i configured my mwan3 module a few weeks ago and everything was working. I have 4 simultanious VPN connections which routes different network clients through the tunnels. After the update all interfaces are showing up as offline, even the wan interfaces comes up offline. The clients which should be routed throught the tunnels have no internet access anymore, even if the tunnels are online. The clients which do not use a tunnel can still access the internet.
Is there any known issue coming up with the latest update?
we have similar issue. We have zones: WAN (wan,wan6, wan2), lan + turris quest. After the upgrade it seems it routes only via wan2 or wan (not both). As we need to get outside connections form wan2 it helps when we restart the wan2 interface and than it routes thru it. Do you have any clue please?
I lost mwan3 functionality in the last couple of days. All three wan interfaces show red / offline in the mwan3 overview. Two of the interfaces are operational, and I can ping the gateway and tracking IP on both interfaces. One device is out of service for unrelated reasons. When I select Check IP Rules I get a message āMissing both of the required interface IP rulesā. When I select Check Routing Table, I get the message āMissing required interface routing table Nā, where N is 2 or 3 depending on which interface I test. IF up/down make no difference. Rebooting multiple times has not helped. I even removed an entire interface from mwan3, saved, rebooted and rebuilt - no difference. IP addresses and other config all appear correct on the Omnia, and I can ping / browse / email when I plug my laptop into an available DMZ switch port between the Omnia and either of the above-mentioned in-service link devices. I even tried setting the tracking IP to blank to disable tracking. Interface still stays red / offline. Iām still researching. Have not found solutions yet but have not exhausted all search options. I would appreciate any help / suggestions / insights on this.
Thanks,
Robert
Doing further research. I am still getting my head around the problem. These posts and a number of similar ones share the āall offlineā pattern, but are not 100% what we are seeing on Omnia. Reposting here to add info to the discussion. I will post my results if/as I progress solving.
From the previous discussion link⦠mwan3 requires that conntrac be running on the interfaces. Checked my Start Up page. Conntracd was disabled. I enabled, started, sent ifup to both active interfaces. No change thus far. Not sure why conntracd was disabled either.
Oddly when I click Detailed Status I see āNo detailed status information availableā, which does not seem right. Iāve not used that feature much - generally go from the live view to diagnostics tab. Not sure if the lack of detail info is new or longstanding.
Same with me: mwan3 stopped working.
Running mwan status command via ssh, I get an iptables error:
Current ipv4 policies:
iptables v1.6.1: canāt initialize iptables table `mangleā: Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
Current ipv6 policies:
ip6tables v1.6.1: canāt initialize ip6tables table `mangleā: Table does not exist (do you need to insmod?)
Perhaps ip6tables or your kernel needs to be upgraded.
in 3.11.1 it looks better, but mwan3 is still not working:
root@qicala:~# mwan3 restart
ip: invalid argument '0x3d00/0x3F00' to 'fwmark'
ip: invalid argument '0x3e00/0x3F00' to 'fwmark'
ip: invalid argument '0x100/0x3F00' to 'fwmark'
/sbin/hotplug-call: /etc/hotplug.d/iface/15-mwan3: line 481: network_get_metric: not found
uci: Entry not found
ip: invalid argument '0x200/0x3F00' to 'fwmark'
root@qicala:~# uci: Entry not found
Here is my config:
config globals 'globals'
option mmx_mask '0x3F00'
option rtmon_interval '5'
config member 'WiFi'
option interface 'Bla'
option weight '10'
option metric '5'
config member 'Mobile'
option interface 'Vodafone'
option metric '10'
option weight '10'
config rule 'https'
option sticky '1'
option dest_port '443'
option proto 'tcp'
option use_policy 'Failover'
option timeout '60'
config rule 'default_rule'
option dest_ip '0.0.0.0/0'
option proto 'all'
option sticky '0'
config interface 'Bla'
option enabled '1'
option reliability '1'
option count '3'
option timeout '2'
option interval '5'
option down '3'
option up '3'
list track_ip '8.8.8.8'
list track_ip '8.8.4.4'
list track_ip '1.1.1.1'
config interface 'Vodafone'
option enabled '1'
option timeout '2'
option interval '5'
option down '3'
option up '3'
option count '3'
config policy 'Failover'
list use_member 'WiFi'
list use_member 'Mobile'
option last_resort 'unreachable'
Itās not working even without mmx_mask, because then it uses some default values.
Interface status:
interface Bla is error and tracking is active
interface Vodafone is error and tracking is active
Failover:
Bla (100%)
Failover:
unreachable
Directly connected ipv4 networks:
Iāve tried also ip-tiny package, but problem is the same. Also when I made some lame āpatchesā for those network_get_metric errors, itās still broken.
The main problem is imho in that āipā call. Without it, the rest of the environment configuration doesnāt make much sense (as far as I understand).
Maybe try ip-full version update? Because in mwan3.sh that line with āipā call is from 2017 (but I donāt know how about parameters/variables content).
Similar here, mwan3 unusable as it is. There is the network_get_metric function missing in network.sh and even with ip-full installed and calls to it changed to be /usr/sbin/ip instead of ip it is not any better (to make sure not to call busybox).
Unless someone finds a fix and with the season holidays in progress this might not get sorted soon. Thus a workaround is perhaps to either rollback to TOS 3.10.8 or try alternatively VPN policy based routing possible?, which works in 3.11.1 but does not provide load balancing.
After that, I rebuilt my rules in /etc/config/mwan3 (basically, search-replaced all wanb to wwan, set all IPv6 rules to disabled, removed the default http policy and changed the default rule to policy wan_wwan) and then ran /usr/sbin/mwan3 restart - and it worked!
Turns out, with the new update, you need the full path to ip for fwmark to work, and if you donāt have IPv6 rules in your config (which I donāt, since I donāt have IPv6 natively on either of my connections), the rtmon script break everything (and spams the logs with uci errors).
The network_get_metric error is still there, but it does not appear to affect my setup as far as I can tell.
@Pepe, you may want to update your bug with the above info.
At the moment, I also have turned off automatic updates to be sure, non of the changed files are overwritten by an update and break the installation again.
