Since last update is wifi practically unusable - I am using first card with 5Ghz and it is often disconnecting. Last example:
2016-12-12T23:02:22+01:00 info hostapd[]: wlan0: STA 2c:f0:a2:be:71:72 IEEE 802.11: disassociated due to inactivity
2016-12-12T23:02:23+01:00 info hostapd[]: wlan0: STA 2c:f0:a2:be:71:72 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2016-12-12T23:02:35+01:00 notice netifd[]: Network device 'wlan0' link is down
In that “inactivity” time was connected at least one phone and laptop. I am seriously thinkong about deactivating wifi at all, use omnia as “only” router and use for wifi some more stable solution.
Here is an example form the system log but it keeps going on:
2016-12-13T08:31:08+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 IEEE 802.11: disassociated
2016-12-13T08:31:09+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2016-12-13T08:31:10+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a IEEE 802.11: disassociated
2016-12-13T08:31:11+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a IEEE 802.11: authenticated
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a IEEE 802.11: associated (aid 1)
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a RADIUS: starting accounting session BA7841B15EB2CA45
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 8c:fa:ba:5e:fa:1a WPA: pairwise key handshake completed (RSN)
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 IEEE 802.11: authenticated
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 IEEE 802.11: associated (aid 2)
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 RADIUS: starting accounting session 09AD85A67276A1DA
2016-12-13T08:31:17+01:00 info hostapd[]: wlan1: STA 64:a3:cb:c4:58:45 WPA: pairwise key handshake completed (RSN)
2016-12-13T09:31:17+01:00 info dnsmasq-dhcp[2042]: DHCPREQUEST(br-lan) 192.168.1.153 64:a3:cb:c4:58:45
2016-12-13T09:31:17+01:00 info dnsmasq-dhcp[2042]: DHCPACK(br-lan) 192.168.1.153 64:a3:cb:c4:58:45 iPhonedeJulieta
2016-12-13T09:31:17+01:00 info dnsmasq-dhcp[2042]: DHCPREQUEST(br-lan) 192.168.1.228 8c:fa:ba:5e:fa:1a
2016-12-13T09:31:17+01:00 info dnsmasq-dhcp[2042]: DHCPACK(br-lan) 192.168.1.228 8c:fa:ba:5e:fa:1a iPad-de-Julieta
Here is the kernel log. Could it be related with ATH10K, as @czbird mentioned?
