Can not use Reforis on TOS 5+ - ControllerMissing
The issue seems to be that you have explicit configuration foris-controller.ubus=ubus in the UCI. The reForis works only with mqtt bus. The enough fix should be:
uci set foris-controller.ubus=mqtt
uci commit foris-controller
/etc/init.d/foris-controller
The Turris OS 5.3.0 is going to remove the ability to run foris-controller on any other bus than MQTT and thus resolving this issue.
Why installation of reforis-netboot-plugin helped is because it pulled in reforis-remote-devices-plugin and that depends on foris-controller-subordinates-module which works only with MQTT so it forces foris-controller to switch to it. It should be safe to remove netboot once you set MQTT as the foris-controller’s bus or after Turris OS 5.3.0 release.
I’m on 5.3.3 and have just been surprised with this same issue.
Going thorugh the thread, I also installed reforis-netboot-plugin which sorted it out, but then went through the fix in foris-controller, which seems to work as @cynerd says even after removing the netboot package.
I have checked /etc/config/foris-controller before issuing the uci command, and the line config mqtt 'ubus' was not present.
My MOX reForis is inaccessbile since last updates due the ControllerMissing error.
