.549211] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   19.593940] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   19.601054] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   19.611526] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.621191] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   19.630874] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   21.730917] ath10k_pci 0000:02:00.0: failed to receive control response completion, polling..
[   22.730915] ath10k_pci 0000:02:00.0: Service connect timeout
[   22.736589] ath10k_pci 0000:02:00.0: failed to connect htt (-110)
[   22.821267] ath10k_pci 0000:02:00.0: could not init core (-110)
[   22.827225] ath10k_pci 0000:02:00.0: could not probe fw (-110)
[   24.371243] u32 classifier
[   24.373959]     input device check on
[   24.377627]     Actions configured
[   24.831208] Mirror/redirect action on
[   25.681182] GACT probability on
[   29.041253] netem: version 1.3
[   30.474080] fuse init (API version 7.23)
[   30.702441] usbcore: registered new interface driver cdc_wdm
[   30.711910] Ebtables v2.0 registered
[   30.717493] ip_tables: (C) 2000-2006 Netfilter Core Team
[   30.804616] ctnetlink v0.93: registering with nfnetlink.
[   31.044810] nfnl_acct: registering with nfnetlink.
[   31.050509] PPP MPPE Compression module registered
[   31.055885] NET: Registered protocol family 24
[   31.064066] usbcore: registered new interface driver ums-alauda
[   31.070821] usbcore: registered new interface driver ums-cypress
[   31.077859] usbcore: registered new interface driver ums-datafab
[   31.084763] usbcore: registered new interface driver ums-freecom
[   31.091747] usbcore: registered new interface driver ums-isd200
[   31.098716] usbcore: registered new interface driver ums-jumpshot
[   31.105704] usbcore: registered new interface driver ums-karma
[   31.112865] usbcore: registered new interface driver ums-sddr09
[   31.119774] usbcore: registered new interface driver ums-sddr55
[   31.126909] usbcore: registered new interface driver ums-usbat
[   31.139184] usbcore: registered new interface driver usbserial
[   31.145082] usbcore: registered new interface driver usbserial_generic
[   31.151657] usbserial: USB Serial support registered for generic
[   31.170158] xt_time: kernel timezone is -0000
[   31.192512] usbcore: registered new interface driver cdc_ether
[   31.207432] usbcore: registered new interface driver qmi_wwan
[   31.214372] usbcore: registered new interface driver rndis_host
[   31.224425] vmap allocation for size 102400 failed: use vmalloc= to increase size.
[   31.232568] vmalloc: allocation failure: 95849 bytes
[   31.237543] kmodloader: page allocation failure: order:0, mode:0x24000c0
[   31.244272] CPU: 1 PID: 882 Comm: kmodloader Not tainted 4.4.131-a2dbf3bef3d0c1f725e0a5f0801935a1-2 #1
[   31.253599] Hardware name: Marvell Armada 380/385 (Device Tree)
[   31.259529] Backtrace:
[   31.261996] [] (dump_backtrace) from [] (show_stack+0x18/0x1c)
[   31.269581]  r6:00000000 r5:60000013 r4:c0730428 r3:00000000
[   31.275297] [] (show_stack) from [] (dump_stack+0x98/0xac)
[   31.282539] [] (dump_stack) from [] (warn_alloc_failed+0xec/0x120)
[   31.290472]  r6:00000001 r5:00000000 r4:024000c0 r3:c0728e74
[   31.296189] [] (warn_alloc_failed) from [] (__vmalloc_node_range+0x170/0x214)
[   31.305079]  r3:00017669 r2:c0620450
[   31.308680]  r6:c008cc4c r5:00000000 r4:00017669
[   31.313339] [] (__vmalloc_node_range) from [] (module_alloc+0x5c/0xbc)
[   31.321619]  r10:f09914c0 r9:f097c000 r8:00017669 r7:ffffffff r6:c008cc4c r5:024000c0
[   31.329518]  r4:c074a11c
[   31.332068] [] (module_alloc) from [] (load_module+0x7b4/0x1d1c)
[   31.339827]  r8:00017669 r7:00000aa0 r6:f0991ba4 r5:000002ea r4:ede89f34
[   31.346595] [] (load_module) from [] (SyS_init_module+0xdc/0x14c)
[   31.354441]  r10:00000051 r9:0001223f r8:ede88000 r7:f099c0a4 r6:b67300b4 r5:00000000
[   31.362338]  r4:000000a4
[   31.364887] [] (SyS_init_module) from [] (ret_fast_syscall+0x0/0x48)
[   31.372994]  r10:00000000 r9:ede88000 r8:c0009ec4 r7:00000080 r6:00000000 r5:00000000
[   31.380891]  r4:00000000
[   31.383443] Mem-Info:
[   31.385726] active_anon:150 inactive_anon:2 isolated_anon:0
[   31.385726]  active_file:3085 inactive_file:954 isolated_file:0
[   31.385726]  unevictable:0 dirty:0 writeback:0 unstable:0
[   31.385726]  slab_reclaimable:465 slab_unreclaimable:1538
[   31.385726]  mapped:1837 shmem:2 pagetables:21 bounce:0
[   31.385726]  free:247161 free_pcp:347 free_cma:0
[   31.417887] Normal free:732560kB min:3504kB low:4380kB high:5256kB active_anon:300kB inactive_anon:0kB active_file:9372kB inactive_file:3036kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:786432kB managed:768840kB mlocked:0kB dirty:0kB writeback:0kB mapped:5216kB shmem:0kB slab_reclaimable:1860kB slab_unreclaimable:6152kB kernel_stack:1184kB pagetables:84kB unstable:0kB bounce:0kB free_pcp:1036kB local_pcp:444kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[   31.461951] lowmem_reserve[]: 0 2048 2048
[   31.466017] HighMem free:256084kB min:256kB low:552kB high:852kB active_anon:300kB inactive_anon:8kB active_file:2968kB inactive_file:780kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:262144kB managed:262144kB mlocked:0kB dirty:0kB writeback:0kB mapped:2132kB shmem:8kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:352kB local_pcp:108kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[   31.508860] lowmem_reserve[]: 0 0 0
[   31.512400] Normal: 2*4kB (ME) 8*8kB (UE) 4*16kB (UM) 1*32kB (M) 0*64kB 0*128kB 1*256kB (M) 0*512kB 1*1024kB (M) 1*2048kB (E) 178*4096kB (M) = 732584kB
[   31.526207] HighMem: 17*4kB (UM) 6*8kB (UM) 2*16kB (UM) 2*32kB (U) 2*64kB (UM) 0*128kB 1*256kB (M) 1*512kB (M) 1*1024kB (M) 2*2048kB (UM) 61*4096kB (M) = 256084kB
[   31.540998] 4041 total pagecache pages
[   31.544754] 0 pages in swap cache
[   31.548073] Swap cache stats: add 0, delete 0, find 0/0
[   31.553315] Free swap  = 0kB
[   31.556199] Total swap = 0kB
[   31.559083] 262144 pages RAM
[   31.561974] 65536 pages HighMem/MovableOnly
[   31.566164] 4398 pages reserved
[   31.573547] pci 0000:00:01.0: enabling device (0140 -> 0142)
[   31.665807] ath: EEPROM regdomain: 0x0
[   31.665811] ath: EEPROM indicates default country code should be used
[   31.665814] ath: doing EEPROM country->regdmn map search
[   31.665818] ath: country maps to regdmn code: 0x3a
[   31.665821] ath: Country alpha2 being used: US
[   31.665824] ath: Regpair used: 0x3a
[   31.677646] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   31.679044] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf09a0000, irq=108
[   31.688153] usbcore: registered new interface driver option
[   31.693798] usbserial: USB Serial support registered for GSM modem (1-port)
[   31.701393] usbcore: registered new interface driver qcserial
[   31.707186] usbserial: USB Serial support registered for Qualcomm USB modem
[   34.132690] random: nonblocking pool is initialized
[   36.985419] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   37.062604] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   37.066095] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   38.980976] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   38.981002] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   39.061079] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   39.061106] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[   39.967603] device eth0 entered promiscuous mode
[   39.968518] br-lan: port 1(eth0) entered forwarding state
[   39.968533] br-lan: port 1(eth0) entered forwarding state
[   39.981088] br-lan: port 1(eth0) entered disabled state
[   39.985771] device eth2 entered promiscuous mode
[   40.072495] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   40.352923] ath: EEPROM regdomain: 0x80cb
[   40.352931] ath: EEPROM indicates we should expect a country code
[   40.352934] ath: doing EEPROM country->regdmn map search
[   40.352937] ath: country maps to regdmn code: 0x36
[   40.352940] ath: Country alpha2 being used: CZ
[   40.352943] ath: Regpair used: 0x36
[   40.352946] ath: regdomain 0x80cb dynamically updated by user
[   41.482702] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[   41.506566] device wlan1 entered promiscuous mode
[   41.970989] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   41.971079] br-lan: port 1(eth0) entered forwarding state
[   41.971111] br-lan: port 1(eth0) entered forwarding state
[   41.981014] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   41.981047] br-lan: port 2(eth2) entered forwarding state
[   41.981072] br-lan: port 2(eth2) entered forwarding state
[   43.071340] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[   43.071361] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   43.970953] br-lan: port 1(eth0) entered forwarding state
[   43.980958] br-lan: port 2(eth2) entered forwarding state
(cut slightly before the end when MAC and IP addresses started to appear)
It should have accepted qca988x firmware but it didn’t. I suspect for real that it’s problem we know already. So if you are in contact with @Pepe then just talk to him about giving it to @Jan.H for fix probably.
Hi guys!
I have a similar problem. After the update to 3.10 my 2Ghz card (R11e-2HPnD) and my SATA disk are gone. Both are no longer accessible in the system and also can no longer be found via lspci.
root@turris:~# lspci -v
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
	Flags: fast devsel
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	Prefetchable memory behind bridge: 00000000-000fffff
	Capabilities: [40] Express Root Port (Slot+), MSI 00
lspci: Unable to load libkmod resources: error -12
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	Memory behind bridge: e0000000-e02fffff
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
	Flags: fast devsel
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
02:00.0 Network controller: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Network Adapter
	Subsystem: Device 19b6:d03c
	Flags: bus master, fast devsel, latency 0, IRQ 119
	Memory at e0000000 (64-bit, non-prefetchable) [size=2M]
	Expansion ROM at e0200000 [disabled] [size=64K]
	Capabilities: [40] Power Management version 2
	Capabilities: [50] MSI: Enable+ Count=1/8 Maskable+ 64bit-
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Virtual Channel
	Capabilities: [160] Device Serial Number 00-00-00-00-00-00-00-00
	Kernel driver in use: ath10k_pci
With a MEDKIT-reset, we were back. After a reboot, however, the problem occurs again. What happened during the update? There is something wrong with the PCI ports now!
It’s a Omnia 2GB device.
What can we do?
The problem suspected in this topic is not global PCI problem but rather problem with single card and its single revision. Because of that I suspect that you have different problem.
Please reboot your device and post output from dmesg (as soon as possible after reboot). That should give us better understanding what is happening in your case. But I suspect that your problem is rather missing firmware or kernel driver. So could you also check what packages are being removed when you update to Turris 3.10?
Not sure if I have the same issue, but I have the same symptoms. Well, except 5GHz wlan is still visible on lspci output.
“Solution” I am using is either several reboots (so long until ath10k_pci start to work) or power off and power on again.
dmesg part when ath10_pci works
[   19.382148] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   19.388012] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   19.564548] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   19.575291] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.594116] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   19.604510] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.630781] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   19.640069] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   19.649668] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   19.694424] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   19.701542] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   19.712013] ath10k_pci 0000:02:00.0: Falling back to user helper
[   19.730675] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   20.859737] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
dmesg part when ath10_pci doesn't work
[   21.492221] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   21.497910] ath10k_pci 0000:02:00.0: enabling device (0140 -> 0142)
[   21.504390] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   21.684599] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   21.695336] ath10k_pci 0000:02:00.0: Falling back to user helper
[   21.714164] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   21.724552] ath10k_pci 0000:02:00.0: Falling back to user helper
[   21.750760] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   21.760039] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   21.769634] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   21.814366] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   21.821483] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   21.831948] ath10k_pci 0000:02:00.0: Falling back to user helper
[   21.850549] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   23.950927] ath10k_pci 0000:02:00.0: failed to receive control response completion, polling..
[   24.950923] ath10k_pci 0000:02:00.0: Service connect timeout
[   24.956596] ath10k_pci 0000:02:00.0: failed to connect htt (-110)
[   25.041278] ath10k_pci 0000:02:00.0: could not init core (-110)
[   25.047233] ath10k_pci 0000:02:00.0: could not probe fw (-110)
Cards are mounted:
Our experience is that WiFi cards are pretty hot, so in your case, there are two solutions.
  1. Put the heatsink on 5 GHz card and see if it helps for you
  2. If you live in Prague I can pick up your router and give it to our HW guys and they will change the capacitors or you can send it to us.
Sent PM
(Lorem ipsum)
i reboot my router and now the 5Ghz Wifi is on again.
Is there any possible to check, if 5Ghz card is faulty? From serial number or such? I have indiegogo 2GB + Wifi perk :disappointed_relieved:, but I deinstall 5Ghz card from the start (even before first plug I think), because I dont need it yet (and not all my devices supports 5Ghz)…
Btw., I think its strange that those problems appears to some users after 3.10 update, at least it seems to me that way.
@Jan.H should know serial numbers. It’s also somewhere here on forum. It’s about a year old problem.
Problem with it is that it’s caused by interference on board. That specific card has fault where it’s more prone to be affected by it. Two right slots share reference time and if one of cards generates some noise then it can affect second card if it doesn’t have sufficient filtering. Real problem is that this noise don’t have to be just from second card but also from other sources. So this can start happening just because you moved router to some spot with just right problematic interference. That is why it propagates dynamically. But it might not ever show. All boards propagating given error are requested to be sent to us for repair (as pepe wrote, capacitors change). It makes no sense to recall all routers because most of them wont encounter problem because it really depends on combination of factors. In my case for example it manifested when I tried to move a lot of data to drive (connected using SATA card). I swapped ac and g cards, ac being in left most port and since then I had no problems. But we failed to reproduce it for example with msata or other cards.
As you can see there is no guaranteed way to ensure that it won’t happen or that it happens. That capacitors replacement is more or less just hack to overcome this specific problem but when some card misbehaves then there is nothing hardware designer can do.
And why it seems to be problematic with 3.10? I don’t think that it’s. But even if it would then it’s possible that some software change just makes it more inclined to this problem. But I currently know only about one person that started having problems after 3.10. Other one in this topic encounters problems for longer time period. And I don’t know about anyone else.
So, now from me three different dmesg outputs I have generated today. The behavior of the Omnia is currently not reproducible. Problems definitely occurred since the weekend and after the update to 3.10. Everything was stable before.
I really need assistance here!
a) All cards work (mSATA, 802.11n, 802.11ac)
[    7.023204] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    7.029922] BTRFS: has skinny extents
[    7.038110] BTRFS: detected SSD devices, enabling SSD mode
[    7.080924] VFS: Mounted root (btrfs filesystem) on device 0:13.
[    7.087071] Freeing unused kernel memory: 284K
[    7.139262] init: Console is alive
[    7.142757] init: - watchdog -
[    7.495863] usbcore: registered new interface driver usbfs
[    7.501405] usbcore: registered new interface driver hub
[    7.506762] usbcore: registered new device driver usb
[    7.513655] exFAT: Version 1.2.9
[    7.531226] JFS: nTxBlock = 8192, nTxLock = 65536
[    7.592013] SGI XFS with security attributes, no debug enabled
[    7.599467] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    7.606394] ehci-platform: EHCI generic platform driver
[    7.612027] ehci-orion: EHCI orion driver
[    7.616149] orion-ehci f1058000.usb: EHCI Host Controller
[    7.621592] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    7.629238] orion-ehci f1058000.usb: irq 39, io mem 0xf1058000
[    7.650913] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    7.657109] hub 1-0:1.0: USB hub found
[    7.660883] hub 1-0:1.0: 1 port detected
[    7.665889] uhci_hcd: USB Universal Host Controller Interface driver
[    7.675395] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.680730] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    7.688352] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.696928] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    7.702948] hub 2-0:1.0: USB hub found
[    7.706718] hub 2-0:1.0: 1 port detected
[    7.710743] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.716086] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    7.723649] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.731974] hub 3-0:1.0: USB hub found
[    7.735744] hub 3-0:1.0: 1 port detected
[    7.739817] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.745165] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    7.752762] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.761334] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    7.767329] hub 4-0:1.0: USB hub found
[    7.771112] hub 4-0:1.0: 1 port detected
[    7.775129] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.780457] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    7.788001] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.796320] hub 5-0:1.0: USB hub found
[    7.800089] hub 5-0:1.0: 1 port detected
[    7.805274] usbcore: registered new interface driver usb-storage
[    8.146068] init: - preinit -
[   11.196996] mount_root: mounting /dev/root
[   11.202070] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   11.209425] mount_root: loading kmods from internal overlay
[   11.421937] block: attempting to load /etc/config/fstab
[   11.428010] block: extroot: not configured
[   11.434510] procd: - early -
[   11.437417] procd: - watchdog -
[   11.535556] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.562042] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.597415] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.622019] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.657747] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.682580] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.718049] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.742693] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.778356] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.803123] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   12.003934] procd: - ubus -
[   13.009282] procd: - init -
[   13.067310] marvell-cesa f1090000.crypto: CESA device successfully registered
[   13.080379] NET: Registered protocol family 38
[   13.096152] md: linear personality registered for level -1
[   13.102051] md: raid0 personality registered for level 0
[   13.108075] md: raid1 personality registered for level 1
[   13.114497] md: raid10 personality registered for level 10
[   13.120362] async_tx: api initialized (async)
[   13.127741] md: raid6 personality registered for level 6
[   13.133092] md: raid5 personality registered for level 5
[   13.138415] md: raid4 personality registered for level 4
[   13.145598] FS-Cache: Loaded
[   13.148918] md: multipath personality registered for level -4
[   13.155873] NET: Registered protocol family 8
[   13.160241] NET: Registered protocol family 20
[   13.168435] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[   13.179265] Key type dns_resolver registered
[   13.186401] NET: Registered protocol family 33
[   13.190858] Key type rxrpc registered
[   13.194548] Key type rxrpc_s registered
[   13.201568] kAFS: Red Hat AFS client v0.1 registering.
[   13.206752] FS-Cache: Netfs 'afs' registered for caching
[   13.241298] RPC: Registered named UNIX socket transport module.
[   13.247236] RPC: Registered udp transport module.
[   13.251976] RPC: Registered tcp transport module.
[   13.256688] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.281093] NFS: Registering the id_resolver key type
[   13.286177] Key type id_resolver registered
[   13.290369] Key type id_legacy registered
[   13.295015] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   13.304261] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   13.314102] RxRPC: Registered security type 2 'rxkad'
[   13.330646] tun: Universal TUN/TAP device driver, 1.6
[   13.335747] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   13.345563] sit: IPv6 over IPv4 tunneling driver
[   13.352368] gre: GRE over IPv4 demultiplexor driver
[   13.357884] ip_gre: GRE over IPv4 tunneling driver
[   13.377756] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   13.386411] PPP generic driver version 2.4.2
[   13.393984] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   13.404326] cryptodev: driver 1.8 loaded.
[   13.412155] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[   13.420181] Backport generated by backports.git backports-20160324-13-g24da7d3c
[   13.496993] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   13.502892] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   13.684394] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   13.695128] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.704892] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.714022] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   13.724408] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.733969] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.750648] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 19b6:d03c
[   13.759920] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.769447] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   13.814197] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   13.821313] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.831779] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.841518] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.850446] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   14.977243] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   15.061356] ath: EEPROM regdomain: 0x0
[   15.061361] ath: EEPROM indicates default country code should be used
[   15.061364] ath: doing EEPROM country->regdmn map search
[   15.061368] ath: country maps to regdmn code: 0x3a
[   15.061371] ath: Country alpha2 being used: US
[   15.061374] ath: Regpair used: 0x3a
[   15.067002] u32 classifier
[   15.069725]     input device check on
[   15.073414]     Actions configured
[   15.077493] Mirror/redirect action on
[   15.082315] GACT probability on
[   15.089875] netem: version 1.3
[   15.098088] fuse init (API version 7.23)
[   15.113858] usbcore: registered new interface driver cdc_wdm
[   15.122498] Ebtables v2.0 registered
[   15.127444] ip_tables: (C) 2000-2006 Netfilter Core Team
[   15.139339] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   15.304263] Netfilter messages via NETLINK v0.30.
[   15.309819] PPP MPPE Compression module registered
[   15.315162] NET: Registered protocol family 24
[   15.323029] usbcore: registered new interface driver ums-alauda
[   15.329706] usbcore: registered new interface driver ums-cypress
[   15.336637] usbcore: registered new interface driver ums-datafab
[   15.343454] usbcore: registered new interface driver ums-freecom
[   15.350328] usbcore: registered new interface driver ums-isd200
[   15.357277] usbcore: registered new interface driver ums-jumpshot
[   15.364191] usbcore: registered new interface driver ums-karma
[   15.371232] usbcore: registered new interface driver ums-sddr09
[   15.378054] usbcore: registered new interface driver ums-sddr55
[   15.385013] usbcore: registered new interface driver ums-usbat
[   15.396775] usbcore: registered new interface driver usbserial
[   15.402662] usbcore: registered new interface driver usbserial_generic
[   15.409229] usbserial: USB Serial support registered for generic
[   15.424055] xt_time: kernel timezone is -0000
[   15.442275] usbcore: registered new interface driver cdc_ether
[   15.452663] ctnetlink v0.93: registering with nfnetlink.
[   15.461620] usbcore: registered new interface driver qmi_wwan
[   15.468556] usbcore: registered new interface driver rndis_host
[   15.482089] pci 0000:00:03.0: enabling device (0140 -> 0142)
[   15.494132] ath: EEPROM regdomain: 0x0
[   15.494136] ath: EEPROM indicates default country code should be used
[   15.494139] ath: doing EEPROM country->regdmn map search
[   15.494143] ath: country maps to regdmn code: 0x3a
[   15.494146] ath: Country alpha2 being used: US
[   15.494149] ath: Regpair used: 0x3a
[   15.500943] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   15.502336] ieee80211 phy1: Atheros AR9300 Rev:4 mem=0xf1d40000, irq=109
[   15.510833] usbcore: registered new interface driver option
[   15.516486] usbserial: USB Serial support registered for GSM modem (1-port)
[   15.524151] usbcore: registered new interface driver qcserial
[   15.529940] usbserial: USB Serial support registered for Qualcomm USB modem
[   18.403937] random: nonblocking pool is initialized
[   20.812785] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.892601] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   20.896075] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   21.356204] BTRFS: device fsid 7d18474d-e990-412f-a557-b3c0a0b49e44 devid 1 transid 266 /dev/sda1
[   22.373899] device eth0 entered promiscuous mode
[   22.374867] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   22.396669] device eth2 entered promiscuous mode
[   22.483100] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   22.787192] ath: EEPROM regdomain: 0x8114
[   22.787199] ath: EEPROM indicates we should expect a country code
[   22.787203] ath: doing EEPROM country->regdmn map search
[   22.787206] ath: country maps to regdmn code: 0x37
[   22.787209] ath: Country alpha2 being used: DE
[   22.787211] ath: Regpair used: 0x37
[   22.787215] ath: regdomain 0x8114 dynamically updated by user
[   22.787252] ath: EEPROM regdomain: 0x8114
[   22.787255] ath: EEPROM indicates we should expect a country code
[   22.787258] ath: doing EEPROM country->regdmn map search
[   22.787260] ath: country maps to regdmn code: 0x37
[   22.787263] ath: Country alpha2 being used: DE
[   22.787265] ath: Regpair used: 0x37
[   22.787268] ath: regdomain 0x8114 dynamically updated by user
[   24.370991] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   24.394176] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   25.817535] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.818454] br-lan: port 1(eth0) entered forwarding state
[   25.818480] br-lan: port 1(eth0) entered forwarding state
[   25.818524] br-lan: port 2(eth2) entered forwarding state
[   25.818535] br-lan: port 2(eth2) entered forwarding state
[   25.819168] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   25.873448] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[   25.888734] device wlan1 entered promiscuous mode
[   25.888775] br-lan: port 3(wlan1) entered forwarding state
[   25.888792] br-lan: port 3(wlan1) entered forwarding state
[   25.921063] device wlan1 left promiscuous mode
[   25.921114] br-lan: port 3(wlan1) entered disabled state
[   27.810955] br-lan: port 2(eth2) entered forwarding state
[   27.810992] br-lan: port 1(eth0) entered forwarding state
b) After a reboot the mSATA-SSD is gone.
[    7.555415] exFAT: Version 1.2.9
[    7.573033] JFS: nTxBlock = 8192, nTxLock = 65536
[    7.634135] SGI XFS with security attributes, no debug enabled
[    7.641605] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    7.648447] ehci-platform: EHCI generic platform driver
[    7.654077] ehci-orion: EHCI orion driver
[    7.658196] orion-ehci f1058000.usb: EHCI Host Controller
[    7.663634] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    7.671300] orion-ehci f1058000.usb: irq 39, io mem 0xf1058000
[    7.690851] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    7.697044] hub 1-0:1.0: USB hub found
[    7.700813] hub 1-0:1.0: 1 port detected
[    7.705840] uhci_hcd: USB Universal Host Controller Interface driver
[    7.715316] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.720652] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    7.728265] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.736837] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    7.742850] hub 2-0:1.0: USB hub found
[    7.746619] hub 2-0:1.0: 1 port detected
[    7.750646] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.755990] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    7.763529] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.771853] hub 3-0:1.0: USB hub found
[    7.775623] hub 3-0:1.0: 1 port detected
[    7.779692] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.785042] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    7.792644] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.801214] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    7.807214] hub 4-0:1.0: USB hub found
[    7.810996] hub 4-0:1.0: 1 port detected
[    7.815017] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.820344] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    7.827883] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.836201] hub 5-0:1.0: USB hub found
[    7.839970] hub 5-0:1.0: 1 port detected
[    7.845143] usbcore: registered new interface driver usb-storage
[    8.185361] init: - preinit -
[   11.233590] mount_root: mounting /dev/root
[   11.238637] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   11.246004] mount_root: loading kmods from internal overlay
[   11.456455] block: attempting to load /etc/config/fstab
[   11.462507] block: extroot: not configured
[   11.468933] procd: - early -
[   11.471856] procd: - watchdog -
[   11.575058] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.601683] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.637013] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.661405] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.697220] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.721769] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.757211] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.781663] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.817122] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.841606] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   12.042454] procd: - ubus -
[   13.047479] procd: - init -
[   13.106328] marvell-cesa f1090000.crypto: CESA device successfully registered
[   13.119366] NET: Registered protocol family 38
[   13.135088] md: linear personality registered for level -1
[   13.140992] md: raid0 personality registered for level 0
[   13.147279] md: raid1 personality registered for level 1
[   13.153486] md: raid10 personality registered for level 10
[   13.159338] async_tx: api initialized (async)
[   13.166669] md: raid6 personality registered for level 6
[   13.172011] md: raid5 personality registered for level 5
[   13.177334] md: raid4 personality registered for level 4
[   13.184477] FS-Cache: Loaded
[   13.187804] md: multipath personality registered for level -4
[   13.194733] NET: Registered protocol family 8
[   13.199101] NET: Registered protocol family 20
[   13.207287] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[   13.218122] Key type dns_resolver registered
[   13.225237] NET: Registered protocol family 33
[   13.229693] Key type rxrpc registered
[   13.233382] Key type rxrpc_s registered
[   13.240357] kAFS: Red Hat AFS client v0.1 registering.
[   13.245566] FS-Cache: Netfs 'afs' registered for caching
[   13.280203] RPC: Registered named UNIX socket transport module.
[   13.286167] RPC: Registered udp transport module.
[   13.290892] RPC: Registered tcp transport module.
[   13.295606] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.319960] NFS: Registering the id_resolver key type
[   13.325079] Key type id_resolver registered
[   13.329271] Key type id_legacy registered
[   13.333907] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   13.343122] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   13.352991] RxRPC: Registered security type 2 'rxkad'
[   13.369541] tun: Universal TUN/TAP device driver, 1.6
[   13.374630] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   13.384401] sit: IPv6 over IPv4 tunneling driver
[   13.390992] gre: GRE over IPv4 demultiplexor driver
[   13.396601] ip_gre: GRE over IPv4 tunneling driver
[   13.416503] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   13.425117] PPP generic driver version 2.4.2
[   13.432771] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   13.443718] cryptodev: driver 1.8 loaded.
[   13.451533] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[   13.459558] Backport generated by backports.git backports-20160324-13-g24da7d3c
[   13.533062] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   13.538940] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   13.714354] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   13.725096] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.734865] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.743993] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   13.754388] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.763982] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.780676] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 19b6:d03c
[   13.789957] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.799534] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   13.844293] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   13.851413] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.861884] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.871553] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.880461] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   15.007502] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   15.091312] ath: EEPROM regdomain: 0x0
[   15.091316] ath: EEPROM indicates default country code should be used
[   15.091319] ath: doing EEPROM country->regdmn map search
[   15.091323] ath: country maps to regdmn code: 0x3a
[   15.091326] ath: Country alpha2 being used: US
[   15.091329] ath: Regpair used: 0x3a
[   15.096851] u32 classifier
[   15.099568]     input device check on
[   15.103257]     Actions configured
[   15.109488] Mirror/redirect action on
[   15.114896] GACT probability on
[   15.122790] netem: version 1.3
[   15.131167] fuse init (API version 7.23)
[   15.146894] usbcore: registered new interface driver cdc_wdm
[   15.155564] Ebtables v2.0 registered
[   15.160491] ip_tables: (C) 2000-2006 Netfilter Core Team
[   15.172421] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   15.324206] Netfilter messages via NETLINK v0.30.
[   15.329759] PPP MPPE Compression module registered
[   15.335079] NET: Registered protocol family 24
[   15.342946] usbcore: registered new interface driver ums-alauda
[   15.349621] usbcore: registered new interface driver ums-cypress
[   15.356555] usbcore: registered new interface driver ums-datafab
[   15.363372] usbcore: registered new interface driver ums-freecom
[   15.370243] usbcore: registered new interface driver ums-isd200
[   15.377174] usbcore: registered new interface driver ums-jumpshot
[   15.384118] usbcore: registered new interface driver ums-karma
[   15.391159] usbcore: registered new interface driver ums-sddr09
[   15.397985] usbcore: registered new interface driver ums-sddr55
[   15.404948] usbcore: registered new interface driver ums-usbat
[   15.416699] usbcore: registered new interface driver usbserial
[   15.422589] usbcore: registered new interface driver usbserial_generic
[   15.429157] usbserial: USB Serial support registered for generic
[   15.443931] xt_time: kernel timezone is -0000
[   15.462144] usbcore: registered new interface driver cdc_ether
[   15.472515] ctnetlink v0.93: registering with nfnetlink.
[   15.481462] usbcore: registered new interface driver qmi_wwan
[   15.488390] usbcore: registered new interface driver rndis_host
[   15.501910] pci 0000:00:03.0: enabling device (0140 -> 0142)
[   15.513986] ath: EEPROM regdomain: 0x0
[   15.513990] ath: EEPROM indicates default country code should be used
[   15.513993] ath: doing EEPROM country->regdmn map search
[   15.513997] ath: country maps to regdmn code: 0x3a
[   15.514000] ath: Country alpha2 being used: US
[   15.514002] ath: Regpair used: 0x3a
[   15.520796] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   15.522278] ieee80211 phy1: Atheros AR9300 Rev:4 mem=0xf1d40000, irq=109
[   15.530758] usbcore: registered new interface driver option
[   15.536415] usbserial: USB Serial support registered for GSM modem (1-port)
[   15.544093] usbcore: registered new interface driver qcserial
[   15.549884] usbserial: USB Serial support registered for Qualcomm USB modem
[   18.423692] random: nonblocking pool is initialized
[   20.829403] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.912539] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   20.916016] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   22.317958] device eth0 entered promiscuous mode
[   22.319317] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   22.336490] device eth2 entered promiscuous mode
[   22.422344] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   22.775705] ath: EEPROM regdomain: 0x8114
[   22.775713] ath: EEPROM indicates we should expect a country code
[   22.775717] ath: doing EEPROM country->regdmn map search
[   22.775720] ath: country maps to regdmn code: 0x37
[   22.775723] ath: Country alpha2 being used: DE
[   22.775726] ath: Regpair used: 0x37
[   22.775729] ath: regdomain 0x8114 dynamically updated by user
[   22.775767] ath: EEPROM regdomain: 0x8114
[   22.775770] ath: EEPROM indicates we should expect a country code
[   22.775772] ath: doing EEPROM country->regdmn map search
[   22.775775] ath: country maps to regdmn code: 0x37
[   22.775777] ath: Country alpha2 being used: DE
[   22.775780] ath: Regpair used: 0x37
[   22.775782] ath: regdomain 0x8114 dynamically updated by user
[   24.310933] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   24.350928] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   25.818496] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.820027] br-lan: port 1(eth0) entered forwarding state
[   25.820056] br-lan: port 1(eth0) entered forwarding state
[   25.820095] br-lan: port 2(eth2) entered forwarding state
[   25.820105] br-lan: port 2(eth2) entered forwarding state
[   25.821254] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   25.869791] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
[   25.882180] device wlan1 entered promiscuous mode
[   25.882220] br-lan: port 3(wlan1) entered forwarding state
[   25.882251] br-lan: port 3(wlan1) entered forwarding state
[   26.810976] br-lan: port 3(wlan1) entered disabled state
[   27.364171] wlan0: authenticate with 64:d1:54:a2:1d:36
[   27.371178] wlan0: send auth to 64:d1:54:a2:1d:36 (try 1/3)
[   27.371604] wlan0: authenticated
[   27.380914] wlan0: associate with 64:d1:54:a2:1d:36 (try 1/3)
[   27.382883] wlan0: RX AssocResp from 64:d1:54:a2:1d:36 (capab=0x431 status=0 aid=2)
[   27.384154] wlan0: associated
[   27.384249] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   27.810874] br-lan: port 2(eth2) entered forwarding state
[   27.810921] br-lan: port 1(eth0) entered forwarding state
[   33.093784] IPv6: ADDRCONF(NETDEV_CHANGE): wlan1: link becomes ready
[   33.093859] br-lan: port 3(wlan1) entered forwarding state
[   33.093883] br-lan: port 3(wlan1) entered forwarding state
[   35.090846] br-lan: port 3(wlan1) entered forwarding state
c) After the next reboot Wifi-Card 2Ghz and msata cards are no longer there.
[    5.021654] Waiting 2 sec before mounting root device...
[    7.033641] BTRFS: device fsid 8bce2376-f3be-45ef-b0fa-b62236e9bd02 devid 1 transid 182 /dev/root
[    7.043123] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    7.049840] BTRFS: has skinny extents
[    7.057229] BTRFS: detected SSD devices, enabling SSD mode
[    7.100850] VFS: Mounted root (btrfs filesystem) on device 0:13.
[    7.106996] Freeing unused kernel memory: 284K
[    7.158439] init: Console is alive
[    7.161919] init: - watchdog -
[    7.516398] usbcore: registered new interface driver usbfs
[    7.521964] usbcore: registered new interface driver hub
[    7.527322] usbcore: registered new device driver usb
[    7.534231] exFAT: Version 1.2.9
[    7.551998] JFS: nTxBlock = 8192, nTxLock = 65536
[    7.612838] SGI XFS with security attributes, no debug enabled
[    7.620268] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    7.627156] ehci-platform: EHCI generic platform driver
[    7.632788] ehci-orion: EHCI orion driver
[    7.636906] orion-ehci f1058000.usb: EHCI Host Controller
[    7.642346] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[    7.649994] orion-ehci f1058000.usb: irq 39, io mem 0xf1058000
[    7.670843] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[    7.677035] hub 1-0:1.0: USB hub found
[    7.680806] hub 1-0:1.0: 1 port detected
[    7.685848] uhci_hcd: USB Universal Host Controller Interface driver
[    7.695376] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.700711] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    7.708330] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.716903] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    7.722919] hub 2-0:1.0: USB hub found
[    7.726689] hub 2-0:1.0: 1 port detected
[    7.730714] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.736056] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[    7.743616] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.751941] hub 3-0:1.0: USB hub found
[    7.755709] hub 3-0:1.0: 1 port detected
[    7.759775] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.765123] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    7.772724] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.781295] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    7.787290] hub 4-0:1.0: USB hub found
[    7.791071] hub 4-0:1.0: 1 port detected
[    7.795093] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.800420] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[    7.807961] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.816279] hub 5-0:1.0: USB hub found
[    7.820047] hub 5-0:1.0: 1 port detected
[    7.825219] usbcore: registered new interface driver usb-storage
[    8.165230] init: - preinit -
[   11.216898] mount_root: mounting /dev/root
[   11.221965] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   11.229322] mount_root: loading kmods from internal overlay
[   11.439209] block: attempting to load /etc/config/fstab
[   11.445306] block: extroot: not configured
[   11.451781] procd: - early -
[   11.454687] procd: - watchdog -
[   11.555157] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.581839] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.617605] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.642210] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.677953] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.702650] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.738433] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.763091] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.798439] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   11.822874] random: jshn: uninitialized urandom read (4 bytes read, 21 bits of entropy available)
[   12.022321] procd: - ubus -
[   13.031906] procd: - init -
[   13.090717] marvell-cesa f1090000.crypto: CESA device successfully registered
[   13.103845] NET: Registered protocol family 38
[   13.120098] md: linear personality registered for level -1
[   13.126218] md: raid0 personality registered for level 0
[   13.132318] md: raid1 personality registered for level 1
[   13.138491] md: raid10 personality registered for level 10
[   13.144359] async_tx: api initialized (async)
[   13.151700] md: raid6 personality registered for level 6
[   13.157028] md: raid5 personality registered for level 5
[   13.162361] md: raid4 personality registered for level 4
[   13.169517] FS-Cache: Loaded
[   13.172873] md: multipath personality registered for level -4
[   13.179799] NET: Registered protocol family 8
[   13.184178] NET: Registered protocol family 20
[   13.192407] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[   13.203243] Key type dns_resolver registered
[   13.210372] NET: Registered protocol family 33
[   13.214844] Key type rxrpc registered
[   13.218514] Key type rxrpc_s registered
[   13.225509] kAFS: Red Hat AFS client v0.1 registering.
[   13.230698] FS-Cache: Netfs 'afs' registered for caching
[   13.265132] RPC: Registered named UNIX socket transport module.
[   13.271083] RPC: Registered udp transport module.
[   13.275797] RPC: Registered tcp transport module.
[   13.280509] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   13.304812] NFS: Registering the id_resolver key type
[   13.309899] Key type id_resolver registered
[   13.314128] Key type id_legacy registered
[   13.318774] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[   13.328016] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   13.337794] RxRPC: Registered security type 2 'rxkad'
[   13.354498] tun: Universal TUN/TAP device driver, 1.6
[   13.359565] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   13.369383] sit: IPv6 over IPv4 tunneling driver
[   13.376247] gre: GRE over IPv4 demultiplexor driver
[   13.381832] ip_gre: GRE over IPv4 tunneling driver
[   13.401735] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   13.411318] PPP generic driver version 2.4.2
[   13.418945] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   13.431514] cryptodev: driver 1.8 loaded.
[   13.439191] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[   13.447250] Backport generated by backports.git backports-20160324-13-g24da7d3c
[   13.520748] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   13.526639] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   13.704321] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   13.715054] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.724869] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.733992] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   13.744377] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.753973] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.770664] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 19b6:d03c
[   13.779935] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.789540] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   13.834271] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
[   13.841386] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.851851] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.861550] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.870459] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   14.997465] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
[   15.081289] ath: EEPROM regdomain: 0x0
[   15.081294] ath: EEPROM indicates default country code should be used
[   15.081296] ath: doing EEPROM country->regdmn map search
[   15.081301] ath: country maps to regdmn code: 0x3a
[   15.081303] ath: Country alpha2 being used: US
[   15.081306] ath: Regpair used: 0x3a
[   15.086779] u32 classifier
[   15.089496]     input device check on
[   15.093193]     Actions configured
[   15.099445] Mirror/redirect action on
[   15.104888] GACT probability on
[   15.112792] netem: version 1.3
[   15.121068] fuse init (API version 7.23)
[   15.136757] usbcore: registered new interface driver cdc_wdm
[   15.145479] Ebtables v2.0 registered
[   15.150414] ip_tables: (C) 2000-2006 Netfilter Core Team
[   15.162342] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   15.354195] Netfilter messages via NETLINK v0.30.
[   15.359745] PPP MPPE Compression module registered
[   15.365088] NET: Registered protocol family 24
[   15.372960] usbcore: registered new interface driver ums-alauda
[   15.379642] usbcore: registered new interface driver ums-cypress
[   15.386586] usbcore: registered new interface driver ums-datafab
[   15.393412] usbcore: registered new interface driver ums-freecom
[   15.400290] usbcore: registered new interface driver ums-isd200
[   15.407243] usbcore: registered new interface driver ums-jumpshot
[   15.414169] usbcore: registered new interface driver ums-karma
[   15.421216] usbcore: registered new interface driver ums-sddr09
[   15.428044] usbcore: registered new interface driver ums-sddr55
[   15.435013] usbcore: registered new interface driver ums-usbat
[   15.446777] usbcore: registered new interface driver usbserial
[   15.452673] usbcore: registered new interface driver usbserial_generic
[   15.459242] usbserial: USB Serial support registered for generic
[   15.474072] xt_time: kernel timezone is -0000
[   15.492292] usbcore: registered new interface driver cdc_ether
[   15.502676] ctnetlink v0.93: registering with nfnetlink.
[   15.511655] usbcore: registered new interface driver qmi_wwan
[   15.518561] usbcore: registered new interface driver rndis_host
[   15.533222] usbcore: registered new interface driver option
[   15.538849] usbserial: USB Serial support registered for GSM modem (1-port)
[   15.546485] usbcore: registered new interface driver qcserial
[   15.552303] usbserial: USB Serial support registered for Qualcomm USB modem
[   18.427520] random: nonblocking pool is initialized
[   20.836237] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.912525] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   20.915960] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   22.322354] device eth0 entered promiscuous mode
[   22.323332] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   22.341726] device eth2 entered promiscuous mode
[   22.422293] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   22.679144] ath: EEPROM regdomain: 0x8114
[   22.679151] ath: EEPROM indicates we should expect a country code
[   22.679154] ath: doing EEPROM country->regdmn map search
[   22.679157] ath: country maps to regdmn code: 0x37
[   22.679160] ath: Country alpha2 being used: DE
[   22.679162] ath: Regpair used: 0x37
[   22.679166] ath: regdomain 0x8114 dynamically updated by user
[   24.310907] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   24.330898] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   25.685429] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   25.685522] br-lan: port 1(eth0) entered forwarding state
[   25.685555] br-lan: port 1(eth0) entered forwarding state
[   25.685593] br-lan: port 2(eth2) entered forwarding state
[   25.685604] br-lan: port 2(eth2) entered forwarding state
[   25.686850] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   27.680861] br-lan: port 2(eth2) entered forwarding state
[   27.680903] br-lan: port 1(eth0) entered forwarding state
@cynerd:
I have the following setup:
  • Indiegogo-campaign 2GB WIFI-model
  • TOS v3.10 installed a day after it has been released
  • Indiegogo-campaign WLE900VX 7AA in port 00:01.0 setup in bgn-mode with custom firmware-5.bin (https://github.com/kvalo/ath10k-firmware/blob/master/QCA988X/hw2.0/10.2.4.70/firmware-5.bin_10.2.4.70.67)
  • WLE1216V5-20 in port 00:02.0 setup in 5GHz-mode
  • never had a problem with a QCA988X-card not comming up before (I own the first TO since Indiegogo and bought a second one around 2 months ago)
  • I have setup main SSIDs on both cards to be able to roam between 5GHz and 2,4GHz
  • haven’t physically moved or even touched router since about 3 days
root@Router:~# lspci
01:00.0 Network controller: Qualcomm Atheros QCA986x/988x 802.11ac Wireless Network Adapter
02:00.0 Network controller: Qualcomm Atheros Device 0046
  • demsg-output when WLE900VX 7AA doesn’t come up:
root@Router:~# dmesg
[    4.203984] armada38x-rtc f10a3800.rtc: rtc core: registered f10a3800.rtc as rtc0
[    4.490928] ata2: SATA link down (SStatus 0 SControl 300)
[    4.496365] ata1: SATA link down (SStatus 0 SControl 300)
[    4.721040] i2c /dev entries driver
[    4.725271] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[    4.732047] i2c i2c-0: Added multiplexed i2c bus 1
[    4.736914] i2c i2c-0: Added multiplexed i2c bus 2
[    4.741789] i2c i2c-0: Added multiplexed i2c bus 3
[    4.746653] i2c i2c-0: Added multiplexed i2c bus 4
[    4.751528] i2c i2c-0: Added multiplexed i2c bus 5
[    4.756390] i2c i2c-0: Added multiplexed i2c bus 6
[    4.761263] i2c i2c-0: Added multiplexed i2c bus 7
[    4.768068] i2c i2c-0: Added multiplexed i2c bus 8
[    4.772882] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[    4.780451] orion_wdt: Initial timeout 171 sec
[    4.785043] cpu: dev_pm_opp_of_cpumask_add_table: couldn't find opp table for cpu:0, -19
[    4.793287] sdhci: Secure Digital Host Controller Interface driver
[    4.799480] sdhci: Copyright(c) Pierre Ossman
[    4.803984] sdhci-pxav3 f10d8000.sdhci: No vmmc regulator found
[    4.809917] sdhci-pxav3 f10d8000.sdhci: No vqmmc regulator found
[    4.860929] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[    4.868380] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.883407] NET: Registered protocol family 10
[    4.888320] NET: Registered protocol family 17
[    4.892803] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    4.905459] Bridge firewalling registered
[    4.909479] 8021q: 802.1Q VLAN Support v1.8
[    4.913743] Registering SWP/SWPB emulation handler
[    4.918878] BTRFS: using crc32c-generic for crc32c
[    4.923941] Btrfs loaded, integrity-checker=on
[    4.928973] mvsw61xx 10.mvsw61xx: Found MV88E6176 at f1072004.mdio-mii:10
[    4.935810] mvsw61xx 10.mvsw61xx: Using indirect addressing
[    4.954061] mmc0: MAN_BKOPS_EN bit is not set
[    4.961661] mmc0: new high speed MMC card at address 0001
[    4.967287] mmcblk0: mmc0:0001 H8G4a▒ 7.28 GiB
[    4.971931] mmcblk0boot0: mmc0:0001 H8G4a▒ partition 1 4.00 MiB
[    4.977936] mmcblk0boot1: mmc0:0001 H8G4a▒ partition 2 4.00 MiB
[    4.983951] mmcblk0rpmb: mmc0:0001 H8G4a▒ partition 3 4.00 MiB
[    4.990830]  mmcblk0: p1
[    5.012040] armada38x-rtc f10a3800.rtc: setting system clock to 2018-05-31 21:05:12 UTC (1527800712)
[    5.022043] Waiting 2 sec before mounting root device...
[    7.033569] BTRFS: device fsid a325ed36-3d66-4a0e-ad1f-82940efc2599 devid 1 transid 634947 /dev/root
[    7.043326] BTRFS info (device mmcblk0p1): disk space caching is enabled
[    7.050043] BTRFS: has skinny extents
[    7.058540] BTRFS: detected SSD devices, enabling SSD mode
[    7.090942] VFS: Mounted root (btrfs filesystem) on device 0:13.
[    7.097088] Freeing unused kernel memory: 284K
[    7.148709] init: Console is alive
[    7.152192] init: - watchdog -
[    7.337896] usbcore: registered new interface driver usbfs
[    7.343453] usbcore: registered new interface driver hub
[    7.348807] usbcore: registered new device driver usb
[    7.354860] uhci_hcd: USB Universal Host Controller Interface driver
[    7.364263] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.369601] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 1
[    7.377226] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.385803] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[    7.391840] hub 1-0:1.0: USB hub found
[    7.395612] hub 1-0:1.0: 1 port detected
[    7.399642] xhci-hcd f10f0000.usb3: xHCI Host Controller
[    7.404984] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[    7.412532] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.420852] hub 2-0:1.0: USB hub found
[    7.424634] hub 2-0:1.0: 1 port detected
[    7.428711] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.434058] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 3
[    7.441655] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x00010010
[    7.450215] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[    7.456218] hub 3-0:1.0: USB hub found
[    7.459986] hub 3-0:1.0: 1 port detected
[    7.464024] xhci-hcd f10f8000.usb3: xHCI Host Controller
[    7.469352] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[    7.476889] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.485216] hub 4-0:1.0: USB hub found
[    7.488984] hub 4-0:1.0: 1 port detected
[    8.155499] init: - preinit -
[   11.206791] mount_root: mounting /dev/root
[   11.211529] BTRFS info (device mmcblk0p1): disk space caching is enabled
[   11.220537] procd: - early -
[   11.223471] procd: - watchdog -
[   11.314538] random: jshn: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.344366] random: jshn: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.372736] random: jshn: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.401068] random: jshn: uninitialized urandom read (4 bytes read, 16 bits of entropy available)
[   11.791985] procd: - ubus -
[   12.796586] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.805649] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.814651] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.823725] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.832722] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.841741] random: ubusd: uninitialized urandom read (4 bytes read, 17 bits of entropy available)
[   12.850807] procd: - init -
[   12.913276] NET: Registered protocol family 8
[   12.917646] NET: Registered protocol family 20
[   12.923555] tun: Universal TUN/TAP device driver, 1.6
[   12.928619] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[   12.938234] sit: IPv6 over IPv4 tunneling driver
[   12.944955] gre: GRE over IPv4 demultiplexor driver
[   12.950331] ip_gre: GRE over IPv4 tunneling driver
[   12.959973] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
[   12.968895] PPP generic driver version 2.4.2
[   12.974880] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   12.985323] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
[   12.993398] Backport generated by backports.git backports-20160324-13-g24da7d3c
[   13.064412] pci 0000:00:02.0: enabling device (0140 -> 0142)
[   13.070334] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   13.202354] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
[   13.213095] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.222944] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.232064] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
[   13.242458] ath10k_pci 0000:02:00.0: Falling back to user helper
[   13.252076] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
[   13.280245] ath10k_pci 0000:02:00.0: qca9984/qca9994 hw1.0 target 0x01000000 chip_id 0x00000000 sub 168c:cafe
[   13.290233] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.302159] ath10k_pci 0000:02:00.0: firmware ver 10.4-3.6-00140 api 5 features no-p2p,mfp,peer-flow-ctrl,btcoex-param,allows-mesh-bcast crc32 6211363e
[   14.550333] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id 0:1 crc32 dd6d039c
[   17.141318] ath10k_pci 0000:02:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal otp max-sta 512 raw 0 hwcrypto 1
[   17.221372] ath: EEPROM regdomain: 0x0
[   17.221377] ath: EEPROM indicates default country code should be used
[   17.221380] ath: doing EEPROM country->regdmn map search
[   17.221385] ath: country maps to regdmn code: 0x3a
[   17.221388] ath: Country alpha2 being used: US
[   17.221390] ath: Regpair used: 0x3a
[   17.226689] u32 classifier
[   17.229405]     input device check on
[   17.233090]     Actions configured
[   17.239198] Mirror/redirect action on
[   17.244382] GACT probability on
[   17.251537] netem: version 1.3
[   17.259094] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[   17.275413] usbcore: registered new interface driver cdc_wdm
[   17.283666] Ebtables v2.0 registered
[   17.288315] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.433560] Netfilter messages via NETLINK v0.30.
[   17.439047] PPP MPPE Compression module registered
[   17.444233] NET: Registered protocol family 24
[   17.453896] usbcore: registered new interface driver usbserial
[   17.459776] usbcore: registered new interface driver usbserial_generic
[   17.466357] usbserial: USB Serial support registered for generic
[   17.480147] xt_time: kernel timezone is -0000
[   17.497224] usbcore: registered new interface driver cdc_ether
[   17.507364] ctnetlink v0.93: registering with nfnetlink.
[   17.515786] usbcore: registered new interface driver qmi_wwan
[   17.522355] usbcore: registered new interface driver rndis_host
[   17.535969] usbcore: registered new interface driver option
[   17.541614] usbserial: USB Serial support registered for GSM modem (1-port)
[   17.549095] usbcore: registered new interface driver qcserial
[   17.554898] usbserial: USB Serial support registered for Qualcomm USB modem
[   20.433952] random: nonblocking pool is initialized
[   22.849270] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   22.932621] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   22.936089] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   24.255191] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready
[   24.257452] device eth2.5 entered promiscuous mode
[   24.257459] device eth2 entered promiscuous mode
[   24.258449] IPv6: ADDRCONF(NETDEV_UP): br-gast: link is not ready
[   24.269125] device eth2.2 entered promiscuous mode
[   24.270538] IPv6: ADDRCONF(NETDEV_UP): br-iot: link is not ready
[   24.292875] device eth0 entered promiscuous mode
[   24.293888] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[   24.384931] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   24.662538] ath: EEPROM regdomain: 0x8114
[   24.662547] ath: EEPROM indicates we should expect a country code
[   24.662550] ath: doing EEPROM country->regdmn map search
[   24.662553] ath: country maps to regdmn code: 0x37
[   24.662557] ath: Country alpha2 being used: DE
[   24.662559] ath: Regpair used: 0x37
[   24.662562] ath: regdomain 0x8114 dynamically updated by user
[   26.250947] mvneta f1070000.ethernet eth2: Link is Up - 1Gbps/Full - flow control off
[   26.290930] mvneta f1030000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   29.362808] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   29.362888] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[   29.363073] br-lan: port 1(eth0) entered forwarding state
[   29.363090] br-lan: port 1(eth0) entered forwarding state
[   29.363464] br-iot: port 1(eth2.2) entered forwarding state
[   29.363480] br-iot: port 1(eth2.2) entered forwarding state
[   29.363513] br-gast: port 1(eth2.5) entered forwarding state
[   29.363523] br-gast: port 1(eth2.5) entered forwarding state
[   29.363550] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[   29.363603] IPv6: ADDRCONF(NETDEV_CHANGE): br-iot: link becomes ready
[   29.363650] IPv6: ADDRCONF(NETDEV_CHANGE): br-gast: link becomes ready
[   29.364193] device wlan0 entered promiscuous mode
[   29.371656] IPv6: ADDRCONF(NETDEV_UP): tun1: link is not ready
[   29.485384] IPv6: ADDRCONF(NETDEV_UP): tun0: link is not ready
[   29.591604] IPv6: ADDRCONF(NETDEV_UP): tun0: link is not ready
[   29.605859] IPv6: ADDRCONF(NETDEV_UP): tun1: link is not ready
[   30.031743] device iot0 entered promiscuous mode
[   30.043625] IPv6: ADDRCONF(NETDEV_UP): iot0: link is not ready
[   30.043644] br-iot: port 2(iot0) entered forwarding state
[   30.043669] br-iot: port 2(iot0) entered forwarding state
[   30.051400] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   30.051481] br-lan: port 2(wlan0) entered forwarding state
[   30.051502] br-lan: port 2(wlan0) entered forwarding state
[   30.135968] device gast0 entered promiscuous mode
[   30.147671] IPv6: ADDRCONF(NETDEV_UP): gast0: link is not ready
[   30.147686] br-gast: port 2(gast0) entered forwarding state
[   30.147704] br-gast: port 2(gast0) entered forwarding state
[   30.151280] IPv6: ADDRCONF(NETDEV_CHANGE): iot0: link becomes ready
[   30.225717] IPv6: ADDRCONF(NETDEV_CHANGE): gast0: link becomes ready
[   31.361056] br-gast: port 1(eth2.5) entered forwarding state
[   31.361105] br-iot: port 1(eth2.2) entered forwarding state
[   31.361120] br-lan: port 1(eth0) entered forwarding state
[   32.040963] br-iot: port 2(iot0) entered forwarding state
[   32.050965] br-lan: port 2(wlan0) entered forwarding state
[   32.140947] br-gast: port 2(gast0) entered forwarding state
[   34.381469] mvneta f1034000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[   34.381495] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
  • delta dmesg when WLE900VX 7AA comes up:
[   13.101016] pci 0000:00:01.0: enabling device (0140 -> 0142)
[   13.106883] ath10k_pci 0000:01:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   13.283526] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:01:00.0.bin failed with error -2
[   13.294264] ath10k_pci 0000:01:00.0: Falling back to user helper
[   13.304106] firmware ath10k!pre-cal-pci-0000:01:00.0.bin: firmware_loading_store: map pages failed
[   13.313229] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/cal-pci-0000:01:00.0.bin failed with error -2
[   13.323626] ath10k_pci 0000:01:00.0: Falling back to user helper
[   13.333240] firmware ath10k!cal-pci-0000:01:00.0.bin: firmware_loading_store: map pages failed
[   13.349872] ath10k_pci 0000:01:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
[   13.359145] ath10k_pci 0000:01:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   13.368755] ath10k_pci 0000:01:00.0: firmware ver 10.2.4-1.0-00029 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 88595bb8
[   13.413510] ath10k_pci 0000:01:00.0: board id is not exist in otp, ignore it
[   13.420620] ath10k_pci 0000:01:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[   13.431092] ath10k_pci 0000:01:00.0: Falling back to user helper
[   13.440808] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
[   13.451157] ath10k_pci 0000:01:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
[   14.580010] ath10k_pci 0000:01:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
  • Yesterday evening I added a new device to the network, a iPhone 7.
    Then after a reboot the WLE900VX 7AA didn’t show up anymore.
  • As it after three reboots still wouldn’t show up, I reverted firmware-5.bin back to default-one. Can’t tell if that was the real trigger but wifi showed up after (4th) reboot and I decided to not reboot again for now (as the WAF of a not showing up wifi is pretty much zero).
I will watch that behaviour like a hawk for the next time and report again if it shows up again…
Update 2018Jun07: The problem is not linked to alternate firmware-5.bin and keeps occuring after each reboot… :frowning: what to do to stop it?
I am also having the same problem.
    root@turris:~# lspci
    00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
    00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
    00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04)
    01:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
This happens every time I restart the router.
I correct it manually by removing the file /etc/config/wireless and then it shows up correctly on the web page.
How do I fix this issue? Any help would be appreciated.
Thanks
That unfortunately doesn’t work for me.
@cynerd maybe there was some change in 3.10 update as to how the hardware is utilized? some driver update -> power management -> interference ?
I cannot tell exactly how, but the following is always working: When rebooting disconnect power, wait for some minutes (to cool down the wifi-card in slot 2?), reconnect power.
Maybe the WiFi-card (WLE1216V5-20) gets to hot and won’t come up OR it is the interference-problem @cynerd described. OR maybe both?
