can you please advise me where the buy spare antennas? What is the model and who is the make?
Thank you.
Thank you.
Thank you. Do I need to purchase the connecting cables to the card separately?
pigtails? I think yes. I didn’t buy antennas from them.
You will need u.fl (depends on card/s) to rp-sma (depends on antenna/s)
For example TSBohemia in Czech is selling them , but they are too long.
I think 15-20cm would be better.
I’m considering to replace the wifi card once this one comes out.
http://www.compex.com.sg/product/wle1216v5-20/
it has 4 antenna outputs, I assume I will have to install additional antennas for this.
