Ok, I did another try. So I first removed all openvpn & tun0 related stuff from NordVPN. Then I thought let’s now try with cleaned up config on emmc first. So I created medkit, flashed it with 4 LED option to internal emmc and then switched with fw_setenv -s boot_emmc.
This worked like a charm and so I started the TOS 5.1.4 (yes it’s actually 5.1.3 not 5.3 sorry for the confusion there) and migration worked perfectly. Had 1-2 small glithes in luci with wifi networks and /etc/fw_config.env beeing erased but that was quickly repaired.
So I thought ok, if the cleanup of my tun0 interface and openvpn did the trick let’s do the exactly same thing when booting from ssd.
But now is where the trouble really begins! It again fucked up the migration of the switch. So currently my 5.1.4 on external ssd still again has no eth0 and you cannot connect to it therefore.
I backup the output of the boot_process from serial console which looks like this jand as you can see there is errors loading firmwares which I don’t get. This is now really beyound my scope:
U-Boot SPL 2015.10-rc2 (Aug 18 2016 - 20:43:35)
High speed PHY - Version: 2.0
SERDES0 card detect: SATA
Initialize Turris board topology
Detected Device ID 6820
board SerDes lanes topology details:
| Lane # | Speed | Type |
| 0 | 6 | SATA0 |
| 1 | 5 | USB3 HOST0 |
| 2 | 5 | PCIe1 |
| 3 | 5 | USB3 HOST1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
poll_op_execute: TIMEOUT
:** Link is Gen1, check the EP capability
PCIe, Idx 2: remains Gen1
DDR3 Training Sequence - Ver TIP-1.29.0
Memory config in EEPROM: 0x02
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
U-Boot 2015.10-rc2 (Aug 18 2016 - 20:43:35 +0200), Build:
jenkins-omnia-master-2
3
SoC: MV88F6820-A0
Watchdog enabled
I2C: ready
SPI: ready
DRAM: 2 GiB (ECC not enabled)
Enabling Armada 385 watchdog.
Disabling MCU startup watchdog.
Regdomain set to **
MMC: mv_sdh: 0
SF: Detected S25FL164K with page size 256 Bytes, erase size 64 KiB,
total 8 MiB
PCI:
00:01.0 - 168c:0040 - Network controller
PCI:
01:00.0 - 11ab:6820 - Memory controller
01:01.0 - 168c:002e - Network controller
Model: Marvell Armada 385 GP
Board: Turris Omnia SN: 0000000B0000F2FD
Regdomain set to **
SCSI: MVEBU SATA INIT
Target spinup took 0 ms.
SATA link 1 timeout.
AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq led only pmp fbss pio slum part sxs
Net: neta2
Hit any key to stop autoboot: 0
Setting bus to 1
BOOT eMMC FS
scanning bus for devices...
Device 0: (0:0) Vendor: ATA Prod.: KINGSTON SMS200S Rev: 60AA
Type: Hard Disk
Capacity: 114473.4 MB = 111.7 GB (234441648 x 512)
Found 1 device(s).
BtrFS init: Max node or leaf size 16384
3349336 bytes read in 134 ms (23.8 MiB/s)
18773 bytes read in 108 ms (168.9 KiB/s)
Kernel image @ 0x1000000 [ 0x000000 - 0x331b58 ]
## Flattened Device Tree blob at 02000000
Booting using the fdt blob at 0x2000000
Loading Device Tree to 0fff8000, end 0ffff954 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.206 (packaging@turris.cz) (gcc version
7.5.0 (
OpenWrt GCC 7.5.0 589c3cf)) #0 SMP Fri Nov 13 04:11:07 2020
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7),
cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing
instructio
n cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] random: get_random_bytes called from
start_kernel+0x8c/0x4cc with
crng_init=0
[ 0.000000] percpu: Embedded 11 pages/cpu s15372 r8192 d21492 u45056
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 522560
[ 0.000000] Kernel command line: earlyprintk console=ttyS0,115200
rootfstype=
btrfs rootwait root=/dev/sda1 rootflags=subvol=@,commit=5 rw
cfg80211.freg=**
[ 0.000000] Bootloader command line not present
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288
bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144
bytes)
[ 0.000000] Memory: 2066968K/2097152K available (7168K kernel code,
239K rwda
ta, 1676K rodata, 1024K init, 257K bss, 30184K reserved, 0K
cma-reserved, 131072
0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
[ 0.000000] .data : 0xc0b00000 - 0xc0b3bc00 ( 239 kB)
[ 0.000000] .bss : 0xc0b3bc00 - 0xc0b7c3d8 ( 258 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C: DT/platform modifies aux control register:
0x06070000 -> 0x1
6070000
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000006] sched_clock: 64 bits at 800MHz, resolution 1ns, wraps
every 43980
46511103ns
[ 0.000016] clocksource: arm_global_timer: mask: 0xffffffffffffffff
max_cycle
s: 0xb881274fa3, max_idle_ns: 440795210636 ns
[ 0.000029] Switching to timer-based delay loop, resolution 1ns
[ 0.000159] Ignoring duplicate/late registration of
read_current_timer delay
[ 0.000166] clocksource: armada_370_xp_clocksource: mask: 0xffffffff
max_cycl
es: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.000335] Console: colour dummy device 80x30
[ 0.000353] Calibrating delay loop (skipped), value calculated using
timer fr
equency.. 1600.00 BogoMIPS (lpj=8000000)
[ 0.000360] pid_max: default: 32768 minimum: 301
[ 0.000421] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000426] Mountpoint-cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 0.000708] CPU: Testing write buffer coherency: ok
[ 0.000720] CPU0: Spectre v2: using BPIALL workaround
[ 0.000840] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.000970] Setting up static identity map for 0x100000 - 0x100060
[ 0.001046] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.001124] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.001175] Hierarchical SRCU implementation.
[ 0.001370] smp: Bringing up secondary CPUs ...
[ 0.001504] Booting CPU 1
[ 0.001660] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.001663] CPU1: Spectre v2: using BPIALL workaround
[ 0.001713] smp: Brought up 1 node, 2 CPUs
[ 0.001718] SMP: Total of 2 processors activated (3200.00 BogoMIPS).
[ 0.001721] CPU: All CPU(s) started in SVC mode.
[ 0.002258] devtmpfs: initialized
[ 0.003867] VFP support v0.3: implementor 41 architecture 3 part 30
variant 9
rev 4
[ 0.003923] clocksource: jiffies: mask: 0xffffffff max_cycles:
0xffffffff, ma
x_idle_ns: 19112604462750000 ns
[ 0.003931] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.003998] xor: measuring software checksum speed
[ 0.100067] arm4regs : 2392.000 MB/sec
[ 0.200067] 8regs : 1861.600 MB/sec
[ 0.300065] 32regs : 2047.600 MB/sec
[ 0.400066] neon : 1837.200 MB/sec
[ 0.400070] xor: using function: arm4regs (2392.000 MB/sec)
[ 0.400076] pinctrl core: initialized pinctrl subsystem
[ 0.400445] NET: Registered protocol family 16
[ 0.400952] DMA: preallocated 256 KiB pool for atomic coherent
allocations
[ 0.401502] cpuidle: using governor ladder
[ 0.401595] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1
watchpoint
registers.
[ 0.401599] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.401722] mvebu-pmsu: CPU hotplug support is currently broken on
Armada 38x
: disabling
[ 0.401728] mvebu-pmsu: CPU idle is currently broken on Armada 38x:
disabling
[ 0.570265] raid6: int32x1 gen() 171 MB/s
[ 0.740169] raid6: int32x1 xor() 243 MB/s
[ 0.910170] raid6: int32x2 gen() 255 MB/s
[ 1.080084] raid6: int32x2 xor() 290 MB/s
[ 1.250249] raid6: int32x4 gen() 304 MB/s
[ 1.420082] raid6: int32x4 xor() 252 MB/s
[ 1.590138] raid6: int32x8 gen() 328 MB/s
[ 1.760114] raid6: int32x8 xor() 229 MB/s
[ 1.930101] raid6: neonx1 gen() 1111 MB/s
[ 2.100090] raid6: neonx1 xor() 1058 MB/s
[ 2.270094] raid6: neonx2 gen() 1303 MB/s
[ 2.440070] raid6: neonx2 xor() 1351 MB/s
[ 2.610094] raid6: neonx4 gen() 1070 MB/s
[ 2.780078] raid6: neonx4 xor() 1328 MB/s
[ 2.950105] raid6: neonx8 gen() 1014 MB/s
[ 3.120071] raid6: neonx8 xor() 914 MB/s
[ 3.120074] raid6: using algorithm neonx2 gen() 1303 MB/s
[ 3.120077] raid6: .... xor() 1351 MB/s, rmw enabled
[ 3.120080] raid6: using neon recovery algorithm
[ 3.120371] SCSI subsystem initialized
[ 3.120587] usbcore: registered new interface driver usbfs
[ 3.120617] usbcore: registered new interface driver hub
[ 3.120646] usbcore: registered new device driver usb
[ 3.121318] clocksource: Switched to clocksource arm_global_timer
[ 3.125223] NET: Registered protocol family 2
[ 3.125491] TCP established hash table entries: 8192 (order: 3, 32768
bytes)
[ 3.125529] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 3.125590] TCP: Hash tables configured (established 8192 bind 8192)
[ 3.125637] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 3.125663] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 3.125758] NET: Registered protocol family 1
[ 3.126090] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7
counter s
available
[ 3.127072] Crashlog allocated RAM at address 0x3f00000
[ 3.127198] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 3.129130] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.129140] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME)
(CMODE_PRIORIT
Y) (c) 2001-2006 Red Hat, Inc.
[ 3.130860] bounce: pool size: 64 pages
[ 3.130870] io scheduler noop registered
[ 3.130874] io scheduler deadline registered (default)
[ 3.131378] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl
driver
[ 3.132706] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[ 3.132719] pci_bus 0000:00: root bus resource [io 0x1000-0xfffff]
[ 3.132724] pci_bus 0000:00: root bus resource [mem
0xe0000000-0xe7ffffff]
[ 3.132729] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.132979] PCI: bus0: Fast back to back transfers disabled
[ 3.132987] pci 0000:00:01.0: bridge configuration invalid ([bus
00-00]), rec
onfiguring
[ 3.132994] pci 0000:00:02.0: bridge configuration invalid ([bus
00-00]), rec
onfiguring
[ 3.132999] pci 0000:00:03.0: bridge configuration invalid ([bus
00-00]), rec
onfiguring
[ 3.133034] PCI: bus1: Fast back to back transfers enabled
[ 3.133235] PCI: bus2: Fast back to back transfers disabled
[ 3.133469] PCI: bus3: Fast back to back transfers disabled
[ 3.133495] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0000000-0xe01fffff]
[ 3.133501] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0200000-0xe02fffff]
[ 3.133506] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 3.133516] pci 0000:02:00.0: BAR 0: assigned [mem
0xe0000000-0xe01fffff 64bi
t]
[ 3.133525] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 3.133530] pci 0000:00:02.0: bridge window [mem 0xe0000000-0xe01fffff]
[ 3.133537] pci 0000:03:00.0: BAR 0: assigned [mem
0xe0200000-0xe020ffff 64bi
t]
[ 3.133546] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 3.133551] pci 0000:00:03.0: bridge window [mem 0xe0200000-0xe02fffff]
[ 3.133787] mv_xor f1060800.xor: Marvell shared XOR driver
[ 3.191779] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor
cpy int r )
[ 3.191902] mv_xor f1060900.xor: Marvell shared XOR driver
[ 3.251757] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor
cpy int r )
[ 3.251982] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 3.253145] console [ttyS0] disabled
[ 3.273216] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 22,
base_baud =
15625000) is a 16550A
[ 4.151364] console [ttyS0] enabled
[ 4.175114] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 23,
base_baud =
[ 4.185929] loop: module loaded
[ 4.189391] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports
6 Gbps 0x3
impl platform mode
[ 4.198480] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only
pmp fbs
pio slum part sxs
[ 4.207644] scsi host0: ahci-mvebu
[ 4.211191] scsi host1: ahci-mvebu
[ 4.214675] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff]
port 0x1 00
irq 44
[ 4.222620] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff]
port 0x1 80
irq 44
[ 4.231360] m25p80 spi0.0: s25fl164k (8192 Kbytes)
[ 4.236233] 2 fixed-partitions partitions found on MTD device spi0.0
[ 4.242619] Creating 2 MTD partitions on "spi0.0":
[ 4.247421] 0x000000000000-0x000000100000 : "U-Boot"
[ 4.252729] 0x000000100000-0x000000800000 : "Rescue system"
[ 4.258781] libphy: Fixed MDIO Bus: probed
[ 4.263228] libphy: orion_mdio_bus: probed
[ 4.267838] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected:
Marvell 8
8E6176, revision 1
[ 4.419503] libphy: mv88e6xxx SMI: probed
[ 4.427319] mvneta f1070000.ethernet eth0: Using hardware mac address
d8:58:d
7:00:5c:d5
[ 4.436087] mvneta f1030000.ethernet eth1: Using hardware mac address
d8:58:d
7:00:5c:d3
[ 4.444784] mvneta f1034000.ethernet eth2: Using hardware mac address
d8:58:d
7:00:5c:d4
[ 4.452969] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.459513] ehci-pci: EHCI PCI platform driver
[ 4.464001] ehci-platform: EHCI generic platform driver
[ 4.469302] ehci-orion: EHCI orion driver
[ 4.473418] orion-ehci f1058000.usb: EHCI Host Controller
[ 4.478839] orion-ehci f1058000.usb: new USB bus registered, assigned
bus num ber 1
[ 4.486479] orion-ehci f1058000.usb: irq 40, io mem 0xf1058000
[ 4.521323] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 4.527545] hub 1-0:1.0: USB hub found
[ 4.531330] hub 1-0:1.0: 1 port detected
[ 4.535613] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 4.540945] xhci-hcd f10f0000.usb3: new USB bus registered, assigned
bus numb er 2
[ 4.548515] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version
0x100 q
uirks 0x0000000000010010
[ 4.557784] xhci-hcd f10f0000.usb3: irq 46, io mem 0xf10f0000
[ 4.563785] hub 2-0:1.0: USB hub found
[ 4.567511] ata2: SATA link down (SStatus 0 SControl 300)
[ 4.567557] hub 2-0:1.0: 1 port detected
[ 4.576994] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 4.582331] xhci-hcd f10f0000.usb3: new USB bus registered, assigned
bus numb er 3
[ 4.589839] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[ 4.596334] usb usb3: We don't know the algorithms for LPM for this
host, dis
abling LPM.
[ 4.604654] hub 3-0:1.0: USB hub found
[ 4.608424] hub 3-0:1.0: 1 port detected
[ 4.612526] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 4.617857] xhci-hcd f10f8000.usb3: new USB bus registered, assigned
bus numb er 4
[ 4.625415] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version
0x100 q
[ 4.634681] xhci-hcd f10f8000.usb3: irq 47, io mem 0xf10f8000
[ 4.640660] hub 4-0:1.0: USB hub found
[ 4.644459] hub 4-0:1.0: 1 port detected
[ 4.648487] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 4.653827] xhci-hcd f10f8000.usb3: new USB bus registered, assigned
bus numb er 5
[ 4.661338] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[ 4.667831] usb usb5: We don't know the algorithms for LPM for this
host, dis
abling LPM.
[ 4.676140] hub 5-0:1.0: USB hub found
[ 4.679910] hub 5-0:1.0: 1 port detected
[ 4.684059] usbcore: registered new interface driver usb-storage
[ 4.690503] armada38x-rtc f10a3800.rtc: registered as rtc0
[ 4.696143] i2c /dev entries driver
[ 4.710134] (NULL device *): hwmon_device_register() is deprecated.
Please co
nvert the driver to use hwmon_device_register_with_info().
[ 4.722617] orion_wdt: Initial timeout 171 sec
[ 4.727325] sdhci: Secure Digital Host Controller Interface driver
[ 4.733531] sdhci: Copyright(c) Pierre Ossman
[ 4.741340] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 4.754549] ata1.00: ATA-8: KINGSTON SMS200S3120G, 60AABBF0, max UDMA/133
[ 4.761416] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 4.773091] ata1.00: configured for UDMA/133
[ 4.777550] scsi 0:0:0:0: Direct-Access ATA KINGSTON SMS200S
BBF0 PQ : 0
ANSI: 5
[ 4.786108] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120
GB/112 GiB)
[ 4.793655] sd 0:0:0:0: [sda] Write Protect is off
[ 4.798493] sd 0:0:0:0: [sda] Write cache: enabled, read cache:
enabled, does
n't support DPO or FUA
[ 4.801320] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci]
using A DMA
[ 4.815015] sda: sda1 sda2 sda3
[ 4.815089] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.818737] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 4.830035] marvell-cesa f1090000.crypto: CESA device successfully
registered
[ 4.837675] NET: Registered protocol family 10
[ 4.842712] Segment Routing with IPv6
[ 4.846410] NET: Registered protocol family 17
[ 4.850878] bridge: filtering via arp/ip/ip6tables is no longer
available by
default. Update your scripts to load br_netfilter if you need this.
[ 4.864085] 8021q: 802.1Q VLAN Support v1.8
[ 4.868357] Registering SWP/SWPB emulation handler
[ 4.877532] Btrfs loaded, crc32c=crc32c-generic
[ 4.883006] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected:
Marvell 8
8E6176, revision 1
[ 4.977981] mmc0: new high speed MMC card at address 0001
[ 4.983558] mmcblk0: mmc0:0001 H8G4a▒ 7.28 GiB
[ 4.988177] mmcblk0boot0: mmc0:0001 H8G4a▒ partition 1 4.00 MiB
[ 4.994189] mmcblk0boot1: mmc0:0001 H8G4a▒ partition 2 4.00 MiB
[ 5.000180] mmcblk0rpmb: mmc0:0001 H8G4a▒ partition 3 4.00 MiB,
chardev (250:
0)
[ 5.008834] mmcblk0: p1
[ 5.011436] usb 4-1: new high-speed USB device number 2 using xhci-hcd
[ 5.080906] libphy: mv88e6xxx SMI: probed
[ 5.084989] DSA: switch 0 0 parsed
[ 5.088403] DSA: tree 0 parsed
[ 5.192963] usb-storage 4-1:1.0: USB Mass Storage device detected
[ 5.199197] scsi host2: usb-storage 4-1:1.0
[ 5.795414] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY
[mv88e6x
xx-1:00] driver [Marvell 88E1540]
[ 5.917650] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY
[mv88e6x
xx-1:01] driver [Marvell 88E1540]
[ 6.035416] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY
[mv88e6x
xx-1:02] driver [Marvell 88E1540]
[ 6.155420] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY
[mv88e6x
xx-1:03] driver [Marvell 88E1540]
[ 6.231890] scsi 2:0:0:0: Direct-Access Corsair Voyager Mini
0.00 PQ : 0
ANSI: 2
[ 6.240950] sd 2:0:0:0: [sdb] 31582352 512-byte logical blocks: (16.2
GB/15.1 GiB)
[ 6.248800] sd 2:0:0:0: [sdb] Write Protect is off
[ 6.253861] sd 2:0:0:0: [sdb] Asking for cache data failed
[ 6.259360] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.277674] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY
[mv88e6x
xx-1:04] driver [Marvell 88E1540]
[ 6.297942] armada38x-rtc f10a3800.rtc: setting system clock to
2021-01-03 17
:31:27 UTC (1609695087)
[ 6.697954] sdb: sdb1
[ 7.276027] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 7.287994] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 7.294814] F2FS-fs (sda1): Can't find valid F2FS filesystem in 1th
superbloc k
[ 7.302175] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 7.308978] F2FS-fs (sda1): Can't find valid F2FS filesystem in 2th
superbloc k
[ 7.316230] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 7.323044] F2FS-fs (sda1): Can't find valid F2FS filesystem in 1th
superbloc k
[ 7.330282] F2FS-fs (sda1): Magic Mismatch, valid(0xf2f52010) - read(0x0)
[ 7.337089] F2FS-fs (sda1): Can't find valid F2FS filesystem in 2th
superbloc k
[ 7.344786] BTRFS: device fsid f80a2b71-e64c-4b82-8663-338426af3b3d
devid 1 t
ransid 31350 /dev/root
[ 7.354218] BTRFS info (device sda1): disk space caching is enabled
[ 7.360501] BTRFS info (device sda1): has skinny extents
[ 7.375802] BTRFS info (device sda1): enabling ssd optimizations
[ 7.385979] VFS: Mounted root (btrfs filesystem) on device 0:12.
[ 7.392641] devtmpfs: mounted
[ 7.396185] Freeing unused kernel memory: 1024K
[ 7.454645] init: Console is alive
[ 7.458114] init: - watchdog -
[ 7.489426] random: fast init done
[ 7.538818] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 7.548995] usbcore: registered new interface driver uas
[ 7.554402] kmodloader: done loading kernel modules from
[ 7.564251] init: - preinit -
[ 7.625133] random: jshn: uninitialized urandom read (4 bytes read)
[ 7.642266] random: jshn: uninitialized urandom read (4 bytes read)
ls: /sys/bus/pci/devices/0000:00:01.0/000*/iee*/phy*: No such file or
directory
ls: /sys/bus/pci/devices/0000:00:02.0/000*/iee*/phy*: No such f[
7.674615] ra
ile or directory
ls: /sys/bus/pci/devices/0000:00:03.0/000*/iee*/phy*: No such file or
directory
RTNETLINK answers: Network is down
sendto(): Network unreachable
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 10.772934] mount_root: mounting /dev/root
[ 10.777522] BTRFS info (device sda1): disk space caching is enabled
Failed to find nls_cp437. Maybe it is a built in module ?
Failed to find nls_iso8859-1. Maybe it is a built in module ?
Failed to find fat. Maybe it is a built in module ?
Failed to find vfat. Maybe it is a built in module ?
Log: api: open_ni2c_dev: Couldn't open native I2C device.
Device couldn't be opened.
Scanning for Btrfs filesystems
[ 11.433283] BTRFS: device fsid cbadfbf2-ae27-4c41-97d4-e1ec7ab947d5
devid 1 t
ransid 488 /dev/mmcblk0p1
[ 11.442747] BTRFS: device label srv devid 1 transid 104 /dev/sda3
[ 11.457484] procd: - early -
[ 11.460396] procd: - watchdog -
[ 12.077782] procd: - watchdog -
[ 12.081035] procd: - ubus -
[ 12.087775] urandom_read: 2 callbacks suppressed
[ 12.087778] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.134125] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.140634] random: ubusd: uninitialized urandom read (4 bytes read)
[ 12.147411] procd: - init -
Please press Enter to activate this console.
[ 12.301212] kmodloader: loading kernel modules from /etc/modules.d/*
[ 12.313220] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 12.323170] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 12.333677] Netfilter messages via NETLINK v0.30.
[ 12.339246] ip_set: protocol 6
[ 12.370746] i2c i2c-0: Added multiplexed i2c bus 1
[ 12.376024] i2c i2c-0: Added multiplexed i2c bus 2
[ 12.386245] i2c i2c-0: Added multiplexed i2c bus 3
[ 12.391599] i2c i2c-0: Added multiplexed i2c bus 4
[ 12.405196] i2c i2c-0: Added multiplexed i2c bus 5
[ 12.410414] i2c i2c-0: Added multiplexed i2c bus 6
[ 12.417228] i2c i2c-0: Added multiplexed i2c bus 7
[ 12.422816] pca953x 8-0071: 8-0071 supply vcc not found, using dummy
regulato r
[ 12.441546] i2c i2c-0: Added multiplexed i2c bus 8
[ 12.446354] pca954x 0-0070: registered 8 multiplexed busses for I2C
mux pca95 47
[ 12.460320] Mirror/redirect action on
[ 12.477364] u32 classifier
[ 12.480080] input device check on
[ 12.483791] Actions configured
[ 12.490860] sch_cake: Unknown symbol nf_conntrack_find_get (err 0)
[ 12.497206] sch_cake: Unknown symbol nf_ct_get_tuplepr (err 0)
[ 12.524098] Bridge firewalling registered
[ 12.528845] usbcore: registered new interface driver cdc_wdm
[ 12.539777] Loading modules backported from Linux version
v4.19.137-0-gc076c7
9e03c6
[ 12.547482] Backport generated by backports.git v4.19.137-1-0-g60c3a249
[ 12.558982] Ebtables v2.0 registered
[ 12.563835] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 12.575019] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 12.583457] ctnetlink v0.93: registering with nfnetlink.
[ 12.590700] random: crng init done
[ 12.594163] random: 2 urandom warning(s) missed due to ratelimiting
[ 12.605541] usbcore: registered new interface driver ums-alauda
[ 12.611946] usbcore: registered new interface driver ums-cypress
[ 12.618399] usbcore: registered new interface driver ums-datafab
[ 12.624983] usbcore: registered new interface driver ums-freecom
[ 12.631374] usbcore: registered new interface driver ums-isd200
[ 12.637775] usbcore: registered new interface driver ums-jumpshot
[ 12.644531] usbcore: registered new interface driver ums-karma
[ 12.650951] usbcore: registered new interface driver ums-sddr09
[ 12.657388] usbcore: registered new interface driver ums-sddr55
[ 12.663988] usbcore: registered new interface driver ums-usbat
[ 12.673177] usbcore: registered new interface driver usbserial
[ 12.679081] usbcore: registered new interface driver usbserial_generic
[ 12.685692] usbserial: USB Serial support registered for generic
[ 12.703195] xt_time: kernel timezone is -0000
[ 12.708895] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[ 12.716792] usbcore: registered new interface driver cdc_ncm
[ 12.734436] usbcore: registered new interface driver huawei_cdc_ncm
[ 12.758871] PPP generic driver version 2.4.2
[ 12.764022] NET: Registered protocol family 24
[ 12.780047] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 12.786095] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2
irq_mode 0 r
eset_mode 0
[ 12.962726] ath10k_pci 0000:02:00.0: Direct firmware load for
ath10k/pre-cal-
pci-0000:02:00.0.bin failed with error -2
[ 12.973488] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.806899] firmware ath10k!pre-cal-pci-0000:02:00.0.bin:
firmware_loading_st
ore: map pages failed
[ 14.816015] ath10k_pci 0000:02:00.0: Direct firmware load for
ath10k/cal-pci-
[ 14.826430] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.837017] firmware ath10k!cal-pci-0000:02:00.0.bin:
firmware_loading_store:
map pages failed
[ 14.845824] ath10k_pci 0000:02:00.0: Direct firmware load for
ath10k/QCA99X0/
hw2.0/firmware-6.bin failed with error -2
[ 14.856565] ath10k_pci 0000:02:00.0: Falling back to user helper
[ 14.867097] firmware ath10k!QCA99X0!hw2.0!firmware-6.bin:
firmware_loading_st
[ 14.885870] ath10k_pci 0000:02:00.0: qca99x0 hw2.0 target 0x01000000
chip_id
0x003b01ff sub 168c:0002
[ 14.895143] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1
tracing 0 dfs
1 testmode 1
[ 14.905896] ath10k_pci 0000:02:00.0: firmware ver 10.4.1.00030-1 api
5 featur es
no-p2p crc32 d2901e01
[ 16.362757] ath10k_pci 0000:02:00.0: board_file api 2 bmi_id 1:1
crc32 08fa09 f2
[ 18.956156] ath10k_pci 0000:02:00.0: htt-ver 2.2 wmi-op 6 htt-op 4
cal otp ma
x-sta 512 raw 0 hwcrypto 1
[ 19.061494] usbcore: registered new interface driver option
[ 19.067126] usbserial: USB Serial support registered for GSM modem
(1-port)
[ 19.076364] usbcore: registered new interface driver qcserial
[ 19.082210] usbserial: USB Serial support registered for Qualcomm USB
modem
[ 19.095187] pci 0000:00:03.0: enabling device (0140 -> 0142)
[ 19.203373] ieee80211 phy1: Atheros AR9287 Rev:2 mem=0xf10e0000, irq=79
[ 19.211413] kmodloader: done loading kernel modules from /etc/modules.d/*
Router Turris successfully started.
So now I have 2 questions:
- can it easily be fixe by adjusting some paths or something as I left the non-working 5.1.4 on the ssd intact?
- if not, will erasing the ssd contents and re-deploying a fresh medkit from emmc solve the problem or will it show the same broken firmware loading issues?
Oh and btw. Upgrading to TOS 5.1.4 kills the file /etc/fw_env.config which I think is a very bad thing cause you have to hunt the forums afterwards to recreate it before you can again switch from emmc to ssd and back.
So any help in fixing those firmware loading errors I would really appreciate as it goes beyound my knowledge. Maybe @vcunat or @Pepe can shed some light here or some other dev that is familiar with boot process and devices initizialisation.
