root@turris:~# cat /etc/os-release
NAME="TurrisOS"
VERSION="4.0.1"
ID="turrisos"
ID_LIKE="lede openwrt"
PRETTY_NAME="TurrisOS 4.0.1"
VERSION_ID="4.0.1"
HOME_URL="https://www.turris.cz/"
BUG_URL="https://gitlab.labs.nic.cz/groups/turris/-/issues"
SUPPORT_URL="https://www.turris.cz/support/"
BUILD_ID="80076f9"
LEDE_BOARD="mvebu/cortexa9"
LEDE_ARCH="arm_cortex-a9_vfpv3"
LEDE_TAINTS="busybox"
LEDE_DEVICE_MANUFACTURER="CZ.NIC"
LEDE_DEVICE_MANUFACTURER_URL="https://www.turris.cz"
LEDE_DEVICE_PRODUCT="Turris Omnia"
LEDE_DEVICE_REVISION="v0"
LEDE_RELEASE="TurrisOS 4.0.1 80076f9"
root@turris:~# uname -a
Linux turris 4.14.148 #0 SMP Tue Oct 8 23:24:25 2019 armv7l GNU/Linux
root@turris:~# cat /etc/hotplug.d/net/20-smp-tune
#!/bin/sh
[ "$ACTION" = add ] || exit
NPROCS="$(grep -c "^processor.*:" /proc/cpuinfo)"
[ "$NPROCS" -gt 1 ] || exit
PROC_MASK="$(( (1 << $NPROCS) - 1 ))"
find_irq_cpu() {
local dev="$1"
local match="$(grep -m 1 "$dev\$" /proc/interrupts)"
local cpu=0
[ -n "$match" ] && {
set -- $match
shift
for cur in `seq 1 $NPROCS`; do
[ "$1" -gt 0 ] && {
cpu=$(($cur - 1))
break
shift
done
echo "$cpu"
set_hex_val() {
local file="$1"
local val="$2"
val="$(printf %x "$val")"
[ -n "$DEBUG" ] && echo "$file = $val"
echo "$val" > "$file"
default_ps="$(uci get "network.@globals[0].default_ps")"
[ -n "$default_ps" -a "$default_ps" != 1 ] && exit 0
exec 512>/var/lock/smp_tune.lock
flock 512 || exit 1
for dev in /sys/class/net/*; do
[ -d "$dev" ] || continue
# ignore virtual interfaces
[ -n "$(ls "${dev}/" | grep '^lower_')" ] && continue
[ -d "${dev}/device" ] || continue
device="$(readlink "${dev}/device")"
device="$(basename "$device")"
irq_cpu="$(find_irq_cpu "$device")"
irq_cpu_mask="$((1 << $irq_cpu))"
for q in ${dev}/queues/rx-*; do
set_hex_val "$q/rps_cpus" "$(($PROC_MASK & ~$irq_cpu_mask))"
done
ntxq="$(ls -d ${dev}/queues/tx-* | wc -l)"
idx=$(($irq_cpu + 1))
for q in ${dev}/queues/tx-*; do
set_hex_val "$q/xps_cpus" "$((1 << $idx))"
let "idx = idx + 1"
[ "$idx" -ge "$NPROCS" ] && idx=0
done
done
So it looks like TOS4 inherited the new rps distribution code from OpenWrt (as it should).
But while the new method ostensibly makes sense, it starts to fail once the router comes under heavy sirq loads, like wifi and especially traffic shaping, as then eveything competes for a single CPU while tho other idles. Sure, processing packets coming in on CPU0 on CPU1 causes cross-CPU traffic and will not be ideal in regards to caching, but if the processing CPU is maxed out even these inefficiencies allow for greater performance. So at least for mvebu ipq8XXX devices the new defaults are less than ideal. I am not sure of the anything goes the “echo 3” essentially configures on dual core devices is the optimum, but it certainly helps once the router gets into heavy lifting. With internet access links getting faster and faster I believe the heavy lifting scenario will rather get more common…
I believe that /etc/hotplug.d/net/20-smp-tune might not be ideal for mvebu socs like the omnia, but the permant solution is to either change 20/smp-tune or add another script to tune on mvebu…
Thanks, these seem relevant, and as far as I can tell these will come in once TOS is based on either the elusive 19.7 or whatever comes after that. Unless someone backports these.
One year, a lot of testing and regular correspondence with the MOX support team later here an update on the situation:
The support was not helpful at all. Every few months I would get an email asking if the issue still exists, so I would reply with “yes it still exists” and provided renewed speed tests and my MOX logs, I factory reset the MOX multiple times, I tried minimal installations. After that nothing would happen and after a few months the cycle would repeat.
Last month there was a break through, I got asked to send my MOX in, so I did. But the result was really disappointing.
First the complaint report stated that there was an issue with the SDIO Wi-Fi (which was not the reason why I send it in).
Second the external antenna of the SDIO Wi-Fi were not connected.
And the WAN bottleneck still persists. Here my latest Iperf3 WAN tests:
Accepted connection from 192.168.2.20, port 57413
[ 5] local 192.168.2.30 port 5201 connected to 192.168.2.20 port 57414
To replicate the WAN test follow this guide https://www.tp-link.com/se/support/faq/2408/
You maybe have to set a firewall rule to allow your devices to talk to each other.
Tl;dr Support was not helpful, even when I send the MOX in. I’m still not able to get 1Gbit/s through WAN regardless of installed packages.
Hi! @respi did you see any progress on this?
I just got a MOX (Classic + C) and I also can’t get beyond 450/470Mbps download.
The poor TP-Link I was using before the MOX was able to get me to 920/940Mbps steady.
My WAN is a PPPoE connection (with VLAN) while on the LAN side there is nothing special.
The test is being conducted from my PC (wired to the LAN port of the MOX) to the WAN (speedtest.net).
top does not show any process consuming CPU more than expected.
What I noted is that I have dropped packets in RX:
root@turris:~# ip -s l show pppoe-WAN
66: pppoe-WAN: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc fq_codel state UNKNOWN mode DEFAULT group default qlen 3
link/ppp
RX: bytes packets errors dropped overrun mcast
4757055526 3576658 0 38662 0 0
TX: bytes packets errors dropped carrier collsns
1090023033 1423352 0 0 0 0
root@turris:~# ip -s l show lan3.835
65: lan3.835@lan3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1510 qdisc noqueue state UP mode DEFAULT group default qlen 1000
link/ether d8:58:d7:00:cd:df brd ff:ff:ff:ff:ff:ff
4785688022 3576847 0 0 0 0
1121374079 1423552 0 0 0 0
6: lan3@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1510 qdisc noqueue state UP mode DEFAULT group default qlen 1000
11601792001 8641915 0 150242 0 0
2526609006 3193342 0 0 0 0
I got no further with my mox. It is only used an Wifi-Access-Point right now. After a new TOS release, I check the WAN speeds, but I saw no improvement.
Feel free to document your journey in the forum, it might help to solve this issue.
There is quite a lot of interrupt processing on CPU0, maybe moving eth0 or eth1 onto CPU1 might help… but that will only work if your mox is saturating one CPU during your throughput tests.
@moeller0 The driver/kernel should take care of using either CPU without the user doing anything, no?
How would you suggest to “move eth0 or eth1 onto CPU1”?
@respi I reached out to support and I Was basically told that this is a known limitation at the moment. They are hoping that improvements will come with new kernel/driver along with new releases of TurrisOS.
I am gonna see if they have open tickets and what not to check them and potentially test.
MOX A+D
As I recently got my connection upgraded I made some simple tests with a couple of speed test services in the browser on my laptop.
My MOX is in router mode.
Results spans from about 700 to 980
I found this topic via Google, and I seem to have the same problem:
I own a first-gen Turris Omnia, and now about five years later, I bought a MOX (Start+G+E+E+B) and I’m in the process of setting it up to take over for the Omnia.
At this point, both are connected in parallel to the same device(modem/gateway) provided the service provider.
The Omnia has a number of devices connected to it, and there I’m using a brand new laptop connected to it (the Omnia) via a Cat5e gigabit connection.
On the MOX, I have a single Thinkpad T470 hooked up, over a Cat6 gigabit connection.
If I do a speedtest (go to speedtest.net over a browser) on the Omnia, I get 936 Mbit/s down and 41 Mbit/s up, while on the MOX I only get 457 Mbit/s down and 41 Mbit/s up. In both cases I use the same Speedtest server.
At this point, I can only think that the only difference is that the hardware of the Omnia may still be more capable than that of the MOX.
Another difference is that MOX is running TurrisOS 5.2.7 and my Omnia has TurrisOS 3.11.23.
