mSATA (FAST + relieving the int.flash of the Omnia)
Conventional SATA HDs using the NAS perk (normal/fast speeds + relieving the int. flash).
external-USB-HDD (slower but still relieving the int.flash + possibly LARGE storage-wise)
internal flash (relatively small / sensitive to āwearingā by reads/writes to it).
Still I am thinking of going for option 1 (for the high performance and to keep the housing small). But I do have one worry that may push me to buy the NAS/SATA upgrade:
Does an mSATA_ SSD fit into the normal (non-NAS) housing of the Turris Omnia?
mSATA SSDs are the same form factor as mini-PCIe cards. Their only difference is the pinout of the connector.
There is another option 1+2: mSATA SSD + up to 2 internal SATA HDD/SSD. But this one will only allow one WiFi card and no LTE.
Maybe option 2 with a SSD and a HDD is a better version of this. Still allows 2 WiFi or 1 WiFi + UMTS/LTE.
I would still go for option 1+3(b): minimized access time on the internal SSD, fast enough large space and 1 WiFi + UMTS/LTE. Option 3b are network connected drives (SAN using iSCSI build from an old NAS).
mSata (for the root LXC root FSs) + external HD (for volume/storage) is my current go-to solution. Still speedy (mSATA SSD) and enough ābreathing roomā for data (external disk).
Second choice: run the LXC containers entirely from the external (USB3) disk. Cheap.
Would running it all from an external (USB3) disk be really that slow (how would that compare - for instance - to running a RaspberrypiB+ from an class10 SD card / comparible / slower / quicker)?
I would say faster in general, but there is one trick - with classic HDD I prefer to let it spin down when it is not doing anything and in this setup it will be faster if HDD is spinning but could take some time to spin it up. Got fifth option for you - USB3 flash drive - easily replaceable, nowadays quite large and fast and not spinning.
And regarding other question you posted long time ago, you can get LXC container from ARM and run it on your x86 PC using qemu, with qemu-user and binfmt it should work quite fine, would be slower than native x86 container but from my experience it is quite usable unless you need real performance - so as a temporally backup solution you can use even your PC.
Yah, I thought of that (buying a 32Gb thumbdrive and using it for my LXC-rootfs/snapshots). Do you reckon it is reliable enough to run, say, a web + mail server (what about it wearing)?
Ooooh, thanks! Iāll look into that (so much to learn in this areaā¦)!
Thumbdrives have increased in size lately and are relatively ābigā, but not that big. Nowadays they are about what size; 16GB, 32GB, or maybe 64GB tops (to stay affordable / as otherwise the internal sata-SDD would be better choice for sure, if not already)?
Hence my question: does anyone have good knowledge (or reference) to apply āoverlayfsā (on the Omnia)? So LXC-snapshots would require little to no space (only storing the deltas)?
I wonder how LXC is applied in general on the Omnia b.t.w. I asked cz.nic to release documentation in advance. But cz.nic officials seem fairly inactive on this forum (probably too busy gathering/testing for release etc.). So I fear Iāll have to wait on the actual shipment date for that to be released too. But any (3rd party) information about the LXC implementation and appliance on the Turris Omnia is more then welcome (it being my main appliance, next to securely routing of course)!
Internal SATA is much better choice for sure, USBs are just much more affordable. Yep, they will die, but if you set them up right, they can last long and you can do RAID out of them. Internal mSATA would warn you before dying.
You can use overlayfs, but AFAIK only by hand - so if you want to use squashfs with overlayfs to save some space, you would probably have to script it.
Same as everywhere else - lxc-start, lxc-stop, lxc-console and such
I tried to Google on how to do this (I have a general understanding of a layered-fs, but no practical experience whatsoever). But to no avail.
@miska could you summarize the general process steps for me using the most simple route (Iād say using overlayfs as that is in the linux kernel by default), including actually making the LXC-snapshot? Ofc. Iāll google the details; but just to push me into the general direction (now I seem to drown in the conceptual info.)?
Ah so that is good! That does assume an SSH connection (or at least a CLI). I just read that that is indeed possible, I just did not think of SSH-ing into my router at a first thought. Usually router-administration is done (primarily) via a web-interface. I guess much is different in the Omnia camp!
Would that all work out-of-the-box b.t.w. (I think that was promised by cz.nic)?
Depends what do you want to achieve. I thought you had some idea what you want to use overlayfs as you were asking for it
You can create for example squashfs[see mksquashfs], use overlayfs[mount -t overlay ā¦] to attach writeable overlay on top of it and use that in LXC. So you would save some space. You can create squahfs periodically from the resulting dir and remount everything and backup that squashfs.
Or you could have one squashfs (just base OS) with multiple writeable overlays used by different containers.
LXC uses just directories on your disk and it doesnāt care what fs is underneath and AFAIK lxc-snapshot just creates copy of it. So you can make whatever you want out of it.
There is a web wizard to guide you through simple setup and web UI, but ssh will work out of the box (maybe once you are done with wizard). I think there is even web page in OpenWRT where you can enter command, it will run them and tell you the output. So think about Omnia more like a computer that has more network cards
I do; I want to run system crytical services on my Omnia (such as my personal e-mail server etc.). I do not want them to be down (for a long time) and possibly even be transportable (sadly real migration may require HW virtualisation - which is too demanding - even for an Omnia).
As I am slowly getting adapt at Linux I am still fairly inexperienced. I know enough to make terrible mistakes when tinkering with the system. So once I have a reasonable stable configuration going; I want to snapshot that so when I mess up during later āexperimentationā I can relatively easily switch back to the situation that was stable.
To minimize the snapshotsā overhead (and hence keep disk space at bay e.g. if I indeed use an 64Gb Thumb-drive for instance) I thought a layered approach would be best (only storing the deltaās additionally with each snapshot).
So I think it should be very easy if the original containerās ābacking storeā (I must read up on what that is exactly (I understand that it is where the lxc rootfs is stored)) is a layered-filesystem to begin with. But the text quoted above also suggest that the -B argument may help make an overlayfs when cloning / taking a snapshot from a directory-backed container.
Iāll experiment a little with that!
@nerdpunk Iāll look into that specific one (as it seems to surface in about every how-to/tutorial I read!
The thing is so much to do so little timeā¦ canāt the Omnia be delayed a little more?
apparently it works as such; lxc-clone -s -B overlayfs -o foo -n bar
It should create a clone (bar) of the base container (foo), as an overlay on top of it. That one (the clone ābarā) will have an overlayfs and is hence snapshot-able in a layered fashion from there onwards:
I was confused as at my end it did not work due to a bug - kernel rename of āoverlayfsā to āoverlayā not taken into account - in the Debian package I was/am using (anyone able to verify that it does work in another distro)? Luckily (for me) it is marked as fixed in versions lxc/1:1.1.5-1 though!
B.t.w.: lxc-clone -s -B aufs -o foo -n bar does work for me at this point!
@nerdpunk I read up on it and it seems a nice alternative (not sure whether I am ready to replace ext4 by it though as it still fairly young / not picked up a lot yet). But it sure looks promising!
As āoverlayfsā is in mainline it is supported and work. AUFS AFAIK is not there (neither mainline nor Omnia).
In theory same as everywhere else - LXC and kernel and overlayfs is pretty much the same as on any Linux distribution. But how exactly I canāt tell as I wouldnāt use it via lxc tools if I would use it at all. I would use overlayfs to create rootfs directories I want managing overlays by hand and run lxc on top of those.
Yah (and that should be an option as - like you said - the Omnia can be regarded a small form-factor computer with linux). The reason I am leaning towards using LXC specific tooling is that that seems simpler / delicately build for LXC usage.
I thought to build a directory backed root-fs and clone that one into a new (base) container having an overlayfs (to be used as the base to make layered lxc-snapshots from):
Maybe doing it manually as you are planning on is better though. Or even simply the ānormal/typicalā way to do it, as I can not seem to find any other way. I should read up on how to do that (or could you conceptually sum up the basic steps one should perform to do so?).
for all of you, who want to use unpriviledged LXC containers (with TurrisOS or plain openWrt/LEDE), i got kind of a howto (not a beginners guide, that one is located here), and i hope the devs will pick it up and integrate this into TurrisOS
basically it boils down to:
apply this patch to the packages feed, select and install shadow-newgidmap and shadow-newuidmap
add appropiate values to /etc/subgid and /etc/subuid files
applying this patch (quick and dirty, sry ;)) to an openwrt build root, will enable you to build and install uidmapshift, a utility to shift the uid:gid of an existing container
the last issue gave me a headache for some time, until i digged it up in the kernel sources: procd mounts proc and sys with the noatime flag (which is quite unusual, at least never saw that on another distro), and if lxc mounts proc and sys into another namespace, noatime needs to be set there, too, at least if itās not mounted as root (which is the case for unpriviledged containers, of cause)
long story short: starting an unpriviledged container will fail on openWrt/LEDE, unless you add ānoatimeā to the proc+sys mount options in your containers configā¦ orā¦ imo the better way (because you can stick to default configs, like āproc:mixedā and such) -> use this patch to change procdās mount flags for proc+sys to ārelatimeā, which actually works
