just we are waiting for the delivery WLE1216V5-20 for tests. It is not just about slot compatibility, but also in terms of drivers. Currently, probably not likely that drivers would be able to fully exploit the capabilities of this card.
As you should have received the new card by now - how’s the driver situation and the hardware compatibility?
According to the other thread about the *-18-version the driver now supports the card. But what about specific techniques like beamforming etc - you mentioned it to be not likely
that drivers would be able to fully exploit the capabilities of this card. ?
I would advise you to go with the WLE650V5-25 if you want to have the best TX power per radio chain. It is a perfect card for countries with a EIRP of 100mW ( 20dBm ).
Say that you set an output power of 17 dBm and that you use 2 antennas (x2 the power so +3 dB) with 2 dB lost due to the antenna patchs and 3 dB lost due to the diplexers used by the Omnia and that the antennas for the omnia have a passive gain of 5 dB:
17+3-3-2+5 … 20 dBm
Furthermore, notebooks with 3 radio chains are not common and I do not think I ever met one with 4. So you migth as well spare you the trouble with the power hogs that are those 4*4 cards.
According to my experience, you will not met any problem with the Turris PCIe version 1.0 x1 interface of the mPCIe slot. But it is true that an official answer is long overdue.
I bought the WLE650V5-25 about two weeks ago and tested it.
First of all there are two different versions of the WLE650V5-25 card on the market. The earlier modules use
the QCA8886 and the newer once the QCA9888 - I got one with the QCA9888 SoC.
I tested this module with all sorts of ath10k drivers and none really worked. The best one was this one:
With this driver the card works but with a very weak signal strenght. Even with cables and antennas
attachd to it - the cards behaves like there would be no atennas attached to to card at all.
If someone has an idea what the cause might be, I am happy to continue testing and to post the findings.
@zoverl: as you advertise the -25 - did you get it working? See @Tom’s post above.
For me the -25-card is of no use as it is not capable of using 160MHz and therefore with it you cannot unleash the full power of wave2.
The 44-cards do not require to have a 44 wifi-client as they are using 2SS at 160 MHz!
But they are not completely useable as atm there’s no laptop wifi-card available capable of handling 160 MHz-streams, right? The Intel 9260 has been long advertised, but is still not on the market.
So I will definitely go with a 4*4-card but not before Intel releases the 9260.
@Tom: this maybe because of a card defect, I had something like that before with a Intel card
The Debian project published today an update for the hostapd and the wpasupplicant packages, the software used to make an access point and a sta with a wireless NIC.
So it may be enough to update those softwares without any change to the drivers.
From what I understand, if either the sta or the access point was updated, the vulnerability can not be exploited. To be verified.
