Issue:
Turris can not provide v6-Internet if the upstream Internet-router was rebooted (or was completely down).
Normal:
Turris provides v6 + v4 to hosts in the network, works mostly fine.
v4 (static) always operational.
Question:
- How can I overcome this v6 failure?
- How to enable Turris to re-connect v6 ?
- Workaround in dhcp possible? Known bug??
Thank you very much in advance for help and hints!!
Situation / Details
Devices
- requesting router: Turris Omnia - rtrom01, OS 3.11.4, ICMP Reachable, config firewall, routing: factory default;
- delegating router: Fritz 7430, FRITZ!OS 07.01
- Layout: like in RFC 3633 page 3
(+ 2. Turris for testing purpose having default factory settings; same behaviour like 1st Turris) - ISP: v6 native Hansenet + v4 Telefonica; v6 native Hansenet provides Prefix Delegation
Case 1:
First boot Fritz. When up and connected boot up Turris. Hosts are connected to Turris by Ethernet LAN (+ WLAN hosts)
Works fine.
Hosts connect via v6 or v4 to Internet.
IA-PD from Fritz is fine.
„ip a“ on hosts shows global address like
inet6 2a01:c23:6859:5bfc::8c0/128 scope global dynamic noprefixroute
inet6 2a01:c23:6859:5bfc:30df:de32:64:7fa5/64 scope global temporary dynamic
inet6 2a01:c23:6859:5bfc:76da:38ff:fea1:2659/64 scope global dynamic mngtmpaddr noprefixroute
Turris shows in Luci-GUI:
Typ: dhcpv6-pd
Prefix Delegated: 2a01:c23:6859:5bfc::/62
Adresse: 2a01:c23:6859:5b00:da58:d7ff:fe00:268c/64
Gateway: fe80::7eff:4dff:fec6:f7a
DNS 1: fd00::7eff:4dff:fec6:f7a
Case 2:
We start like case 1, everything fine.
Then reboot Fritz. Or power down Fritz. Then reboot Fritz. Immediately or hours later (no difference).
Unchanged: Turris, Hosts (permanently up and running).
Problem:
- No v6 connect to Internet any more for Hosts (LAN, WLAN). Does not come back within hours.
„ip a“ on Host shows
inet6 2a01:c23:6859:5bfc:30df:de32:64:7fa5/64 scope global temporary deprecated dynamic
inet6 2a01:c23:6859:5bfc:76da:38ff:fea1:2659/64 scope global deprecated dynamic mngtmpaddr noprefixroute
all ping-able.
Typ: dhcpv6
Adresse: 2a01:c23:742e:f400:da58:d7ff:fe00:268c/64
Case 3:
Case 1 + Case 2 + Turris rebooted
Works fine like Case 1.
------- Case 1 example / samples -------------
root@turris:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br-lan state UP group default qlen 532
link/ether d8:ZZ:ZZ:ZZ:ZZ:8b brd ff:ff:ff:ff:ff:ff
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 532
link/ether d8:ZZ:ZZ:ZZ:ZZ:8c brd ff:ff:ff:ff:ff:ff
inet 192.168.ZZZ.222/24 brd 192.168.ZZZ.255 scope global eth1
inet6 2a01:c23:6859:5b00:da58:d7ff:fe00:268c/64 scope global noprefixroute dynamic
valid_lft 6884sec preferred_lft 3284sec
inet6 fe80::da58:d7ff:fe00:268c/64 scope link
4: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br-lan state UP group default qlen 532
link/ether d8:ZZ:ZZ:ZZ:ZZ:8d brd ff:ff:ff:ff:ff:ff
5: ifb0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether 72:ZZ:ZZ:ZZ:ZZ:82 brd ff:ff:ff:ff:ff:ff
6: ifb1: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 32
link/ether 06:ZZ:ZZ:ZZ:ZZ:d8 brd ff:ff:ff:ff:ff:ff
8: teql0: mtu 1500 qdisc noop state DOWN group default qlen 100
link/void
10: br-lan: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.ZZZ.Z1/24 brd 192.168.ZZZ.255 scope global br-lan
inet6 2a01:c23:6859:5bfc::1/62 scope global noprefixroute dynamic
valid_lft 6660sec preferred_lft 3060sec
inet6 fd13:5c6a:a163::1/60 scope global noprefixroute
inet6 fe80::da58:d7ff:fe00:268b/64 scope link
11: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master br-lan state UP group default qlen 1000
link/ether 04:ZZ:ZZ:ZZ:ZZ:5f brd ff:ff:ff:ff:ff:ff
inet6 fe80::6f0:21ff:fe24:b5f/64 scope link
12: wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master br-lan state UP group default qlen 1000
link/ether 04:ZZ:ZZ:ZZ:ZZ:8b brd ff:ff:ff:ff:ff:ff
inet6 fe80::6f0:21ff:fe23:3d8b/64 scope link
Host:
enp6s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1280 qdisc fq_codel state UP group default qlen 1000
link/ether 74:da:ZZ:ZZ:ZZ:59 brd ff:ff:ff:ff:ff:ff
inet 192.168.ZZZ.Z3/24 brd 192.168.ZZZ.255 scope global noprefixroute enp6s0
inet6 fd13:5c6a:a163::8c0/128 scope global noprefixroute
valid_lft 6527sec preferred_lft 2927sec
inet6 fd13:5c6a:a163:0:30df:de32:64:7fa5/64 scope global temporary dynamic
valid_lft 7088sec preferred_lft 1688sec
inet6 fd13:5c6a:a163:0:76da:38ff:fea1:2659/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 6526sec preferred_lft 1688sec
inet6 fe80::76da:38ff:fea1:2659/64 scope link noprefixroute
Host:
:~$ ip -6 route show
2a01:c23:6859:5bfc::8c0 dev enp6s0 proto kernel metric 101 pref medium
2a01:c23:6859:5bfc::/64 dev enp6s0 proto ra metric 101 pref medium
2a01:c23:6859:5bfc::/62 via fe80::da58:d7ff:fe00:268b dev enp6s0 proto ra metric 101 pref medium
fd13:5c6a:a163::8c0 dev enp6s0 proto kernel metric 101 pref medium
fd13:5c6a:a163::/64 dev enp6s0 proto ra metric 101 pref medium
fd13:5c6a:a163::/48 via fe80::da58:d7ff:fe00:268b dev enp6s0 proto ra metric 101 pref medium
fe80::/64 dev enp6s0 proto kernel metric 101 pref medium
default via fe80::da58:d7ff:fe00:268b dev enp6s0 proto ra metric 20101 pref medium
Host:
:~$ netstat -rn -A inet6
Kernel IPv6 routing table
Destination Next Hop Flag Met Ref Use If
::1/128 :: U 256 1 0 lo
2a01:c23:6859:5bfc::8c0/128 :: U 101 1 0 enp6s0
2a01:c23:6859:5bfc::/64 :: U 101 5 145 enp6s0
2a01:c23:6859:5bfc::/62 fe80::da58:d7ff:fe00:268b UG 101 1 0 enp6s0
fd13:5c6a:a163::8c0/128 :: U 101 1 0 enp6s0
fd13:5c6a:a163::/64 :: U 101 5 401 enp6s0
fd13:5c6a:a163::/48 fe80::da58:d7ff:fe00:268b UG 101 1 0 enp6s0
fe80::/64 :: U 101 1 0 enp6s0
::/0 fe80::da58:d7ff:fe00:268b UG 20101 5 2061 enp6s0
::1/128 :: Un 0 6 20 lo
2a01:c23:6859:5bfc::8c0/128 :: Un 0 2 0 enp6s0
2a01:c23:6859:5bfc:30df:de32:64:7fa5/128 :: Un 0 5 816 enp6s0
2a01:c23:6859:5bfc:76da:38ff:fea1:2659/128 :: Un 0 2 0 enp6s0
fd13:5c6a:a163::8c0/128 :: Un 0 2 0 enp6s0
fd13:5c6a:a163:0:30df:de32:64:7fa5/128 :: Un 0 5 527 enp6s0
fd13:5c6a:a163:0:76da:38ff:fea1:2659/128 :: Un 0 2 0 enp6s0
fe80::76da:38ff:fea1:2659/128 :: Un 0 5 185 enp6s0
ff00::/8 :: U 256 5 308 enp6s0
::/0 :: !n -1 1 1 lo
WLAN Host:
wlan1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether f0:d5:ZZ:ZZ:ZZ:d5 brd ff:ff:ff:ff:ff:ff
inet 192.168.ZZZ.Z85/24 brd 192.168.ZZZ.255 scope global noprefixroute wlan1
inet6 fd13:5c6a:a163::90f/128 scope global noprefixroute
inet6 2a01:c23:6859:5bfc::90f/128 scope global dynamic noprefixroute
valid_lft 5131sec preferred_lft 1531sec
inet6 fd13:5c6a:a163:0:4ce0:b395:57d7:908f/64 scope global dynamic noprefixroute
valid_lft 7094sec preferred_lft 1694sec
inet6 2a01:c23:6859:5bfc:f797:d2fe:d373:a4ae/64 scope global dynamic noprefixroute
valid_lft 6931sec preferred_lft 1694sec
inet6 fe80::29ef:d330:685:fc7/64 scope link noprefixroute
::1 dev lo proto kernel metric 256 pref medium
2a01:c23:6859:5bfc::90f dev wlan1 proto kernel metric 600 pref medium
2a01:c23:6859:5bfc::/64 dev wlan1 proto ra metric 600 pref medium
2a01:c23:6859:5bfc::/62 via fe80::da58:d7ff:fe00:268b dev wlan1 proto ra metric 600 pref medium
fd13:5c6a:a163::90f dev wlan1 proto kernel metric 600 pref medium
fd13:5c6a:a163::/64 dev wlan1 proto ra metric 600 pref medium
fd13:5c6a:a163::/48 via fe80::da58:d7ff:fe00:268b dev wlan1 proto ra metric 600 pref medium
fe80::/64 dev wlan1 proto kernel metric 600 pref medium
default via fe80::da58:d7ff:fe00:268b dev wlan1 proto ra metric 20600 pref medium
::1/128 :: U 256 2 0 lo
2a01:c23:6859:5bfc::90f/128 :: U 600 1 0 wlan1
2a01:c23:6859:5bfc::/64 :: U 600 1 0 wlan1
2a01:c23:6859:5bfc::/62 fe80::da58:d7ff:fe00:268b UG 600 1 0 wlan1
fd13:5c6a:a163::90f/128 :: U 600 1 0 wlan1
fd13:5c6a:a163::/64 :: U 600 1 0 wlan1
fd13:5c6a:a163::/48 fe80::da58:d7ff:fe00:268b UG 600 1 0 wlan1
fe80::/64 :: U 600 2 0 wlan1
::/0 fe80::da58:d7ff:fe00:268b UG 20600 5 0 wlan1
::1/128 :: Un 0 6 0 lo
2a01:c23:6859:5bfc::90f/128 :: Un 0 4 0 wlan1
2a01:c23:6859:5bfc:f797:d2fe:d373:a4ae/128 :: Un 0 4 0 wlan1
fd13:5c6a:a163::90f/128 :: Un 0 2 0 wlan1
fd13:5c6a:a163:0:4ce0:b395:57d7:908f/128 :: Un 0 4 0 wlan1
fe80::29ef:d330:685:fc7/128 :: Un 0 5 0 wlan1
ff00::/8 :: U 256 6 0 wlan1
::/0 :: !n -1 1 0 lo
------- Case 2 example samples -------------
Case 2:
Fritz rebooted.
Problem:
- No v6 connect to Internet any more for Hosts. Does not come back within hours.
Typ: dhcpv6
Turris:
_turris:~# ip -6 route show
default from 2a01:c23:742e:f400::/64 via fe80::7eff:4dff:fec6:f7a dev eth1 proto static metric 512
default from fd00::/64 via fe80::7eff:4dff:fec6:f7a dev eth1 proto static metric 512
2a01:c23:742e:f400::/56 from 2a01:c23:742e:f400::/64 via fe80::7eff:4dff:fec6:f7a dev eth1 proto static metric 512
2a01:c23:742e:f400::/56 from fd00::/64 via fe80::7eff:4dff:fec6:f7a dev eth1 proto static metric 512
2a01:c23:742e:f400::/64 dev eth1 proto static metric 256
fd00::/64 dev eth1 proto static metric 256
fd13:5c6a:a163::/64 dev br-lan proto static metric 1024
unreachable fd13:5c6a:a163::/48 dev lo proto static metric 2147483647 error -113
fe80::/64 dev br-lan proto kernel metric 256
fe80::/64 dev wlan0 proto kernel metric 256
fe80::/64 dev wlan1 proto kernel metric 256
fe80::/64 dev eth1 proto kernel metric 256
_turris:~# route -A inet6
Destination Next Hop Flags Metric Ref Use Iface
::/0 fe80::7eff:4dff:fec6:f7a UG 512 2 78 eth1
::/0 fe80::7eff:4dff:fec6:f7a UG 512 0 0 eth1
2a01:c23:742e:f400::/56 fe80::7eff:4dff:fec6:f7a UG 512 0 0 eth1
2a01:c23:742e:f400::/64 :: U 256 2 5 eth1
fd00::/64 :: U 256 0 0 eth1
fd00::/64 fe80::7eff:4dff:fec6:f7a UG 512 0 0 eth1
fd13:5c6a:a163::/64 :: U 1024 2 908 br-lan
fd13:5c6a:a163::/48 :: !n 2147483647 0 0 lo
fe80::/64 :: U 256 2 55 br-lan
fe80::/64 :: U 256 0 0 wlan0
fe80::/64 :: U 256 0 0 wlan1
fe80::/64 :: U 256 0 0 eth1
::/0 :: !n -1 1 235678 lo
::1/128 :: Un 0 3 37 lo
2a01:c23:6859:5bfc::/128 :: Un 0 1 0 lo
2a01:c23:6859:5bfc::1/128 :: Un 0 3 365 lo
2a01:c23:742e:f400::/128 :: Un 0 1 0 lo
2a01:c23:742e:f400:da58:d7ff:fe00:268c/128 :: Un 0 3 83 lo
fd00::/128 :: Un 0 1 0 lo
fd00::da58:d7ff:fe00:268c/128 :: Un 0 1 0 lo
fd13:5c6a:a163::/128 :: Un 0 1 0 lo
fd13:5c6a:a163::1/128 :: Un 0 3 992 lo
fe80::/128 :: Un 0 1 0 lo
fe80::6f0:21ff:fe23:3d8b/128 :: Un 0 1 0 lo
fe80::6f0:21ff:fe24:b5f/128 :: Un 0 1 0 lo
fe80::da58:d7ff:fe00:268b/128 :: Un 0 3 788 lo
fe80::da58:d7ff:fe00:268c/128 :: Un 0 2 600 lo
ff00::/8 :: U 256 2 2948 br-lan
ff00::/8 :: U 256 0 0 wlan0
ff00::/8 :: U 256 0 0 wlan1
ff00::/8 :: U 256 2 192 eth1
root@turris:~# ip a
inet6 2a01:c23:742e:f400:da58:d7ff:fe00:268c/64 scope global noprefixroute dynamic
valid_lft 7027sec preferred_lft 3427sec
inet6 fd00::da58:d7ff:fe00:268c/64 scope global deprecated noprefixroute dynamic
valid_lft 7027sec preferred_lft 0sec
link/void
inet6 2a01:c23:6859:5bfc::1/62 scope global deprecated noprefixroute dynamic
valid_lft 6252sec preferred_lft 0sec
Host:
valid_lft 5781sec preferred_lft 2181sec
valid_lft 7039sec preferred_lft 1639sec
valid_lft 5782sec preferred_lft 0sec
Host
2a01:c23:6859:5bfc::/64 :: U 101 5 193 enp6s0
fd13:5c6a:a163::/64 :: U 101 5 477 enp6s0
2a01:c23:6859:5bfc::8c0/128 :: Un 0 3 3 enp6s0
2a01:c23:6859:5bfc:30df:de32:64:7fa5/128 :: Un 0 6 859 enp6s0
2a01:c23:6859:5bfc:76da:38ff:fea1:2659/128 :: Un 0 4 3 enp6s0
fd13:5c6a:a163:0:30df:de32:64:7fa5/128 :: Un 0 5 597 enp6s0
fe80::76da:38ff:fea1:2659/128 :: Un 0 5 233 enp6s0
ff00::/8 :: U 256 5 369 enp6s0
Fritz in Case2:
IPv6-Adresse: 2a01:c23:7600:6e46:7eff:4dff:fec6:f7d, GĂĽltigkeit: 258603/172203s,
IPv6-Präfix: 2a01:c23:742e:f400::/56, Gültigkeit: 257585/171185s
ULA Unique Local Address FRITZ!Box: fd00::7eff:4dff:fec6:f7a/64
Lokaler DNSv6-Server: fd00:0:0:0:7eff:4dff:fec6:f7a Yes:DNSv6-Server auch ĂĽber Router Advertisement bekanntgeben (RFC 5006)
