I am aware wireguard is still under heavy development, but I realized a problem which I am not sure is either a bug or a feature.
I tested to connect my omnia to an external wireguard “server” to route all my traffic through the vpn as a test. If you set up wireguard and set it to non-auto in the config, you can enable and disable it with ifup/ifdown wg0. While ifup sets up the new routes correctly, ifdown does not restore the default route, which leaves the omnia without wan access.
Enabling/Disabling wireguard through the UI does not have this “bug”, because the UI resets the networking completely, I believe, which recalculates the default route, I believe.
Due to the sparse documentation about wireguard, I am not sure this is a bug or a feature. Also due to missing documentation about the UCI implementation of the wireguard, I don’t know yet how to enable post-up/post-down scripts.
Any ideas how to restore the default routes automatically are welcome.
