Wireless is disabled or not associated
Had to fire up an old AP I had which had the same SSID as my TURRIS. So I decided to disable the one WIFI (AC) while I renamed the other one. Did that through the web interface.
Now I’m done and I go back in and the interface wouldn’t re-enable. I removed it completely but now when I add the AC connect it keeps telling me “Wireless is disabled or not associated”.
Any suggestions? Also when I go into the basic interface I don’t see the AC wifi at all.
