I had working Wireguard VPN from Turris to a remote server. The Wireguard is running from a LXC container with Alpine Linux. Some recent updates broke the Wireguard.
$ wg-quick up vpn
[#] ip link add vpn type wireguard
[#] wg setconf vpn /dev/fd/63
[#] ip -4 address add 10.141.100.141/32 dev vpn
[#] ip -6 address add xxxxxxxxxxxxxxxxxxxxxxxxxxxxx/128 dev vpn
[#] ip link set mtu 1420 up dev vpn
[#] resolvconf -a vpn -m 0 -x
[#] wg set vpn fwmark 51820
[#] ip -6 route add ::/0 dev vpn table 51820
[#] ip -6 rule add not fwmark 51820 table 51820
[#] ip -6 rule add table main suppress_prefixlength 0
[#] ip6tables-restore -n
Warning: Extension addrtype is not supported, missing kernel module?
ip6tables-restore v1.8.10 (nf_tables): Couldn't load match `addrtype':No such file or directory
Error occurred at line: 2
Try `ip6tables-restore -h' or 'ip6tables-restore --help' for more information.
[#] resolvconf -d vpn -f
[#] ip -6 rule delete table 51820
[#] ip -6 rule delete table main suppress_prefixlength 0
[#] ip link delete dev vpn
That’s strange, because the module is there:
$ lsmod | grep addrtype
xt_addrtype 16384 0
x_tables 24576 59 xt_connlimit,iptable_nat,xt_state,xt_nat,xt_helper,xt_conntrack,xt_connmark,xt_connbytes,xt_REDIRECT,xt_MASQUERADE,xt_FLOWOFFLOAD,xt_CT,ipt_REJECT,xt_time,xt_tcpudp,xt_tcpmss,xt_statistic,xt_recent,xt_quot
a,xt_pkttype,xt_owner,xt_multiport,xt_mark,xt_mac,xt_limit,xt_length,xt_hl,xt_ecn,xt_dscp,xt_comment,xt_cgroup,xt_addrtype,xt_TCPMSS,xt_NFLOG,xt_LOG,xt_HL,xt_DSCP,xt_CLASSIFY,iptable_raw,iptable_mangle,iptable_filter,ipt_ECN,ip6table_raw
,ip_tables,ebtables,ebt_vlan,ebt_stp,ebt_redirect,ebt_pkttype,ebt_mark_m,ebt_mark,ebt_limit,ebt_among,ebt_802_3,xt_set,ip6table_mangle,ip6table_filter,ip6_tables,ip6t_REJECT
When I try the same, but only with IPv4, it complains about two modules:
[#] iptables-restore -n
Warning: Extension addrtype revision 0 not supported, missing kernel module?
Warning: Extension comment revision 0 not supported, missing kernel module?
iptables-restore v1.8.10 (nf_tables): Could not fetch rule set generation id: Invalid argument
But the xt_comment module is also loaded.
What could be wrong?
TurrisOS 6.5.0, kernel 5.15.146, Alpine Linux 3.19, wireguard-tools v1.0.20210914
