My nftables are working fine after the migration. However, the migrated configuration looks quite messy. How can i reset it to default? I will gladly do custom configuration again, but I would like to eliminate the migration mess.
Describe mess. And post /etc/config/firewall redacting personal info
config defaults
option input 'ACCEPT'
option output 'ACCEPT'
option synflood_protect '1'
option drop_invalid '1'
option forward 'DROP'
config zone
option name 'lan'
list network 'lan'
option forward 'ACCEPT'
config zone
option name 'wan'
list network 'wan'
list network 'wan6'
option input 'REJECT'
option sentinel_dynfw '1'
option sentinel_fwlogs '1'
option sentinel_minipot '1'
option haas_proxy '1'
option masq '1'
option mtu_fix '1'
option forward 'REJECT'
config forwarding
option src 'lan'
option dest 'wan'
config rule
option name 'Allow-DHCP-Renew'
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option name 'Allow-ICMPv6-Input'
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'destination-unreachable'
list icmp_type 'packet-too-big'
list icmp_type 'time-exceeded'
list icmp_type 'bad-header'
list icmp_type 'unknown-header-type'
list icmp_type 'router-solicitation'
list icmp_type 'neighbour-solicitation'
list icmp_type 'router-advertisement'
list icmp_type 'neighbour-advertisement'
option limit '1000/sec'
config rule
option name 'Allow-ICMPv6-Forward'
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled '0'
config include
option path '/etc/firewall.user'
config zone 'guest_turris'
option name 'tr_guest'
option enabled '0'
list network 'guest_turris'
config rule 'guest_turris_dns_rule'
option name 'guest dns rule'
option src 'tr_guest'
option proto 'tcpudp'
option dest_port '53'
option enabled '0'
config rule 'guest_turris_dhcp_rule'
option name 'guest dhcp rule'
option proto 'udp'
option src_port '67-68'
option dest_port '67-68'
option enabled '0'
config rule 'guest_turris_Allow_DHCPv6'
option proto 'udp'
option src_port '546-547'
option dest_ip 'fe80::/10'
option dest_port '546-547'
config rule 'guest_turris_Allow_MLD'
option proto 'icmp'
config rule 'guest_turris_Allow_ICMPv6_Input'
option proto 'icmp'
config rule 'wan_ssh_turris_rule'
option name 'wan_ssh_turris_rule'
option enabled '0'
option dest_port '22'
option proto 'tcp'
option src 'wan'
config rule
option src 'wan'
option dest_port '12345'
option name 'wan_ssh_12345'
list proto 'tcp'
config rule 'wan_http_turris_rule'
option name 'wan_http_turris_rule'
option enabled '1'
option dest_port '80'
option proto 'tcp'
option src 'wan'
config rule 'wan_https_turris_rule'
option name 'wan_https_turris_rule'
option dest_port '443'
option proto 'tcp'
option src 'wan'
config rule 'turris_wan_6in4_rule'
option enabled '0'
config rule 'turris_wan_6to4_rule'
option enabled '0'
list proto 'tcp'
config redirect
option src 'wan'
option src_dport '22'
option dest 'lan'
option dest_ip '10.x.x.x'
option target 'DNAT'
option name 'gitlab_ssh'
config redirect
list proto 'tcp'
option src_dport '80'
option dest 'lan'
option src 'wan'
option name 'nginx_http'
config redirect
list proto 'tcp'
option src_dport '443'
option dest 'lan'
option src 'wan'
option name 'nginx_https'
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config forwarding
option dest 'lan'
option src 'wan'
config include 'sentinel_firewall'
option path '/usr/libexec/sentinel/firewall.sh'
So your rules are fine. The warning is there probabbly because you have iptables-legacy installed. Get rid of that and optionally install iptables-nft for compatibility with mwan3 for example and the warning should go away.
As for the include parts you may add specifically:
option fw4_compatible '1'
Edit: which version of TOS are you on? Because I remember that some eairlier update fixed that automatically.
I found it!
It suppose to be done in 7.1.3:
root@router:~# opkg update > /dev/null && opkg list | grep fix-iptables-to-nftables
fix-iptables-to-nftables-packages - 1-65 - Change iptables version of packages to nftables if installed.
Its still there in the repo as package. So you may try to install it. Not sure how to actually run it.
