does anyone know a 802.11g/n/a/ac WiFi-card with simultaneous dual-band to save mPCIE-slots on the Turris Omnia?
It’s been discussed a few times on the forum, and so far noone has found one. (One of reasonable size, that is.)
check this out!
https://www.embeddedworks.net/wlan798/
There is no mention of concurrent/simultaneous dual band
this is concurent:
and did anyone tried this setup?
Have you looked at the picture?
MY bad:-)
Can someone explain me, how so that first mpcie can be pcie and msata!? Isn’t wire-ing different, not compatible?!
On top of the size, that card appears to only be able to do 2 spatial streams on each band if you choose to do simultaneous DB.
