Hello
i bought a zisa op151s but im not unable to work it on turris omnia. in an standar switch with SFP im able to communicate to the Zisa and configure it but in turris doesnt work.
2018-02-06T14:15:31+01:00 err sfpswitch.py[2973]: Switching NIC mode to phy-def.
2018-02-06T14:15:32+01:00 err sfpswitch.py[2973]: Shutting down interface eth1
2018-02-06T14:15:32+01:00 err sfpswitch.py[2973]: Bringing up interface eth1
2018-02-06T15:15:32+01:00 info kernel[]: [ 159.762051] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2018-02-06T14:15:34+01:00 err sfpswitch.py[2973]: Zisa GPON SFP detected. Switching to phy-sfp-sgmii mode.
2018-02-06T14:15:34+01:00 err sfpswitch.py[2973]: Switching NIC mode to phy-sfp-sgmii.
2018-02-06T14:15:35+01:00 err sfpswitch.py[2973]: Shutting down interface eth1
2018-02-06T14:15:35+01:00 err sfpswitch.py[2973]: Bringing up interface eth1
2018-02-06T15:15:35+01:00 info kernel[]: [ 162.752055] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2018-02-06T14:15:36+01:00 err kresd[3836]: [priming] cannot resolve ‘.’ NS, next priming query in 10 seconds
2018-02-06T15:15:43+01:00 err nikola[]: (v42) Exception thrown: [Errno 2] No such file or directory
2018-02-06T15:15:43+01:00 err nikola[]: (v42) Exception traceback: [(’/usr/bin/nikola’, 175, ‘’, ‘ssl_context.load_verify_locations(crl_path)’)]
2018-02-06T14:15:58+01:00 err kresd[3836]: [priming] cannot resolve ‘.’ NS, next priming query in 10 seconds
2018-02-06T14:16:01+01:00 info /usr/sbin/cron[11251]: (root) CMD (nethist_stats.lua)
2018-02-06T14:16:01+01:00 info /usr/sbin/cron[11250]: (root) CMD (/usr/bin/rainbow_button_sync.sh)
2018-02-06T14:16:16+01:00 err sfpswitch.py[2973]: Switching NIC mode to phy-def.
2018-02-06T14:16:17+01:00 err sfpswitch.py[2973]: Shutting down interface eth1
2018-02-06T14:16:17+01:00 err sfpswitch.py[2973]: Bringing up interface eth1
2018-02-06T15:16:17+01:00 info kernel[]: [ 204.612057] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
2018-02-06T14:16:18+01:00 err sfpswitch.py[2973]: EEPROM read error: [Errno 6] No such device or address
2018-02-06T14:16:18+01:00 err sfpswitch.py[2973]: Switching NIC mode to phy-sfp.
2018-02-06T14:16:19+01:00 err sfpswitch.py[2973]: Shutting down interface eth1
2018-02-06T14:16:19+01:00 err sfpswitch.py[2973]: Bringing up interface eth1
2018-02-06T15:16:19+01:00 info kernel[]: [ 206.934120] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
needs aditional configuration on turris omnia?aanymodification to the SFP module?
