Wifi 5ghz issue
Hello
It seems since 6.4.0 upgrade wifi 5ghz stop working
2,4Ghz work well
dmesg
[134953.269806] ath10k_pci 0000:02:00.0: pdev param 0 not supported by firmware
[134953.302132] br-lan: port 6(wlan0) entered blocking state
[134953.302145] br-lan: port 6(wlan0) entered disabled state
[134953.302284] device wlan0 entered promiscuous mode
From luci we see not bitrate and wifi analyzer app not see hotspot
Qualcomm Atheros QCA9880 802.11bgnac
Channel: 132 (5.660 GHz) | Bitrate: ? Mbit/s
Cheers
don’t know how but it work again …
[135016.694380] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[135016.694528] br-lan: port 6(wlan0) entered blocking state
[135016.694538] br-lan: port 6(wlan0) entered forwarding state
EDIT: Not working again …
[134951.190217] br-lan: port 5(wlan1) entered forwarding state
[139763.595971] ath10k_pci 0000:02:00.0: failed to flush transmit queue (skip 0 ar-state 1): 0
Ok I cannot hold myself to tell you. So you are using DFS channel. And in case your radio discovers some radar it will shut down and wait some time.
There were countless topics like that on the forum.
Change your 5Ghz channel to 36 and all of your problems with 5GHz WiFi will disappear. Don’t thank me just mark as solved if I am right.
