Say one wants to run several virtual servers (containers if you will) that will mostly be idle (e.g. VPN / SSH-tunneling, backup-NAS, LAMP-mail+webserver) alongside the “standard” Omnia routing (security)services.
- Is it in possible to have multiple LXC containers running or will it be limited to one (in principle LXC would typically support this, but will Omnias default firmware allow for it)?
- If yes: Do you guys/girls think the Turris Omnia will be powerfull enough for the aforementioned use-cases*?
- Will the GUI have (rudimentary) support for starting / stopping the container(s)?
*Note that - in my case - the services will rarely all be active at the same time (e.g. backups will run only at night, so typically when I am not using my VPN etc.). Also my web-services are private with virtually no traffic .
