from last update to 3.11.1 I have some troubles with WiFi. Clients on wlan can’t connect to WiFi after some time. I have to reboot my Omnia. Then it works again.
I found this in /var/log/messages:
2019-01-10 06:29:06 info kernel[]: [ 14.610873] ip_gre: GRE over IPv4 tunneling driver
2019-01-10 06:29:06 info kernel[]: [ 14.629887] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
2019-01-10 06:29:06 info kernel[]: [ 14.638562] PPP generic driver version 2.4.2
2019-01-10 06:29:06 info kernel[]: [ 14.646152] ip6_tables: (C) 2000-2006 Netfilter Core Team
2019-01-10 06:29:06 info kernel[]: [ 14.659067] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
2019-01-10 06:29:06 info kernel[]: [ 15.352245] cryptodev: driver 1.8 loaded.
2019-01-10 06:29:06 info kernel[]: [ 16.622352] Loading modules backported from Linux version wt-2017-01-31-0-ge882dff19e7f
2019-01-10 06:29:06 info kernel[]: [ 16.630378] Backport generated by backports.git backports-20160324-13-g24da7d3c
2019-01-10 06:29:06 info kernel[]: [ 17.052384] pci 0000:00:02.0: enabling device (0140 -> 0142)
2019-01-10 06:29:06 info kernel[]: [ 17.058263] ath10k_pci 0000:02:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
2019-01-10 06:29:06 warning kernel[]: [ 17.234532] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:02:00.0.bin failed with error -2
2019-01-10 06:29:06 warning kernel[]: [ 17.245269] ath10k_pci 0000:02:00.0: Falling back to user helper
2019-01-10 06:29:06 err kernel[]: [ 17.255437] firmware ath10k!pre-cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
2019-01-10 06:29:06 warning kernel[]: [ 17.264538] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/cal-pci-0000:02:00.0.bin failed with error -2
2019-01-10 06:29:06 warning kernel[]: [ 17.274922] ath10k_pci 0000:02:00.0: Falling back to user helper
2019-01-10 06:29:06 err kernel[]: [ 17.285106] firmware ath10k!cal-pci-0000:02:00.0.bin: firmware_loading_store: map pages failed
2019-01-10 06:29:06 info kernel[]: [ 17.302466] ath10k_pci 0000:02:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043202ff sub 0000:0000
2019-01-10 06:29:06 info kernel[]: [ 17.311733] ath10k_pci 0000:02:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
2019-01-10 06:29:06 info kernel[]: [ 17.321345] ath10k_pci 0000:02:00.0: firmware ver 10.2.4-1.0-00041 api 5 features no-p2p,raw-mode,mfp,allows-mesh-bcast crc32 f43fa422
2019-01-10 06:29:06 warning kernel[]: [ 17.366081] ath10k_pci 0000:02:00.0: board id is not exist in otp, ignore it
2019-01-10 06:29:06 warning kernel[]: [ 17.373198] ath10k_pci 0000:02:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
2019-01-10 06:29:06 warning kernel[]: [ 17.383662] ath10k_pci 0000:02:00.0: Falling back to user helper
2019-01-10 06:29:06 err kernel[]: [ 17.393762] firmware ath10k!QCA988X!hw2.0!board-2.bin: firmware_loading_store: map pages failed
2019-01-10 06:29:06 info kernel[]: [ 17.403468] ath10k_pci 0000:02:00.0: board_file api 1 bmi_id N/A crc32 bebc7c08
2019-01-10 06:29:06 info kernel[]: [ 18.539255] ath10k_pci 0000:02:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal otp max-sta 128 raw 0 hwcrypto 1
2019-01-10 06:29:06 debug kernel[]: [ 18.631545] ath: EEPROM regdomain: 0x0
2019-01-10 06:29:06 debug kernel[]: [ 18.631550] ath: EEPROM indicates default country code should be used
2019-01-10 06:29:06 debug kernel[]: [ 18.631553] ath: doing EEPROM country->regdmn map search
2019-01-10 06:29:06 debug kernel[]: [ 18.631558] ath: country maps to regdmn code: 0x3a
2019-01-10 06:29:06 debug kernel[]: [ 18.631561] ath: Country alpha2 being used: US
2019-01-10 06:29:06 debug kernel[]: [ 18.631563] ath: Regpair used: 0x3a
2019-01-10 06:29:06 info kernel[]: [ 18.887014] Linux video capture interface: v2.00
Can you look at it, please?
Thanks
