n.b.f
November 9, 2024, 8:15pm
1
In multiple topics I see advice that little plastic bit is moxtet terminator required for proper operation. Is that right? Does moxtet really require termination like that?
This information should be much more visible if correct.
Topics with this “this plastic is a terminator” advice:
Opened it up (never used it yet, waiting for ISP) and found this piece of plastic falling out when I tilted the device.
What is it? Where does it belong? Is it a problem that it fell out?
[PXL_20210701_113558243]
[image] [image]
After Opening I found the WiFi Antennas on module A disconnected. How should they be connected?
There is a small plastic part. Where does it belong to?
BTW: There is a soldering hack where the WiFi card is connected to module A.
