I have the same issue using âTurrisOS 5.3.9 ecbbb373edf7be017e546be2443e6c422cb9c220 r11430+92-ecbbb373edâ.
Not just with zabbix-extra-wifi but also with zabbix-extra-network. Iâm getting the following error:
root@ap2:~# opkg install zabbix-extra-network
Package zabbix-extra-network (4.0.37-1) installed in root is up to date.
Configuring zabbix-extra-wifi.
Usage: killall [OPTION]⌠[â] NAMEâŚ
killall -l, --list
killall -V, --version
-e,âexact require exact match for very long names
-I,âignore-case case insensitive process name match
-g,âprocess-group kill process group instead of process
-y,âyounger-than kill processes younger than TIME
-o,âolder-than kill processes older than TIME
-i,âinteractive ask for confirmation before killing
-l,âlist list all known signal names
-q,âquiet donât print complaints
-r,âregexp interpret NAME as an extended regular expression
-s,âsignal SIGNAL send this signal instead of SIGTERM
-u,âuser USER kill only process(es) running as USER
-v,âverbose report if the signal was successfully sent
-V,âversion display version information
-w,âwait wait for processes to die
-n,âns PID match processes that belong to the same namespaces
as PID
Configuring zabbix-extra-network.
killall -l, --list
as PID
Collected errors:
- pkg_run_script: package âzabbix-extra-wifiâ postinst script returned status 1.
- opkg_configure: zabbix-extra-wifi.postinst returned 1.
- pkg_run_script: package âzabbix-extra-networkâ postinst script returned status 1.
- opkg_configure: zabbix-extra-network.postinst returned 1.
and:
root@ap2:~# opkg install zabbix-extra-wifi
Package zabbix-extra-wifi (4.0.37-1) installed in root is up to date.
killall -l, --list
as PID
killall -l, --list
as PID
Collected errors:
