Hi. I am unable to start Reforis on TOS 5+ on my Omnia.
I always get an ControllerMissing error:
ControllerMissing: Connection to controller 0000D858D7007753 is lost.
args = ('Connection to controller 0000D858D7007753 is lost.',)
device_id = '0000D858D7007753'
with_traceback = <built-in method with_traceback of ControllerMissing object>
Please tell me what information I have to provide and what actions I can take to try to get Reforis working.
I am worried it gets replaced and I end up with no running management console on my device.
You will need to reach our technical support department so we would be able to look at it more. Would you please take a look at our Getting help article?
Problem solved. I followed the thread âOptional migration from Turris OS 3.x for advanced usersâ since I also got errors in the advanced administration, âSoftwareâ when trying to list packages. Changing to the alternate update repository worked and I was able to list available packages. Suspecting the problem to be related to missing components in Reforis, I searched for that keyword and saw that some of the plugins listed were not installed. I installed them and now it works.
The team at Turris did a great job with the new interface.
I got same issue, resolved it. But why do I need reforis netboot?
I noticed that it is consuming most of the resources now. That does not seem to be clever.
