I am trying to get Fast Roaming (ieee80211r) between my Turris Omnia and my Mox working since days without luck.
Is there someone using this successfully?
Some infos and logs:
Omnia: Turris OS 3.11.16
Mox: Turris OS 4.0.5
Both systems are connected to 3 VLAN (Management, Trusted, Untrusted) and serve two SSID’s (Trusted and Untrusted).
The Omnia serves two 2,4Ghz SSID’s additionally.
The interfaces all look fine, I can see traffic (out of the correct VLAN using tcpdump).
The wireless configuration looks like this (only one SSID for briefness):
Omnia:
config wifi-iface
option device 'radio0'
option mode 'ap'
option encryption 'psk2+tkip+ccmp'
option key 'VerySecretPassword'
option network 'TRUSTED'
option ssid 'BlackPenguin-5G'
option ieee80211r '1'
option mobility_domain '1337'
option ft_psk_generate_local '1'
option pmk_r1_push '1'
Mox:
config wifi-iface
option mode 'ap'
When I now connect a Client to the 5GHz i get tons of logs on both systems…and a network connection for only some seconds.
Logs on the Omnia (repeating all the time):
2020-04-09 18:01:12 info hostapd[]: wlan0: STA a8:34:6a:1f:24:50 WPA: pairwise key handshake completed (RSN)
2020-04-09 18:01:13 info hostapd[]: wlan0: STA a8:34:6a:1f:24:50 IEEE 802.11: authenticated
2020-04-09 18:01:13 info hostapd[]: wlan0: STA a8:34:6a:1f:24:50 IEEE 802.11: associated (aid 2)
2020-04-09 18:01:13 info hostapd[]: wlan0: STA a8:34:6a:1f:24:50 RADIUS: starting accounting session 0020EB2F56C448DB
Logs on the Mox (also repeating all the time):
Apr 9 16:08:22 turris hostapd: wlan0: STA a8:34:6a:1f:24:50 IEEE 802.11: disassociated
Apr 9 16:08:23 turris hostapd: wlan0: STA a8:34:6a:1f:24:50 IEEE 802.11: disassociated
What could I have missed in my configuration?
Someone got Fast Roamint to work using Turris OS?
Thanks for the help.
best,
Stefan
