First of all, let me say thanks for this project. I love the idea, motivation and dedication.
However, it might just not be for me as I just can’t get many things to work. I bought four Omnias from Amazon and I only have a few days left to possibly return them. I tried everything I could find on the forum running anything from stable to night builds.
Assembly wasn’t stellar. I had to open up and fix things in three out of four devices (LED button stuck in case, LEDs misaligned on the case front, etc. Nothing big, my issues are really the software side.
1.) 5Ghz Wifi is still unstable. Android devices often disconnect claiming “no internet”. This has become worse since Turris 3.6 release. Some posts say it’s the driver, for some the 5ghz card doesn’t even reliability appear in PCI after reboot. For me the card appears, but Android clients keep dropping off. I tried all channels, different channel widths, power settings, country settings, antennas, router locations. No fix. I could try a better Wifi module like the R11e-5HacT, but I’m sort of running out of time and really would like to get the hardware I bought to work.
2.) [Fixed] DNSSEC was always reported as working fine in Foris connection check before 3.6. Now it’s red with forwarding and green without. On the other hand, https://www.dnssec.cz/ always displays green, but other test sites don’t agree. I’m lost here, as I know too little about DNSSEC. From what I found on Google it should work with my provider (Deutsche Telekom VDSL).
3.) Disabling forwarding makes DNS super slow. I guess I understand why that it is and that’s probably by design. But could it cache resolved entries longer then?
4.) Updater.sh usually worked fine when running in console, but never when scheduled. I always got the famous /tmp/crl.pem missing errors. I understand that this may just mean WAN connection not available and this should be reported differently in recent builds, but that’s not true. I setup continuous connection tests and there wasn’t even a single glitch when the updater runs and fails. One time I caught it on the console also failing to resolve api.turris.cz. Also, sort of well-known and reported on the forum. I think this actually has something to do with DNS not reliably working. Since 3.6 I’m not getting any messages in Foris regarding updates. Neither failed nor positive ones.
5.) The dhcp-sequential-ip option of dnsmasq somehow doesn’t work. The option in LUCI doesn’t work as the setting is never transformed to /var/etc/dnsmasq.conf. But also, when putting it directly in /etc/dnsmasq.conf (included from /var/etc/dnsmasq.conf) it simply doesn’t work.
6.) [Fixed] Tiny, but LED brightness is always lost after reboot. I usually run it at the lowest setting. The “brightness step” is remembered after reboot, but not the brightness itself. So, I get max brightness after reboot, but after one push of the button LEDs turn completely off.
About my configuration:
• I disabled IPv6 as described on How can I disable IPV6 as my ISP doesn’t provide it. I also set option net_ipv6 ‘0’.
• I configured forwarding to dnsmasq as described on Dnsmasq .lan domain while still using knot resolver as I really need dhcp hostnames to resolve. Also, I think this really should work by default.
• I’m running the Turris behind a TPLINK Archer VR200v. I have the turris configured as DMZ host on the VR200v, so everything is forwarded to it. This also appears to work, even with dynamic upnp mappings on the Turris.
I wouldn’t mind providing remoter access and paying someone to at least look into the issues. I’d hate to send the Omnias back, but I also can’t have 1360 EUR of unstable devices lying around.
Thanks and best regards
