Same problem here, radio0 5Ghz is missing since a few days (10 days). It was working fine before.
config wifi-device 'radio0'
option type 'mac80211'
option hwmode '11a'
option path 'soc/soc:pcie-controller/pci0000:00/0000:00:02.0/0000:02:00.0'
option htmode 'VHT80'
option country 'FR'
option txpower '20'
option channel '36'
But device pci for this radio seems missing:
# lspci -v
00:01.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: e0000000-e00fffff
Prefetchable memory behind bridge: 00000000-000fffff
Capabilities: [40] Express Root Port (Slot+), MSI 00
lspci: Unable to load libkmod resources: error -12
00:02.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Flags: fast devsel
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:03.0 PCI bridge: Marvell Technology Group Ltd. Device 6820 (rev 04) (prog-if 00 [Normal decode])
Flags: fast devsel
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
01:00.0 Network controller: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express) (rev 01)
Subsystem: Qualcomm Atheros Device 30a4
Flags: bus master, fast devsel, latency 0, IRQ 108
Memory at e0000000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [60] Express Legacy Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Virtual Channel
Capabilities: [160] Device Serial Number 00-15-17-ff-ff-24-14-12
Capabilities: [170] Power Budgeting <?>
Kernel driver in use: ath9k
Rebooting fixes this issue, but just for a while.
How to fix that ?
best regards,
Edouard
