Hey all,
I would like to ask you for a help. I am already banging my keyboard for too long and have no idea what else to try.
I am running Home Assistant in LXC. Recently I have decided to upgrade my Zigbee coordinator with Slaesh’s CC2652RB. When it arrived I plugged it in, but Turris did not properly recognized it. I had this issue already with my previous coordinator, but if I remember correctly the solution was to use the front-facing USB port. I have tried both ports without success.
The device is recognized as plugged in, but I believe it should expose CDC_ACM device. The device is recognized currently as Vendor Specific Class.
root@turris ~# lsusb --tree
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
|__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=orion-ehci/1p, 480M
There is no serial port exposed under /dev
. I have installed all sort of serial drivers I could find:
root@turris ~# opkg list-installed | grep kmod-usb
kmod-usb-acm - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-core - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-ehci - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-ohci - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial-ch341 - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial-ftdi - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial-qualcomm - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial-simple - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-serial-wwan - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-storage - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-storage-extras - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-storage-uas - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb-uhci - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb2 - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
kmod-usb3 - 4.14.236-1-67f70e2f39f8e8859c56d42cced0b0b3
When I reconnect the coordinator not much is in dmesg
root@turris ~ [0|1]# dmesg | grep usb
[422514.069278] usb 2-1: USB disconnect, device number 2
[422516.126011] usb 2-1: new full-speed USB device number 3 using xhci-hcd
Do you have any suggestions what to try please?
