For that, on my configuration, I create the 2 wireguard interfaces (seems good for you)
From the router, you need to be able to ping all IP (LAN and to the 2 Wireguard interface), if you can’t, you need to fix it before any other step.
I create a new zone in the firewall (called LAN_WG) where all the Wireguard interface are in and make the rules :
- Lan =>wan+LAN_WG input, output, forward Accept (no masquerading)
- LAN_WG=>wan ACCEPT ACCEPT DROP, no masquerading
- not changed WAN=>drop drop accept drop, with masquerading
After that, in the “Traffic rules” section, I add 1 rule (adapt if required) :
Forwarded (accept forward), IPv4+IPv6, from any zone IP X.X.X.X, Y.Y.Y.Y to any zone X.X.X.X Y.Y.Y.Y
For you, replace X.X.X.X, Y.Y.Y.Y by 192.168.150.0/24, 192.168.140.0/24, 192.168.120.0/24
Maybe I missed some configuration, but I think it’s a good start.
On my setup, I use BIRD for the routes due to a more complex configuration.
Hope it help you, if you have more questions, ask
Edit, the tutorial I make for my configuration : Redundant Wireguard Network with Bird and OSPF
