Neodpovídáte na nějaký jiný dotaz
Vždyť popis menu Luci u mně je zcela jiný než v návodu. Já vám vůbec nerozumím. Mám to tedy nastaveno dobře nebo blbě ? Takto mi to nepracuje … LAN adresa mého Pi-hole je 192.168.2.102…
Nenapoví vám debug log zcela dole ?
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers can access your data via the given token. We have taken these extra steps to secure your data and will work to further reduce any personal information gathered.
*** [ INITIALIZING ]
[i] 2018-01-15:10:47:33 debug log has been initiated.
*** [ INITIALIZING ] Sourcing setup variables
[i] Sourcing /etc/pihole/setupVars.conf...
*** [ DIAGNOSING ]: Core version
[i] Core: v3.2.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.2.1-0-ge602008
*** [ DIAGNOSING ]: Web version
[i] Web: v3.2.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.2.1-0-g31dddd8
*** [ DIAGNOSING ]: FTL version
[✓] FTL: v2.13.2
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.72
*** [ DIAGNOSING ]: lighttpd version
[i] 1.4.35
*** [ DIAGNOSING ]: php version
[i] 5.6.33
*** [ DIAGNOSING ]: Operating system
[✓] Debian GNU/Linux 8 (jessie)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
*** [ DIAGNOSING ]: Networking
[✓] IPv4 address(es) bound to the eth0 interface:
192.168.2.102/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the eth0 interface:
fd35:11d3:9071:0:70da:b4ff:feb2:3b61 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
fe80::70da:b4ff:feb2:3b61 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
^ Please note that you may have more than one IP address listed.
As long as one of them is green, and it matches what is in /etc/pihole/setupVars.conf, there is no need for concern.
The link to the FAQ is for an issue that sometimes occurs when the IPv6 address changes, which is why we check for it.
[i] Default IPv4 gateway: 192.168.2.1
* Pinging 192.168.2.1...
[✓] Gateway responded.
*** [ DIAGNOSING ]: Ports in use
[53] is in use by dnsmasq
[80] is in use by lighttpd
[4711] is in use by pihole-FTL
*** [ DIAGNOSING ]: Name resolution (IPv4) using a random blocked domain and a known ad-serving domain
[✓] adserver.lunarpages.com is 192.168.2.102 via localhost (127.0.0.1)
[✓] adserver.lunarpages.com is 192.168.2.102 via Pi-hole (192.168.2.102)
[✓] doubleclick.com is 216.58.201.110 via a remote, public DNS server (8.8.8.8)
*** [ DIAGNOSING ]: Pi-hole processes
[✓] dnsmasq daemon is active
[✓] lighttpd daemon is active
[✓] pihole-FTL daemon is active
*** [ DIAGNOSING ]: Setup variables
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.2.102/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
*** [ DIAGNOSING ]: Dashboard and block page
[✓] X-Pi-hole: A black hole for Internet advertisements.
[✓] X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity list
-rw-r--r-- 1 root root 4006437 Jan 15 10:08 /etc/pihole/gravity.list
-----head of gravity.list------
192.168.2.102 0.0.0.0
192.168.2.102 0.r.msn.com
192.168.2.102 0.start.bz
192.168.2.102 0000mps.webpreview.dsl.net
-----tail of gravity.list------
192.168.2.102 zzsyw.com
192.168.2.102 zztxdown.com
192.168.2.102 zzz.clickbank.net
192.168.2.102 ɢoogle.com
*** [ DIAGNOSING ]: contents of /etc/pihole
-rw-r--r-- 1 root root 633 Jan 13 14:57 /etc/pihole/adlists.list
https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
https://mirror1.malwaredomains.com/files/justdomains
http://sysctl.org/cameleon/hosts
https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist
https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
https://hosts-file.net/ad_servers.txt
-rw-r--r-- 1 root root 28 Jan 15 09:57 /etc/pihole/blacklist.txt
youtube.com
www.youtube.com
-rw-r--r-- 1 root root 45 Jan 15 10:08 /etc/pihole/local.list
192.168.2.102 LXC_NAME
192.168.2.102 pi.hole
-rw-r--r-- 1 root root 234 Jan 13 14:56 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 117 Jan 13 14:57 /etc/pihole/whitelist.txt
sysctl.org
s3.amazonaws.com
hosts-file.net
*** [ DIAGNOSING ]: contents of /etc/dnsmasq.d
-rw-r--r-- 1 root root 1527 Jan 15 10:11 /etc/dnsmasq.d/01-pihole.conf
addn-hosts=/etc/pihole/gravity.list
addn-hosts=/etc/pihole/black.list
addn-hosts=/etc/pihole/local.list
localise-queries
no-resolv
cache-size=10000
log-queries
log-facility=/var/log/pihole.log
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
domain-needed
bogus-priv
interface=eth0
*** [ DIAGNOSING ]: contents of /etc/lighttpd
-rw-r--r-- 1 root root 3027 Jan 13 14:56 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.document-root = "/var/www/html"
server.error-handler-404 = "pihole/index.php"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
accesslog.filename = "/var/log/lighttpd/access.log"
accesslog.format = "%{%s}t|%V|%r|%s|%b"
index-file.names = ( "index.php", "index.html", "index.lighttpd.html" )
url.access-deny = ( "~", ".inc", ".md", ".yml", ".ini" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/use-ipv6.pl " + server.port
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "find /etc/lighttpd/conf-enabled -name '*.conf' -a ! -name 'letsencrypt.conf' -printf 'include \"%p\"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
setenv.add-response-header = (
"X-Pi-hole" => "The Pi-hole Web interface is working!",
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
setenv.add-response-header = ( "Access-Control-Allow-Origin" => "*" )
$HTTP["url"] =~ "^/admin/\.(.*)" {
url.access-deny = ("")
include_shell "cat external.conf 2>/dev/null"
*** [ DIAGNOSING ]: contents of /etc/cron.d
-rw-r--r-- 1 root root 1630 Jan 13 14:56 /etc/cron.d/pihole
34 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
@reboot root /usr/sbin/logrotate /etc/pihole/logrotate
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
44 18 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
*** [ DIAGNOSING ]: contents of /var/log/lighttpd
-rw-r--r-- 1 www-data www-data 3996 Jan 15 10:41 /var/log/lighttpd/error.log
2018-01-13 14:56:45: (log.c.164) server started
2018-01-13 14:57:02: (server.c.1558) server stopped by UID = 0 PID = 1
2018-01-13 14:57:04: (log.c.164) server started
2018-01-13 17:12:27: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: parse_ini_file(/etc/pihole/pihole-FTL.conf): failed to open stream: No such file or directory in /var/www/html/admin/api_db.php on line 18
2018-01-14 07:34:29: (server.c.1558) server stopped by UID = 0 PID = 0
2018-01-14 07:35:38: (log.c.164) server started
2018-01-14 07:42:49: (log.c.164) server started
2018-01-14 21:56:37: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-14 21:56:37: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-14 21:57:00: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-14 21:57:00: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 08:41:59: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-15 08:41:59: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 08:42:27: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: parse_ini_file(/etc/pihole/pihole-FTL.conf): failed to open stream: No such file or directory in /var/www/html/admin/api_db.php on line 18
2018-01-15 08:46:41: (server.c.1558) server stopped by UID = 0 PID = 0
2018-01-15 08:47:49: (log.c.164) server started
2018-01-15 09:41:10: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-15 09:41:10: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 09:41:15: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-15 09:41:15: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 09:41:52: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-15 09:41:52: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 09:41:57: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
2018-01-15 09:41:57: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: Invalid argument supplied for foreach() in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 123
2018-01-15 09:57:06: (mod_fastcgi.c.2702) FastCGI-stderr: PHP Warning: preg_split(): Delimiter must not be alphanumeric or backslash in /var/www/html/admin/scripts/pi-hole/php/auth.php on line 122
-rw-r--r-- 1 pihole pihole 17949 Jan 15 10:41 /var/log/pihole-FTL.log
[2018-01-13 14:57:05.573]
[2018-01-13 14:57:05.573] FTL branch: v2.13.2
[2018-01-13 14:57:05.573] FTL version: v2.13.2
[2018-01-13 14:57:05.573] FTL commit: 1de2b99c8a812d4d2dbe6b1e4644e20a4b14bb1e
[2018-01-13 14:57:05.573] FTL date: 2018-01-07 17:34:24 -0800
[2018-01-13 14:57:05.573] FTL user: pihole
[2018-01-13 14:57:05.573] Notice: Found no readable FTL config file
[2018-01-13 14:57:05.573] Using default settings
[2018-01-13 14:57:05.573] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2018-01-13 14:57:05.573] SOCKET_LISTENING: only local
[2018-01-13 14:57:05.573] TIMEFRAME: Rolling 24h
[2018-01-13 14:57:05.573] QUERY_DISPLAY: Show queries
[2018-01-13 14:57:05.574] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2018-01-13 14:57:05.574] MAXDBDAYS: max age for stored queries is 365 days
[2018-01-13 14:57:05.574] RESOLVE_IPV6: Resolve IPv6 addresses
[2018-01-13 14:57:05.574] RESOLVE_IPV4: Resolve IPv4 addresses
[2018-01-13 14:57:05.574] DBINTERVAL: saving to DB file every minute
[2018-01-13 14:57:05.574] DBFILE: Using /etc/pihole/pihole-FTL.db
[2018-01-13 14:57:05.574] Finished config file parsing
[2018-01-13 14:57:05.575] Found no other running pihole-FTL process
[2018-01-13 14:57:05.576] PID of FTL process: 6717
[2018-01-13 14:57:05.577] Error: failed to read /etc/pihole/list.preEventHorizon
[2018-01-13 14:57:05.577] Gravity list entries: -1
[2018-01-13 14:57:05.577] No blacklist present
[2018-01-13 14:57:05.577] No wildcard blocking list present
*** [ DIAGNOSING ]: Pi-hole log
-rw-r--r-- 1 dnsmasq root 7342 Jan 15 10:47 /var/log/pihole.log
-----head of pihole.log------
Jan 15 08:41:59 dnsmasq[117]: read /etc/hosts - 4 addresses
Jan 15 08:41:59 dnsmasq[117]: read /etc/pihole/local.list - 2 addresses
Jan 15 08:41:59 dnsmasq[117]: read /etc/pihole/black.list - 1 addresses
Jan 15 08:42:00 dnsmasq[117]: read /etc/pihole/gravity.list - 108807 addresses
Jan 15 08:46:41 dnsmasq[117]: exiting on receipt of SIGTERM
Jan 15 08:47:49 dnsmasq[125]: started, version 2.72 cachesize 10000
Jan 15 08:47:49 dnsmasq[125]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect
Jan 15 08:47:49 dnsmasq[125]: using nameserver 8.8.4.4#53
Jan 15 08:47:49 dnsmasq[125]: using nameserver 8.8.8.8#53
Jan 15 08:47:49 dnsmasq[125]: read /etc/hosts - 4 addresses
Jan 15 08:47:49 dnsmasq[125]: read /etc/pihole/local.list - 2 addresses
Jan 15 08:47:49 dnsmasq[125]: read /etc/pihole/black.list - 1 addresses
Jan 15 08:47:53 dnsmasq[125]: read /etc/pihole/gravity.list - 108807 addresses
Jan 15 09:06:07 dnsmasq[125]: exiting on receipt of SIGTERM
Jan 15 09:06:07 dnsmasq[275]: started, version 2.72 cachesize 10000
Jan 15 09:06:07 dnsmasq[275]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect
Jan 15 09:06:07 dnsmasq[275]: using nameserver 8.8.4.4#53
Jan 15 09:06:07 dnsmasq[275]: using nameserver 8.8.8.8#53
Jan 15 09:06:07 dnsmasq[275]: read /etc/hosts - 4 addresses
[✓] ** FINISHED DEBUGGING! **
* The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[i] Debug script running in automated mode
* Using openssl for transmission.
[✓] Your debug token is: 0m80j08mti
* Provide the token above to the Pi-hole team for assistance at
* https://discourse.pi-hole.net
* Your log will self-destruct on our server after 48 hours.
* A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
