I am trying to get Alpine Linux to run on the Omnia but I am struggling to get the Wi-Fi cards to work.
Am I missing kernel configs? Or are turris kernel patches required for this to work?
excerpt from bootlog:
[ 7.557241] pci 0000:00:01.0: enabling device (0140 -> 0142)
[ 7.557263] ath9k 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.557365] ath: phy0: Failed to read SREV register
[ 7.557371] ath: phy0: Could not read hardware revisions
[ 7.557375] ath: phy0: Unable to initialize hardware; initialization status: -95
[ 7.557382] ath9k 0000:01:00.0: Failed to initialize device
[ 7.557404] ath9k: probe of 0000:01:00.0 failed with error -95
[ 7.611888] ath10k_pci 0000:02:00.0: of_irq_parse_pci: failed with rc=134
[ 7.627594] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 7.627613] ath10k_pci 0000:02:00.0: can't change power state from D3cold to D0 (config space inaccessible)
[ 7.657793] ath10k_pci 0000:02:00.0: failed to wake up device : -110
[ 7.657972] ath10k_pci: probe of 0000:02:00.0 failed with error -110
full bootlog:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.15.78-0-lts (root@syclone) (gcc (Alpine 11.2.1_git20220219) 11.2.1 20220219, GNU ld (GNU Binutils) 2.38) #1-Alpine SMP Fri, 18 Nov 2022 22:48:44 +0000
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Turris Omnia
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x7d000000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000006fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000070000000-0x000000007fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] percpu: Embedded 17 pages/cpu s38156 r8192 d23284 u69632
[ 0.000000] pcpu-alloc: s38156 r8192 d23284 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 520256
[ 0.000000] Kernel command line: console=ttyS0,115200 log_buf_len=5M root=UUID=539e0d92-1c15-45d1-b03b-406156fab0b5 modules=sd-mod,usb-storage,ext4 rootfstype=ext4
[ 0.000000] Unknown kernel command line parameters "modules=sd-mod,usb-storage,ext4", will be passed to user space.
[ 0.000000] printk: log_buf_len: 8388608 bytes
[ 0.000000] printk: early log buf free: 15060(91%)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] Memory: 1969808K/2097152K available (9216K kernel code, 836K rwdata, 3152K rodata, 1024K init, 2815K bss, 78192K reserved, 49152K cma-reserved, 212992K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] ftrace: allocating 31634 entries in 62 pages
[ 0.000000] ftrace: allocated 62 pages with 5 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] L2C: DT/platform modifies aux control register: 0x06070000 -> 0x16070000
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 D prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 Coherent cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310 Coherent: CACHE_ID 0x410054c9, AUX_CTRL 0x56070001
[ 0.000000] sched_clock: 64 bits at 400MHz, resolution 2ns, wraps every 4398046511103ns
[ 0.000018] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x5c4093a7d1, max_idle_ns: 440795210635 ns
[ 0.000035] Switching to timer-based delay loop, resolution 2ns
[ 0.000509] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000516] clocksource: armada_370_xp_clocksource: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.001113] Console: colour dummy device 80x30
[ 0.001145] Calibrating delay loop (skipped), value calculated using timer frequency.. 800.00 BogoMIPS (lpj=4000000)
[ 0.001156] pid_max: default: 32768 minimum: 301
[ 0.001338] LSM: Security Framework initializing
[ 0.001390] landlock: Up and running.
[ 0.001394] Yama: becoming mindful.
[ 0.001497] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.001508] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.002136] CPU: Testing write buffer coherency: ok
[ 0.002161] CPU0: Spectre v2: using BPIALL workaround
[ 0.002314] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002750] Setting up static identity map for 0x300000 - 0x3000ac
[ 0.002895] mvebu-soc-id: MVEBU SoC ID=0x6820, Rev=0x4
[ 0.002987] mvebu-pmsu: Initializing Power Management Service Unit
[ 0.003183] rcu: Hierarchical SRCU implementation.
[ 0.003473] EFI services will not be available.
[ 0.003569] smp: Bringing up secondary CPUs ...
[ 0.003811] Booting CPU 1
[ 0.003957] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.003965] CPU1: Spectre v2: using BPIALL workaround
[ 0.004036] smp: Brought up 1 node, 2 CPUs
[ 0.004044] SMP: Total of 2 processors activated (1600.00 BogoMIPS).
[ 0.004050] CPU: All CPU(s) started in SVC mode.
[ 0.004530] devtmpfs: initialized
[ 0.007126] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.007293] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007313] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.008590] pinctrl core: initialized pinctrl subsystem
[ 0.008968] DMI not present or invalid.
[ 0.009342] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.011571] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.012077] audit: initializing netlink subsys (disabled)
[ 0.012231] audit: type=2000 audit(0.010:1): state=initialized audit_enabled=0 res=1
[ 0.012585] thermal_sys: Registered thermal governor 'fair_share'
[ 0.012590] thermal_sys: Registered thermal governor 'step_wise'
[ 0.012678] cpuidle: using governor ladder
[ 0.012695] cpuidle: using governor menu
[ 0.012788] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.012795] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.012994] mvebu-pmsu: CPU hotplug support is currently broken on Armada 38x: disabling
[ 0.013002] mvebu-pmsu: CPU idle is currently broken on Armada 38x: disabling
[ 0.013258] Serial: AMBA PL011 UART driver
[ 0.023554] Kprobes globally optimized
[ 0.026068] iommu: Default domain type: Translated
[ 0.026078] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.026174] vgaarb: loaded
[ 0.026475] pps_core: LinuxPPS API ver. 1 registered
[ 0.026481] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.026493] PTP clock support registered
[ 0.027320] NetLabel: Initializing
[ 0.027327] NetLabel: domain hash size = 128
[ 0.027331] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.027372] NetLabel: unlabeled traffic allowed by default
[ 0.027564] clocksource: Switched to clocksource arm_global_timer
[ 0.054306] VFS: Disk quotas dquot_6.6.0
[ 0.054366] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.058459] NET: Registered PF_INET protocol family
[ 0.058598] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.059737] tcp_listen_portaddr_hash hash table entries: 1024 (order: 1, 12288 bytes, linear)
[ 0.059821] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.059846] TCP established hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.059945] TCP bind hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.060066] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.060147] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.060189] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 0.060342] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.060363] NET: Registered PF_XDP protocol family
[ 0.060371] PCI: CLS 0 bytes, default 64
[ 0.066220] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.066288] Trying to unpack rootfs image as initramfs...
[ 0.067114] Initialise system trusted keyrings
[ 0.067339] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 0.070004] zbud: loaded
[ 0.070381] Key type asymmetric registered
[ 0.070391] Asymmetric key parser 'x509' registered
[ 0.070496] bounce: pool size: 64 pages
[ 0.070562] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.071456] io scheduler mq-deadline registered
[ 0.071469] io scheduler kyber registered
[ 0.071566] io scheduler bfq registered
[ 0.073570] armada-38x-pinctrl f1018000.pinctrl: registered pinctrl driver
[ 0.074833] debugfs: Directory 'f1018100.gpio' with parent 'regmap' already present!
[ 0.075249] debugfs: Directory 'f1018140.gpio' with parent 'regmap' already present!
[ 0.075678] mvebu-pcie soc:pcie: host bridge /soc/pcie ranges:
[ 0.075713] mvebu-pcie soc:pcie: MEM 0x00f1080000..0x00f1081fff -> 0x0000080000
[ 0.075732] mvebu-pcie soc:pcie: MEM 0x00f1040000..0x00f1041fff -> 0x0000040000
[ 0.075747] mvebu-pcie soc:pcie: MEM 0x00f1044000..0x00f1045fff -> 0x0000044000
[ 0.075761] mvebu-pcie soc:pcie: MEM 0x00f1048000..0x00f1049fff -> 0x0000048000
[ 0.075785] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[ 0.075799] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0100000000
[ 0.075813] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[ 0.075826] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0200000000
[ 0.075839] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[ 0.075852] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0300000000
[ 0.075865] mvebu-pcie soc:pcie: MEM 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[ 0.075875] mvebu-pcie soc:pcie: IO 0xffffffffffffffff..0x00fffffffe -> 0x0400000000
[ 0.076083] mvebu-pcie soc:pcie: PCI host bridge to bus 0000:00
[ 0.076092] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.076101] pci_bus 0000:00: root bus resource [mem 0xf1080000-0xf1081fff] (bus address [0x00080000-0x00081fff])
[ 0.076109] pci_bus 0000:00: root bus resource [mem 0xf1040000-0xf1041fff] (bus address [0x00040000-0x00041fff])
[ 0.076115] pci_bus 0000:00: root bus resource [mem 0xf1044000-0xf1045fff] (bus address [0x00044000-0x00045fff])
[ 0.076122] pci_bus 0000:00: root bus resource [mem 0xf1048000-0xf1049fff] (bus address [0x00048000-0x00049fff])
[ 0.076128] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xe7ffffff]
[ 0.076134] pci_bus 0000:00: root bus resource [io 0x1000-0xeffff]
[ 0.076231] pci 0000:00:01.0: [11ab:6820] type 01 class 0x060400
[ 0.076464] pci 0000:00:02.0: [11ab:6820] type 01 class 0x060400
[ 0.076646] pci 0000:00:03.0: [11ab:6820] type 01 class 0x060400
[ 0.077496] PCI: bus0: Fast back to back transfers disabled
[ 0.077508] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.077519] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.077529] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.077680] pci 0000:01:00.0: [168c:002e] type 00 class 0x028000
[ 0.077705] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 0.077813] pci 0000:01:00.0: supports D1
[ 0.077820] pci 0000:01:00.0: PME# supported from D0 D1 D3hot
[ 0.077965] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.108460] PCI: bus1: Fast back to back transfers enabled
[ 0.108482] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.108638] pci 0000:02:00.0: [168c:003c] type 00 class 0x028000
[ 0.108665] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.108697] pci 0000:02:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.108788] pci 0000:02:00.0: supports D1 D2
[ 0.108946] pci 0000:00:02.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.138435] PCI: bus2: Fast back to back transfers enabled
[ 0.138455] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[ 0.138617] pci 0000:03:00.0: [1b21:0612] type 00 class 0x010601
[ 0.138642] pci 0000:03:00.0: reg 0x10: [io 0x0000-0x0007]
[ 0.138653] pci 0000:03:00.0: reg 0x14: [io 0x0000-0x0003]
[ 0.138663] pci 0000:03:00.0: reg 0x18: [io 0x0000-0x0007]
[ 0.138672] pci 0000:03:00.0: reg 0x1c: [io 0x0000-0x0003]
[ 0.138681] pci 0000:03:00.0: reg 0x20: [io 0x0000-0x001f]
[ 0.138691] pci 0000:03:00.0: reg 0x24: [mem 0x00000000-0x000001ff]
[ 0.138702] pci 0000:03:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[ 0.139711] PCI: bus3: Fast back to back transfers disabled
[ 0.139722] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 03
[ 0.139767] pci 0000:00:01.0: BAR 8: assigned [mem 0xe0000000-0xe00fffff]
[ 0.139778] pci 0000:00:02.0: BAR 8: assigned [mem 0xe0200000-0xe04fffff]
[ 0.139787] pci 0000:00:03.0: BAR 8: assigned [mem 0xe0100000-0xe01fffff]
[ 0.139794] pci 0000:00:03.0: BAR 7: assigned [io 0x10000-0x10fff]
[ 0.139803] pci 0000:01:00.0: BAR 0: assigned [mem 0xe0000000-0xe000ffff 64bit]
[ 0.139813] pci 0000:01:00.0: BAR 0: error updating (0xe0000004 != 0xffffffff)
[ 0.139820] pci 0000:01:00.0: BAR 0: error updating (high 0x000000 != 0xffffffff)
[ 0.139827] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.139835] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe00fffff]
[ 0.139849] pci 0000:02:00.0: BAR 0: assigned [mem 0xe0200000-0xe03fffff 64bit]
[ 0.139858] pci 0000:02:00.0: BAR 0: error updating (0xe0200004 != 0xffffffff)
[ 0.139864] pci 0000:02:00.0: BAR 0: error updating (high 0x000000 != 0xffffffff)
[ 0.139870] pci 0000:02:00.0: BAR 6: assigned [mem 0xe0400000-0xe040ffff pref]
[ 0.139877] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.139884] pci 0000:00:02.0: bridge window [mem 0xe0200000-0xe04fffff]
[ 0.139900] pci 0000:03:00.0: BAR 6: assigned [mem 0xe0100000-0xe010ffff pref]
[ 0.139907] pci 0000:03:00.0: BAR 5: assigned [mem 0xe0110000-0xe01101ff]
[ 0.139916] pci 0000:03:00.0: BAR 4: assigned [io 0x10000-0x1001f]
[ 0.139924] pci 0000:03:00.0: BAR 0: assigned [io 0x10020-0x10027]
[ 0.139932] pci 0000:03:00.0: BAR 2: assigned [io 0x10028-0x1002f]
[ 0.139940] pci 0000:03:00.0: BAR 1: assigned [io 0x10030-0x10033]
[ 0.139947] pci 0000:03:00.0: BAR 3: assigned [io 0x10034-0x10037]
[ 0.139955] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.139961] pci 0000:00:03.0: bridge window [io 0x10000-0x10fff]
[ 0.139970] pci 0000:00:03.0: bridge window [mem 0xe0100000-0xe01fffff]
[ 0.141231] mv_xor f1060800.xor: Marvell shared XOR driver
[ 0.193773] Freeing initrd memory: 6176K
[ 0.198216] mv_xor f1060800.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.198481] mv_xor f1060900.xor: Marvell shared XOR driver
[ 0.258058] mv_xor f1060900.xor: Marvell XOR (Descriptor Mode): ( xor cpy intr )
[ 0.259581] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.261679] printk: console [ttyS0] disabled
[ 0.281811] f1012000.serial: ttyS0 at MMIO 0xf1012000 (irq = 30, base_baud = 15625000) is a 16550A
[ 1.665219] printk: console [ttyS0] enabled
[ 1.690116] f1012100.serial: ttyS1 at MMIO 0xf1012100 (irq = 31, base_baud = 15625000) is a 16550A
[ 1.699783] Serial: AMBA driver
[ 1.703217] msm_serial: driver initialized
[ 1.712736] brd: module loaded
[ 1.717986] armada38x-rtc f10a3800.rtc: registered as rtc0
[ 1.723563] armada38x-rtc f10a3800.rtc: setting system clock to 2022-11-19T09:48:18 UTC (1668851298)
[ 1.734377] orion_wdt: Initial timeout 171 sec
[ 1.739186] sdhci: Secure Digital Host Controller Interface driver
[ 1.745386] sdhci: Copyright(c) Pierre Ossman
[ 1.749900] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.755904] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.762844] ashmem: initialized
[ 1.767019] Key type dns_resolver registered
[ 1.771369] ThumbEE CPU extension supported.
[ 1.775656] Registering SWP/SWPB emulation handler
[ 1.780798] registered taskstats version 1
[ 1.784910] Loading compiled-in X.509 certificates
[ 1.789977] zswap: loaded using pool lzo/zbud
[ 1.794860] Key type .fscrypt registered
[ 1.798817] mmc0: SDHCI controller on f10d8000.sdhci [f10d8000.sdhci] using ADMA
[ 1.806388] Key type fscrypt-provisioning registered
[ 1.815605] Freeing unused kernel image (initmem) memory: 1024K
[ 1.847758] Run /init as init process
[ 1.851436] with arguments:
[ 1.851439] /init
[ 1.851441] with environment:
[ 1.851443] HOME=/
[ 1.851445] TERM=linux
[ 1.851447] modules=sd-mod,usb-storage,ext4
[ 1.878628] Alpine Init 3.6.2-r0
[ 1.882508] Loading boot drivers...
[ 1.901368] SCSI subsystem initialized
[ 1.909848] mmc0: new high speed MMC card at address 0001
[ 1.916060] mmcblk0: mmc0:0001 008G30 7.28 GiB
[ 1.920408] usbcore: registered new interface driver usbfs
[ 1.926205] usbcore: registered new interface driver hub
[ 1.931716] mmcblk0: p1 p2 p3
[ 1.931754] usbcore: registered new device driver usb
[ 1.935470] mmcblk0boot0: mmc0:0001 008G30 4.00 MiB
[ 1.949012] mmcblk0boot1: mmc0:0001 008G30 4.00 MiB
[ 1.952827] usbcore: registered new interface driver usb-storage
[ 1.955100] mmcblk0rpmb: mmc0:0001 008G30 4.00 MiB, chardev (246:0)
[ 2.020796] loop: module loaded
[ 2.075368] Loading boot drivers: ok.
[ 2.091327] Mounting root...
[ 2.169860] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.177230] ehci-orion: EHCI orion driver
[ 2.181489] orion-ehci f1058000.usb: EHCI Host Controller
[ 2.186916] orion-ehci f1058000.usb: new USB bus registered, assigned bus number 1
[ 2.194704] orion-ehci f1058000.usb: irq 49, io mem 0xf1058000
[ 2.237572] orion-ehci f1058000.usb: USB 2.0 started, EHCI 1.00
[ 2.243601] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.251901] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.259150] usb usb1: Product: EHCI Host Controller
[ 2.264039] usb usb1: Manufacturer: Linux 5.15.78-0-lts ehci_hcd
[ 2.270064] usb usb1: SerialNumber: f1058000.usb
[ 2.275081] hub 1-0:1.0: USB hub found
[ 2.278871] hub 1-0:1.0: 1 port detected
[ 2.304393] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 2.310597] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 2
[ 2.326965] xhci-hcd f10f0000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 2.336258] xhci-hcd f10f0000.usb3: irq 55, io mem 0xf10f0000
[ 2.342130] xhci-hcd f10f0000.usb3: xHCI Host Controller
[ 2.347462] xhci-hcd f10f0000.usb3: new USB bus registered, assigned bus number 3
[ 2.354980] xhci-hcd f10f0000.usb3: Host supports USB 3.0 SuperSpeed
[ 2.361440] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.369736] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.376977] usb usb2: Product: xHCI Host Controller
[ 2.381877] usb usb2: Manufacturer: Linux 5.15.78-0-lts xhci-hcd
[ 2.387903] usb usb2: SerialNumber: f10f0000.usb3
[ 2.398591] hub 2-0:1.0: USB hub found
[ 2.402379] hub 2-0:1.0: 1 port detected
[ 2.406591] usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.414784] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.423081] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.430336] usb usb3: Product: xHCI Host Controller
[ 2.435224] usb usb3: Manufacturer: Linux 5.15.78-0-lts xhci-hcd
[ 2.441251] usb usb3: SerialNumber: f10f0000.usb3
[ 2.446301] hub 3-0:1.0: USB hub found
[ 2.450090] hub 3-0:1.0: 1 port detected
[ 2.454519] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 2.459870] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 4
[ 2.467745] xhci-hcd f10f8000.usb3: hcc params 0x0a000990 hci version 0x100 quirks 0x0000000000010010
[ 2.477030] xhci-hcd f10f8000.usb3: irq 56, io mem 0xf10f8000
[ 2.482898] xhci-hcd f10f8000.usb3: xHCI Host Controller
[ 2.488241] xhci-hcd f10f8000.usb3: new USB bus registered, assigned bus number 5
[ 2.495754] xhci-hcd f10f8000.usb3: Host supports USB 3.0 SuperSpeed
[ 2.502255] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.510553] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.517800] usb usb4: Product: xHCI Host Controller
[ 2.522688] usb usb4: Manufacturer: Linux 5.15.78-0-lts xhci-hcd
[ 2.528716] usb usb4: SerialNumber: f10f8000.usb3
[ 2.533800] hub 4-0:1.0: USB hub found
[ 2.537589] hub 4-0:1.0: 1 port detected
[ 2.541783] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
[ 2.549967] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 2.558266] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.565507] usb usb5: Product: xHCI Host Controller
[ 2.570404] usb usb5: Manufacturer: Linux 5.15.78-0-lts xhci-hcd
[ 2.576425] usb usb5: SerialNumber: f10f8000.usb3
[ 2.581594] hub 5-0:1.0: USB hub found
[ 2.585379] hub 5-0:1.0: 1 port detected
[ 2.610148] libata version 3.00 loaded.
[ 2.614485] ahci-mvebu f10a8000.sata: supply ahci not found, using dummy regulator
[ 2.622239] ahci-mvebu f10a8000.sata: supply phy not found, using dummy regulator
[ 2.629793] ahci-mvebu f10a8000.sata: supply target not found, using dummy regulator
[ 2.637674] ahci-mvebu f10a8000.sata: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 2.646749] ahci-mvebu f10a8000.sata: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 2.656568] scsi host0: ahci-mvebu
[ 2.660490] scsi host1: ahci-mvebu
[ 2.664073] ata1: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x100 irq 53
[ 2.672182] ata2: SATA max UDMA/133 mmio [mem 0xf10a8000-0xf10a9fff] port 0x180 irq 53
[ 3.008829] ata2: SATA link down (SStatus 0 SControl 300)
[ 3.014265] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.033791] ahci 0000:03:00.0: version 3.0
[ 3.033814] pci 0000:00:03.0: enabling device (0140 -> 0143)
[ 3.039519] ahci 0000:03:00.0: enabling device (0140 -> 0143)
[ 3.045397] ahci 0000:03:00.0: SSS flag set, parallel bus scan disabled
[ 3.052071] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 3.060199] ahci 0000:03:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs
[ 3.070243] scsi host2: ahci
[ 3.073524] scsi host3: ahci
[ 3.076568] ata3: SATA max UDMA/133 abar m512@0xe0110000 port 0xe0110100 irq 61
[ 3.083942] ata4: SATA max UDMA/133 abar m512@0xe0110000 port 0xe0110180 irq 61
[ 3.418850] ata3: SATA link down (SStatus 0 SControl 300)
[ 3.748844] ata4: SATA link down (SStatus 0 SControl 300)
[ 4.344305] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 4.354459] Mounting root: ok.
[ 5.930666] mvneta_bm f10c8000.bm: Buffer Manager for network controller enabled
[ 6.015936] marvell-cesa f1090000.crypto: CESA device successfully registered
[ 6.050339] mvneta f1070000.ethernet eth0: Using random mac address 8a:52:fc:7b:a5:fd
[ 6.121831] mvneta f1030000.ethernet eth1: Using random mac address ca:2c:1f:96:a1:50
[ 6.279137] i2c i2c-0: Added multiplexed i2c bus 1
[ 6.279250] i2c i2c-0: Added multiplexed i2c bus 2
[ 6.279349] i2c i2c-0: Added multiplexed i2c bus 3
[ 6.279467] i2c i2c-0: Added multiplexed i2c bus 4
[ 6.279569] i2c i2c-0: Added multiplexed i2c bus 5
[ 6.279670] i2c i2c-0: Added multiplexed i2c bus 6
[ 6.279781] i2c i2c-0: Added multiplexed i2c bus 7
[ 6.280155] i2c i2c-0: Added multiplexed i2c bus 8
[ 6.280164] pca954x 0-0070: registered 8 multiplexed busses for I2C mux pca9547
[ 6.382358] pca953x 8-0071: supply vcc not found, using dummy regulator
[ 6.382539] pca953x 8-0071: using no AI
[ 6.383268] pca953x 8-0071: interrupt support not compiled in
[ 6.387781] at24 1-0054: supply vcc not found, using dummy regulator
[ 6.397612] at24 1-0054: 8192 byte 24c64 EEPROM, writable, 1 bytes/write
[ 6.580066] mvneta f1034000.ethernet eth2: Using random mac address 82:8a:33:97:f1:48
[ 6.716093] NET: Registered PF_INET6 protocol family
[ 6.730175] Segment Routing with IPv6
[ 6.730219] In-situ OAM (IOAM) with IPv6
[ 6.749974] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.785807] mv88e6085 f1072004.mdio-mii:10: switch 0x1760 detected: Marvell 88E6176, revision 1
[ 6.868497] spi-nor spi0.0: s25fl164k (8192 Kbytes)
[ 6.873094] 2 fixed-partitions partitions found on MTD device spi0.0
[ 6.873109] Creating 2 MTD partitions on "spi0.0":
[ 6.873116] 0x000000000000-0x000000100000 : "U-Boot"
[ 6.873707] 0x000000100000-0x000000800000 : "Rescue system"
[ 7.118266] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.140297] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.238307] pci 0000:00:01.0: enabling device (0140 -> 0142)
[ 7.238334] ath9k 0000:01:00.0: enabling device (0000 -> 0002)
[ 7.238462] ath: phy0: Failed to read SREV register
[ 7.238468] ath: phy0: Could not read hardware revisions
[ 7.238471] ath: phy0: Unable to initialize hardware; initialization status: -95
[ 7.238478] ath9k 0000:01:00.0: Failed to initialize device
[ 7.238513] ath9k: probe of 0000:01:00.0 failed with error -95
[ 7.292215] ath10k_pci 0000:02:00.0: of_irq_parse_pci: failed with rc=134
[ 7.293310] pci 0000:00:02.0: enabling device (0140 -> 0142)
[ 7.293328] ath10k_pci 0000:02:00.0: can't change power state from D3cold to D0 (config space inaccessible)
[ 7.323532] ath10k_pci 0000:02:00.0: failed to wake up device : -110
[ 7.332159] ath10k_pci: probe of 0000:02:00.0 failed with error -110
[ 7.974625] mv88e6085 f1072004.mdio-mii:10 lan0 (uninitialized): PHY [mv88e6xxx-0:00] driver [Marvell 88E1540] (irq=73)
[ 8.084450] mv88e6085 f1072004.mdio-mii:10 lan1 (uninitialized): PHY [mv88e6xxx-0:01] driver [Marvell 88E1540] (irq=74)
[ 8.192201] mv88e6085 f1072004.mdio-mii:10 lan2 (uninitialized): PHY [mv88e6xxx-0:02] driver [Marvell 88E1540] (irq=75)
[ 8.282488] NET: Registered PF_PACKET protocol family
[ 8.297869] mv88e6085 f1072004.mdio-mii:10 lan3 (uninitialized): PHY [mv88e6xxx-0:03] driver [Marvell 88E1540] (irq=76)
[ 8.402600] mv88e6085 f1072004.mdio-mii:10 lan4 (uninitialized): PHY [mv88e6xxx-0:04] driver [Marvell 88E1540] (irq=77)
[ 8.408381] mv88e6085 f1072004.mdio-mii:10: configuring for fixed/rgmii-id link mode
[ 8.409739] DSA: tree 0 setup
[ 8.413561] mv88e6085 f1072004.mdio-mii:10: Link is Up - 1Gbps/Full - flow control off
[ 8.577480] EXT4-fs (mmcblk0p3): re-mounted. Opts: (null). Quota mode: none.
[ 8.676846] Adding 1908732k swap on /dev/mmcblk0p2. Priority:-2 extents:1 across:1908732k SSFS
[ 8.769560] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 9.148555] mvneta f1034000.ethernet eth2: PHY [f1072004.mdio-mii:01] driver [Marvell 88E1510] (irq=POLL)
[ 9.148818] mvneta f1034000.ethernet eth2: configuring for phy/sgmii link mode
[ 13.287958] mvneta f1034000.ethernet eth2: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.287984] IPv6: ADDRCONF(NETDEV_CHANGE): eth2: link becomes ready
[ 15.781611] random: crng init done
[ 16.214482] fbcon: Taking over console
kernel config:
# Automatically generated file; DO NOT EDIT.
# Linux/arm 5.15.78 Kernel Configuration
CONFIG_CC_VERSION_TEXT="gcc (Debian 10.2.1-6) 10.2.1 20210110"
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=100201
CONFIG_CLANG_VERSION=0
CONFIG_AS_IS_GNU=y
CONFIG_AS_VERSION=23502
CONFIG_LD_IS_BFD=y
CONFIG_LD_VERSION=23502
CONFIG_LLD_VERSION=0
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_TABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
# CONFIG_WERROR is not set
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_INIT=""
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_POSIX_MQUEUE=y
CONFIG_POSIX_MQUEUE_SYSCTL=y
# CONFIG_WATCH_QUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
CONFIG_AUDIT=y
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
CONFIG_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_IRQ_MIGRATION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_IRQ_FASTEOI_HIERARCHY_HANDLERS=y
CONFIG_GENERIC_IRQ_IPI=y
CONFIG_GENERIC_MSI_IRQ=y
CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_BPF=y
CONFIG_HAVE_EBPF_JIT=y
# BPF subsystem
CONFIG_BPF_SYSCALL=y
# CONFIG_BPF_JIT is not set
CONFIG_BPF_UNPRIV_DEFAULT_OFF=y
CONFIG_USERMODE_DRIVER=y
# CONFIG_BPF_PRELOAD is not set
# end of BPF subsystem
# CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY=y
# CONFIG_PREEMPT is not set
CONFIG_SCHED_CORE=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_HAVE_SCHED_AVG_IRQ=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_PSI=y
CONFIG_PSI_DEFAULT_DISABLED=y
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_TASKS_RCU_GENERIC=y
CONFIG_TASKS_RUDE_RCU=y
CONFIG_TASKS_TRACE_RCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
CONFIG_IKCONFIG=m
CONFIG_IKCONFIG_PROC=y
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
# CONFIG_PRINTK_INDEX is not set
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# CONFIG_UCLAMP_TASK is not set
# end of Scheduler features
CONFIG_CGROUPS=y
CONFIG_PAGE_COUNTER=y
CONFIG_MEMCG=y
CONFIG_MEMCG_SWAP=y
CONFIG_MEMCG_KMEM=y
CONFIG_BLK_CGROUP=y
CONFIG_CGROUP_WRITEBACK=y
CONFIG_CGROUP_SCHED=y
CONFIG_FAIR_GROUP_SCHED=y
# CONFIG_CFS_BANDWIDTH is not set
# CONFIG_RT_GROUP_SCHED is not set
CONFIG_CGROUP_PIDS=y
# CONFIG_CGROUP_RDMA is not set
CONFIG_CGROUP_FREEZER=y
# CONFIG_CPUSETS is not set
CONFIG_CGROUP_DEVICE=y
CONFIG_CGROUP_CPUACCT=y
# CONFIG_CGROUP_PERF is not set
CONFIG_CGROUP_BPF=y
# CONFIG_CGROUP_MISC is not set
# CONFIG_CGROUP_DEBUG is not set
CONFIG_SOCK_CGROUP_DATA=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_CHECKPOINT_RESTORE=y
CONFIG_SCHED_AUTOGROUP=y
# CONFIG_SYSFS_DEPRECATED is not set
CONFIG_RELAY=y
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_RD_ZSTD=y
# CONFIG_BOOT_CONFIG is not set
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_LD_ORPHAN_WARN=y
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
CONFIG_EXPERT=y
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
# CONFIG_SYSFS_SYSCALL is not set
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_HAVE_FUTEX_CMPXCHG=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_ALL=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_KCMP=y
CONFIG_RSEQ=y
# CONFIG_DEBUG_RSEQ is not set
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
# CONFIG_SLUB_DEBUG is not set
# CONFIG_COMPAT_BRK is not set
# CONFIG_SLAB is not set
CONFIG_SLUB=y
# CONFIG_SLOB is not set
CONFIG_SLAB_MERGE_DEFAULT=y
CONFIG_SLAB_FREELIST_RANDOM=y
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SLUB_CPU_PARTIAL=y
CONFIG_SYSTEM_DATA_VERIFICATION=y
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_NO_IOPORT_MAP=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_ARCH_HAS_BANDGAP=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_FIQ=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=15
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# end of Multiple platform selection
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_AT91 is not set
CONFIG_ARCH_BCM=y
# IPROC architected SoCs
# CONFIG_ARCH_BCM_CYGNUS is not set
# CONFIG_ARCH_BCM_HR2 is not set
# CONFIG_ARCH_BCM_NSP is not set
# CONFIG_ARCH_BCM_5301X is not set
# KONA architected SoCs
# CONFIG_ARCH_BCM_281XX is not set
# CONFIG_ARCH_BCM_21664 is not set
# CONFIG_ARCH_BCM_23550 is not set
# Other Architectures
CONFIG_ARCH_BCM2835=y
# CONFIG_ARCH_BCM_53573 is not set
# CONFIG_ARCH_BCM_63XX is not set
# CONFIG_ARCH_BRCMSTB is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
CONFIG_ARCH_EXYNOS=y
CONFIG_S5P_DEV_MFC=y
# CONFIG_ARCH_EXYNOS3 is not set
CONFIG_ARCH_EXYNOS4=y
CONFIG_ARCH_EXYNOS5=y
# Exynos SoCs
CONFIG_CPU_EXYNOS4210=y
CONFIG_SOC_EXYNOS4412=y
CONFIG_SOC_EXYNOS5250=y
CONFIG_SOC_EXYNOS5260=y
CONFIG_SOC_EXYNOS5410=y
CONFIG_SOC_EXYNOS5420=y
CONFIG_SOC_EXYNOS5800=y
CONFIG_EXYNOS_MCPM=y
CONFIG_EXYNOS_CPU_SUSPEND=y
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
CONFIG_ARCH_MXC=y
CONFIG_MXC_TZIC=y
CONFIG_HAVE_IMX_ANATOP=y
CONFIG_HAVE_IMX_GPC=y
CONFIG_HAVE_IMX_MMDC=y
CONFIG_HAVE_IMX_SRC=y
# Cortex-A platforms
CONFIG_SOC_IMX5=y
# CONFIG_SOC_IMX50 is not set
CONFIG_SOC_IMX51=y
CONFIG_SOC_IMX53=y
CONFIG_SOC_IMX6=y
CONFIG_SOC_IMX6Q=y
CONFIG_SOC_IMX6SL=y
# CONFIG_SOC_IMX6SLL is not set
CONFIG_SOC_IMX6SX=y
CONFIG_SOC_IMX6UL=y
# CONFIG_SOC_LS1021A is not set
# Cortex-A/Cortex-M asymmetric multiprocessing platforms
CONFIG_SOC_IMX7D_CA7=y
CONFIG_SOC_IMX7D=y
# CONFIG_SOC_IMX7ULP is not set
# CONFIG_SOC_VF610 is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MILBEAUT is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MSTARV7 is not set
CONFIG_ARCH_MVEBU=y
CONFIG_MACH_MVEBU_ANY=y
CONFIG_MACH_MVEBU_V7=y
# CONFIG_MACH_ARMADA_370 is not set
# CONFIG_MACH_ARMADA_375 is not set
CONFIG_MACH_ARMADA_38X=y
# CONFIG_MACH_ARMADA_39X is not set
# CONFIG_MACH_ARMADA_XP is not set
# CONFIG_MACH_DOVE is not set
# CONFIG_ARCH_NPCM is not set
CONFIG_ARCH_OMAP=y
# TI OMAP Common Features
# OMAP Feature Selections
# CONFIG_OMAP_RESET_CLOCKS is not set
CONFIG_OMAP_32K_TIMER=y
# end of TI OMAP Common Features
CONFIG_MACH_OMAP_GENERIC=y
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
CONFIG_SOC_AM33XX=y
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
CONFIG_ARCH_OMAP2PLUS=y
# TI OMAP2/3/4 Specific Features
CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
# CONFIG_SOC_HAS_OMAP2_SDRC is not set
# OMAP Legacy Platform Data Board Type
# end of TI OMAP2/3/4 Specific Features
# end of TI OMAP/AM/DM/DRA Family
CONFIG_ARCH_QCOM=y
# CONFIG_ARCH_IPQ40XX is not set
CONFIG_ARCH_MSM8X60=y
CONFIG_ARCH_MSM8960=y
CONFIG_ARCH_MSM8974=y
# CONFIG_ARCH_MDM9615 is not set
# CONFIG_ARCH_RDA is not set
# CONFIG_ARCH_REALTEK is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_INTEL_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
CONFIG_ARCH_SUNXI=y
CONFIG_MACH_SUN4I=y
CONFIG_MACH_SUN5I=y
CONFIG_MACH_SUN6I=y
CONFIG_MACH_SUN7I=y
CONFIG_MACH_SUN8I=y
CONFIG_MACH_SUN9I=y
CONFIG_ARCH_SUNXI_MC_SMP=y
CONFIG_ARCH_TEGRA=y
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
CONFIG_ARCH_VEXPRESS=y
CONFIG_ARCH_VEXPRESS_CORTEX_A5_A9_ERRATA=y
CONFIG_ARCH_VEXPRESS_DCSCB=y
CONFIG_ARCH_VEXPRESS_SPC=y
CONFIG_ARCH_VEXPRESS_TC2_PM=y
# CONFIG_ARCH_WM8850 is not set
CONFIG_ARCH_ZYNQ=y
CONFIG_PLAT_ORION=y
CONFIG_PLAT_VERSATILE=y
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
CONFIG_ARM_THUMB=y
CONFIG_ARM_THUMBEE=y
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_BIG_ENDIAN is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_HARDEN_BRANCH_HISTORY=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_CACHE_FEROCEON_L2=y
# CONFIG_CACHE_FEROCEON_L2_WRITETHROUGH is not set
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
CONFIG_CACHE_L2X0_PMU=y
CONFIG_PL310_ERRATA_588369=y
CONFIG_PL310_ERRATA_727915=y
CONFIG_PL310_ERRATA_753970=y
CONFIG_PL310_ERRATA_769419=y
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_ARCH_SUPPORTS_BIG_ENDIAN=y
CONFIG_DEBUG_ALIGN_RODATA=y
CONFIG_ARM_ERRATA_430973=y
CONFIG_ARM_ERRATA_643719=y
CONFIG_ARM_ERRATA_720789=y
CONFIG_ARM_ERRATA_754322=y
CONFIG_ARM_ERRATA_754327=y
CONFIG_ARM_ERRATA_764369=y
CONFIG_ARM_ERRATA_775420=y
CONFIG_ARM_ERRATA_798181=y
CONFIG_ARM_ERRATA_773022=y
CONFIG_ARM_ERRATA_818325_852422=y
CONFIG_ARM_ERRATA_821420=y
CONFIG_ARM_ERRATA_825619=y
# CONFIG_ARM_ERRATA_857271 is not set
CONFIG_ARM_ERRATA_852421=y
CONFIG_ARM_ERRATA_852423=y
# CONFIG_ARM_ERRATA_857272 is not set
# end of System Type
# Bus support
CONFIG_ARM_ERRATA_814220=y
# end of Bus support
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
CONFIG_SCHED_MC=y
CONFIG_SCHED_SMT=y
CONFIG_HAVE_ARM_SCU=y
CONFIG_HAVE_ARM_ARCH_TIMER=y
CONFIG_HAVE_ARM_TWD=y
CONFIG_MCPM=y
# CONFIG_BIG_LITTLE is not set
# CONFIG_VMSPLIT_3G is not set
# CONFIG_VMSPLIT_3G_OPT is not set
CONFIG_VMSPLIT_2G=y
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0x80000000
CONFIG_NR_CPUS=4
CONFIG_HOTPLUG_CPU=y
CONFIG_ARM_PSCI=y
CONFIG_ARCH_NR_GPIO=1024
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_HIGHMEM=y
# CONFIG_HIGHPTE is not set
# CONFIG_CPU_SW_DOMAIN_PAN is not set
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
CONFIG_PARAVIRT=y
CONFIG_PARAVIRT_TIME_ACCOUNTING=y
# CONFIG_XEN is not set
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0
CONFIG_ZBOOT_ROM_BSS=0
# CONFIG_ARM_APPENDED_DTB is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
CONFIG_EFI_STUB=y
CONFIG_EFI=y
CONFIG_DMI=y
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
CONFIG_CPU_FREQ_GOV_COMMON=y
CONFIG_CPU_FREQ_STAT=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=m
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM is not set
# CONFIG_ARM_ARMADA_37XX_CPUFREQ is not set
# CONFIG_ARM_ARMADA_8K_CPUFREQ is not set
# CONFIG_ARM_VEXPRESS_SPC_CPUFREQ is not set
CONFIG_ARM_IMX6Q_CPUFREQ=y
# CONFIG_ARM_IMX_CPUFREQ_DT is not set
CONFIG_ARM_OMAP2PLUS_CPUFREQ=y
# CONFIG_ARM_QCOM_CPUFREQ_HW is not set
CONFIG_ARM_TEGRA20_CPUFREQ=m
CONFIG_ARM_TEGRA124_CPUFREQ=y
# CONFIG_ARM_TI_CPUFREQ is not set
# end of CPU Frequency scaling
# CPU Idle
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
# CONFIG_CPU_IDLE_GOV_TEO is not set
# ARM CPU Idle Drivers
# CONFIG_ARM_CPUIDLE is not set
# CONFIG_ARM_PSCI_CPUIDLE is not set
# CONFIG_ARM_BIG_LITTLE_CPUIDLE is not set
# CONFIG_ARM_HIGHBANK_CPUIDLE is not set
# CONFIG_ARM_ZYNQ_CPUIDLE is not set
# CONFIG_ARM_EXYNOS_CPUIDLE is not set
CONFIG_ARM_MVEBU_V7_CPUIDLE=y
# CONFIG_ARM_TEGRA_CPUIDLE is not set
# CONFIG_ARM_QCOM_SPM_CPUIDLE is not set
# end of ARM CPU Idle Drivers
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
CONFIG_KERNEL_MODE_NEON=y
# end of Floating point emulation
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_SUSPEND_SKIP_SYNC is not set
CONFIG_HIBERNATE_CALLBACKS=y
CONFIG_HIBERNATION=y
# CONFIG_HIBERNATION_SNAPSHOT_DEV is not set
CONFIG_PM_STD_PARTITION=""
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
CONFIG_PM_AUTOSLEEP=y
CONFIG_PM_WAKELOCKS=y
CONFIG_PM_WAKELOCKS_LIMIT=100
CONFIG_PM_WAKELOCKS_GC=y
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
CONFIG_PM_GENERIC_DOMAINS=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
CONFIG_PM_GENERIC_DOMAINS_OF=y
CONFIG_CPU_PM=y
# CONFIG_ENERGY_MODEL is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
CONFIG_ARM_CRYPTO=y
CONFIG_CRYPTO_SHA1_ARM=m
CONFIG_CRYPTO_SHA1_ARM_NEON=m
# CONFIG_CRYPTO_SHA1_ARM_CE is not set
# CONFIG_CRYPTO_SHA2_ARM_CE is not set
CONFIG_CRYPTO_SHA256_ARM=m
CONFIG_CRYPTO_SHA512_ARM=m
CONFIG_CRYPTO_BLAKE2S_ARM=y
CONFIG_CRYPTO_BLAKE2B_NEON=m
CONFIG_CRYPTO_AES_ARM=m
CONFIG_CRYPTO_AES_ARM_BS=m
# CONFIG_CRYPTO_AES_ARM_CE is not set
# CONFIG_CRYPTO_GHASH_ARM_CE is not set
# CONFIG_CRYPTO_CRCT10DIF_ARM_CE is not set
# CONFIG_CRYPTO_CRC32_ARM_CE is not set
CONFIG_CRYPTO_CHACHA20_NEON=m
CONFIG_CRYPTO_POLY1305_ARM=m
CONFIG_CRYPTO_NHPOLY1305_NEON=m
CONFIG_CRYPTO_CURVE25519_NEON=m
# General architecture-dependent options
CONFIG_KPROBES=y
CONFIG_JUMP_LABEL=y
# CONFIG_STATIC_KEYS_SELFTEST is not set
CONFIG_OPTPROBES=y
CONFIG_UPROBES=y
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_KRETPROBES=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP=y
CONFIG_SECCOMP_FILTER=y
# CONFIG_SECCOMP_CACHE_DEBUG is not set
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_LTO_NONE=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
# CONFIG_LOCK_EVENT_COUNTS is not set
CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
CONFIG_HAVE_ARCH_PFN_VALID=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_HAVE_GCC_PLUGINS=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS_NONE is not set
CONFIG_MODULE_COMPRESS_GZIP=y
# CONFIG_MODULE_COMPRESS_XZ is not set
# CONFIG_MODULE_COMPRESS_ZSTD is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
CONFIG_MODPROBE_PATH="/sbin/modprobe"
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_CGROUP_RWSTAT=y
CONFIG_BLK_DEV_BSG_COMMON=y
CONFIG_BLK_DEV_BSGLIB=y
CONFIG_BLK_DEV_INTEGRITY=y
CONFIG_BLK_DEV_INTEGRITY_T10=m
# CONFIG_BLK_DEV_ZONED is not set
CONFIG_BLK_DEV_THROTTLING=y
# CONFIG_BLK_DEV_THROTTLING_LOW is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_CGROUP_IOLATENCY=y
# CONFIG_BLK_CGROUP_IOCOST is not set
# CONFIG_BLK_CGROUP_IOPRIO is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# CONFIG_BLK_INLINE_ENCRYPTION is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_AIX_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
# CONFIG_CMDLINE_PARTITION is not set
# end of Partition Types
CONFIG_BLK_MQ_PCI=y
CONFIG_BLK_MQ_VIRTIO=y
CONFIG_BLK_PM=y
CONFIG_BLOCK_HOLDER_DEPRECATED=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
CONFIG_IOSCHED_BFQ=y
CONFIG_BFQ_GROUP_IOSCHED=y
# CONFIG_BFQ_CGROUP_DEBUG is not set
# end of IO Schedulers
CONFIG_PADATA=y
CONFIG_ASN1=y
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
CONFIG_BINFMT_MISC=m
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_MEMORY_BALLOON=y
CONFIG_BALLOON_COMPACTION=y
CONFIG_COMPACTION=y
CONFIG_PAGE_REPORTING=y
CONFIG_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_BOUNCE=y
CONFIG_KSM=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_CLEANCACHE is not set
CONFIG_FRONTSWAP=y
CONFIG_CMA=y
# CONFIG_CMA_DEBUG is not set
# CONFIG_CMA_DEBUGFS is not set
# CONFIG_CMA_SYSFS is not set
CONFIG_CMA_AREAS=7
CONFIG_ZSWAP=y
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_DEFLATE is not set
CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZO=y
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_842 is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZ4 is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_LZ4HC is not set
# CONFIG_ZSWAP_COMPRESSOR_DEFAULT_ZSTD is not set
CONFIG_ZSWAP_COMPRESSOR_DEFAULT="lzo"
CONFIG_ZSWAP_ZPOOL_DEFAULT_ZBUD=y
# CONFIG_ZSWAP_ZPOOL_DEFAULT_Z3FOLD is not set
# CONFIG_ZSWAP_ZPOOL_DEFAULT_ZSMALLOC is not set
CONFIG_ZSWAP_ZPOOL_DEFAULT="zbud"
# CONFIG_ZSWAP_DEFAULT_ON is not set
CONFIG_ZPOOL=y
CONFIG_ZBUD=y
# CONFIG_Z3FOLD is not set
CONFIG_ZSMALLOC=m
# CONFIG_ZSMALLOC_STAT is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_ZONE_DMA=y
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_TEST is not set
CONFIG_KMAP_LOCAL=y
CONFIG_KMAP_LOCAL_NON_LINEAR_PTE_ARRAY=y
# Data Access Monitoring
# CONFIG_DAMON is not set
# end of Data Access Monitoring
# end of Memory Management options
CONFIG_NET=y
CONFIG_NET_INGRESS=y
CONFIG_NET_EGRESS=y
CONFIG_NET_REDIRECT=y
CONFIG_SKB_EXTENSIONS=y
# Networking options
CONFIG_PACKET=m
CONFIG_PACKET_DIAG=m
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_AF_UNIX_OOB=y
CONFIG_UNIX_DIAG=m
CONFIG_TLS=m
# CONFIG_TLS_DEVICE is not set
# CONFIG_TLS_TOE is not set
CONFIG_XFRM=y
CONFIG_XFRM_ALGO=m
CONFIG_XFRM_USER=m
CONFIG_XFRM_INTERFACE=m
CONFIG_XFRM_SUB_POLICY=y
CONFIG_XFRM_MIGRATE=y
CONFIG_XFRM_STATISTICS=y
CONFIG_XFRM_AH=m
CONFIG_XFRM_ESP=m
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
CONFIG_NET_KEY_MIGRATE=y
CONFIG_XDP_SOCKETS=y
# CONFIG_XDP_SOCKETS_DIAG is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
# CONFIG_IP_FIB_TRIE_STATS is not set
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_VERBOSE=y
CONFIG_IP_ROUTE_CLASSID=y
# CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE_DEMUX=m
CONFIG_NET_IP_TUNNEL=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE_COMMON=y
CONFIG_IP_MROUTE=y
CONFIG_IP_MROUTE_MULTIPLE_TABLES=y
# CONFIG_IP_PIMSM_V1 is not set
CONFIG_IP_PIMSM_V2=y
CONFIG_SYN_COOKIES=y
CONFIG_NET_IPVTI=m
CONFIG_NET_UDP_TUNNEL=m
CONFIG_NET_FOU=m
CONFIG_NET_FOU_IP_TUNNELS=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
# CONFIG_INET_ESP_OFFLOAD is not set
# CONFIG_INET_ESPINTCP is not set
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
CONFIG_INET_UDP_DIAG=m
# CONFIG_INET_RAW_DIAG is not set
CONFIG_INET_DIAG_DESTROY=y
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
CONFIG_TCP_CONG_HSTCP=m
CONFIG_TCP_CONG_HYBLA=m
CONFIG_TCP_CONG_VEGAS=m
CONFIG_TCP_CONG_NV=m
CONFIG_TCP_CONG_SCALABLE=m
CONFIG_TCP_CONG_LP=m
CONFIG_TCP_CONG_VENO=m
CONFIG_TCP_CONG_YEAH=m
CONFIG_TCP_CONG_ILLINOIS=m
CONFIG_TCP_CONG_DCTCP=m
CONFIG_TCP_CONG_CDG=m
CONFIG_TCP_CONG_BBR=m
CONFIG_DEFAULT_CUBIC=y
# CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG="cubic"
CONFIG_TCP_MD5SIG=y
CONFIG_IPV6=m
CONFIG_IPV6_ROUTER_PREF=y
CONFIG_IPV6_ROUTE_INFO=y
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
CONFIG_INET6_AH=m
CONFIG_INET6_ESP=m
# CONFIG_INET6_ESP_OFFLOAD is not set
# CONFIG_INET6_ESPINTCP is not set
CONFIG_INET6_IPCOMP=m
CONFIG_IPV6_MIP6=m
CONFIG_IPV6_ILA=m
CONFIG_INET6_XFRM_TUNNEL=m
CONFIG_INET6_TUNNEL=m
CONFIG_IPV6_VTI=m
CONFIG_IPV6_SIT=m
CONFIG_IPV6_SIT_6RD=y
CONFIG_IPV6_NDISC_NODETYPE=y
CONFIG_IPV6_TUNNEL=m
CONFIG_IPV6_GRE=m
CONFIG_IPV6_FOU=m
CONFIG_IPV6_FOU_TUNNEL=m
CONFIG_IPV6_MULTIPLE_TABLES=y
CONFIG_IPV6_SUBTREES=y
CONFIG_IPV6_MROUTE=y
CONFIG_IPV6_MROUTE_MULTIPLE_TABLES=y
CONFIG_IPV6_PIMSM_V2=y
CONFIG_IPV6_SEG6_LWTUNNEL=y
CONFIG_IPV6_SEG6_HMAC=y
# CONFIG_IPV6_RPL_LWTUNNEL is not set
# CONFIG_IPV6_IOAM6_LWTUNNEL is not set
CONFIG_NETLABEL=y
# CONFIG_MPTCP is not set
CONFIG_NETWORK_SECMARK=y
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
CONFIG_NETFILTER=y
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=m
# Core Netfilter Configuration
CONFIG_NETFILTER_INGRESS=y
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_FAMILY_BRIDGE=y
CONFIG_NETFILTER_FAMILY_ARP=y
# CONFIG_NETFILTER_NETLINK_HOOK is not set
CONFIG_NETFILTER_NETLINK_ACCT=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NETFILTER_NETLINK_OSF=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_LOG_SYSLOG=m
CONFIG_NETFILTER_CONNCOUNT=m
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_SECMARK=y
CONFIG_NF_CONNTRACK_ZONES=y
# CONFIG_NF_CONNTRACK_PROCFS is not set
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CONNTRACK_TIMEOUT=y
CONFIG_NF_CONNTRACK_TIMESTAMP=y
CONFIG_NF_CONNTRACK_LABELS=y
CONFIG_NF_CT_PROTO_DCCP=y
CONFIG_NF_CT_PROTO_GRE=y
CONFIG_NF_CT_PROTO_SCTP=y
CONFIG_NF_CT_PROTO_UDPLITE=y
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_BROADCAST=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_SNMP=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SANE=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NF_CT_NETLINK_TIMEOUT=m
CONFIG_NF_CT_NETLINK_HELPER=m
CONFIG_NETFILTER_NETLINK_GLUE_CT=y
CONFIG_NF_NAT=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_SIP=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_REDIRECT=y
CONFIG_NF_NAT_MASQUERADE=y
CONFIG_NETFILTER_SYNPROXY=m
CONFIG_NF_TABLES=m
CONFIG_NF_TABLES_INET=y
CONFIG_NF_TABLES_NETDEV=y
CONFIG_NFT_NUMGEN=m
CONFIG_NFT_CT=m
CONFIG_NFT_FLOW_OFFLOAD=m
CONFIG_NFT_COUNTER=m
CONFIG_NFT_CONNLIMIT=m
CONFIG_NFT_LOG=m
CONFIG_NFT_LIMIT=m
CONFIG_NFT_MASQ=m
CONFIG_NFT_REDIR=m
CONFIG_NFT_NAT=m
CONFIG_NFT_TUNNEL=m
CONFIG_NFT_OBJREF=m
CONFIG_NFT_QUEUE=m
CONFIG_NFT_QUOTA=m
CONFIG_NFT_REJECT=m
CONFIG_NFT_REJECT_INET=m
CONFIG_NFT_COMPAT=m
CONFIG_NFT_HASH=m
CONFIG_NFT_FIB=m
CONFIG_NFT_FIB_INET=m
# CONFIG_NFT_XFRM is not set
CONFIG_NFT_SOCKET=m
CONFIG_NFT_OSF=m
CONFIG_NFT_TPROXY=m
# CONFIG_NFT_SYNPROXY is not set
CONFIG_NF_DUP_NETDEV=m
CONFIG_NFT_DUP_NETDEV=m
CONFIG_NFT_FWD_NETDEV=m
CONFIG_NFT_FIB_NETDEV=m
# CONFIG_NFT_REJECT_NETDEV is not set
CONFIG_NF_FLOW_TABLE_INET=m
CONFIG_NF_FLOW_TABLE=m
CONFIG_NETFILTER_XTABLES=m
# Xtables combined modules
CONFIG_NETFILTER_XT_MARK=m
CONFIG_NETFILTER_XT_CONNMARK=m
CONFIG_NETFILTER_XT_SET=m
# Xtables targets
CONFIG_NETFILTER_XT_TARGET_AUDIT=m
CONFIG_NETFILTER_XT_TARGET_CHECKSUM=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=m
CONFIG_NETFILTER_XT_TARGET_CT=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_HMARK=m
CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_LOG=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_NAT=m
CONFIG_NETFILTER_XT_TARGET_NETMAP=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_REDIRECT=m
CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
CONFIG_NETFILTER_XT_TARGET_TEE=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_SECMARK=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
# Xtables matches
CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=m
CONFIG_NETFILTER_XT_MATCH_BPF=m
CONFIG_NETFILTER_XT_MATCH_CGROUP=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLABEL=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_CPU=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DEVGROUP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ECN=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPCOMP=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_IPVS=m
CONFIG_NETFILTER_XT_MATCH_L2TP=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_NFACCT=m
CONFIG_NETFILTER_XT_MATCH_OSF=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_SOCKET=m
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
# end of Core Netfilter Configuration
CONFIG_IP_SET=m
CONFIG_IP_SET_MAX=256
CONFIG_IP_SET_BITMAP_IP=m
CONFIG_IP_SET_BITMAP_IPMAC=m
CONFIG_IP_SET_BITMAP_PORT=m
CONFIG_IP_SET_HASH_IP=m
CONFIG_IP_SET_HASH_IPMARK=m
CONFIG_IP_SET_HASH_IPPORT=m
CONFIG_IP_SET_HASH_IPPORTIP=m
CONFIG_IP_SET_HASH_IPPORTNET=m
CONFIG_IP_SET_HASH_IPMAC=m
CONFIG_IP_SET_HASH_MAC=m
CONFIG_IP_SET_HASH_NETPORTNET=m
CONFIG_IP_SET_HASH_NET=m
CONFIG_IP_SET_HASH_NETNET=m
CONFIG_IP_SET_HASH_NETPORT=m
CONFIG_IP_SET_HASH_NETIFACE=m
CONFIG_IP_SET_LIST_SET=m
CONFIG_IP_VS=m
CONFIG_IP_VS_IPV6=y
# CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
# IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
CONFIG_IP_VS_PROTO_SCTP=y
# IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_FO=m
CONFIG_IP_VS_OVF=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_MH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
# CONFIG_IP_VS_TWOS is not set
# IPVS SH scheduler
CONFIG_IP_VS_SH_TAB_BITS=8
# IPVS MH scheduler
CONFIG_IP_VS_MH_TAB_INDEX=12
# IPVS application helper
CONFIG_IP_VS_FTP=m
CONFIG_IP_VS_NFCT=y
CONFIG_IP_VS_PE_SIP=m
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_SOCKET_IPV4=m
CONFIG_NF_TPROXY_IPV4=m
CONFIG_NF_TABLES_IPV4=y
CONFIG_NFT_REJECT_IPV4=m
CONFIG_NFT_DUP_IPV4=m
CONFIG_NFT_FIB_IPV4=m
CONFIG_NF_TABLES_ARP=y
CONFIG_NF_FLOW_TABLE_IPV4=m
CONFIG_NF_DUP_IPV4=m
CONFIG_NF_LOG_ARP=m
CONFIG_NF_LOG_IPV4=m
CONFIG_NF_REJECT_IPV4=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_RPFILTER=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_SYNPROXY=m
CONFIG_IP_NF_NAT=m
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_CLUSTERIP=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_SECURITY=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# end of IP: Netfilter Configuration
# IPv6: Netfilter Configuration
CONFIG_NF_SOCKET_IPV6=m
CONFIG_NF_TPROXY_IPV6=m
CONFIG_NF_TABLES_IPV6=y
CONFIG_NFT_REJECT_IPV6=m
CONFIG_NFT_DUP_IPV6=m
CONFIG_NFT_FIB_IPV6=m
CONFIG_NF_FLOW_TABLE_IPV6=m
CONFIG_NF_DUP_IPV6=m
CONFIG_NF_REJECT_IPV6=m
CONFIG_NF_LOG_IPV6=m
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RPFILTER=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_MATCH_SRH=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
# CONFIG_IP6_NF_TARGET_SYNPROXY is not set
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_RAW=m
# CONFIG_IP6_NF_SECURITY is not set
CONFIG_IP6_NF_NAT=m
CONFIG_IP6_NF_TARGET_MASQUERADE=m
CONFIG_IP6_NF_TARGET_NPT=m
# end of IPv6: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV6=m
CONFIG_NF_TABLES_BRIDGE=m
# CONFIG_NFT_BRIDGE_META is not set
CONFIG_NFT_BRIDGE_REJECT=m
CONFIG_NF_CONNTRACK_BRIDGE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_IP6=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
CONFIG_BPFILTER=y
CONFIG_IP_DCCP=m
CONFIG_INET_DCCP_DIAG=m
# DCCP CCIDs Configuration
# CONFIG_IP_DCCP_CCID2_DEBUG is not set
CONFIG_IP_DCCP_CCID3=y
# CONFIG_IP_DCCP_CCID3_DEBUG is not set
CONFIG_IP_DCCP_TFRC_LIB=y
# end of DCCP CCIDs Configuration
# DCCP Kernel Hacking
# CONFIG_IP_DCCP_DEBUG is not set
# end of DCCP Kernel Hacking
CONFIG_IP_SCTP=m
# CONFIG_SCTP_DBG_OBJCNT is not set
CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
# CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
CONFIG_SCTP_COOKIE_HMAC_MD5=y
CONFIG_SCTP_COOKIE_HMAC_SHA1=y
CONFIG_INET_SCTP_DIAG=m
CONFIG_RDS=m
# CONFIG_RDS_TCP is not set
# CONFIG_RDS_DEBUG is not set
CONFIG_TIPC=m
CONFIG_TIPC_MEDIA_UDP=y
CONFIG_TIPC_CRYPTO=y
CONFIG_TIPC_DIAG=m
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
# CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE=m
CONFIG_ATM_MPOA=m
CONFIG_ATM_BR2684=m
# CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_L2TP=m
# CONFIG_L2TP_DEBUGFS is not set
CONFIG_L2TP_V3=y
CONFIG_L2TP_IP=m
CONFIG_L2TP_ETH=m
CONFIG_STP=m
CONFIG_GARP=m
CONFIG_MRP=m
CONFIG_BRIDGE=m
CONFIG_BRIDGE_IGMP_SNOOPING=y
CONFIG_BRIDGE_VLAN_FILTERING=y
# CONFIG_BRIDGE_MRP is not set
# CONFIG_BRIDGE_CFM is not set
CONFIG_NET_DSA=m
# CONFIG_NET_DSA_TAG_AR9331 is not set
CONFIG_NET_DSA_TAG_BRCM_COMMON=m
CONFIG_NET_DSA_TAG_BRCM=m
CONFIG_NET_DSA_TAG_BRCM_LEGACY=m
CONFIG_NET_DSA_TAG_BRCM_PREPEND=m
# CONFIG_NET_DSA_TAG_HELLCREEK is not set
# CONFIG_NET_DSA_TAG_GSWIP is not set
CONFIG_NET_DSA_TAG_DSA_COMMON=m
CONFIG_NET_DSA_TAG_DSA=m
CONFIG_NET_DSA_TAG_EDSA=m
# CONFIG_NET_DSA_TAG_MTK is not set
# CONFIG_NET_DSA_TAG_KSZ is not set
# CONFIG_NET_DSA_TAG_RTL4_A is not set
# CONFIG_NET_DSA_TAG_OCELOT is not set
# CONFIG_NET_DSA_TAG_OCELOT_8021Q is not set
# CONFIG_NET_DSA_TAG_QCA is not set
# CONFIG_NET_DSA_TAG_LAN9303 is not set
# CONFIG_NET_DSA_TAG_SJA1105 is not set
CONFIG_NET_DSA_TAG_TRAILER=m
# CONFIG_NET_DSA_TAG_XRS700X is not set
CONFIG_VLAN_8021Q=m
CONFIG_VLAN_8021Q_GVRP=y
CONFIG_VLAN_8021Q_MVRP=y
# CONFIG_DECNET is not set
CONFIG_LLC=m
CONFIG_LLC2=m
CONFIG_ATALK=m
CONFIG_DEV_APPLETALK=m
CONFIG_IPDDP=m
CONFIG_IPDDP_ENCAP=y
CONFIG_X25=m
CONFIG_LAPB=m
CONFIG_PHONET=m
CONFIG_6LOWPAN=m
# CONFIG_6LOWPAN_DEBUGFS is not set
CONFIG_6LOWPAN_NHC=m
CONFIG_6LOWPAN_NHC_DEST=m
CONFIG_6LOWPAN_NHC_FRAGMENT=m
CONFIG_6LOWPAN_NHC_HOP=m
CONFIG_6LOWPAN_NHC_IPV6=m
CONFIG_6LOWPAN_NHC_MOBILITY=m
CONFIG_6LOWPAN_NHC_ROUTING=m
CONFIG_6LOWPAN_NHC_UDP=m
CONFIG_6LOWPAN_GHC_EXT_HDR_HOP=m
CONFIG_6LOWPAN_GHC_UDP=m
CONFIG_6LOWPAN_GHC_ICMPV6=m
CONFIG_6LOWPAN_GHC_EXT_HDR_DEST=m
CONFIG_6LOWPAN_GHC_EXT_HDR_FRAG=m
CONFIG_6LOWPAN_GHC_EXT_HDR_ROUTE=m
CONFIG_IEEE802154=m
# CONFIG_IEEE802154_NL802154_EXPERIMENTAL is not set
CONFIG_IEEE802154_SOCKET=m
CONFIG_IEEE802154_6LOWPAN=m
CONFIG_MAC802154=m
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
CONFIG_NET_SCH_MULTIQ=m
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFB=m
CONFIG_NET_SCH_SFQ=m
CONFIG_NET_SCH_TEQL=m
CONFIG_NET_SCH_TBF=m
CONFIG_NET_SCH_CBS=m
CONFIG_NET_SCH_ETF=m
# CONFIG_NET_SCH_TAPRIO is not set
CONFIG_NET_SCH_GRED=m
CONFIG_NET_SCH_DSMARK=m
CONFIG_NET_SCH_NETEM=m
CONFIG_NET_SCH_DRR=m
CONFIG_NET_SCH_MQPRIO=m
CONFIG_NET_SCH_SKBPRIO=m
CONFIG_NET_SCH_CHOKE=m
CONFIG_NET_SCH_QFQ=m
CONFIG_NET_SCH_CODEL=m
CONFIG_NET_SCH_FQ_CODEL=m
CONFIG_NET_SCH_CAKE=m
# CONFIG_NET_SCH_FQ is not set
CONFIG_NET_SCH_HHF=m
CONFIG_NET_SCH_PIE=m
# CONFIG_NET_SCH_FQ_PIE is not set
CONFIG_NET_SCH_INGRESS=m
CONFIG_NET_SCH_PLUG=m
# CONFIG_NET_SCH_ETS is not set
# CONFIG_NET_SCH_DEFAULT is not set
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_FW=m
CONFIG_NET_CLS_U32=m
CONFIG_CLS_U32_PERF=y
CONFIG_CLS_U32_MARK=y
CONFIG_NET_CLS_RSVP=m
CONFIG_NET_CLS_RSVP6=m
CONFIG_NET_CLS_FLOW=m
CONFIG_NET_CLS_CGROUP=m
CONFIG_NET_CLS_BPF=m
CONFIG_NET_CLS_FLOWER=m
CONFIG_NET_CLS_MATCHALL=m
CONFIG_NET_EMATCH=y
CONFIG_NET_EMATCH_STACK=32
CONFIG_NET_EMATCH_CMP=m
CONFIG_NET_EMATCH_NBYTE=m
CONFIG_NET_EMATCH_U32=m
CONFIG_NET_EMATCH_META=m
CONFIG_NET_EMATCH_TEXT=m
CONFIG_NET_EMATCH_IPSET=m
CONFIG_NET_EMATCH_IPT=m
CONFIG_NET_CLS_ACT=y
CONFIG_NET_ACT_POLICE=m
CONFIG_NET_ACT_GACT=m
CONFIG_GACT_PROB=y
CONFIG_NET_ACT_MIRRED=m
# CONFIG_NET_ACT_SAMPLE is not set
CONFIG_NET_ACT_IPT=m
CONFIG_NET_ACT_NAT=m
CONFIG_NET_ACT_PEDIT=m
CONFIG_NET_ACT_SIMP=m
CONFIG_NET_ACT_SKBEDIT=m
CONFIG_NET_ACT_CSUM=m
# CONFIG_NET_ACT_MPLS is not set
CONFIG_NET_ACT_VLAN=m
CONFIG_NET_ACT_BPF=m
CONFIG_NET_ACT_CONNMARK=m
# CONFIG_NET_ACT_CTINFO is not set
CONFIG_NET_ACT_SKBMOD=m
CONFIG_NET_ACT_IFE=m
CONFIG_NET_ACT_TUNNEL_KEY=m
# CONFIG_NET_ACT_CT is not set
# CONFIG_NET_ACT_GATE is not set
CONFIG_NET_IFE_SKBMARK=m
CONFIG_NET_IFE_SKBPRIO=m
CONFIG_NET_IFE_SKBTCINDEX=m
# CONFIG_NET_TC_SKB_EXT is not set
CONFIG_NET_SCH_FIFO=y
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
CONFIG_OPENVSWITCH=m
CONFIG_OPENVSWITCH_GRE=m
CONFIG_OPENVSWITCH_VXLAN=m
CONFIG_VSOCKETS=m
CONFIG_VSOCKETS_DIAG=m
CONFIG_VSOCKETS_LOOPBACK=m
CONFIG_VIRTIO_VSOCKETS=m
CONFIG_VIRTIO_VSOCKETS_COMMON=m
CONFIG_NETLINK_DIAG=m
CONFIG_MPLS=y
CONFIG_NET_MPLS_GSO=m
CONFIG_MPLS_ROUTING=m
CONFIG_MPLS_IPTUNNEL=m
CONFIG_NET_NSH=m
# CONFIG_HSR is not set
CONFIG_NET_SWITCHDEV=y
CONFIG_NET_L3_MASTER_DEV=y
# CONFIG_QRTR is not set
CONFIG_NET_NCSI=y
# CONFIG_NCSI_OEM_CMD_GET_MAC is not set
# CONFIG_NCSI_OEM_CMD_KEEP_PHY is not set
CONFIG_PCPU_DEV_REFCNT=y
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_SOCK_RX_QUEUE_MAPPING=y
CONFIG_XPS=y
CONFIG_HWBM=y
# CONFIG_CGROUP_NET_PRIO is not set
CONFIG_CGROUP_NET_CLASSID=y
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_STREAM_PARSER is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
CONFIG_NET_PKTGEN=m
# CONFIG_NET_DROP_MONITOR is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
CONFIG_BT=m
CONFIG_BT_BREDR=y
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m
CONFIG_BT_HS=y
CONFIG_BT_LE=y
CONFIG_BT_6LOWPAN=m
CONFIG_BT_LEDS=y
# CONFIG_BT_MSFTEXT is not set
# CONFIG_BT_AOSPEXT is not set
# CONFIG_BT_DEBUGFS is not set
# CONFIG_BT_SELFTEST is not set
# CONFIG_BT_FEATURE_DEBUG is not set
# Bluetooth device drivers
CONFIG_BT_INTEL=m
CONFIG_BT_BCM=m
CONFIG_BT_RTL=m
CONFIG_BT_QCA=m
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIBTUSB_AUTOSUSPEND=y
CONFIG_BT_HCIBTUSB_BCM=y
# CONFIG_BT_HCIBTUSB_MTK is not set
CONFIG_BT_HCIBTUSB_RTL=y
CONFIG_BT_HCIBTSDIO=m
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_ATH3K=y
# CONFIG_BT_HCIUART_INTEL is not set
CONFIG_BT_HCIUART_AG6XX=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIVHCI=m
# CONFIG_BT_MRVL is not set
CONFIG_BT_ATH3K=m
# CONFIG_BT_MTKSDIO is not set
CONFIG_BT_QCOMSMD=m
CONFIG_BT_HCIRSI=m
CONFIG_BT_VIRTIO=m
# end of Bluetooth device drivers
CONFIG_AF_RXRPC=m
# CONFIG_AF_RXRPC_IPV6 is not set
# CONFIG_AF_RXRPC_INJECT_LOSS is not set
# CONFIG_AF_RXRPC_DEBUG is not set
# CONFIG_RXKAD is not set
# CONFIG_AF_KCM is not set
CONFIG_STREAM_PARSER=y
# CONFIG_MCTP is not set
CONFIG_FIB_RULES=y
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_SPY=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=m
CONFIG_NL80211_TESTMODE=y
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
# CONFIG_CFG80211_CERTIFICATION_ONUS is not set
CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
CONFIG_LIB80211=m
CONFIG_LIB80211_CRYPT_WEP=m
CONFIG_LIB80211_CRYPT_CCMP=m
CONFIG_LIB80211_CRYPT_TKIP=m
# CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
CONFIG_MAC80211_MESH=y
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
CONFIG_RFKILL=m
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
# CONFIG_RFKILL_GPIO is not set
CONFIG_NET_9P=m
CONFIG_NET_9P_VIRTIO=m
# CONFIG_NET_9P_DEBUG is not set
# CONFIG_CAIF is not set
CONFIG_CEPH_LIB=m
# CONFIG_CEPH_LIB_PRETTYDEBUG is not set
# CONFIG_CEPH_LIB_USE_DNS_RESOLVER is not set
CONFIG_NFC=m
CONFIG_NFC_DIGITAL=m
CONFIG_NFC_NCI=m
CONFIG_NFC_NCI_SPI=m
CONFIG_NFC_NCI_UART=m
CONFIG_NFC_HCI=m
CONFIG_NFC_SHDLC=y
# Near Field Communication (NFC) devices
CONFIG_NFC_TRF7970A=m
CONFIG_NFC_SIM=m
CONFIG_NFC_PORT100=m
# CONFIG_NFC_VIRTUAL_NCI is not set
CONFIG_NFC_FDP=m
CONFIG_NFC_FDP_I2C=m
CONFIG_NFC_PN544=m
CONFIG_NFC_PN544_I2C=m
CONFIG_NFC_PN533=m
CONFIG_NFC_PN533_USB=m
CONFIG_NFC_PN533_I2C=m
CONFIG_NFC_MICROREAD=m
CONFIG_NFC_MICROREAD_I2C=m
CONFIG_NFC_MRVL=m
CONFIG_NFC_MRVL_USB=m
CONFIG_NFC_MRVL_UART=m
CONFIG_NFC_MRVL_I2C=m
CONFIG_NFC_MRVL_SPI=m
CONFIG_NFC_ST21NFCA=m
CONFIG_NFC_ST21NFCA_I2C=m
CONFIG_NFC_ST_NCI=m
CONFIG_NFC_ST_NCI_I2C=m
CONFIG_NFC_ST_NCI_SPI=m
CONFIG_NFC_NXP_NCI=m
CONFIG_NFC_NXP_NCI_I2C=m
CONFIG_NFC_S3FWRN5=m
CONFIG_NFC_S3FWRN5_I2C=m
CONFIG_NFC_ST95HF=m
# end of Near Field Communication (NFC) devices
CONFIG_PSAMPLE=m
CONFIG_NET_IFE=m
CONFIG_LWTUNNEL=y
CONFIG_LWTUNNEL_BPF=y
CONFIG_DST_CACHE=y
CONFIG_GRO_CELLS=y
CONFIG_NET_SELFTESTS=y
CONFIG_NET_SOCK_MSG=y
CONFIG_NET_DEVLINK=y
CONFIG_PAGE_POOL=y
CONFIG_FAILOVER=m
CONFIG_ETHTOOL_NETLINK=y
# Device Drivers
CONFIG_ARM_AMBA=y
CONFIG_TEGRA_AHB=y
CONFIG_HAVE_PCI=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCI_DOMAINS_GENERIC=y
CONFIG_PCI_SYSCALL=y
# CONFIG_PCIEPORTBUS is not set
CONFIG_PCIEASPM=y
CONFIG_PCIEASPM_DEFAULT=y
# CONFIG_PCIEASPM_POWERSAVE is not set
# CONFIG_PCIEASPM_POWER_SUPERSAVE is not set
# CONFIG_PCIEASPM_PERFORMANCE is not set
# CONFIG_PCIE_PTM is not set
CONFIG_PCI_MSI=y
CONFIG_PCI_MSI_IRQ_DOMAIN=y
CONFIG_PCI_QUIRKS=y
# CONFIG_PCI_DEBUG is not set
# CONFIG_PCI_STUB is not set
CONFIG_PCI_BRIDGE_EMUL=y
# CONFIG_PCI_IOV is not set
# CONFIG_PCI_PRI is not set
# CONFIG_PCI_PASID is not set
CONFIG_PCI_LABEL=y
# CONFIG_PCIE_BUS_TUNE_OFF is not set
CONFIG_PCIE_BUS_DEFAULT=y
# CONFIG_PCIE_BUS_SAFE is not set
# CONFIG_PCIE_BUS_PERFORMANCE is not set
# CONFIG_PCIE_BUS_PEER2PEER is not set
# CONFIG_HOTPLUG_PCI is not set
# PCI controller drivers
CONFIG_PCI_MVEBU=y
# CONFIG_PCI_FTPCI100 is not set
# CONFIG_PCI_TEGRA is not set
# CONFIG_PCI_HOST_GENERIC is not set
# CONFIG_PCIE_XILINX is not set
# CONFIG_PCI_V3_SEMI is not set
# CONFIG_PCIE_ALTERA is not set
# CONFIG_PCIE_BRCMSTB is not set
# CONFIG_PCIE_MICROCHIP_HOST is not set
# DesignWare PCI Core Support
# CONFIG_PCIE_DW_PLAT_HOST is not set
# CONFIG_PCI_EXYNOS is not set
# CONFIG_PCI_IMX6 is not set
# CONFIG_PCI_LAYERSCAPE is not set
# CONFIG_PCIE_QCOM is not set
# CONFIG_PCIE_ARMADA_8K is not set
# CONFIG_PCI_MESON is not set
# end of DesignWare PCI Core Support
# Mobiveil PCIe Core Support
# end of Mobiveil PCIe Core Support
# Cadence PCIe controllers support
# CONFIG_PCIE_CADENCE_PLAT_HOST is not set
# CONFIG_PCI_J721E_HOST is not set
# end of Cadence PCIe controllers support
# end of PCI controller drivers
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# end of PCI Endpoint
# PCI switch controller drivers
# CONFIG_PCI_SW_SWITCHTEC is not set
# end of PCI switch controller drivers
# CONFIG_CXL_BUS is not set
# CONFIG_PCCARD is not set
# CONFIG_RAPIDIO is not set
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
# CONFIG_PREVENT_FIRMWARE_BUILD is not set
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
CONFIG_FW_CACHE=y
# end of Firmware loader
CONFIG_WANT_DEV_COREDUMP=y
# CONFIG_ALLOW_DEV_COREDUMP is not set
# CONFIG_DEBUG_DRIVER is not set
CONFIG_DEBUG_DEVRES=y
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_GENERIC_CPU_VULNERABILITIES=y
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=m
CONFIG_REGMAP_SPI=m
CONFIG_REGMAP_SPMI=m
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# end of Generic Driver Options
# Bus devices
CONFIG_ARM_CCI=y
CONFIG_ARM_CCI400_COMMON=y
CONFIG_ARM_CCI400_PORT_CTRL=y
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_MOXTET is not set
# CONFIG_IMX_WEIM is not set
CONFIG_MVEBU_MBUS=y
# CONFIG_OMAP_INTERCONNECT is not set
# CONFIG_OMAP_OCP2SCP is not set
# CONFIG_QCOM_EBI2 is not set
# CONFIG_SUN50I_DE2_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_TEGRA_GMI is not set
CONFIG_TI_SYSC=y
CONFIG_VEXPRESS_CONFIG=y
# CONFIG_FSL_MC_BUS is not set
# CONFIG_MHI_BUS is not set
# end of Bus devices
CONFIG_CONNECTOR=y
CONFIG_PROC_EVENTS=y
# Firmware Drivers
# ARM System Control and Management Interface Protocol
# CONFIG_ARM_SCMI_PROTOCOL is not set
# end of ARM System Control and Management Interface Protocol
CONFIG_FIRMWARE_MEMMAP=y
CONFIG_DMIID=y
# CONFIG_DMI_SYSFS is not set
CONFIG_QCOM_SCM=y
# CONFIG_QCOM_SCM_DOWNLOAD_MODE_DEFAULT is not set
CONFIG_SYSFB=y
CONFIG_SYSFB_SIMPLEFB=y
# CONFIG_TRUSTED_FOUNDATIONS is not set
# CONFIG_GOOGLE_FIRMWARE is not set
# EFI (Extensible Firmware Interface) Support
CONFIG_EFI_ESRT=y
CONFIG_EFI_VARS_PSTORE=m
CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE=y
CONFIG_EFI_PARAMS_FROM_FDT=y
CONFIG_EFI_RUNTIME_WRAPPERS=y
CONFIG_EFI_GENERIC_STUB=y
CONFIG_EFI_ARMSTUB_DTB_LOADER=y
CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER=y
# CONFIG_EFI_BOOTLOADER_CONTROL is not set
# CONFIG_EFI_CAPSULE_LOADER is not set
# CONFIG_EFI_TEST is not set
# CONFIG_RESET_ATTACK_MITIGATION is not set
# CONFIG_EFI_DISABLE_PCI_DMA is not set
# end of EFI (Extensible Firmware Interface) Support
CONFIG_ARM_PSCI_FW=y
# CONFIG_ARM_PSCI_CHECKER is not set
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y
CONFIG_ARM_SMCCC_SOC_ID=y
# Tegra firmware driver
# CONFIG_TEGRA_IVC is not set
# end of Tegra firmware driver
# end of Firmware Drivers
# CONFIG_GNSS is not set
CONFIG_MTD=y
CONFIG_MTD_TESTS=m
# Partition parsers
CONFIG_MTD_AR7_PARTS=m
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
CONFIG_MTD_REDBOOT_PARTS=m
CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
# CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
# CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
# end of Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
# Note that in some cases UBI block is preferred. See MTD_UBI_BLOCK.
CONFIG_FTL=m
CONFIG_NFTL=m
CONFIG_NFTL_RW=y
CONFIG_INFTL=m
CONFIG_RFD_FTL=m
CONFIG_SSFDC=m
CONFIG_SM_FTL=m
CONFIG_MTD_OOPS=m
CONFIG_MTD_SWAP=m
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
CONFIG_MTD_JEDECPROBE=m
CONFIG_MTD_GEN_PROBE=m
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_CFI_INTELEXT=m
CONFIG_MTD_CFI_AMDSTD=m
CONFIG_MTD_CFI_STAA=m
CONFIG_MTD_CFI_UTIL=m
CONFIG_MTD_RAM=m
CONFIG_MTD_ROM=m
CONFIG_MTD_ABSENT=m
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=m
# CONFIG_MTD_PHYSMAP_COMPAT is not set
# CONFIG_MTD_PHYSMAP_OF is not set
# CONFIG_MTD_PHYSMAP_GPIO_ADDR is not set
# CONFIG_MTD_IMPA7 is not set
# CONFIG_MTD_PCI is not set
# CONFIG_MTD_INTEL_VR_NOR is not set
CONFIG_MTD_PLATRAM=m
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
CONFIG_MTD_DATAFLASH=m
# CONFIG_MTD_DATAFLASH_WRITE_VERIFY is not set
# CONFIG_MTD_DATAFLASH_OTP is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_MCHP48L640 is not set
# CONFIG_MTD_SST25L is not set
CONFIG_MTD_SLRAM=m
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLOCK2MTD=m
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# NAND
CONFIG_MTD_NAND_CORE=y
CONFIG_MTD_ONENAND=m
# CONFIG_MTD_ONENAND_VERIFY_WRITE is not set
# CONFIG_MTD_ONENAND_GENERIC is not set
# CONFIG_MTD_ONENAND_SAMSUNG is not set
CONFIG_MTD_ONENAND_OTP=y
CONFIG_MTD_ONENAND_2X_PROGRAM=y
CONFIG_MTD_RAW_NAND=y
# Raw/parallel NAND flash controllers
# CONFIG_MTD_NAND_DENALI_PCI is not set
# CONFIG_MTD_NAND_DENALI_DT is not set
# CONFIG_MTD_NAND_OMAP2 is not set
# CONFIG_MTD_NAND_CAFE is not set
# CONFIG_MTD_NAND_ORION is not set
CONFIG_MTD_NAND_MARVELL=y
# CONFIG_MTD_NAND_BRCMNAND is not set
# CONFIG_MTD_NAND_MXC is not set
# CONFIG_MTD_NAND_SUNXI is not set
# CONFIG_MTD_NAND_QCOM is not set
# CONFIG_MTD_NAND_MXIC is not set
# CONFIG_MTD_NAND_TEGRA is not set
# CONFIG_MTD_NAND_GPIO is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_NAND_CADENCE is not set
# CONFIG_MTD_NAND_ARASAN is not set
# CONFIG_MTD_NAND_INTEL_LGM is not set
# CONFIG_MTD_NAND_PL35X is not set
# Misc
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_RICOH is not set
# CONFIG_MTD_NAND_DISKONCHIP is not set
CONFIG_MTD_SPI_NAND=m
# ECC engine support
CONFIG_MTD_NAND_ECC=y
CONFIG_MTD_NAND_ECC_SW_HAMMING=y
# CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
# CONFIG_MTD_NAND_ECC_SW_BCH is not set
# end of ECC engine support
# end of NAND
# LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_LPDDR=m
CONFIG_MTD_QINFO_PROBE=m
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
CONFIG_MTD_SPI_NOR=y
# CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set
# CONFIG_MTD_SPI_NOR_SWP_DISABLE is not set
CONFIG_MTD_SPI_NOR_SWP_DISABLE_ON_VOLATILE=y
# CONFIG_MTD_SPI_NOR_SWP_KEEP is not set
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_LIMIT=20
# CONFIG_MTD_UBI_FASTMAP is not set
# CONFIG_MTD_UBI_GLUEBI is not set
# CONFIG_MTD_UBI_BLOCK is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_DYNAMIC=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_RESERVED_MEM=y
CONFIG_OF_RESOLVE=y
CONFIG_OF_OVERLAY=y
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
CONFIG_CDROM=m
# CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
CONFIG_ZRAM=m
# CONFIG_ZRAM_DEF_COMP_LZORLE is not set
# CONFIG_ZRAM_DEF_COMP_ZSTD is not set
CONFIG_ZRAM_DEF_COMP_LZ4=y
# CONFIG_ZRAM_DEF_COMP_LZO is not set
# CONFIG_ZRAM_DEF_COMP_LZ4HC is not set
CONFIG_ZRAM_DEF_COMP="lz4"
# CONFIG_ZRAM_WRITEBACK is not set
# CONFIG_ZRAM_MEMORY_TRACKING is not set
CONFIG_BLK_DEV_LOOP=m
CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_DRBD=m
# CONFIG_DRBD_FAULT_INJECTION is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_SX8 is not set
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_CDROM_PKTCDVD=m
CONFIG_CDROM_PKTCDVD_BUFFERS=8
# CONFIG_CDROM_PKTCDVD_WCACHE is not set
CONFIG_ATA_OVER_ETH=m
CONFIG_VIRTIO_BLK=m
CONFIG_BLK_DEV_RBD=m
# CONFIG_BLK_DEV_RSXX is not set
# NVME Support
CONFIG_NVME_CORE=m
# CONFIG_BLK_DEV_NVME is not set
CONFIG_NVME_MULTIPATH=y
CONFIG_NVME_HWMON=y
CONFIG_NVME_FABRICS=m
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TCP is not set
CONFIG_NVME_TARGET=m
# CONFIG_NVME_TARGET_PASSTHRU is not set
CONFIG_NVME_TARGET_LOOP=m
# CONFIG_NVME_TARGET_FC is not set
# CONFIG_NVME_TARGET_TCP is not set
# end of NVME Support
# Misc devices
CONFIG_SENSORS_LIS3LV02D=m
CONFIG_AD525X_DPOT=m
CONFIG_AD525X_DPOT_I2C=m
CONFIG_AD525X_DPOT_SPI=m
# CONFIG_DUMMY_IRQ is not set
# CONFIG_PHANTOM is not set
# CONFIG_TIFM_CORE is not set
CONFIG_ICS932S401=m
CONFIG_ENCLOSURE_SERVICES=m
# CONFIG_GEHC_ACHC is not set
# CONFIG_HI6421V600_IRQ is not set
# CONFIG_HP_ILO is not set
# CONFIG_QCOM_COINCELL is not set
# CONFIG_QCOM_FASTRPC is not set
CONFIG_APDS9802ALS=m
CONFIG_ISL29003=m
CONFIG_ISL29020=m
CONFIG_SENSORS_TSL2550=m
CONFIG_SENSORS_BH1770=m
CONFIG_SENSORS_APDS990X=m
CONFIG_HMC6352=m
CONFIG_DS1682=m
# CONFIG_LATTICE_ECP3_CONFIG is not set
CONFIG_SRAM=y
CONFIG_SRAM_EXEC=y
# CONFIG_DW_XDATA_PCIE is not set
# CONFIG_PCI_ENDPOINT_TEST is not set
# CONFIG_XILINX_SDFEC is not set
CONFIG_MISC_RTSX=m
# CONFIG_HISI_HIKEY_USB is not set
CONFIG_C2PORT=m
# EEPROM support
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_EEPROM_LEGACY=m
CONFIG_EEPROM_MAX6875=m
CONFIG_EEPROM_93CX6=m
CONFIG_EEPROM_93XX46=m
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# CONFIG_CB710_CORE is not set
# Texas Instruments shared transport line discipline
CONFIG_TI_ST=m
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
CONFIG_SENSORS_LIS3_I2C=m
CONFIG_ALTERA_STAPL=m
# CONFIG_ECHO is not set
# CONFIG_BCM_VK is not set
# CONFIG_MISC_ALCOR_PCI is not set
# CONFIG_MISC_RTSX_PCI is not set
CONFIG_MISC_RTSX_USB=m
# CONFIG_HABANA_AI is not set
# CONFIG_UACCE is not set
CONFIG_PVPANIC=y
CONFIG_PVPANIC_MMIO=m
# CONFIG_PVPANIC_PCI is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=m
CONFIG_RAID_ATTRS=m
CONFIG_SCSI_COMMON=y
CONFIG_SCSI=m
CONFIG_SCSI_DMA=y
CONFIG_SCSI_NETLINK=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
CONFIG_CHR_DEV_ST=m
CONFIG_BLK_DEV_SR=m
CONFIG_CHR_DEV_SG=m
CONFIG_BLK_DEV_BSG=y
CONFIG_CHR_DEV_SCH=m
CONFIG_SCSI_ENCLOSURE=m
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
CONFIG_SCSI_SCAN_ASYNC=y
# SCSI Transports
CONFIG_SCSI_SPI_ATTRS=m
CONFIG_SCSI_FC_ATTRS=m
CONFIG_SCSI_ISCSI_ATTRS=m
CONFIG_SCSI_SAS_ATTRS=m
CONFIG_SCSI_SAS_LIBSAS=m
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_SAS_HOST_SMP=y
CONFIG_SCSI_SRP_ATTRS=m
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_ISCSI_BOOT_SYSFS=m
# CONFIG_SCSI_CXGB3_ISCSI is not set
# CONFIG_SCSI_CXGB4_ISCSI is not set
# CONFIG_SCSI_BNX2_ISCSI is not set
# CONFIG_SCSI_BNX2X_FCOE is not set
# CONFIG_BE2ISCSI is not set
# CONFIG_BLK_DEV_3W_XXXX_RAID is not set
# CONFIG_SCSI_HPSA is not set
# CONFIG_SCSI_3W_9XXX is not set
# CONFIG_SCSI_3W_SAS is not set
# CONFIG_SCSI_ACARD is not set
# CONFIG_SCSI_AACRAID is not set
# CONFIG_SCSI_AIC7XXX is not set
# CONFIG_SCSI_AIC79XX is not set
# CONFIG_SCSI_AIC94XX is not set
# CONFIG_SCSI_MVSAS is not set
# CONFIG_SCSI_MVUMI is not set
# CONFIG_SCSI_ADVANSYS is not set
# CONFIG_SCSI_ARCMSR is not set
# CONFIG_SCSI_ESAS2R is not set
# CONFIG_MEGARAID_NEWGEN is not set
# CONFIG_MEGARAID_LEGACY is not set
# CONFIG_MEGARAID_SAS is not set
# CONFIG_SCSI_MPT3SAS is not set
# CONFIG_SCSI_MPT2SAS is not set
# CONFIG_SCSI_MPI3MR is not set
# CONFIG_SCSI_SMARTPQI is not set
CONFIG_SCSI_UFSHCD=m
# CONFIG_SCSI_UFSHCD_PCI is not set
# CONFIG_SCSI_UFSHCD_PLATFORM is not set
# CONFIG_SCSI_UFS_BSG is not set
# CONFIG_SCSI_UFS_HPB is not set
# CONFIG_SCSI_HPTIOP is not set
# CONFIG_SCSI_MYRB is not set
# CONFIG_SCSI_MYRS is not set
CONFIG_LIBFC=m
CONFIG_LIBFCOE=m
# CONFIG_FCOE is not set
# CONFIG_SCSI_SNIC is not set
# CONFIG_SCSI_DMX3191D is not set
# CONFIG_SCSI_FDOMAIN_PCI is not set
# CONFIG_SCSI_IPS is not set
# CONFIG_SCSI_INITIO is not set
# CONFIG_SCSI_INIA100 is not set
# CONFIG_SCSI_STEX is not set
# CONFIG_SCSI_SYM53C8XX_2 is not set
# CONFIG_SCSI_IPR is not set
# CONFIG_SCSI_QLOGIC_1280 is not set
# CONFIG_SCSI_QLA_FC is not set
# CONFIG_SCSI_QLA_ISCSI is not set
# CONFIG_SCSI_LPFC is not set
# CONFIG_SCSI_EFCT is not set
# CONFIG_SCSI_DC395x is not set
# CONFIG_SCSI_AM53C974 is not set
# CONFIG_SCSI_NSP32 is not set
# CONFIG_SCSI_WD719X is not set
CONFIG_SCSI_DEBUG=m
# CONFIG_SCSI_PMCRAID is not set
# CONFIG_SCSI_PM8001 is not set
# CONFIG_SCSI_BFA_FC is not set
CONFIG_SCSI_VIRTIO=m
# CONFIG_SCSI_CHELSIO_FCOE is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
CONFIG_HAVE_PATA_PLATFORM=y
CONFIG_ATA=m
CONFIG_SATA_HOST=y
CONFIG_PATA_TIMINGS=y
CONFIG_ATA_VERBOSE_ERROR=y
CONFIG_ATA_FORCE=y
CONFIG_SATA_PMP=y
# Controllers with non-SFF native interface
CONFIG_SATA_AHCI=m
CONFIG_SATA_MOBILE_LPM_POLICY=0
CONFIG_SATA_AHCI_PLATFORM=m
# CONFIG_AHCI_DM816 is not set
CONFIG_AHCI_IMX=m
# CONFIG_AHCI_CEVA is not set
CONFIG_AHCI_MVEBU=m
CONFIG_AHCI_SUNXI=m
# CONFIG_AHCI_TEGRA is not set
# CONFIG_AHCI_QORIQ is not set
# CONFIG_SATA_INIC162X is not set
# CONFIG_SATA_ACARD_AHCI is not set
# CONFIG_SATA_SIL24 is not set
CONFIG_ATA_SFF=y
# SFF controllers with custom DMA interface
# CONFIG_PDC_ADMA is not set
# CONFIG_SATA_QSTOR is not set
# CONFIG_SATA_SX4 is not set
CONFIG_ATA_BMDMA=y
# SATA SFF controllers with BMDMA
# CONFIG_ATA_PIIX is not set
# CONFIG_SATA_DWC is not set
CONFIG_SATA_MV=m
# CONFIG_SATA_NV is not set
# CONFIG_SATA_PROMISE is not set
# CONFIG_SATA_SIL is not set
# CONFIG_SATA_SIS is not set
# CONFIG_SATA_SVW is not set
# CONFIG_SATA_ULI is not set
# CONFIG_SATA_VIA is not set
# CONFIG_SATA_VITESSE is not set
# PATA SFF controllers with BMDMA
# CONFIG_PATA_ALI is not set
# CONFIG_PATA_AMD is not set
# CONFIG_PATA_ARTOP is not set
# CONFIG_PATA_ATIIXP is not set
# CONFIG_PATA_ATP867X is not set
# CONFIG_PATA_CMD64X is not set
# CONFIG_PATA_CYPRESS is not set
# CONFIG_PATA_EFAR is not set
# CONFIG_PATA_HPT366 is not set
# CONFIG_PATA_HPT37X is not set
# CONFIG_PATA_HPT3X2N is not set
# CONFIG_PATA_HPT3X3 is not set
CONFIG_PATA_IMX=m
# CONFIG_PATA_IT8213 is not set
# CONFIG_PATA_IT821X is not set
# CONFIG_PATA_JMICRON is not set
# CONFIG_PATA_MARVELL is not set
# CONFIG_PATA_NETCELL is not set
# CONFIG_PATA_NINJA32 is not set
# CONFIG_PATA_NS87415 is not set
# CONFIG_PATA_OLDPIIX is not set
# CONFIG_PATA_OPTIDMA is not set
# CONFIG_PATA_PDC2027X is not set
# CONFIG_PATA_PDC_OLD is not set
# CONFIG_PATA_RADISYS is not set
# CONFIG_PATA_RDC is not set
# CONFIG_PATA_SCH is not set
# CONFIG_PATA_SERVERWORKS is not set
# CONFIG_PATA_SIL680 is not set
# CONFIG_PATA_SIS is not set
# CONFIG_PATA_TOSHIBA is not set
# CONFIG_PATA_TRIFLEX is not set
# CONFIG_PATA_VIA is not set
# CONFIG_PATA_WINBOND is not set
# PIO-only SFF controllers
# CONFIG_PATA_CMD640_PCI is not set
# CONFIG_PATA_MPIIX is not set
# CONFIG_PATA_NS87410 is not set
# CONFIG_PATA_OPTI is not set
CONFIG_PATA_PLATFORM=m
# CONFIG_PATA_OF_PLATFORM is not set
# CONFIG_PATA_RZ1000 is not set
# Generic fallback / legacy drivers
# CONFIG_ATA_GENERIC is not set
# CONFIG_PATA_LEGACY is not set
CONFIG_MD=y
CONFIG_BLK_DEV_MD=y
# CONFIG_MD_AUTODETECT is not set
CONFIG_MD_LINEAR=m
CONFIG_MD_RAID0=m
CONFIG_MD_RAID1=m
CONFIG_MD_RAID10=m
CONFIG_MD_RAID456=m
CONFIG_MD_MULTIPATH=m
CONFIG_MD_FAULTY=m
# CONFIG_MD_CLUSTER is not set
CONFIG_BCACHE=m
# CONFIG_BCACHE_DEBUG is not set
# CONFIG_BCACHE_CLOSURES_DEBUG is not set
# CONFIG_BCACHE_ASYNC_REGISTRATION is not set
CONFIG_BLK_DEV_DM_BUILTIN=y
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_DEBUG is not set
CONFIG_DM_BUFIO=m
# CONFIG_DM_DEBUG_BLOCK_MANAGER_LOCKING is not set
CONFIG_DM_BIO_PRISON=m
CONFIG_DM_PERSISTENT_DATA=m
CONFIG_DM_UNSTRIPED=m
CONFIG_DM_CRYPT=m
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_THIN_PROVISIONING=m
CONFIG_DM_CACHE=m
CONFIG_DM_CACHE_SMQ=m
CONFIG_DM_WRITECACHE=m
# CONFIG_DM_ERA is not set
# CONFIG_DM_CLONE is not set
CONFIG_DM_MIRROR=m
CONFIG_DM_LOG_USERSPACE=m
CONFIG_DM_RAID=m
CONFIG_DM_ZERO=m
CONFIG_DM_MULTIPATH=m
CONFIG_DM_MULTIPATH_QL=m
CONFIG_DM_MULTIPATH_ST=m
# CONFIG_DM_MULTIPATH_HST is not set
# CONFIG_DM_MULTIPATH_IOA is not set
CONFIG_DM_DELAY=m
# CONFIG_DM_DUST is not set
CONFIG_DM_UEVENT=y
CONFIG_DM_FLAKEY=m
CONFIG_DM_VERITY=m
# CONFIG_DM_VERITY_VERIFY_ROOTHASH_SIG is not set
CONFIG_DM_VERITY_FEC=y
# CONFIG_DM_SWITCH is not set
CONFIG_DM_LOG_WRITES=m
CONFIG_DM_INTEGRITY=m
CONFIG_TARGET_CORE=m
CONFIG_TCM_IBLOCK=m
CONFIG_TCM_FILEIO=m
CONFIG_TCM_PSCSI=m
CONFIG_TCM_USER2=m
CONFIG_LOOPBACK_TARGET=m
CONFIG_TCM_FC=m
CONFIG_ISCSI_TARGET=m
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_FIREWIRE is not set
# CONFIG_FIREWIRE_NOSY is not set
# end of IEEE 1394 (FireWire) support
CONFIG_NETDEVICES=y
CONFIG_MII=m
CONFIG_NET_CORE=y
CONFIG_BONDING=m
CONFIG_DUMMY=m
CONFIG_WIREGUARD=m
# CONFIG_WIREGUARD_DEBUG is not set
CONFIG_EQUALIZER=m
# CONFIG_NET_FC is not set
CONFIG_IFB=m
CONFIG_NET_TEAM=m
CONFIG_NET_TEAM_MODE_BROADCAST=m
CONFIG_NET_TEAM_MODE_ROUNDROBIN=m
# CONFIG_NET_TEAM_MODE_RANDOM is not set
CONFIG_NET_TEAM_MODE_ACTIVEBACKUP=m
CONFIG_NET_TEAM_MODE_LOADBALANCE=m
CONFIG_MACVLAN=m
CONFIG_MACVTAP=m
CONFIG_IPVLAN_L3S=y
CONFIG_IPVLAN=m
# CONFIG_IPVTAP is not set
CONFIG_VXLAN=m
# CONFIG_GENEVE is not set
# CONFIG_BAREUDP is not set
CONFIG_GTP=m
CONFIG_MACSEC=m
CONFIG_NETCONSOLE=m
CONFIG_NETCONSOLE_DYNAMIC=y
CONFIG_NETPOLL=y
CONFIG_NET_POLL_CONTROLLER=y
CONFIG_TUN=m
CONFIG_TAP=m
# CONFIG_TUN_VNET_CROSS_LE is not set
CONFIG_VETH=m
CONFIG_VIRTIO_NET=m
# CONFIG_NLMON is not set
CONFIG_NET_VRF=m
# CONFIG_ARCNET is not set
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_DUMMY=m
CONFIG_ATM_TCP=m
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
# CONFIG_ATM_NICSTAR is not set
# CONFIG_ATM_IDT77252 is not set
# CONFIG_ATM_IA is not set
# CONFIG_ATM_FORE200E is not set
# CONFIG_ATM_HE is not set
# CONFIG_ATM_SOLOS is not set
# Distributed Switch Architecture drivers
CONFIG_B53=m
CONFIG_B53_SPI_DRIVER=m
CONFIG_B53_MDIO_DRIVER=m
CONFIG_B53_MMAP_DRIVER=m
CONFIG_B53_SRAB_DRIVER=m
CONFIG_B53_SERDES=m
# CONFIG_NET_DSA_BCM_SF2 is not set
# CONFIG_NET_DSA_LOOP is not set
# CONFIG_NET_DSA_LANTIQ_GSWIP is not set
# CONFIG_NET_DSA_MT7530 is not set
# CONFIG_NET_DSA_MV88E6060 is not set
# CONFIG_NET_DSA_MICROCHIP_KSZ9477 is not set
# CONFIG_NET_DSA_MICROCHIP_KSZ8795 is not set
CONFIG_NET_DSA_MV88E6XXX=m
# CONFIG_NET_DSA_MV88E6XXX_PTP is not set
# CONFIG_NET_DSA_AR9331 is not set
# CONFIG_NET_DSA_SJA1105 is not set
# CONFIG_NET_DSA_XRS700X_I2C is not set
# CONFIG_NET_DSA_XRS700X_MDIO is not set
# CONFIG_NET_DSA_QCA8K is not set
# CONFIG_NET_DSA_REALTEK_SMI is not set
# CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
# CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
# CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
# CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
# end of Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_3COM=y
# CONFIG_TYPHOON is not set
CONFIG_NET_VENDOR_ADAPTEC=y
# CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_NET_VENDOR_AGERE=y
# CONFIG_ET131X is not set
CONFIG_NET_VENDOR_ALACRITECH=y
# CONFIG_SLICOSS is not set
CONFIG_NET_VENDOR_ALLWINNER=y
CONFIG_SUN4I_EMAC=m
CONFIG_NET_VENDOR_ALTEON=y
# CONFIG_ACENIC is not set
CONFIG_ALTERA_TSE=m
# CONFIG_NET_VENDOR_AMAZON is not set
CONFIG_NET_VENDOR_AMD=y
# CONFIG_AMD8111_ETH is not set
# CONFIG_PCNET32 is not set
CONFIG_NET_VENDOR_AQUANTIA=y
# CONFIG_AQTION is not set
CONFIG_NET_VENDOR_ARC=y
CONFIG_NET_VENDOR_ATHEROS=y
# CONFIG_ATL2 is not set
# CONFIG_ATL1 is not set
# CONFIG_ATL1E is not set
# CONFIG_ATL1C is not set
# CONFIG_ALX is not set
CONFIG_NET_VENDOR_BROADCOM=y
CONFIG_B44=m
CONFIG_B44_PCI_AUTOSELECT=y
CONFIG_B44_PCICORE_AUTOSELECT=y
CONFIG_B44_PCI=y
CONFIG_BCMGENET=m
# CONFIG_BNX2 is not set
# CONFIG_CNIC is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2X is not set
# CONFIG_SYSTEMPORT is not set
# CONFIG_BNXT is not set
CONFIG_NET_VENDOR_CADENCE=y
CONFIG_MACB=m
CONFIG_MACB_USE_HWSTAMP=y
# CONFIG_MACB_PCI is not set
# CONFIG_NET_VENDOR_CAVIUM is not set
CONFIG_NET_VENDOR_CHELSIO=y
# CONFIG_CHELSIO_T1 is not set
# CONFIG_CHELSIO_T3 is not set
# CONFIG_CHELSIO_T4 is not set
# CONFIG_CHELSIO_T4VF is not set
CONFIG_NET_VENDOR_CIRRUS=y
# CONFIG_CS89x0_PLATFORM is not set
CONFIG_NET_VENDOR_CISCO=y
# CONFIG_ENIC is not set
# CONFIG_NET_VENDOR_CORTINA is not set
# CONFIG_DM9000 is not set
CONFIG_DNET=m
CONFIG_NET_VENDOR_DEC=y
# CONFIG_NET_TULIP is not set
CONFIG_NET_VENDOR_DLINK=y
# CONFIG_DL2K is not set
# CONFIG_SUNDANCE is not set
CONFIG_NET_VENDOR_EMULEX=y
# CONFIG_BE2NET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
CONFIG_NET_VENDOR_FARADAY=y
# CONFIG_FTMAC100 is not set
# CONFIG_FTGMAC100 is not set
CONFIG_NET_VENDOR_FREESCALE=y
CONFIG_FEC=m
CONFIG_FSL_PQ_MDIO=m
CONFIG_FSL_XGMAC_MDIO=m
# CONFIG_GIANFAR is not set
# CONFIG_FSL_DPAA2_SWITCH is not set
# CONFIG_FSL_ENETC is not set
# CONFIG_FSL_ENETC_VF is not set
# CONFIG_FSL_ENETC_IERB is not set
# CONFIG_FSL_ENETC_MDIO is not set
CONFIG_NET_VENDOR_GOOGLE=y
# CONFIG_NET_VENDOR_HISILICON is not set
CONFIG_NET_VENDOR_HUAWEI=y
CONFIG_NET_VENDOR_I825XX=y
CONFIG_NET_VENDOR_INTEL=y
# CONFIG_E100 is not set
# CONFIG_E1000 is not set
# CONFIG_E1000E is not set
# CONFIG_IGB is not set
# CONFIG_IGBVF is not set
# CONFIG_IXGB is not set
# CONFIG_IXGBE is not set
# CONFIG_IXGBEVF is not set
# CONFIG_I40E is not set
# CONFIG_I40EVF is not set
# CONFIG_ICE is not set
# CONFIG_FM10K is not set
# CONFIG_IGC is not set
# CONFIG_JME is not set
# CONFIG_NET_VENDOR_LITEX is not set
CONFIG_NET_VENDOR_MARVELL=y
CONFIG_MV643XX_ETH=m
CONFIG_MVMDIO=m
CONFIG_MVNETA_BM_ENABLE=m
CONFIG_MVNETA=m
CONFIG_MVNETA_BM=m
# CONFIG_MVPP2 is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
# CONFIG_PRESTERA is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLX4_EN is not set
# CONFIG_MLX5_CORE is not set
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
CONFIG_NET_VENDOR_MICREL=y
CONFIG_KS8842=m
CONFIG_KS8851=m
CONFIG_KS8851_MLL=m
# CONFIG_KSZ884X_PCI is not set
CONFIG_NET_VENDOR_MICROCHIP=y
CONFIG_ENC28J60=m
# CONFIG_ENC28J60_WRITEVERIFY is not set
CONFIG_ENCX24J600=m
# CONFIG_LAN743X is not set
# CONFIG_NET_VENDOR_MICROSEMI is not set
# CONFIG_NET_VENDOR_MICROSOFT is not set
CONFIG_NET_VENDOR_MYRI=y
# CONFIG_MYRI10GE is not set
# CONFIG_FEALNX is not set
# CONFIG_NET_VENDOR_NI is not set
CONFIG_NET_VENDOR_NATSEMI=y
# CONFIG_NATSEMI is not set
# CONFIG_NS83820 is not set
CONFIG_NET_VENDOR_NETERION=y
# CONFIG_S2IO is not set
# CONFIG_VXGE is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_NFP is not set
CONFIG_NET_VENDOR_8390=y
# CONFIG_AX88796 is not set
# CONFIG_NE2K_PCI is not set
CONFIG_NET_VENDOR_NVIDIA=y
# CONFIG_FORCEDETH is not set
CONFIG_NET_VENDOR_OKI=y
CONFIG_ETHOC=m
CONFIG_NET_VENDOR_PACKET_ENGINES=y
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
CONFIG_NET_VENDOR_PENSANDO=y
CONFIG_NET_VENDOR_QLOGIC=y
# CONFIG_QLA3XXX is not set
# CONFIG_QLCNIC is not set
# CONFIG_NETXEN_NIC is not set
# CONFIG_QED is not set
CONFIG_NET_VENDOR_BROCADE=y
# CONFIG_BNA is not set
# CONFIG_NET_VENDOR_QUALCOMM is not set
CONFIG_NET_VENDOR_RDC=y
# CONFIG_R6040 is not set
CONFIG_NET_VENDOR_REALTEK=y
# CONFIG_8139CP is not set
# CONFIG_8139TOO is not set
# CONFIG_R8169 is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
# CONFIG_ROCKER is not set
# CONFIG_NET_VENDOR_SAMSUNG is not set
CONFIG_NET_VENDOR_SEEQ=y
CONFIG_NET_VENDOR_SILAN=y
# CONFIG_SC92031 is not set
CONFIG_NET_VENDOR_SIS=y
# CONFIG_SIS900 is not set
# CONFIG_SIS190 is not set
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_SFC is not set
# CONFIG_SFC_FALCON is not set
CONFIG_NET_VENDOR_SMSC=y
# CONFIG_SMC91X is not set
# CONFIG_EPIC100 is not set
# CONFIG_SMC911X is not set
# CONFIG_SMSC911X is not set
# CONFIG_SMSC9420 is not set
# CONFIG_NET_VENDOR_SOCIONEXT is not set
CONFIG_NET_VENDOR_STMICRO=y
CONFIG_STMMAC_ETH=m
# CONFIG_STMMAC_SELFTESTS is not set
CONFIG_STMMAC_PLATFORM=m
CONFIG_DWMAC_DWC_QOS_ETH=m
CONFIG_DWMAC_GENERIC=m
CONFIG_DWMAC_IPQ806X=m
CONFIG_DWMAC_QCOM_ETHQOS=m
CONFIG_DWMAC_SUNXI=m
CONFIG_DWMAC_SUN8I=m
CONFIG_DWMAC_IMX8=m
# CONFIG_DWMAC_INTEL_PLAT is not set
# CONFIG_DWMAC_LOONGSON is not set
# CONFIG_STMMAC_PCI is not set
CONFIG_NET_VENDOR_SUN=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NIU is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_NET_VENDOR_TEHUTI=y
# CONFIG_TEHUTI is not set
CONFIG_NET_VENDOR_TI=y
CONFIG_TI_DAVINCI_MDIO=m
CONFIG_TI_CPSW_PHY_SEL=y
CONFIG_TI_CPSW=m
# CONFIG_TI_CPSW_SWITCHDEV is not set
# CONFIG_TI_CPTS is not set
# CONFIG_TLAN is not set
CONFIG_NET_VENDOR_VIA=y
# CONFIG_VIA_RHINE is not set
# CONFIG_VIA_VELOCITY is not set
CONFIG_NET_VENDOR_WIZNET=y
CONFIG_WIZNET_W5100=m
CONFIG_WIZNET_W5300=m
# CONFIG_WIZNET_BUS_DIRECT is not set
# CONFIG_WIZNET_BUS_INDIRECT is not set
CONFIG_WIZNET_BUS_ANY=y
CONFIG_WIZNET_W5100_SPI=m
CONFIG_NET_VENDOR_XILINX=y
# CONFIG_XILINX_EMACLITE is not set
# CONFIG_XILINX_AXI_EMAC is not set
# CONFIG_XILINX_LL_TEMAC is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_PHYLINK=m
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
CONFIG_FIXED_PHY=y
CONFIG_SFP=m
# MII PHY device drivers
CONFIG_AMD_PHY=m
# CONFIG_ADIN_PHY is not set
CONFIG_AQUANTIA_PHY=m
CONFIG_AX88796B_PHY=m
CONFIG_BROADCOM_PHY=m
# CONFIG_BCM54140_PHY is not set
CONFIG_BCM7XXX_PHY=m
# CONFIG_BCM84881_PHY is not set
CONFIG_BCM87XX_PHY=m
CONFIG_BCM_NET_PHYLIB=m
CONFIG_CICADA_PHY=m
# CONFIG_CORTINA_PHY is not set
CONFIG_DAVICOM_PHY=m
CONFIG_ICPLUS_PHY=m
CONFIG_LXT_PHY=m
CONFIG_INTEL_XWAY_PHY=m
CONFIG_LSI_ET1011C_PHY=m
CONFIG_MARVELL_PHY=m
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MARVELL_88X2222_PHY is not set
# CONFIG_MAXLINEAR_GPHY is not set
# CONFIG_MEDIATEK_GE_PHY is not set
CONFIG_MICREL_PHY=m
CONFIG_MICROCHIP_PHY=m
# CONFIG_MICROCHIP_T1_PHY is not set
CONFIG_MICROSEMI_PHY=m
# CONFIG_MOTORCOMM_PHY is not set
CONFIG_NATIONAL_PHY=m
# CONFIG_NXP_C45_TJA11XX_PHY is not set
# CONFIG_NXP_TJA11XX_PHY is not set
# CONFIG_AT803X_PHY is not set
CONFIG_QSEMI_PHY=m
CONFIG_REALTEK_PHY=m
CONFIG_RENESAS_PHY=m
# CONFIG_ROCKCHIP_PHY is not set
CONFIG_SMSC_PHY=m
CONFIG_STE10XP=m
CONFIG_TERANETICS_PHY=m
CONFIG_DP83822_PHY=m
# CONFIG_DP83TC811_PHY is not set
CONFIG_DP83848_PHY=m
CONFIG_DP83867_PHY=m
# CONFIG_DP83869_PHY is not set
CONFIG_VITESSE_PHY=m
CONFIG_XILINX_GMII2RGMII=m
CONFIG_MICREL_KS8995MA=m
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_FWNODE_MDIO=y
CONFIG_OF_MDIO=y
CONFIG_MDIO_DEVRES=y
CONFIG_MDIO_SUN4I=m
CONFIG_MDIO_BITBANG=m
CONFIG_MDIO_BCM_UNIMAC=m
CONFIG_MDIO_GPIO=m
# CONFIG_MDIO_HISI_FEMAC is not set
CONFIG_MDIO_I2C=m
# CONFIG_MDIO_MVUSB is not set
# CONFIG_MDIO_MSCC_MIIM is not set
# CONFIG_MDIO_IPQ4019 is not set
# CONFIG_MDIO_IPQ8064 is not set
# MDIO Multiplexers
CONFIG_MDIO_BUS_MUX=m
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# PCS device drivers
CONFIG_PCS_XPCS=m
# end of PCS device drivers
CONFIG_PPP=m
CONFIG_PPP_BSDCOMP=m
CONFIG_PPP_DEFLATE=m
CONFIG_PPP_FILTER=y
CONFIG_PPP_MPPE=m
CONFIG_PPP_MULTILINK=y
CONFIG_PPPOATM=m
CONFIG_PPPOE=m
CONFIG_PPTP=m
CONFIG_PPPOL2TP=m
CONFIG_PPP_ASYNC=m
CONFIG_PPP_SYNC_TTY=m
CONFIG_SLIP=m
CONFIG_SLHC=m
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
# Host-side USB support is needed for USB Network Adapter support
CONFIG_USB_NET_DRIVERS=m
CONFIG_USB_CATC=m
CONFIG_USB_KAWETH=m
CONFIG_USB_PEGASUS=m
CONFIG_USB_RTL8150=m
# CONFIG_USB_RTL8152 is not set
CONFIG_USB_LAN78XX=m
CONFIG_USB_USBNET=m
CONFIG_USB_NET_AX8817X=m
CONFIG_USB_NET_AX88179_178A=m
CONFIG_USB_NET_CDCETHER=m
CONFIG_USB_NET_CDC_EEM=m
CONFIG_USB_NET_CDC_NCM=m
# CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
# CONFIG_USB_NET_CDC_MBIM is not set
CONFIG_USB_NET_DM9601=m
# CONFIG_USB_NET_SR9700 is not set
# CONFIG_USB_NET_SR9800 is not set
CONFIG_USB_NET_SMSC75XX=m
CONFIG_USB_NET_SMSC95XX=m
CONFIG_USB_NET_GL620A=m
CONFIG_USB_NET_NET1080=m
CONFIG_USB_NET_PLUSB=m
CONFIG_USB_NET_MCS7830=m
CONFIG_USB_NET_RNDIS_HOST=m
CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
CONFIG_USB_NET_CDC_SUBSET=m
CONFIG_USB_ALI_M5632=y
CONFIG_USB_AN2720=y
CONFIG_USB_BELKIN=y
CONFIG_USB_ARMLINUX=y
CONFIG_USB_EPSON2888=y
CONFIG_USB_KC2190=y
CONFIG_USB_NET_ZAURUS=m
CONFIG_USB_NET_CX82310_ETH=m
CONFIG_USB_NET_KALMIA=m
CONFIG_USB_NET_QMI_WWAN=m
CONFIG_USB_HSO=m
CONFIG_USB_NET_INT51X1=m
CONFIG_USB_CDC_PHONET=m
CONFIG_USB_IPHETH=m
CONFIG_USB_SIERRA_NET=m
CONFIG_USB_VL600=m
CONFIG_USB_NET_CH9200=m
# CONFIG_USB_NET_AQC111 is not set
CONFIG_USB_RTL8153_ECM=m
CONFIG_WLAN=y
# CONFIG_WLAN_VENDOR_ADMTEK is not set
CONFIG_ATH_COMMON=m
CONFIG_WLAN_VENDOR_ATH=y
# CONFIG_ATH_DEBUG is not set
# CONFIG_ATH5K is not set
# CONFIG_ATH5K_PCI is not set
CONFIG_ATH9K_HW=m
CONFIG_ATH9K_COMMON=m
CONFIG_ATH9K_BTCOEX_SUPPORT=y
CONFIG_ATH9K=m
CONFIG_ATH9K_PCI=y
CONFIG_ATH9K_AHB=y
# CONFIG_ATH9K_DEBUGFS is not set
# CONFIG_ATH9K_DYNACK is not set
# CONFIG_ATH9K_WOW is not set
CONFIG_ATH9K_RFKILL=y
# CONFIG_ATH9K_CHANNEL_CONTEXT is not set
# CONFIG_ATH9K_PCOEM is not set
# CONFIG_ATH9K_PCI_NO_EEPROM is not set
CONFIG_ATH9K_HTC=m
# CONFIG_ATH9K_HTC_DEBUGFS is not set
# CONFIG_ATH9K_HWRNG is not set
CONFIG_CARL9170=m
CONFIG_CARL9170_LEDS=y
CONFIG_CARL9170_WPC=y
CONFIG_CARL9170_HWRNG=y
CONFIG_ATH6KL=m
CONFIG_ATH6KL_SDIO=m
CONFIG_ATH6KL_USB=m
CONFIG_ATH6KL_DEBUG=y
# CONFIG_ATH6KL_TRACING is not set
CONFIG_AR5523=m
# CONFIG_WIL6210 is not set
CONFIG_ATH10K=m
CONFIG_ATH10K_CE=y
CONFIG_ATH10K_PCI=m
CONFIG_ATH10K_AHB=y
# CONFIG_ATH10K_SDIO is not set
# CONFIG_ATH10K_USB is not set
# CONFIG_ATH10K_SNOC is not set
# CONFIG_ATH10K_DEBUG is not set
# CONFIG_ATH10K_DEBUGFS is not set
# CONFIG_ATH10K_TRACING is not set
# CONFIG_WCN36XX is not set
# CONFIG_ATH11K is not set
# CONFIG_WLAN_VENDOR_ATMEL is not set
CONFIG_WLAN_VENDOR_BROADCOM=y
CONFIG_B43=m
CONFIG_B43_BCMA=y
CONFIG_B43_SSB=y
CONFIG_B43_BUSES_BCMA_AND_SSB=y
# CONFIG_B43_BUSES_BCMA is not set
# CONFIG_B43_BUSES_SSB is not set
CONFIG_B43_PCI_AUTOSELECT=y
CONFIG_B43_PCICORE_AUTOSELECT=y
CONFIG_B43_SDIO=y
CONFIG_B43_BCMA_PIO=y
CONFIG_B43_PIO=y
CONFIG_B43_PHY_G=y
CONFIG_B43_PHY_N=y
CONFIG_B43_PHY_LP=y
CONFIG_B43_PHY_HT=y
CONFIG_B43_LEDS=y
CONFIG_B43_HWRNG=y
# CONFIG_B43_DEBUG is not set
CONFIG_B43LEGACY=m
CONFIG_B43LEGACY_PCI_AUTOSELECT=y
CONFIG_B43LEGACY_PCICORE_AUTOSELECT=y
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_HWRNG=y
CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
CONFIG_BRCMUTIL=m
CONFIG_BRCMSMAC=m
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
CONFIG_BRCMFMAC_USB=y
# CONFIG_BRCMFMAC_PCIE is not set
# CONFIG_BRCM_TRACING is not set
# CONFIG_BRCMDBG is not set
# CONFIG_WLAN_VENDOR_CISCO is not set
CONFIG_WLAN_VENDOR_INTEL=y
# CONFIG_IPW2100 is not set
# CONFIG_IPW2200 is not set
# CONFIG_IWL4965 is not set
# CONFIG_IWL3945 is not set
# CONFIG_IWLWIFI is not set
CONFIG_WLAN_VENDOR_INTERSIL=y
CONFIG_HOSTAP=m
CONFIG_HOSTAP_FIRMWARE=y
CONFIG_HOSTAP_FIRMWARE_NVRAM=y
# CONFIG_HOSTAP_PLX is not set
# CONFIG_HOSTAP_PCI is not set
# CONFIG_HERMES is not set
CONFIG_P54_COMMON=m
CONFIG_P54_USB=m
# CONFIG_P54_PCI is not set
CONFIG_P54_SPI=m
# CONFIG_P54_SPI_DEFAULT_EEPROM is not set
CONFIG_P54_LEDS=y
CONFIG_WLAN_VENDOR_MARVELL=y
CONFIG_LIBERTAS=m
CONFIG_LIBERTAS_USB=m
CONFIG_LIBERTAS_SDIO=m
CONFIG_LIBERTAS_SPI=m
# CONFIG_LIBERTAS_DEBUG is not set
CONFIG_LIBERTAS_MESH=y
CONFIG_LIBERTAS_THINFIRM=m
# CONFIG_LIBERTAS_THINFIRM_DEBUG is not set
CONFIG_LIBERTAS_THINFIRM_USB=m
CONFIG_MWIFIEX=m
CONFIG_MWIFIEX_SDIO=m
# CONFIG_MWIFIEX_PCIE is not set
CONFIG_MWIFIEX_USB=m
# CONFIG_MWL8K is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
CONFIG_MT7601U=m
CONFIG_MT76_CORE=m
CONFIG_MT76_LEDS=y
CONFIG_MT76_USB=m
CONFIG_MT76x02_LIB=m
CONFIG_MT76x02_USB=m
CONFIG_MT76x0_COMMON=m
CONFIG_MT76x0U=m
# CONFIG_MT76x0E is not set
CONFIG_MT76x2_COMMON=m
# CONFIG_MT76x2E is not set
CONFIG_MT76x2U=m
# CONFIG_MT7603E is not set
# CONFIG_MT7615E is not set
# CONFIG_MT7663U is not set
# CONFIG_MT7663S is not set
# CONFIG_MT7915E is not set
# CONFIG_MT7921E is not set
CONFIG_WLAN_VENDOR_MICROCHIP=y
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
CONFIG_WLAN_VENDOR_RALINK=y
CONFIG_RT2X00=m
# CONFIG_RT2400PCI is not set
# CONFIG_RT2500PCI is not set
# CONFIG_RT61PCI is not set
# CONFIG_RT2800PCI is not set
CONFIG_RT2500USB=m
CONFIG_RT73USB=m
CONFIG_RT2800USB=m
CONFIG_RT2800USB_RT33XX=y
# CONFIG_RT2800USB_RT35XX is not set
# CONFIG_RT2800USB_RT3573 is not set
CONFIG_RT2800USB_RT53XX=y
# CONFIG_RT2800USB_RT55XX is not set
CONFIG_RT2800USB_UNKNOWN=y
CONFIG_RT2800_LIB=m
CONFIG_RT2X00_LIB_USB=m
CONFIG_RT2X00_LIB=m
CONFIG_RT2X00_LIB_FIRMWARE=y
CONFIG_RT2X00_LIB_CRYPTO=y
CONFIG_RT2X00_LIB_LEDS=y
# CONFIG_RT2X00_DEBUG is not set
CONFIG_WLAN_VENDOR_REALTEK=y
# CONFIG_RTL8180 is not set
CONFIG_RTL8187=m
CONFIG_RTL8187_LEDS=y
CONFIG_RTL_CARDS=m
# CONFIG_RTL8192CE is not set
# CONFIG_RTL8192SE is not set
# CONFIG_RTL8192DE is not set
# CONFIG_RTL8723AE is not set
# CONFIG_RTL8723BE is not set
# CONFIG_RTL8188EE is not set
# CONFIG_RTL8192EE is not set
# CONFIG_RTL8821AE is not set
CONFIG_RTL8192CU=m
CONFIG_RTLWIFI=m
CONFIG_RTLWIFI_USB=m
# CONFIG_RTLWIFI_DEBUG is not set
CONFIG_RTL8192C_COMMON=m
CONFIG_RTL8XXXU=m
CONFIG_RTL8XXXU_UNTESTED=y
# CONFIG_RTW88 is not set
CONFIG_WLAN_VENDOR_RSI=y
CONFIG_RSI_91X=m
CONFIG_RSI_DEBUGFS=y
CONFIG_RSI_SDIO=m
CONFIG_RSI_USB=m
CONFIG_RSI_COEX=y
CONFIG_WLAN_VENDOR_ST=y
# CONFIG_CW1200 is not set
CONFIG_WLAN_VENDOR_TI=y
CONFIG_WL1251=m
CONFIG_WL1251_SPI=m
CONFIG_WL1251_SDIO=m
CONFIG_WL12XX=m
CONFIG_WL18XX=m
CONFIG_WLCORE=m
CONFIG_WLCORE_SPI=m
CONFIG_WLCORE_SDIO=m
CONFIG_WILINK_PLATFORM_DATA=y
CONFIG_WLAN_VENDOR_ZYDAS=y
CONFIG_USB_ZD1201=m
CONFIG_ZD1211RW=m
# CONFIG_ZD1211RW_DEBUG is not set
CONFIG_WLAN_VENDOR_QUANTENNA=y
# CONFIG_QTNFMAC_PCIE is not set
CONFIG_MAC80211_HWSIM=m
CONFIG_USB_NET_RNDIS_WLAN=m
# CONFIG_VIRT_WIFI is not set
CONFIG_WAN=y
CONFIG_HDLC=m
CONFIG_HDLC_RAW=m
CONFIG_HDLC_RAW_ETH=m
CONFIG_HDLC_CISCO=m
CONFIG_HDLC_FR=m
CONFIG_HDLC_PPP=m
CONFIG_HDLC_X25=m
# CONFIG_PCI200SYN is not set
# CONFIG_WANXL is not set
# CONFIG_PC300TOO is not set
# CONFIG_FARSYNC is not set
# CONFIG_SLIC_DS26522 is not set
CONFIG_LAPBETHER=m
CONFIG_IEEE802154_DRIVERS=m
CONFIG_IEEE802154_FAKELB=m
# CONFIG_IEEE802154_AT86RF230 is not set
CONFIG_IEEE802154_MRF24J40=m
CONFIG_IEEE802154_CC2520=m
CONFIG_IEEE802154_ATUSB=m
CONFIG_IEEE802154_ADF7242=m
# CONFIG_IEEE802154_CA8210 is not set
CONFIG_IEEE802154_MCR20A=m
# CONFIG_IEEE802154_HWSIM is not set
# Wireless WAN
# CONFIG_WWAN is not set
# end of Wireless WAN
# CONFIG_VMXNET3 is not set
# CONFIG_NETDEVSIM is not set
CONFIG_NET_FAILOVER=m
# CONFIG_ISDN is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=m
CONFIG_INPUT_FF_MEMLESS=m
CONFIG_INPUT_SPARSEKMAP=m
CONFIG_INPUT_MATRIXKMAP=m
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=m
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=m
CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_EVBUG=m
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
CONFIG_KEYBOARD_GPIO_POLLED=m
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_SNVS_PWRKEY is not set
# CONFIG_KEYBOARD_IMX is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_TEGRA is not set
# CONFIG_KEYBOARD_OPENCORES is not set
CONFIG_KEYBOARD_PMIC8XXX=m
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_SUN4I_LRADC is not set
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
CONFIG_KEYBOARD_BCM=m
CONFIG_INPUT_MOUSE=y
# CONFIG_MOUSE_PS2 is not set
CONFIG_MOUSE_SERIAL=m
CONFIG_MOUSE_APPLETOUCH=m
CONFIG_MOUSE_BCM5974=m
CONFIG_MOUSE_CYAPA=m
# CONFIG_MOUSE_ELAN_I2C is not set
CONFIG_MOUSE_VSXXXAA=m
CONFIG_MOUSE_GPIO=m
CONFIG_MOUSE_SYNAPTICS_I2C=m
CONFIG_MOUSE_SYNAPTICS_USB=m
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ADS7846=m
CONFIG_TOUCHSCREEN_AD7877=m
CONFIG_TOUCHSCREEN_AD7879=m
CONFIG_TOUCHSCREEN_AD7879_I2C=m
CONFIG_TOUCHSCREEN_AD7879_SPI=m
# CONFIG_TOUCHSCREEN_ADC is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
CONFIG_TOUCHSCREEN_ATMEL_MXT=m
# CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
CONFIG_TOUCHSCREEN_BU21013=m
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
CONFIG_TOUCHSCREEN_CY8CTMG110=m
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
CONFIG_TOUCHSCREEN_DYNAPRO=m
CONFIG_TOUCHSCREEN_HAMPSHIRE=m
CONFIG_TOUCHSCREEN_EETI=m
# CONFIG_TOUCHSCREEN_EGALAX is not set
CONFIG_TOUCHSCREEN_EGALAX_SERIAL=m
# CONFIG_TOUCHSCREEN_EXC3000 is not set
CONFIG_TOUCHSCREEN_FUJITSU=m
# CONFIG_TOUCHSCREEN_GOODIX is not set
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_ILITEK is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
CONFIG_TOUCHSCREEN_GUNZE=m
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
CONFIG_TOUCHSCREEN_ELO=m
CONFIG_TOUCHSCREEN_WACOM_W8001=m
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MSG2638 is not set
CONFIG_TOUCHSCREEN_MTOUCH=m
CONFIG_TOUCHSCREEN_IMX6UL_TSC=m
CONFIG_TOUCHSCREEN_INEXIO=m
CONFIG_TOUCHSCREEN_MK712=m
CONFIG_TOUCHSCREEN_PENMOUNT=m
# CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
CONFIG_TOUCHSCREEN_TOUCHRIGHT=m
CONFIG_TOUCHSCREEN_TOUCHWIN=m
# CONFIG_TOUCHSCREEN_TI_AM335X_TSC is not set
CONFIG_TOUCHSCREEN_UCB1400=m
CONFIG_TOUCHSCREEN_PIXCIR=m
CONFIG_TOUCHSCREEN_WDT87XX_I2C=m
CONFIG_TOUCHSCREEN_WM97XX=m
CONFIG_TOUCHSCREEN_WM9705=y
CONFIG_TOUCHSCREEN_WM9712=y
CONFIG_TOUCHSCREEN_WM9713=y
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
# CONFIG_TOUCHSCREEN_MC13783 is not set
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_USB_JASTEC=y
CONFIG_TOUCHSCREEN_USB_ELO=y
CONFIG_TOUCHSCREEN_USB_E2I=y
CONFIG_TOUCHSCREEN_USB_ZYTRONIC=y
CONFIG_TOUCHSCREEN_USB_ETT_TC45USB=y
CONFIG_TOUCHSCREEN_USB_NEXIO=y
# CONFIG_TOUCHSCREEN_USB_EASYTOUCH is not set
CONFIG_TOUCHSCREEN_TOUCHIT213=m
CONFIG_TOUCHSCREEN_TS4800=m
CONFIG_TOUCHSCREEN_TSC_SERIO=m
CONFIG_TOUCHSCREEN_TSC200X_CORE=m
CONFIG_TOUCHSCREEN_TSC2004=m
# CONFIG_TOUCHSCREEN_TSC2005 is not set
CONFIG_TOUCHSCREEN_TSC2007=m
# CONFIG_TOUCHSCREEN_TSC2007_IIO is not set
CONFIG_TOUCHSCREEN_RM_TS=m
CONFIG_TOUCHSCREEN_SILEAD=m
CONFIG_TOUCHSCREEN_SIS_I2C=m
CONFIG_TOUCHSCREEN_ST1232=m
# CONFIG_TOUCHSCREEN_STMFTS is not set
CONFIG_TOUCHSCREEN_SUN4I=m
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
CONFIG_TOUCHSCREEN_TPS6507X=m
# CONFIG_TOUCHSCREEN_ZET6223 is not set
CONFIG_TOUCHSCREEN_ZFORCE=m
CONFIG_TOUCHSCREEN_ROHM_BU21023=m
# CONFIG_TOUCHSCREEN_IQS5XX is not set
# CONFIG_TOUCHSCREEN_ZINITIX is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_AD714X=m
CONFIG_INPUT_AD714X_I2C=m
CONFIG_INPUT_AD714X_SPI=m
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
CONFIG_INPUT_E3X0_BUTTON=m
# CONFIG_INPUT_PM8941_PWRKEY is not set
CONFIG_INPUT_PM8XXX_VIBRATOR=m
CONFIG_INPUT_PMIC8XXX_PWRKEY=m
# CONFIG_INPUT_MC13783_PWRBUTTON is not set
CONFIG_INPUT_MMA8450=m
CONFIG_INPUT_GPIO_BEEPER=m
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_KEYSPAN_REMOTE=m
CONFIG_INPUT_KXTJ9=m
CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_YEALINK=m
CONFIG_INPUT_CM109=m
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
# CONFIG_INPUT_TPS65218_PWRBUTTON is not set
CONFIG_INPUT_AXP20X_PEK=m
CONFIG_INPUT_UINPUT=m
CONFIG_INPUT_PCF50633_PMU=m
CONFIG_INPUT_PCF8574=m
CONFIG_INPUT_PWM_BEEPER=m
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_RK805_PWRKEY is not set
CONFIG_INPUT_GPIO_ROTARY_ENCODER=m
# CONFIG_INPUT_DA7280_HAPTICS is not set
CONFIG_INPUT_ADXL34X=m
CONFIG_INPUT_ADXL34X_I2C=m
CONFIG_INPUT_ADXL34X_SPI=m
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_IQS269A is not set
# CONFIG_INPUT_IQS626A is not set
CONFIG_INPUT_CMA3000=m
CONFIG_INPUT_CMA3000_I2C=m
# CONFIG_INPUT_DRV260X_HAPTICS is not set
CONFIG_INPUT_DRV2665_HAPTICS=m
# CONFIG_INPUT_DRV2667_HAPTICS is not set
CONFIG_RMI4_CORE=m
CONFIG_RMI4_I2C=m
CONFIG_RMI4_SPI=m
# CONFIG_RMI4_SMB is not set
CONFIG_RMI4_F03=y
CONFIG_RMI4_F03_SERIO=m
CONFIG_RMI4_2D_SENSOR=y
CONFIG_RMI4_F11=y
CONFIG_RMI4_F12=y
CONFIG_RMI4_F30=y
# CONFIG_RMI4_F34 is not set
# CONFIG_RMI4_F3A is not set
# CONFIG_RMI4_F54 is not set
# CONFIG_RMI4_F55 is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=m
# CONFIG_SERIO_AMBAKMI is not set
# CONFIG_SERIO_PCIPS2 is not set
CONFIG_SERIO_LIBPS2=y
CONFIG_SERIO_RAW=m
CONFIG_SERIO_ALTERA_PS2=m
CONFIG_SERIO_PS2MULT=m
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
# CONFIG_LEGACY_PTYS is not set
# CONFIG_LDISC_AUTOLOAD is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
CONFIG_SERIAL_8250_16550A_VARIANTS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_EXAR=y
# CONFIG_SERIAL_8250_MEN_MCB is not set
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_DWLIB=y
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
# CONFIG_SERIAL_8250_OMAP is not set
CONFIG_SERIAL_8250_TEGRA=y
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
CONFIG_SERIAL_AMBA_PL010=y
CONFIG_SERIAL_AMBA_PL010_CONSOLE=y
CONFIG_SERIAL_AMBA_PL011=y
CONFIG_SERIAL_AMBA_PL011_CONSOLE=y
CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST=y
CONFIG_SERIAL_SAMSUNG=y
CONFIG_SERIAL_SAMSUNG_UARTS_4=y
CONFIG_SERIAL_SAMSUNG_UARTS=4
CONFIG_SERIAL_SAMSUNG_CONSOLE=y
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
CONFIG_SERIAL_IMX=y
CONFIG_SERIAL_IMX_CONSOLE=y
CONFIG_SERIAL_IMX_EARLYCON=y
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_JSM is not set
CONFIG_SERIAL_MSM=y
CONFIG_SERIAL_MSM_CONSOLE=y
CONFIG_SERIAL_OMAP=y
CONFIG_SERIAL_OMAP_CONSOLE=y
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_RP2 is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_MEN_Z135 is not set
# CONFIG_SERIAL_SPRD is not set
# CONFIG_SERIAL_MVEBU_UART is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
CONFIG_SERIAL_NONSTANDARD=y
# CONFIG_MOXA_INTELLIO is not set
# CONFIG_MOXA_SMARTIO is not set
# CONFIG_SYNCLINK_GT is not set
CONFIG_N_HDLC=m
# CONFIG_N_GSM is not set
# CONFIG_NOZOMI is not set
# CONFIG_NULL_TTY is not set
CONFIG_HVC_DRIVER=y
# CONFIG_HVC_DCC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_TTY_PRINTK is not set
CONFIG_VIRTIO_CONSOLE=m
CONFIG_IPMI_HANDLER=m
CONFIG_IPMI_DMI_DECODE=y
CONFIG_IPMI_PLAT_DATA=y
# CONFIG_IPMI_PANIC_EVENT is not set
CONFIG_IPMI_DEVICE_INTERFACE=m
CONFIG_IPMI_SI=m
CONFIG_IPMI_SSIF=m
CONFIG_IPMI_WATCHDOG=m
CONFIG_IPMI_POWEROFF=m
# CONFIG_IPMB_DEVICE_INTERFACE is not set
CONFIG_HW_RANDOM=m
CONFIG_HW_RANDOM_TIMERIOMEM=m
# CONFIG_HW_RANDOM_BA431 is not set
CONFIG_HW_RANDOM_BCM2835=m
CONFIG_HW_RANDOM_IPROC_RNG200=m
CONFIG_HW_RANDOM_OMAP=m
CONFIG_HW_RANDOM_VIRTIO=m
CONFIG_HW_RANDOM_IMX_RNGC=m
CONFIG_HW_RANDOM_EXYNOS=m
# CONFIG_HW_RANDOM_CCTRNG is not set
# CONFIG_HW_RANDOM_XIPHERA is not set
CONFIG_HW_RANDOM_ARM_SMCCC_TRNG=m
# CONFIG_APPLICOM is not set
CONFIG_DEVMEM=y
CONFIG_DEVPORT=y
CONFIG_TCG_TPM=m
CONFIG_HW_RANDOM_TPM=y
# CONFIG_TCG_TIS is not set
# CONFIG_TCG_TIS_SPI is not set
# CONFIG_TCG_TIS_I2C_CR50 is not set
# CONFIG_TCG_TIS_I2C_ATMEL is not set
# CONFIG_TCG_TIS_I2C_INFINEON is not set
# CONFIG_TCG_TIS_I2C_NUVOTON is not set
# CONFIG_TCG_VTPM_PROXY is not set
# CONFIG_TCG_TIS_ST33ZP24_I2C is not set
# CONFIG_TCG_TIS_ST33ZP24_SPI is not set
# CONFIG_XILLYBUS is not set
# CONFIG_XILLYUSB is not set
CONFIG_RANDOM_TRUST_BOOTLOADER=y
# end of Character devices
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=m
CONFIG_I2C_MUX=m
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
CONFIG_I2C_MUX_GPIO=m
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
CONFIG_I2C_MUX_PCA9541=m
CONFIG_I2C_MUX_PCA954x=m
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=m
CONFIG_I2C_ALGOPCA=m
# I2C Hardware Bus support
# PC SMBus host controller drivers
# CONFIG_I2C_ALI1535 is not set
# CONFIG_I2C_ALI1563 is not set
# CONFIG_I2C_ALI15X3 is not set
# CONFIG_I2C_AMD756 is not set
# CONFIG_I2C_AMD8111 is not set
# CONFIG_I2C_I801 is not set
# CONFIG_I2C_ISCH is not set
# CONFIG_I2C_PIIX4 is not set
# CONFIG_I2C_NFORCE2 is not set
# CONFIG_I2C_NVIDIA_GPU is not set
# CONFIG_I2C_SIS5595 is not set
# CONFIG_I2C_SIS630 is not set
# CONFIG_I2C_SIS96X is not set
# CONFIG_I2C_VIA is not set
# CONFIG_I2C_VIAPRO is not set
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_BCM2835 is not set
CONFIG_I2C_BRCMSTB=m
# CONFIG_I2C_CADENCE is not set
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_DESIGNWARE_PCI is not set
# CONFIG_I2C_EMEV2 is not set
CONFIG_I2C_EXYNOS5=y
CONFIG_I2C_GPIO=m
# CONFIG_I2C_GPIO_FAULT_INJECTOR is not set
CONFIG_I2C_IMX=m
# CONFIG_I2C_IMX_LPI2C is not set
CONFIG_I2C_MV64XXX=m
# CONFIG_I2C_NOMADIK is not set
CONFIG_I2C_OCORES=m
CONFIG_I2C_OMAP=y
CONFIG_I2C_PCA_PLATFORM=m
# CONFIG_I2C_PXA is not set
# CONFIG_I2C_QCOM_CCI is not set
CONFIG_I2C_QUP=m
# CONFIG_I2C_RK3X is not set
CONFIG_HAVE_S3C2410_I2C=y
CONFIG_I2C_S3C2410=y
CONFIG_I2C_SIMTEC=m
# CONFIG_I2C_SUN6I_P2WI is not set
# CONFIG_I2C_TEGRA is not set
# CONFIG_I2C_VERSATILE is not set
CONFIG_I2C_XILINX=m
# External I2C/SMBus adapter drivers
CONFIG_I2C_DIOLAN_U2C=m
# CONFIG_I2C_DLN2 is not set
# CONFIG_I2C_CP2615 is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
CONFIG_I2C_TAOS_EVM=m
CONFIG_I2C_TINY_USB=m
# Other I2C/SMBus bus drivers
CONFIG_I2C_VIRTIO=m
# end of I2C Hardware Bus support
CONFIG_I2C_STUB=m
CONFIG_I2C_SLAVE=y
CONFIG_I2C_SLAVE_EEPROM=m
# CONFIG_I2C_SLAVE_TESTUNIT is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
CONFIG_SPI_MEM=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_ARMADA_3700 is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
# CONFIG_SPI_BCM2835 is not set
# CONFIG_SPI_BCM2835AUX is not set
# CONFIG_SPI_BCM_QSPI is not set
CONFIG_SPI_BITBANG=m
CONFIG_SPI_CADENCE=m
# CONFIG_SPI_CADENCE_QUADSPI is not set
CONFIG_SPI_DESIGNWARE=m
# CONFIG_SPI_DW_DMA is not set
# CONFIG_SPI_DW_PCI is not set
# CONFIG_SPI_DW_MMIO is not set
# CONFIG_SPI_DLN2 is not set
# CONFIG_SPI_FSL_LPSPI is not set
CONFIG_SPI_FSL_QUADSPI=m
# CONFIG_SPI_NXP_FLEXSPI is not set
CONFIG_SPI_GPIO=m
CONFIG_SPI_IMX=m
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_OMAP24XX is not set
# CONFIG_SPI_TI_QSPI is not set
CONFIG_SPI_ORION=m
# CONFIG_SPI_PL022 is not set
# CONFIG_SPI_PXA2XX is not set
CONFIG_SPI_ROCKCHIP=m
# CONFIG_SPI_QCOM_QSPI is not set
CONFIG_SPI_QUP=m
CONFIG_SPI_S3C64XX=m
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
CONFIG_SPI_SUN4I=m
# CONFIG_SPI_SUN6I is not set
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_TEGRA210_QUAD is not set
# CONFIG_SPI_TEGRA20_SFLASH is not set
CONFIG_SPI_XCOMM=m
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQ_QSPI is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# CONFIG_SPI_AMD is not set
# SPI Multiplexer support
# CONFIG_SPI_MUX is not set
# SPI Protocol Masters
CONFIG_SPI_SPIDEV=m
# CONFIG_SPI_LOOPBACK_TEST is not set
CONFIG_SPI_TLE62X0=m
# CONFIG_SPI_SLAVE is not set
CONFIG_SPI_DYNAMIC=y
CONFIG_SPMI=m
# CONFIG_SPMI_HISI3670 is not set
CONFIG_SPMI_MSM_PMIC_ARB=m
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC=m
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PTP_1588_CLOCK_KVM=y
# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# CONFIG_PTP_1588_CLOCK_OCP is not set
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_GENERIC_PINCTRL_GROUPS=y
CONFIG_PINMUX=y
CONFIG_GENERIC_PINMUX_FUNCTIONS=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
CONFIG_PINCTRL_AXP209=m
# CONFIG_PINCTRL_MCP23S08 is not set
CONFIG_PINCTRL_SINGLE=y
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
CONFIG_PINCTRL_ZYNQ=y
# CONFIG_PINCTRL_RK805 is not set
# CONFIG_PINCTRL_OCELOT is not set
# CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
CONFIG_PINCTRL_BCM2835=y
CONFIG_PINCTRL_IMX=y
CONFIG_PINCTRL_IMX51=y
CONFIG_PINCTRL_IMX53=y
CONFIG_PINCTRL_IMX6Q=y
CONFIG_PINCTRL_IMX6SL=y
CONFIG_PINCTRL_IMX6SX=y
CONFIG_PINCTRL_IMX6UL=y
CONFIG_PINCTRL_IMX7D=y
# CONFIG_PINCTRL_IMX8MM is not set
# CONFIG_PINCTRL_IMX8MN is not set
# CONFIG_PINCTRL_IMX8MP is not set
# CONFIG_PINCTRL_IMX8MQ is not set
# CONFIG_PINCTRL_IMX8ULP is not set
CONFIG_PINCTRL_MVEBU=y
CONFIG_PINCTRL_ARMADA_38X=y
CONFIG_PINCTRL_MSM=y
CONFIG_PINCTRL_APQ8064=m
CONFIG_PINCTRL_APQ8084=m
# CONFIG_PINCTRL_IPQ4019 is not set
CONFIG_PINCTRL_IPQ8064=m
# CONFIG_PINCTRL_IPQ8074 is not set
# CONFIG_PINCTRL_IPQ6018 is not set
# CONFIG_PINCTRL_MSM8226 is not set
CONFIG_PINCTRL_MSM8660=m
CONFIG_PINCTRL_MSM8960=m
# CONFIG_PINCTRL_MDM9607 is not set
# CONFIG_PINCTRL_MDM9615 is not set
# CONFIG_PINCTRL_MSM8X74 is not set
CONFIG_PINCTRL_MSM8916=m
# CONFIG_PINCTRL_MSM8953 is not set
# CONFIG_PINCTRL_MSM8976 is not set
# CONFIG_PINCTRL_MSM8994 is not set
# CONFIG_PINCTRL_MSM8996 is not set
CONFIG_PINCTRL_MSM8998=m
# CONFIG_PINCTRL_QCS404 is not set
CONFIG_PINCTRL_QCOM_SPMI_PMIC=m
CONFIG_PINCTRL_QCOM_SSBI_PMIC=m
# CONFIG_PINCTRL_SC7180 is not set
# CONFIG_PINCTRL_SC7280 is not set
# CONFIG_PINCTRL_SC8180X is not set
# CONFIG_PINCTRL_SDM660 is not set
# CONFIG_PINCTRL_SDM845 is not set
# CONFIG_PINCTRL_SDX55 is not set
# CONFIG_PINCTRL_SM6115 is not set
# CONFIG_PINCTRL_SM6125 is not set
# CONFIG_PINCTRL_SM8150 is not set
# CONFIG_PINCTRL_SM8250 is not set
# CONFIG_PINCTRL_SM8350 is not set
# CONFIG_PINCTRL_LPASS_LPI is not set
# Renesas pinctrl drivers
# end of Renesas pinctrl drivers
CONFIG_PINCTRL_SAMSUNG=y
CONFIG_PINCTRL_EXYNOS=y
CONFIG_PINCTRL_EXYNOS_ARM=y
CONFIG_PINCTRL_SUNXI=y
CONFIG_PINCTRL_SUN4I_A10=y
CONFIG_PINCTRL_SUN5I=y
CONFIG_PINCTRL_SUN6I_A31=y
CONFIG_PINCTRL_SUN6I_A31_R=y
CONFIG_PINCTRL_SUN8I_A23=y
CONFIG_PINCTRL_SUN8I_A33=y
CONFIG_PINCTRL_SUN8I_A83T=y
CONFIG_PINCTRL_SUN8I_A83T_R=y
CONFIG_PINCTRL_SUN8I_A23_R=y
CONFIG_PINCTRL_SUN8I_H3=y
CONFIG_PINCTRL_SUN8I_H3_R=y
CONFIG_PINCTRL_SUN8I_V3S=y
CONFIG_PINCTRL_SUN9I_A80=y
CONFIG_PINCTRL_SUN9I_A80_R=y
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_A100 is not set
# CONFIG_PINCTRL_SUN50I_A100_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
# CONFIG_PINCTRL_SUN50I_H6 is not set
# CONFIG_PINCTRL_SUN50I_H6_R is not set
# CONFIG_PINCTRL_SUN50I_H616 is not set
# CONFIG_PINCTRL_SUN50I_H616_R is not set
CONFIG_PINCTRL_TEGRA_XUSB=y
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIOLIB_IRQCHIP=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
CONFIG_GPIO_CDEV=y
CONFIG_GPIO_CDEV_V1=y
CONFIG_GPIO_GENERIC=y
CONFIG_GPIO_MAX730X=m
# Memory mapped GPIO drivers
CONFIG_GPIO_74XX_MMIO=m
CONFIG_GPIO_ALTERA=m
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_EXAR is not set
# CONFIG_GPIO_FTGPIO010 is not set
CONFIG_GPIO_GENERIC_PLATFORM=y
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MENZ127 is not set
# CONFIG_GPIO_MPC8XXX is not set
CONFIG_GPIO_MVEBU=y
CONFIG_GPIO_MXC=y
CONFIG_GPIO_OMAP=y
# CONFIG_GPIO_PL061 is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SIFIVE is not set
CONFIG_GPIO_SYSCON=m
CONFIG_GPIO_TEGRA=y
CONFIG_GPIO_TS4800=m
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_ZYNQ is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
CONFIG_GPIO_ADP5588=m
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
CONFIG_GPIO_MAX7300=m
CONFIG_GPIO_MAX732X=m
CONFIG_GPIO_PCA953X=m
# CONFIG_GPIO_PCA953X_IRQ is not set
# CONFIG_GPIO_PCA9570 is not set
CONFIG_GPIO_PCF857X=m
# CONFIG_GPIO_TPIC2810 is not set
# CONFIG_GPIO_TS4900 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# CONFIG_GPIO_DLN2 is not set
# CONFIG_HTC_EGPIO is not set
CONFIG_GPIO_TPS65218=m
# CONFIG_GPIO_UCB1400 is not set
# CONFIG_GPIO_WM8994 is not set
# end of MFD GPIO expanders
# PCI GPIO expanders
# CONFIG_GPIO_BT8XX is not set
# CONFIG_GPIO_PCI_IDIO_16 is not set
# CONFIG_GPIO_PCIE_IDIO_24 is not set
# CONFIG_GPIO_RDC321X is not set
# end of PCI GPIO expanders
# SPI GPIO expanders
CONFIG_GPIO_74X164=m
# CONFIG_GPIO_MAX3191X is not set
CONFIG_GPIO_MAX7301=m
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# Virtual GPIO drivers
# CONFIG_GPIO_AGGREGATOR is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_VIRTIO is not set
# end of Virtual GPIO drivers
# CONFIG_W1 is not set
CONFIG_POWER_RESET=y
# CONFIG_POWER_RESET_BRCMKONA is not set
# CONFIG_POWER_RESET_BRCMSTB is not set
# CONFIG_POWER_RESET_GPIO is not set
CONFIG_POWER_RESET_GPIO_RESTART=y
# CONFIG_POWER_RESET_LINKSTATION is not set
CONFIG_POWER_RESET_MSM=y
CONFIG_POWER_RESET_QCOM_PON=m
# CONFIG_POWER_RESET_LTC2952 is not set
# CONFIG_POWER_RESET_QNAP is not set
# CONFIG_POWER_RESET_REGULATOR is not set
# CONFIG_POWER_RESET_RESTART is not set
CONFIG_POWER_RESET_VERSATILE=y
CONFIG_POWER_RESET_VEXPRESS=y
CONFIG_POWER_RESET_SYSCON=y
CONFIG_POWER_RESET_SYSCON_POWEROFF=y
CONFIG_REBOOT_MODE=m
# CONFIG_SYSCON_REBOOT_MODE is not set
# CONFIG_NVMEM_REBOOT_MODE is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_CW2015 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
CONFIG_CHARGER_AXP20X=m
CONFIG_BATTERY_AXP20X=m
CONFIG_AXP20X_POWER=m
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_PCF50633 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_LTC4162L is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_QCOM_SMBB is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ2515X is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_BQ25980 is not set
# CONFIG_CHARGER_BQ256XX is not set
# CONFIG_CHARGER_SMB347 is not set
CONFIG_CHARGER_TPS65217=m
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_BATTERY_GOLDFISH is not set
# CONFIG_BATTERY_RT5033 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_CHARGER_BD99954 is not set
CONFIG_HWMON=m
CONFIG_HWMON_VID=m
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
CONFIG_SENSORS_AD7314=m
CONFIG_SENSORS_AD7414=m
CONFIG_SENSORS_AD7418=m
CONFIG_SENSORS_ADM1021=m
CONFIG_SENSORS_ADM1025=m
CONFIG_SENSORS_ADM1026=m
CONFIG_SENSORS_ADM1029=m
CONFIG_SENSORS_ADM1031=m
# CONFIG_SENSORS_ADM1177 is not set
CONFIG_SENSORS_ADM9240=m
CONFIG_SENSORS_ADT7X10=m
CONFIG_SENSORS_ADT7310=m
# CONFIG_SENSORS_ADT7410 is not set
CONFIG_SENSORS_ADT7411=m
CONFIG_SENSORS_ADT7462=m
CONFIG_SENSORS_ADT7470=m
CONFIG_SENSORS_ADT7475=m
# CONFIG_SENSORS_AHT10 is not set
# CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set
# CONFIG_SENSORS_AS370 is not set
CONFIG_SENSORS_ASC7621=m
# CONFIG_SENSORS_AXI_FAN_CONTROL is not set
# CONFIG_SENSORS_ASPEED is not set
CONFIG_SENSORS_ATXP1=m
# CONFIG_SENSORS_CORSAIR_CPRO is not set
# CONFIG_SENSORS_CORSAIR_PSU is not set
# CONFIG_SENSORS_DRIVETEMP is not set
CONFIG_SENSORS_DS620=m
CONFIG_SENSORS_DS1621=m
# CONFIG_SENSORS_I5K_AMB is not set
CONFIG_SENSORS_F71805F=m
CONFIG_SENSORS_F71882FG=m
CONFIG_SENSORS_F75375S=m
# CONFIG_SENSORS_MC13783_ADC is not set
CONFIG_SENSORS_FTSTEUTATES=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_GL520SM=m
CONFIG_SENSORS_G760A=m
# CONFIG_SENSORS_G762 is not set
CONFIG_SENSORS_GPIO_FAN=m
# CONFIG_SENSORS_HIH6130 is not set
CONFIG_SENSORS_IBMAEM=m
CONFIG_SENSORS_IBMPEX=m
# CONFIG_SENSORS_IIO_HWMON is not set
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_JC42=m
CONFIG_SENSORS_POWR1220=m
CONFIG_SENSORS_LINEAGE=m
CONFIG_SENSORS_LTC2945=m
# CONFIG_SENSORS_LTC2947_I2C is not set
# CONFIG_SENSORS_LTC2947_SPI is not set
CONFIG_SENSORS_LTC2990=m
# CONFIG_SENSORS_LTC2992 is not set
CONFIG_SENSORS_LTC4151=m
CONFIG_SENSORS_LTC4215=m
CONFIG_SENSORS_LTC4222=m
CONFIG_SENSORS_LTC4245=m
CONFIG_SENSORS_LTC4260=m
CONFIG_SENSORS_LTC4261=m
CONFIG_SENSORS_MAX1111=m
# CONFIG_SENSORS_MAX127 is not set
CONFIG_SENSORS_MAX16065=m
CONFIG_SENSORS_MAX1619=m
CONFIG_SENSORS_MAX1668=m
# CONFIG_SENSORS_MAX197 is not set
CONFIG_SENSORS_MAX31722=m
# CONFIG_SENSORS_MAX31730 is not set
# CONFIG_SENSORS_MAX6621 is not set
CONFIG_SENSORS_MAX6639=m
CONFIG_SENSORS_MAX6642=m
CONFIG_SENSORS_MAX6650=m
CONFIG_SENSORS_MAX6697=m
CONFIG_SENSORS_MAX31790=m
CONFIG_SENSORS_MCP3021=m
CONFIG_SENSORS_MLXREG_FAN=m
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_TPS23861 is not set
# CONFIG_SENSORS_MR75203 is not set
CONFIG_SENSORS_ADCXX=m
CONFIG_SENSORS_LM63=m
CONFIG_SENSORS_LM70=m
CONFIG_SENSORS_LM73=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM78=m
CONFIG_SENSORS_LM80=m
CONFIG_SENSORS_LM83=m
CONFIG_SENSORS_LM85=m
CONFIG_SENSORS_LM87=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_LM92=m
CONFIG_SENSORS_LM93=m
# CONFIG_SENSORS_LM95234 is not set
CONFIG_SENSORS_LM95241=m
CONFIG_SENSORS_LM95245=m
CONFIG_SENSORS_PC87360=m
CONFIG_SENSORS_PC87427=m
# CONFIG_SENSORS_NTC_THERMISTOR is not set
CONFIG_SENSORS_NCT6683=m
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
CONFIG_SENSORS_NPCM7XX=m
# CONFIG_SENSORS_NZXT_KRAKEN2 is not set
# CONFIG_SENSORS_OCC_P8_I2C is not set
CONFIG_SENSORS_PCF8591=m
CONFIG_PMBUS=m
CONFIG_SENSORS_PMBUS=m
# CONFIG_SENSORS_ADM1266 is not set
CONFIG_SENSORS_ADM1275=m
# CONFIG_SENSORS_BEL_PFE is not set
# CONFIG_SENSORS_BPA_RS600 is not set
# CONFIG_SENSORS_FSP_3Y is not set
# CONFIG_SENSORS_IBM_CFFPS is not set
# CONFIG_SENSORS_DPS920AB is not set
# CONFIG_SENSORS_INSPUR_IPSPS is not set
# CONFIG_SENSORS_IR35221 is not set
# CONFIG_SENSORS_IR36021 is not set
# CONFIG_SENSORS_IR38064 is not set
# CONFIG_SENSORS_IRPS5401 is not set
# CONFIG_SENSORS_ISL68137 is not set
CONFIG_SENSORS_LM25066=m
CONFIG_SENSORS_LTC2978=m
# CONFIG_SENSORS_LTC2978_REGULATOR is not set
CONFIG_SENSORS_LTC3815=m
# CONFIG_SENSORS_MAX15301 is not set
CONFIG_SENSORS_MAX16064=m
# CONFIG_SENSORS_MAX16601 is not set
# CONFIG_SENSORS_MAX20730 is not set
CONFIG_SENSORS_MAX20751=m
# CONFIG_SENSORS_MAX31785 is not set
CONFIG_SENSORS_MAX34440=m
CONFIG_SENSORS_MAX8688=m
# CONFIG_SENSORS_MP2888 is not set
# CONFIG_SENSORS_MP2975 is not set
# CONFIG_SENSORS_PIM4328 is not set
# CONFIG_SENSORS_PM6764TR is not set
# CONFIG_SENSORS_PXE1610 is not set
# CONFIG_SENSORS_Q54SJ108A2 is not set
# CONFIG_SENSORS_STPDDC60 is not set
CONFIG_SENSORS_TPS40422=m
# CONFIG_SENSORS_TPS53679 is not set
CONFIG_SENSORS_UCD9000=m
CONFIG_SENSORS_UCD9200=m
# CONFIG_SENSORS_XDPE122 is not set
CONFIG_SENSORS_ZL6100=m
CONFIG_SENSORS_PWM_FAN=m
# CONFIG_SENSORS_SBTSI is not set
# CONFIG_SENSORS_SBRMI is not set
CONFIG_SENSORS_SHT15=m
CONFIG_SENSORS_SHT21=m
CONFIG_SENSORS_SHT3x=m
# CONFIG_SENSORS_SHT4x is not set
CONFIG_SENSORS_SHTC1=m
# CONFIG_SENSORS_SIS5595 is not set
CONFIG_SENSORS_DME1737=m
CONFIG_SENSORS_EMC1403=m
CONFIG_SENSORS_EMC2103=m
CONFIG_SENSORS_EMC6W201=m
CONFIG_SENSORS_SMSC47M1=m
CONFIG_SENSORS_SMSC47M192=m
CONFIG_SENSORS_SMSC47B397=m
CONFIG_SENSORS_SCH56XX_COMMON=m
CONFIG_SENSORS_SCH5627=m
CONFIG_SENSORS_SCH5636=m
# CONFIG_SENSORS_STTS751 is not set
CONFIG_SENSORS_SMM665=m
CONFIG_SENSORS_ADC128D818=m
CONFIG_SENSORS_ADS7828=m
CONFIG_SENSORS_ADS7871=m
CONFIG_SENSORS_AMC6821=m
CONFIG_SENSORS_INA209=m
# CONFIG_SENSORS_INA2XX is not set
CONFIG_SENSORS_INA3221=m
# CONFIG_SENSORS_TC74 is not set
CONFIG_SENSORS_THMC50=m
CONFIG_SENSORS_TMP102=m
CONFIG_SENSORS_TMP103=m
# CONFIG_SENSORS_TMP108 is not set
CONFIG_SENSORS_TMP401=m
CONFIG_SENSORS_TMP421=m
# CONFIG_SENSORS_TMP513 is not set
# CONFIG_SENSORS_VEXPRESS is not set
# CONFIG_SENSORS_VIA686A is not set
CONFIG_SENSORS_VT1211=m
# CONFIG_SENSORS_VT8231 is not set
CONFIG_SENSORS_W83773G=m
CONFIG_SENSORS_W83781D=m
CONFIG_SENSORS_W83791D=m
CONFIG_SENSORS_W83792D=m
CONFIG_SENSORS_W83793=m
CONFIG_SENSORS_W83795=m
CONFIG_SENSORS_W83795_FANCTRL=y
CONFIG_SENSORS_W83L785TS=m
CONFIG_SENSORS_W83L786NG=m
CONFIG_SENSORS_W83627HF=m
CONFIG_SENSORS_W83627EHF=m
CONFIG_THERMAL=y
# CONFIG_THERMAL_NETLINK is not set
CONFIG_THERMAL_STATISTICS=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
CONFIG_THERMAL_GOV_FAIR_SHARE=y
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_CPU_THERMAL is not set
# CONFIG_DEVFREQ_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
# CONFIG_IMX_THERMAL is not set
# CONFIG_IMX8MM_THERMAL is not set
# CONFIG_SUN8I_THERMAL is not set
CONFIG_ARMADA_THERMAL=m
# Broadcom thermal drivers
# CONFIG_BCM2711_THERMAL is not set
# CONFIG_BCM2835_THERMAL is not set
# end of Broadcom thermal drivers
# Texas Instruments thermal drivers
# CONFIG_TI_SOC_THERMAL is not set
# end of Texas Instruments thermal drivers
# Samsung thermal drivers
CONFIG_EXYNOS_THERMAL=y
# end of Samsung thermal drivers
# NVIDIA Tegra thermal drivers
# CONFIG_TEGRA_SOCTHERM is not set
# end of NVIDIA Tegra thermal drivers
# CONFIG_GENERIC_ADC_THERMAL is not set
# Qualcomm thermal drivers
CONFIG_QCOM_TSENS=m
# CONFIG_QCOM_SPMI_ADC_TM5 is not set
# CONFIG_QCOM_SPMI_TEMP_ALARM is not set
# CONFIG_QCOM_LMH is not set
# end of Qualcomm thermal drivers
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
CONFIG_WATCHDOG_SYSFS=y
# CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=m
CONFIG_GPIO_WATCHDOG=m
# CONFIG_MENZ069_WATCHDOG is not set
CONFIG_XILINX_WATCHDOG=m
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_MLX_WDT is not set
# CONFIG_ARM_SP805_WATCHDOG is not set
# CONFIG_ARMADA_37XX_WATCHDOG is not set
CONFIG_CADENCE_WATCHDOG=m
# CONFIG_FTWDT010_WATCHDOG is not set
CONFIG_S3C2410_WATCHDOG=m
# CONFIG_DW_WATCHDOG is not set
CONFIG_OMAP_WATCHDOG=m
CONFIG_ORION_WATCHDOG=y
CONFIG_SUNXI_WATCHDOG=m
# CONFIG_TS4800_WATCHDOG is not set
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_IMX2_WDT is not set
# CONFIG_IMX7ULP_WDT is not set
# CONFIG_TEGRA_WATCHDOG is not set
CONFIG_QCOM_WDT=m
# CONFIG_ARM_SMC_WATCHDOG is not set
# CONFIG_PM8916_WATCHDOG is not set
# CONFIG_ALIM7101_WDT is not set
# CONFIG_I6300ESB_WDT is not set
# CONFIG_BCM2835_WDT is not set
# CONFIG_MEN_A21_WDT is not set
# PCI-based Watchdog Cards
# CONFIG_PCIPCWATCHDOG is not set
# CONFIG_WDTPCI is not set
# USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_SSB_POSSIBLE=y
CONFIG_SSB=m
CONFIG_SSB_SPROM=y
CONFIG_SSB_BLOCKIO=y
CONFIG_SSB_PCIHOST_POSSIBLE=y
CONFIG_SSB_PCIHOST=y
CONFIG_SSB_B43_PCI_BRIDGE=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
CONFIG_SSB_SDIOHOST=y
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE=y
# CONFIG_SSB_DRIVER_GPIO is not set
CONFIG_BCMA_POSSIBLE=y
CONFIG_BCMA=m
CONFIG_BCMA_BLOCKIO=y
CONFIG_BCMA_HOST_PCI_POSSIBLE=y
CONFIG_BCMA_HOST_PCI=y
# CONFIG_BCMA_HOST_SOC is not set
CONFIG_BCMA_DRIVER_PCI=y
CONFIG_BCMA_DRIVER_GMAC_CMN=y
CONFIG_BCMA_DRIVER_GPIO=y
# CONFIG_BCMA_DEBUG is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
CONFIG_MFD_ATMEL_HLCDC=m
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
CONFIG_MFD_AC100=m
CONFIG_MFD_AXP20X=m
CONFIG_MFD_AXP20X_I2C=m
CONFIG_MFD_AXP20X_RSB=m
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
CONFIG_MFD_DLN2=m
# CONFIG_MFD_EXYNOS_LPASS is not set
# CONFIG_MFD_GATEWORKS_GSC is not set
CONFIG_MFD_MC13XXX=m
CONFIG_MFD_MC13XXX_SPI=m
CONFIG_MFD_MC13XXX_I2C=m
# CONFIG_MFD_MP2629 is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_MFD_HI6421_SPMI is not set
CONFIG_HTC_PASIC3=m
# CONFIG_HTC_I2CPLD is not set
# CONFIG_LPC_ICH is not set
# CONFIG_LPC_SCH is not set
# CONFIG_MFD_INTEL_PMT is not set
# CONFIG_MFD_IQS62X is not set
# CONFIG_MFD_JANZ_CMODIO is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
CONFIG_MFD_MAX77686=m
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6360 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_NTXEC is not set
# CONFIG_MFD_RETU is not set
CONFIG_MFD_PCF50633=m
CONFIG_PCF50633_ADC=m
CONFIG_PCF50633_GPIO=m
CONFIG_UCB1400_CORE=m
CONFIG_MFD_PM8XXX=m
# CONFIG_MFD_QCOM_RPM is not set
CONFIG_MFD_SPMI_PMIC=m
# CONFIG_MFD_RDC321X is not set
# CONFIG_MFD_RT4831 is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
CONFIG_MFD_RK808=m
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
CONFIG_MFD_SM501=m
# CONFIG_MFD_SM501_GPIO is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
CONFIG_MFD_TI_AM335X_TSCADC=m
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
CONFIG_MFD_OMAP_USB_HOST=y
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
CONFIG_TPS65010=m
CONFIG_TPS6507X=m
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
CONFIG_MFD_TPS65217=m
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
CONFIG_MFD_TPS65218=m
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
CONFIG_MFD_WL1273_CORE=m
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_VX855 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
CONFIG_MFD_WM8994=m
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_ROHM_BD957XMUF is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# CONFIG_MFD_ATC260X_I2C is not set
# CONFIG_MFD_QCOM_PM8008 is not set
CONFIG_MFD_VEXPRESS_SYSREG=y
# CONFIG_MFD_INTEL_M10_BMC is not set
# CONFIG_MFD_RSMU_I2C is not set
# CONFIG_MFD_RSMU_SPI is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
CONFIG_REGULATOR_ANATOP=y
CONFIG_REGULATOR_AXP20X=m
# CONFIG_REGULATOR_DA9121 is not set
# CONFIG_REGULATOR_DA9210 is not set
CONFIG_REGULATOR_DA9211=m
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_FAN53880 is not set
# CONFIG_REGULATOR_GPIO is not set
CONFIG_REGULATOR_ISL9305=m
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
CONFIG_REGULATOR_LTC3589=m
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8893 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
CONFIG_REGULATOR_MAX77686=m
# CONFIG_REGULATOR_MAX77802 is not set
# CONFIG_REGULATOR_MAX77826 is not set
CONFIG_REGULATOR_MC13XXX_CORE=m
CONFIG_REGULATOR_MC13783=m
CONFIG_REGULATOR_MC13892=m
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MP5416 is not set
# CONFIG_REGULATOR_MP8859 is not set
# CONFIG_REGULATOR_MP886X is not set
# CONFIG_REGULATOR_MPQ7920 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_MT6315 is not set
# CONFIG_REGULATOR_PBIAS is not set
# CONFIG_REGULATOR_PCA9450 is not set
# CONFIG_REGULATOR_PCF50633 is not set
# CONFIG_REGULATOR_PF8X00 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
CONFIG_REGULATOR_PV88060=m
# CONFIG_REGULATOR_PV88080 is not set
CONFIG_REGULATOR_PV88090=m
CONFIG_REGULATOR_PWM=m
CONFIG_REGULATOR_QCOM_SMD_RPM=m
# CONFIG_REGULATOR_QCOM_SPMI is not set
# CONFIG_REGULATOR_QCOM_USB_VBUS is not set
# CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set
CONFIG_REGULATOR_RK808=m
# CONFIG_REGULATOR_RT4801 is not set
# CONFIG_REGULATOR_RT6160 is not set
# CONFIG_REGULATOR_RT6245 is not set
# CONFIG_REGULATOR_RTQ2134 is not set
# CONFIG_REGULATOR_RTMV20 is not set
# CONFIG_REGULATOR_RTQ6752 is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_TI_ABB is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_SY8827N is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
CONFIG_REGULATOR_TPS65217=m
CONFIG_REGULATOR_TPS65218=m
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
# CONFIG_REGULATOR_VEXPRESS is not set
# CONFIG_REGULATOR_VQMMC_IPQ4019 is not set
# CONFIG_REGULATOR_WM8994 is not set
# CONFIG_REGULATOR_QCOM_LABIBB is not set
CONFIG_RC_CORE=m
CONFIG_RC_MAP=m
# CONFIG_LIRC is not set
CONFIG_RC_DECODERS=y
CONFIG_IR_NEC_DECODER=m
CONFIG_IR_RC5_DECODER=m
CONFIG_IR_RC6_DECODER=m
CONFIG_IR_JVC_DECODER=m
CONFIG_IR_SONY_DECODER=m
CONFIG_IR_SANYO_DECODER=m
CONFIG_IR_SHARP_DECODER=m
CONFIG_IR_MCE_KBD_DECODER=m
CONFIG_IR_XMP_DECODER=m
CONFIG_IR_IMON_DECODER=m
# CONFIG_IR_RCMM_DECODER is not set
CONFIG_RC_DEVICES=y
CONFIG_RC_ATI_REMOTE=m
CONFIG_IR_HIX5HD2=m
CONFIG_IR_IMON=m
CONFIG_IR_IMON_RAW=m
CONFIG_IR_MCEUSB=m
CONFIG_IR_REDRAT3=m
CONFIG_IR_STREAMZAP=m
CONFIG_IR_IGORPLUGUSB=m
CONFIG_IR_IGUANA=m
# CONFIG_IR_TTUSBIR is not set
CONFIG_RC_LOOPBACK=m
CONFIG_IR_GPIO_CIR=m
CONFIG_IR_SUNXI=m
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
# CONFIG_RC_XBOX_DVD is not set
# CONFIG_IR_TOY is not set
CONFIG_CEC_CORE=m
CONFIG_CEC_NOTIFIER=y
CONFIG_CEC_PIN=y
# CONFIG_MEDIA_CEC_RC is not set
# CONFIG_CEC_PIN_ERROR_INJ is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_SUPPORT=m
# CONFIG_MEDIA_SUPPORT_FILTER is not set
CONFIG_MEDIA_SUBDRV_AUTOSELECT=y
# Media device types
CONFIG_MEDIA_CAMERA_SUPPORT=y
CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
CONFIG_MEDIA_RADIO_SUPPORT=y
CONFIG_MEDIA_SDR_SUPPORT=y
CONFIG_MEDIA_PLATFORM_SUPPORT=y
CONFIG_MEDIA_TEST_SUPPORT=y
# end of Media device types
# Media core support
CONFIG_VIDEO_DEV=m
CONFIG_MEDIA_CONTROLLER=y
CONFIG_DVB_CORE=m
# end of Media core support
# Video4Linux options
CONFIG_VIDEO_V4L2=m
CONFIG_VIDEO_V4L2_I2C=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_VIDEO_TUNER=m
CONFIG_V4L2_MEM2MEM_DEV=m
CONFIG_V4L2_FLASH_LED_CLASS=m
CONFIG_V4L2_FWNODE=m
CONFIG_V4L2_ASYNC=m
CONFIG_VIDEOBUF_GEN=m
CONFIG_VIDEOBUF_VMALLOC=m
# end of Video4Linux options
# Media controller options
# CONFIG_MEDIA_CONTROLLER_DVB is not set
# end of Media controller options
# Digital TV options
# CONFIG_DVB_MMAP is not set
CONFIG_DVB_NET=y
CONFIG_DVB_MAX_ADAPTERS=8
# CONFIG_DVB_DYNAMIC_MINORS is not set
# CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
# CONFIG_DVB_ULE_DEBUG is not set
# end of Digital TV options
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=m
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
CONFIG_USB_GSPCA=m
CONFIG_USB_M5602=m
CONFIG_USB_STV06XX=m
CONFIG_USB_GL860=m
CONFIG_USB_GSPCA_BENQ=m
CONFIG_USB_GSPCA_CONEX=m
CONFIG_USB_GSPCA_CPIA1=m
CONFIG_USB_GSPCA_DTCS033=m
CONFIG_USB_GSPCA_ETOMS=m
CONFIG_USB_GSPCA_FINEPIX=m
CONFIG_USB_GSPCA_JEILINJ=m
CONFIG_USB_GSPCA_JL2005BCD=m
CONFIG_USB_GSPCA_KINECT=m
# CONFIG_USB_GSPCA_KONICA is not set
CONFIG_USB_GSPCA_MARS=m
CONFIG_USB_GSPCA_MR97310A=m
CONFIG_USB_GSPCA_NW80X=m
CONFIG_USB_GSPCA_OV519=m
CONFIG_USB_GSPCA_OV534=m
CONFIG_USB_GSPCA_OV534_9=m
CONFIG_USB_GSPCA_PAC207=m
CONFIG_USB_GSPCA_PAC7302=m
CONFIG_USB_GSPCA_PAC7311=m
CONFIG_USB_GSPCA_SE401=m
CONFIG_USB_GSPCA_SN9C2028=m
CONFIG_USB_GSPCA_SN9C20X=m
CONFIG_USB_GSPCA_SONIXB=m
CONFIG_USB_GSPCA_SONIXJ=m
CONFIG_USB_GSPCA_SPCA500=m
CONFIG_USB_GSPCA_SPCA501=m
CONFIG_USB_GSPCA_SPCA505=m
CONFIG_USB_GSPCA_SPCA506=m
CONFIG_USB_GSPCA_SPCA508=m
CONFIG_USB_GSPCA_SPCA561=m
# CONFIG_USB_GSPCA_SPCA1528 is not set
CONFIG_USB_GSPCA_SQ905=m
CONFIG_USB_GSPCA_SQ905C=m
# CONFIG_USB_GSPCA_SQ930X is not set
CONFIG_USB_GSPCA_STK014=m
# CONFIG_USB_GSPCA_STK1135 is not set
CONFIG_USB_GSPCA_STV0680=m
CONFIG_USB_GSPCA_SUNPLUS=m
CONFIG_USB_GSPCA_T613=m
CONFIG_USB_GSPCA_TOPRO=m
CONFIG_USB_GSPCA_TOUPTEK=m
CONFIG_USB_GSPCA_TV8532=m
CONFIG_USB_GSPCA_VC032X=m
CONFIG_USB_GSPCA_VICAM=m
# CONFIG_USB_GSPCA_XIRLINK_CIT is not set
CONFIG_USB_GSPCA_ZC3XX=m
# CONFIG_USB_PWC is not set
# CONFIG_VIDEO_CPIA2 is not set
CONFIG_USB_ZR364XX=m
CONFIG_USB_STKWEBCAM=m
CONFIG_USB_S2255=m
# CONFIG_VIDEO_USBTV is not set
# Analog TV USB devices
# CONFIG_VIDEO_PVRUSB2 is not set
# CONFIG_VIDEO_HDPVR is not set
# CONFIG_VIDEO_STK1160_COMMON is not set
# CONFIG_VIDEO_GO7007 is not set
# Analog/digital TV USB devices
# CONFIG_VIDEO_AU0828 is not set
CONFIG_VIDEO_CX231XX=m
CONFIG_VIDEO_CX231XX_RC=y
CONFIG_VIDEO_CX231XX_ALSA=m
CONFIG_VIDEO_CX231XX_DVB=m
CONFIG_VIDEO_TM6000=m
CONFIG_VIDEO_TM6000_ALSA=m
CONFIG_VIDEO_TM6000_DVB=m
# Digital TV USB devices
CONFIG_DVB_USB=m
# CONFIG_DVB_USB_DEBUG is not set
CONFIG_DVB_USB_DIB3000MC=m
CONFIG_DVB_USB_A800=m
CONFIG_DVB_USB_DIBUSB_MB=m
# CONFIG_DVB_USB_DIBUSB_MB_FAULTY is not set
CONFIG_DVB_USB_DIBUSB_MC=m
CONFIG_DVB_USB_DIB0700=m
CONFIG_DVB_USB_UMT_010=m
CONFIG_DVB_USB_CXUSB=m
# CONFIG_DVB_USB_CXUSB_ANALOG is not set
CONFIG_DVB_USB_M920X=m
CONFIG_DVB_USB_DIGITV=m
CONFIG_DVB_USB_VP7045=m
CONFIG_DVB_USB_VP702X=m
CONFIG_DVB_USB_GP8PSK=m
CONFIG_DVB_USB_NOVA_T_USB2=m
CONFIG_DVB_USB_TTUSB2=m
CONFIG_DVB_USB_DTT200U=m
CONFIG_DVB_USB_OPERA1=m
CONFIG_DVB_USB_AF9005=m
CONFIG_DVB_USB_AF9005_REMOTE=m
CONFIG_DVB_USB_PCTV452E=m
CONFIG_DVB_USB_DW2102=m
CONFIG_DVB_USB_CINERGY_T2=m
CONFIG_DVB_USB_DTV5100=m
CONFIG_DVB_USB_AZ6027=m
CONFIG_DVB_USB_TECHNISAT_USB2=m
CONFIG_DVB_USB_V2=m
CONFIG_DVB_USB_AF9015=m
CONFIG_DVB_USB_AF9035=m
CONFIG_DVB_USB_ANYSEE=m
CONFIG_DVB_USB_AU6610=m
CONFIG_DVB_USB_AZ6007=m
CONFIG_DVB_USB_CE6230=m
CONFIG_DVB_USB_EC168=m
CONFIG_DVB_USB_GL861=m
CONFIG_DVB_USB_LME2510=m
CONFIG_DVB_USB_MXL111SF=m
CONFIG_DVB_USB_RTL28XXU=m
CONFIG_DVB_USB_DVBSKY=m
# CONFIG_DVB_USB_ZD1301 is not set
# CONFIG_DVB_TTUSB_BUDGET is not set
# CONFIG_DVB_TTUSB_DEC is not set
# CONFIG_SMS_USB_DRV is not set
CONFIG_DVB_B2C2_FLEXCOP_USB=m
# CONFIG_DVB_B2C2_FLEXCOP_USB_DEBUG is not set
# CONFIG_DVB_AS102 is not set
# Webcam, TV (analog/digital) USB devices
CONFIG_VIDEO_EM28XX=m
CONFIG_VIDEO_EM28XX_V4L2=m
CONFIG_VIDEO_EM28XX_ALSA=m
CONFIG_VIDEO_EM28XX_DVB=m
CONFIG_VIDEO_EM28XX_RC=m
# Software defined radio USB devices
# CONFIG_USB_AIRSPY is not set
# CONFIG_USB_HACKRF is not set
# CONFIG_USB_MSI2500 is not set
# CONFIG_MEDIA_PCI_SUPPORT is not set
# CONFIG_RADIO_ADAPTERS is not set
CONFIG_VIDEO_CX2341X=m
CONFIG_VIDEO_TVEEPROM=m
CONFIG_TTPCI_EEPROM=m
CONFIG_CYPRESS_FIRMWARE=m
CONFIG_VIDEOBUF2_CORE=m
CONFIG_VIDEOBUF2_V4L2=m
CONFIG_VIDEOBUF2_MEMOPS=m
CONFIG_VIDEOBUF2_DMA_CONTIG=m
CONFIG_VIDEOBUF2_VMALLOC=m
CONFIG_DVB_B2C2_FLEXCOP=m
# CONFIG_V4L_PLATFORM_DRIVERS is not set
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_CODA is not set
# CONFIG_VIDEO_IMX_PXP is not set
# CONFIG_VIDEO_IMX8_JPEG is not set
CONFIG_VIDEO_MEM2MEM_DEINTERLACE=m
# CONFIG_VIDEO_SAMSUNG_S5P_G2D is not set
# CONFIG_VIDEO_SAMSUNG_S5P_JPEG is not set
# CONFIG_VIDEO_SAMSUNG_S5P_MFC is not set
CONFIG_VIDEO_SAMSUNG_EXYNOS_GSC=m
# CONFIG_VIDEO_SUN8I_DEINTERLACE is not set
# CONFIG_VIDEO_SUN8I_ROTATE is not set
# CONFIG_DVB_PLATFORM_DRIVERS is not set
# CONFIG_SDR_PLATFORM_DRIVERS is not set
# MMC/SDIO DVB adapters
# CONFIG_SMS_SDIO_DRV is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# CONFIG_DVB_TEST_DRIVERS is not set
# end of Media drivers
# Media ancillary drivers
CONFIG_MEDIA_ATTACH=y
# IR I2C driver auto-selected by 'Autoselect ancillary drivers'
CONFIG_VIDEO_IR_I2C=m
# Audio decoders, processors and mixers
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TDA1997X is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
CONFIG_VIDEO_MSP3400=m
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_UDA1342 is not set
# CONFIG_VIDEO_WM8775 is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# CONFIG_VIDEO_SONY_BTF_MPX is not set
# end of Audio decoders, processors and mixers
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# end of RDS decoders
# Video decoders
# CONFIG_VIDEO_ADV7180 is not set
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_ADV748X is not set
# CONFIG_VIDEO_ADV7604 is not set
# CONFIG_VIDEO_ADV7842 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_SAA7110 is not set
CONFIG_VIDEO_SAA711X=m
# CONFIG_VIDEO_TC358743 is not set
# CONFIG_VIDEO_TVP514X is not set
CONFIG_VIDEO_TVP5150=m
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_TW2804 is not set
# CONFIG_VIDEO_TW9903 is not set
# CONFIG_VIDEO_TW9906 is not set
# CONFIG_VIDEO_TW9910 is not set
# CONFIG_VIDEO_VPX3220 is not set
# CONFIG_VIDEO_MAX9286 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
CONFIG_VIDEO_CX25840=m
# end of Video decoders
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_AD9389B is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_THS8200 is not set
# end of Video encoders
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# end of Video improvement chips
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# end of Audio/Video compression chips
# SDR tuner chips
# CONFIG_SDR_MAX2175 is not set
# end of SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_M52790 is not set
# CONFIG_VIDEO_I2C is not set
# CONFIG_VIDEO_ST_MIPID02 is not set
# end of Miscellaneous helper chips
# Camera sensor devices
# CONFIG_VIDEO_HI556 is not set
# CONFIG_VIDEO_IMX208 is not set
# CONFIG_VIDEO_IMX214 is not set
# CONFIG_VIDEO_IMX219 is not set
# CONFIG_VIDEO_IMX258 is not set
# CONFIG_VIDEO_IMX274 is not set
# CONFIG_VIDEO_IMX290 is not set
# CONFIG_VIDEO_IMX319 is not set
# CONFIG_VIDEO_IMX334 is not set
# CONFIG_VIDEO_IMX335 is not set
# CONFIG_VIDEO_IMX355 is not set
# CONFIG_VIDEO_IMX412 is not set
# CONFIG_VIDEO_OV02A10 is not set
CONFIG_VIDEO_OV2640=m
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV2680 is not set
# CONFIG_VIDEO_OV2685 is not set
# CONFIG_VIDEO_OV5640 is not set
# CONFIG_VIDEO_OV5645 is not set
# CONFIG_VIDEO_OV5647 is not set
# CONFIG_VIDEO_OV5648 is not set
# CONFIG_VIDEO_OV6650 is not set
# CONFIG_VIDEO_OV5670 is not set
# CONFIG_VIDEO_OV5675 is not set
# CONFIG_VIDEO_OV5695 is not set
# CONFIG_VIDEO_OV7251 is not set
# CONFIG_VIDEO_OV772X is not set
# CONFIG_VIDEO_OV7640 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_OV7740 is not set
# CONFIG_VIDEO_OV8856 is not set
# CONFIG_VIDEO_OV8865 is not set
# CONFIG_VIDEO_OV9282 is not set
# CONFIG_VIDEO_OV9640 is not set
# CONFIG_VIDEO_OV9650 is not set
# CONFIG_VIDEO_OV13858 is not set
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_MT9M001 is not set
# CONFIG_VIDEO_MT9M032 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9P031 is not set
# CONFIG_VIDEO_MT9T001 is not set
# CONFIG_VIDEO_MT9T112 is not set
CONFIG_VIDEO_MT9V011=m
# CONFIG_VIDEO_MT9V032 is not set
# CONFIG_VIDEO_MT9V111 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# CONFIG_VIDEO_NOON010PC30 is not set
# CONFIG_VIDEO_M5MOLS is not set
# CONFIG_VIDEO_RDACM20 is not set
# CONFIG_VIDEO_RDACM21 is not set
# CONFIG_VIDEO_RJ54N1 is not set
# CONFIG_VIDEO_S5K6AA is not set
# CONFIG_VIDEO_S5K6A3 is not set
# CONFIG_VIDEO_S5K4ECGX is not set
# CONFIG_VIDEO_S5K5BAF is not set
# CONFIG_VIDEO_CCS is not set
# CONFIG_VIDEO_ET8EK8 is not set
# CONFIG_VIDEO_S5C73M3 is not set
# end of Camera sensor devices
# Lens drivers
# CONFIG_VIDEO_AD5820 is not set
# CONFIG_VIDEO_AK7375 is not set
# CONFIG_VIDEO_DW9714 is not set
# CONFIG_VIDEO_DW9768 is not set
# CONFIG_VIDEO_DW9807_VCM is not set
# end of Lens drivers
# Flash devices
# CONFIG_VIDEO_ADP1653 is not set
# CONFIG_VIDEO_LM3560 is not set
# CONFIG_VIDEO_LM3646 is not set
# end of Flash devices
# SPI helper chips
# CONFIG_VIDEO_GS1662 is not set
# end of SPI helper chips
# Media SPI Adapters
CONFIG_CXD2880_SPI_DRV=m
# end of Media SPI Adapters
CONFIG_MEDIA_TUNER=m
# Customize TV tuners
CONFIG_MEDIA_TUNER_SIMPLE=m
CONFIG_MEDIA_TUNER_TDA18250=m
CONFIG_MEDIA_TUNER_TDA8290=m
CONFIG_MEDIA_TUNER_TDA827X=m
CONFIG_MEDIA_TUNER_TDA18271=m
CONFIG_MEDIA_TUNER_TDA9887=m
CONFIG_MEDIA_TUNER_TEA5761=m
CONFIG_MEDIA_TUNER_TEA5767=m
# CONFIG_MEDIA_TUNER_MSI001 is not set
CONFIG_MEDIA_TUNER_MT20XX=m
CONFIG_MEDIA_TUNER_MT2060=m
CONFIG_MEDIA_TUNER_MT2063=m
CONFIG_MEDIA_TUNER_MT2266=m
# CONFIG_MEDIA_TUNER_MT2131 is not set
CONFIG_MEDIA_TUNER_QT1010=m
CONFIG_MEDIA_TUNER_XC2028=m
CONFIG_MEDIA_TUNER_XC5000=m
CONFIG_MEDIA_TUNER_XC4000=m
CONFIG_MEDIA_TUNER_MXL5005S=m
CONFIG_MEDIA_TUNER_MXL5007T=m
CONFIG_MEDIA_TUNER_MC44S803=m
CONFIG_MEDIA_TUNER_MAX2165=m
CONFIG_MEDIA_TUNER_TDA18218=m
CONFIG_MEDIA_TUNER_FC0011=m
CONFIG_MEDIA_TUNER_FC0012=m
CONFIG_MEDIA_TUNER_FC0013=m
CONFIG_MEDIA_TUNER_TDA18212=m
CONFIG_MEDIA_TUNER_E4000=m
CONFIG_MEDIA_TUNER_FC2580=m
# CONFIG_MEDIA_TUNER_M88RS6000T is not set
CONFIG_MEDIA_TUNER_TUA9001=m
CONFIG_MEDIA_TUNER_SI2157=m
CONFIG_MEDIA_TUNER_IT913X=m
CONFIG_MEDIA_TUNER_R820T=m
# CONFIG_MEDIA_TUNER_MXL301RF is not set
CONFIG_MEDIA_TUNER_QM1D1C0042=m
# CONFIG_MEDIA_TUNER_QM1D1B0004 is not set
# end of Customize TV tuners
# Customise DVB Frontends
# Multistandard (satellite) frontends
CONFIG_DVB_STB0899=m
CONFIG_DVB_STB6100=m
CONFIG_DVB_STV090x=m
# CONFIG_DVB_STV0910 is not set
CONFIG_DVB_STV6110x=m
# CONFIG_DVB_STV6111 is not set
# CONFIG_DVB_MXL5XX is not set
CONFIG_DVB_M88DS3103=m
# Multistandard (cable + terrestrial) frontends
CONFIG_DVB_DRXK=m
CONFIG_DVB_TDA18271C2DD=m
CONFIG_DVB_SI2165=m
CONFIG_DVB_MN88472=m
CONFIG_DVB_MN88473=m
# DVB-S (satellite) frontends
# CONFIG_DVB_CX24110 is not set
CONFIG_DVB_CX24123=m
CONFIG_DVB_MT312=m
# CONFIG_DVB_ZL10036 is not set
CONFIG_DVB_ZL10039=m
CONFIG_DVB_S5H1420=m
CONFIG_DVB_STV0288=m
CONFIG_DVB_STB6000=m
CONFIG_DVB_STV0299=m
CONFIG_DVB_STV6110=m
CONFIG_DVB_STV0900=m
# CONFIG_DVB_TDA8083 is not set
CONFIG_DVB_TDA10086=m
# CONFIG_DVB_TDA8261 is not set
# CONFIG_DVB_VES1X93 is not set
CONFIG_DVB_TUNER_ITD1000=m
CONFIG_DVB_TUNER_CX24113=m
CONFIG_DVB_TDA826X=m
# CONFIG_DVB_TUA6100 is not set
CONFIG_DVB_CX24116=m
# CONFIG_DVB_CX24117 is not set
CONFIG_DVB_CX24120=m
CONFIG_DVB_SI21XX=m
CONFIG_DVB_TS2020=m
CONFIG_DVB_DS3000=m
# CONFIG_DVB_MB86A16 is not set
CONFIG_DVB_TDA10071=m
# DVB-T (terrestrial) frontends
# CONFIG_DVB_SP887X is not set
# CONFIG_DVB_CX22700 is not set
CONFIG_DVB_CX22702=m
# CONFIG_DVB_S5H1432 is not set
CONFIG_DVB_DRXD=m
# CONFIG_DVB_L64781 is not set
CONFIG_DVB_TDA1004X=m
CONFIG_DVB_NXT6000=m
CONFIG_DVB_MT352=m
CONFIG_DVB_ZL10353=m
CONFIG_DVB_DIB3000MB=m
CONFIG_DVB_DIB3000MC=m
CONFIG_DVB_DIB7000M=m
CONFIG_DVB_DIB7000P=m
# CONFIG_DVB_DIB9000 is not set
CONFIG_DVB_TDA10048=m
CONFIG_DVB_AF9013=m
CONFIG_DVB_EC100=m
# CONFIG_DVB_STV0367 is not set
CONFIG_DVB_CXD2820R=m
CONFIG_DVB_CXD2841ER=m
CONFIG_DVB_RTL2830=m
CONFIG_DVB_RTL2832=m
CONFIG_DVB_RTL2832_SDR=m
CONFIG_DVB_SI2168=m
# CONFIG_DVB_ZD1301_DEMOD is not set
CONFIG_DVB_GP8PSK_FE=m
# CONFIG_DVB_CXD2880 is not set
# DVB-C (cable) frontends
# CONFIG_DVB_VES1820 is not set
# CONFIG_DVB_TDA10021 is not set
CONFIG_DVB_TDA10023=m
CONFIG_DVB_STV0297=m
# ATSC (North American/Korean Terrestrial/Cable DTV) frontends
CONFIG_DVB_NXT200X=m
# CONFIG_DVB_OR51211 is not set
# CONFIG_DVB_OR51132 is not set
CONFIG_DVB_BCM3510=m
CONFIG_DVB_LGDT330X=m
CONFIG_DVB_LGDT3305=m
CONFIG_DVB_LGDT3306A=m
CONFIG_DVB_LG2160=m
CONFIG_DVB_S5H1409=m
# CONFIG_DVB_AU8522_DTV is not set
# CONFIG_DVB_AU8522_V4L is not set
CONFIG_DVB_S5H1411=m
CONFIG_DVB_MXL692=m
# ISDB-T (terrestrial) frontends
CONFIG_DVB_S921=m
CONFIG_DVB_DIB8000=m
CONFIG_DVB_MB86A20S=m
# ISDB-S (satellite) & ISDB-T (terrestrial) frontends
CONFIG_DVB_TC90522=m
# CONFIG_DVB_MN88443X is not set
# Digital terrestrial only tuners/PLL
CONFIG_DVB_PLL=m
CONFIG_DVB_TUNER_DIB0070=m
CONFIG_DVB_TUNER_DIB0090=m
# SEC control devices for DVB-S
CONFIG_DVB_DRX39XYJ=m
# CONFIG_DVB_LNBH25 is not set
# CONFIG_DVB_LNBH29 is not set
CONFIG_DVB_LNBP21=m
CONFIG_DVB_LNBP22=m
# CONFIG_DVB_ISL6405 is not set
CONFIG_DVB_ISL6421=m
CONFIG_DVB_ISL6423=m
CONFIG_DVB_A8293=m
# CONFIG_DVB_LGS8GL5 is not set
CONFIG_DVB_LGS8GXX=m
CONFIG_DVB_ATBM8830=m
# CONFIG_DVB_TDA665x is not set
CONFIG_DVB_IX2505V=m
CONFIG_DVB_M88RS2000=m
CONFIG_DVB_AF9033=m
# CONFIG_DVB_HORUS3A is not set
# CONFIG_DVB_ASCOT2E is not set
# CONFIG_DVB_HELENE is not set
# Common Interface (EN50221) controller drivers
# CONFIG_DVB_CXD2099 is not set
CONFIG_DVB_SP2=m
# end of Customise DVB Frontends
# Tools to develop new frontends
# CONFIG_DVB_DUMMY_FE is not set
# end of Media ancillary drivers
# Graphics support
CONFIG_VGA_ARB=y
CONFIG_VGA_ARB_MAX_GPUS=16
CONFIG_TEGRA_HOST1X=m
CONFIG_TEGRA_HOST1X_FIREWALL=y
CONFIG_IMX_IPUV3_CORE=m
CONFIG_DRM=m
CONFIG_DRM_MIPI_DSI=y
CONFIG_DRM_DP_AUX_BUS=m
CONFIG_DRM_DP_AUX_CHARDEV=y
# CONFIG_DRM_DEBUG_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=m
# CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
CONFIG_DRM_DP_CEC=y
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
CONFIG_DRM_GEM_SHMEM_HELPER=y
CONFIG_DRM_SCHED=m
# I2C encoder or helper chips
CONFIG_DRM_I2C_CH7006=m
CONFIG_DRM_I2C_SIL164=m
CONFIG_DRM_I2C_NXP_TDA998X=m
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
CONFIG_DRM_HDLCD=m
# CONFIG_DRM_HDLCD_SHOW_UNDERRUN is not set
CONFIG_DRM_MALI_DISPLAY=m
CONFIG_DRM_KOMEDA=m
# end of ARM devices
# CONFIG_DRM_RADEON is not set
# CONFIG_DRM_AMDGPU is not set
# CONFIG_DRM_NOUVEAU is not set
CONFIG_DRM_VGEM=m
# CONFIG_DRM_VKMS is not set
CONFIG_DRM_EXYNOS=m
# CRTCs
CONFIG_DRM_EXYNOS_FIMD=y
CONFIG_DRM_EXYNOS5433_DECON=y
CONFIG_DRM_EXYNOS7_DECON=y
CONFIG_DRM_EXYNOS_MIXER=y
CONFIG_DRM_EXYNOS_VIDI=y
# Encoders and Bridges
CONFIG_DRM_EXYNOS_DPI=y
CONFIG_DRM_EXYNOS_DSI=y
CONFIG_DRM_EXYNOS_DP=y
CONFIG_DRM_EXYNOS_HDMI=y
CONFIG_DRM_EXYNOS_MIC=y
# Sub-drivers
# CONFIG_DRM_EXYNOS_G2D is not set
CONFIG_DRM_EXYNOS_IPP=y
CONFIG_DRM_EXYNOS_FIMC=y
CONFIG_DRM_EXYNOS_ROTATOR=y
CONFIG_DRM_EXYNOS_SCALER=y
CONFIG_DRM_UDL=m
# CONFIG_DRM_AST is not set
# CONFIG_DRM_MGAG200 is not set
CONFIG_DRM_ARMADA=m
# CONFIG_DRM_ATMEL_HLCDC is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
CONFIG_DRM_SUN4I=m
CONFIG_DRM_SUN4I_HDMI=m
CONFIG_DRM_SUN4I_HDMI_CEC=y
CONFIG_DRM_SUN4I_BACKEND=m
CONFIG_DRM_SUN6I_DSI=m
CONFIG_DRM_SUN8I_DW_HDMI=m
CONFIG_DRM_SUN8I_MIXER=m
CONFIG_DRM_SUN8I_TCON_TOP=m
CONFIG_DRM_OMAP=m
# CONFIG_OMAP2_DSS_DEBUG is not set
# CONFIG_OMAP2_DSS_DEBUGFS is not set
CONFIG_OMAP2_DSS_DPI=y
CONFIG_OMAP2_DSS_VENC=y
CONFIG_OMAP2_DSS_HDMI_COMMON=y
CONFIG_OMAP4_DSS_HDMI=y
CONFIG_OMAP4_DSS_HDMI_CEC=y
CONFIG_OMAP5_DSS_HDMI=y
CONFIG_OMAP2_DSS_SDI=y
CONFIG_OMAP2_DSS_DSI=y
CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
CONFIG_DRM_TILCDC=m
# CONFIG_DRM_QXL is not set
CONFIG_DRM_VIRTIO_GPU=m
CONFIG_DRM_MSM=m
CONFIG_DRM_MSM_GPU_STATE=y
# CONFIG_DRM_MSM_REGISTER_LOGGING is not set
# CONFIG_DRM_MSM_GPU_SUDO is not set
CONFIG_DRM_MSM_HDMI_HDCP=y
CONFIG_DRM_MSM_DP=y
CONFIG_DRM_MSM_DSI=y
CONFIG_DRM_MSM_DSI_28NM_PHY=y
CONFIG_DRM_MSM_DSI_20NM_PHY=y
CONFIG_DRM_MSM_DSI_28NM_8960_PHY=y
CONFIG_DRM_MSM_DSI_14NM_PHY=y
CONFIG_DRM_MSM_DSI_10NM_PHY=y
CONFIG_DRM_MSM_DSI_7NM_PHY=y
# CONFIG_DRM_FSL_DCU is not set
CONFIG_DRM_TEGRA=m
# CONFIG_DRM_TEGRA_DEBUG is not set
CONFIG_DRM_TEGRA_STAGING=y
CONFIG_DRM_STM=m
CONFIG_DRM_STM_DSI=m
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ABT_Y030XX067A is not set
CONFIG_DRM_PANEL_ARM_VERSATILE=m
# CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
# CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
# CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set
# CONFIG_DRM_PANEL_DSI_CM is not set
# CONFIG_DRM_PANEL_LVDS is not set
CONFIG_DRM_PANEL_SIMPLE=m
# CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
# CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
CONFIG_DRM_PANEL_ILITEK_IL9322=m
# CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_KHADAS_TS050 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
# CONFIG_DRM_PANEL_MANTIX_MLAF057WE51 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
CONFIG_DRM_PANEL_ORISETECH_OTM8009A=m
# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00=m
CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN=m
# CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
CONFIG_DRM_PANEL_RAYDIUM_RM68200=m
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
# CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03=m
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set
CONFIG_DRM_PANEL_SEIKO_43WVF1G=m
CONFIG_DRM_PANEL_SHARP_LQ101R1SX01=m
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
CONFIG_DRM_PANEL_SHARP_LS043T1LE01=m
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX424AKP is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
# CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
# CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set
# CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_CHIPONE_ICN6211 is not set
# CONFIG_DRM_CHRONTEL_CH7033 is not set
# CONFIG_DRM_DISPLAY_CONNECTOR is not set
# CONFIG_DRM_LONTIUM_LT8912B is not set
# CONFIG_DRM_LONTIUM_LT9611 is not set
# CONFIG_DRM_LONTIUM_LT9611UXC is not set
# CONFIG_DRM_ITE_IT66121 is not set
# CONFIG_DRM_LVDS_CODEC is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NWL_MIPI_DSI is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_PARADE_PS8640 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
CONFIG_DRM_SII9234=m
# CONFIG_DRM_SIMPLE_BRIDGE is not set
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358762 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
# CONFIG_DRM_TOSHIBA_TC358775 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI83 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_TI_TPD12S015 is not set
# CONFIG_DRM_ANALOGIX_ANX6345 is not set
CONFIG_DRM_ANALOGIX_ANX78XX=m
CONFIG_DRM_ANALOGIX_DP=m
# CONFIG_DRM_ANALOGIX_ANX7625 is not set
CONFIG_DRM_I2C_ADV7511=m
CONFIG_DRM_I2C_ADV7511_AUDIO=y
CONFIG_DRM_I2C_ADV7511_CEC=y
# CONFIG_DRM_CDNS_MHDP8546 is not set
CONFIG_DRM_DW_HDMI=m
CONFIG_DRM_DW_HDMI_AHB_AUDIO=m
CONFIG_DRM_DW_HDMI_I2S_AUDIO=m
CONFIG_DRM_DW_HDMI_CEC=m
CONFIG_DRM_DW_MIPI_DSI=m
# end of Display Interface Bridges
CONFIG_DRM_STI=m
CONFIG_DRM_IMX=m
CONFIG_DRM_IMX_PARALLEL_DISPLAY=m
CONFIG_DRM_IMX_TVE=m
CONFIG_DRM_IMX_LDB=m
CONFIG_DRM_IMX_HDMI=m
CONFIG_DRM_V3D=m
CONFIG_DRM_VC4=m
CONFIG_DRM_VC4_HDMI_CEC=y
CONFIG_DRM_ETNAVIV=m
CONFIG_DRM_ETNAVIV_THERMAL=y
CONFIG_DRM_MXS=y
CONFIG_DRM_MXSFB=m
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
CONFIG_DRM_GM12U320=m
CONFIG_DRM_SIMPLEDRM=m
# CONFIG_TINYDRM_HX8357D is not set
# CONFIG_TINYDRM_ILI9225 is not set
# CONFIG_TINYDRM_ILI9341 is not set
# CONFIG_TINYDRM_ILI9486 is not set
# CONFIG_TINYDRM_MI0283QT is not set
# CONFIG_TINYDRM_REPAPER is not set
# CONFIG_TINYDRM_ST7586 is not set
# CONFIG_TINYDRM_ST7735R is not set
# CONFIG_DRM_PL111 is not set
CONFIG_DRM_TVE200=m
CONFIG_DRM_LIMA=m
CONFIG_DRM_PANFROST=m
# CONFIG_DRM_MCDE is not set
CONFIG_DRM_TIDSS=m
CONFIG_DRM_GUD=m
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=m
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CFB_FILLRECT=m
CONFIG_FB_CFB_COPYAREA=m
CONFIG_FB_CFB_IMAGEBLIT=m
CONFIG_FB_SYS_FILLRECT=m
CONFIG_FB_SYS_COPYAREA=m
CONFIG_FB_SYS_IMAGEBLIT=m
CONFIG_FB_PROVIDE_GET_FB_UNMAPPED_AREA=y
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=m
CONFIG_FB_DEFERRED_IO=y
# CONFIG_FB_MODE_HELPERS is not set
CONFIG_FB_TILEBLITTING=y
# Frame buffer hardware drivers
# CONFIG_FB_CIRRUS is not set
# CONFIG_FB_PM2 is not set
# CONFIG_FB_ARMCLCD is not set
# CONFIG_FB_IMX is not set
# CONFIG_FB_CYBER2000 is not set
# CONFIG_FB_ASILIANT is not set
# CONFIG_FB_IMSTT is not set
# CONFIG_FB_UVESA is not set
# CONFIG_FB_EFI is not set
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_NVIDIA is not set
# CONFIG_FB_RIVA is not set
# CONFIG_FB_I740 is not set
# CONFIG_FB_MATROX is not set
# CONFIG_FB_RADEON is not set
# CONFIG_FB_ATY128 is not set
# CONFIG_FB_ATY is not set
# CONFIG_FB_S3 is not set
# CONFIG_FB_SAVAGE is not set
# CONFIG_FB_SIS is not set
# CONFIG_FB_NEOMAGIC is not set
# CONFIG_FB_KYRO is not set
# CONFIG_FB_3DFX is not set
# CONFIG_FB_VOODOO1 is not set
# CONFIG_FB_VT8623 is not set
# CONFIG_FB_TRIDENT is not set
# CONFIG_FB_ARK is not set
# CONFIG_FB_PM3 is not set
# CONFIG_FB_CARMINE is not set
# CONFIG_FB_SM501 is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_XILINX is not set
# CONFIG_FB_DA8XX is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_MB862XX is not set
# CONFIG_FB_MX3 is not set
# CONFIG_FB_SIMPLE is not set
# CONFIG_FB_SSD1307 is not set
# CONFIG_FB_SM712 is not set
# end of Frame buffer Devices
# Backlight & LCD device support
CONFIG_LCD_CLASS_DEVICE=m
CONFIG_LCD_L4F00242T03=m
CONFIG_LCD_LMS283GF05=m
CONFIG_LCD_LTV350QV=m
# CONFIG_LCD_ILI922X is not set
CONFIG_LCD_ILI9320=m
CONFIG_LCD_TDO24M=m
CONFIG_LCD_VGG2432A4=m
CONFIG_LCD_PLATFORM=m
CONFIG_LCD_AMS369FG06=m
CONFIG_LCD_LMS501KF03=m
CONFIG_LCD_HX8357=m
# CONFIG_LCD_OTM3225A is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_KTD253 is not set
CONFIG_BACKLIGHT_PWM=m
# CONFIG_BACKLIGHT_QCOM_WLED is not set
CONFIG_BACKLIGHT_ADP8860=m
# CONFIG_BACKLIGHT_ADP8870 is not set
CONFIG_BACKLIGHT_PCF50633=m
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_TPS65217 is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_BACKLIGHT_LED is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
# CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION=y
CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER=y
# end of Console display driver support
# CONFIG_LOGO is not set
# end of Graphics support
CONFIG_SOUND=m
CONFIG_SOUND_OSS_CORE=y
CONFIG_SOUND_OSS_CORE_PRECLAIM=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_PCM_ELD=y
CONFIG_SND_PCM_IEC958=y
CONFIG_SND_DMAENGINE_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_SEQ_DEVICE=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_PCM_TIMER=y
CONFIG_SND_HRTIMER=m
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_MAX_CARDS=8
# CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_PROC_FS=y
# CONFIG_SND_VERBOSE_PROCFS is not set
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_SEQUENCER_OSS=m
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_SEQ_MIDI_EVENT=m
CONFIG_SND_SEQ_MIDI=m
CONFIG_SND_SEQ_VIRMIDI=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_ALOOP=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
CONFIG_SND_AC97_POWER_SAVE=y
CONFIG_SND_AC97_POWER_SAVE_DEFAULT=0
CONFIG_SND_PCI=y
# CONFIG_SND_AD1889 is not set
# CONFIG_SND_ALS300 is not set
# CONFIG_SND_ALI5451 is not set
# CONFIG_SND_ATIIXP is not set
# CONFIG_SND_ATIIXP_MODEM is not set
# CONFIG_SND_AU8810 is not set
# CONFIG_SND_AU8820 is not set
# CONFIG_SND_AU8830 is not set
# CONFIG_SND_AW2 is not set
# CONFIG_SND_AZT3328 is not set
# CONFIG_SND_BT87X is not set
# CONFIG_SND_CA0106 is not set
# CONFIG_SND_CMIPCI is not set
# CONFIG_SND_OXYGEN is not set
# CONFIG_SND_CS4281 is not set
# CONFIG_SND_CS46XX is not set
# CONFIG_SND_CTXFI is not set
# CONFIG_SND_DARLA20 is not set
# CONFIG_SND_GINA20 is not set
# CONFIG_SND_LAYLA20 is not set
# CONFIG_SND_DARLA24 is not set
# CONFIG_SND_GINA24 is not set
# CONFIG_SND_LAYLA24 is not set
# CONFIG_SND_MONA is not set
# CONFIG_SND_MIA is not set
# CONFIG_SND_ECHO3G is not set
# CONFIG_SND_INDIGO is not set
# CONFIG_SND_INDIGOIO is not set
# CONFIG_SND_INDIGODJ is not set
# CONFIG_SND_INDIGOIOX is not set
# CONFIG_SND_INDIGODJX is not set
# CONFIG_SND_EMU10K1 is not set
# CONFIG_SND_EMU10K1X is not set
# CONFIG_SND_ENS1370 is not set
# CONFIG_SND_ENS1371 is not set
# CONFIG_SND_ES1938 is not set
# CONFIG_SND_ES1968 is not set
# CONFIG_SND_FM801 is not set
# CONFIG_SND_HDSP is not set
# CONFIG_SND_HDSPM is not set
# CONFIG_SND_ICE1712 is not set
# CONFIG_SND_ICE1724 is not set
# CONFIG_SND_INTEL8X0 is not set
# CONFIG_SND_INTEL8X0M is not set
# CONFIG_SND_KORG1212 is not set
# CONFIG_SND_LOLA is not set
# CONFIG_SND_MAESTRO3 is not set
# CONFIG_SND_MIXART is not set
# CONFIG_SND_NM256 is not set
# CONFIG_SND_PCXHR is not set
# CONFIG_SND_RIPTIDE is not set
# CONFIG_SND_RME32 is not set
# CONFIG_SND_RME96 is not set
# CONFIG_SND_RME9652 is not set
# CONFIG_SND_SE6X is not set
# CONFIG_SND_SONICVIBES is not set
# CONFIG_SND_TRIDENT is not set
# CONFIG_SND_VIA82XX is not set
# CONFIG_SND_VIA82XX_MODEM is not set
# CONFIG_SND_VIRTUOSO is not set
# CONFIG_SND_VX222 is not set
# CONFIG_SND_YMFPCI is not set
# HD-Audio
# CONFIG_SND_HDA_INTEL is not set
# CONFIG_SND_HDA_TEGRA is not set
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=4096
CONFIG_SND_ARM=y
CONFIG_SND_ARMAACI=m
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
CONFIG_SND_USB_UA101=m
CONFIG_SND_USB_CAIAQ=m
# CONFIG_SND_USB_CAIAQ_INPUT is not set
CONFIG_SND_USB_6FIRE=m
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
CONFIG_SND_USB_LINE6=m
CONFIG_SND_USB_POD=m
CONFIG_SND_USB_PODHD=m
CONFIG_SND_USB_TONEPORT=m
CONFIG_SND_USB_VARIAX=m
CONFIG_SND_SOC=m
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_ADI is not set
CONFIG_SND_SOC_AMD_ACP=m
CONFIG_SND_SOC_AMD_CZ_RT5645_MACH=m
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_BCM2835_SOC_I2S is not set
# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
CONFIG_SND_SOC_FSL_ASRC=m
CONFIG_SND_SOC_FSL_SAI=m
# CONFIG_SND_SOC_FSL_MQS is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
CONFIG_SND_SOC_FSL_SSI=m
CONFIG_SND_SOC_FSL_SPDIF=m
CONFIG_SND_SOC_FSL_ESAI=m
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_FSL_EASRC is not set
# CONFIG_SND_SOC_FSL_XCVR is not set
# CONFIG_SND_SOC_FSL_AUD2HTX is not set
# CONFIG_SND_SOC_FSL_RPMSG is not set
CONFIG_SND_SOC_IMX_PCM_DMA=m
CONFIG_SND_SOC_IMX_AUDMUX=m
CONFIG_SND_IMX_SOC=m
CONFIG_SND_SOC_IMX_PCM_FIQ=m
# SoC Audio support for Freescale i.MX boards:
CONFIG_SND_SOC_EUKREA_TLV320=m
CONFIG_SND_SOC_IMX_ES8328=m
CONFIG_SND_SOC_IMX_SGTL5000=m
CONFIG_SND_SOC_IMX_SPDIF=m
CONFIG_SND_SOC_FSL_ASOC_CARD=m
# CONFIG_SND_SOC_IMX_AUDMIX is not set
# CONFIG_SND_SOC_IMX_HDMI is not set
# CONFIG_SND_SOC_IMX_RPMSG is not set
# CONFIG_SND_SOC_IMX_CARD is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_KIRKWOOD_SOC is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
CONFIG_SND_SOC_QCOM=m
CONFIG_SND_SOC_LPASS_CPU=m
CONFIG_SND_SOC_LPASS_PLATFORM=m
CONFIG_SND_SOC_LPASS_IPQ806X=m
CONFIG_SND_SOC_STORM=m
# CONFIG_SND_SOC_APQ8016_SBC is not set
# CONFIG_SND_SOC_SC7180 is not set
CONFIG_SND_SOC_SAMSUNG=m
# CONFIG_SND_SAMSUNG_PCM is not set
# CONFIG_SND_SAMSUNG_SPDIF is not set
CONFIG_SND_SAMSUNG_I2S=m
# CONFIG_SND_SOC_SAMSUNG_SMDK_WM8994 is not set
# CONFIG_SND_SOC_SAMSUNG_SMDK_SPDIF is not set
# CONFIG_SND_SOC_SMDK_WM8994_PCM is not set
# CONFIG_SND_SOC_SNOW is not set
CONFIG_SND_SOC_ODROID=m
# CONFIG_SND_SOC_ARNDALE is not set
# CONFIG_SND_SOC_SAMSUNG_ARIES_WM8994 is not set
# CONFIG_SND_SOC_SAMSUNG_MIDAS_WM1811 is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=m
# CONFIG_SND_SUN8I_CODEC is not set
# CONFIG_SND_SUN8I_CODEC_ANALOG is not set
CONFIG_SND_SUN4I_I2S=m
CONFIG_SND_SUN4I_SPDIF=m
# end of Allwinner SoC Audio support
# Audio support for Texas Instruments SoCs
CONFIG_SND_SOC_TI_SDMA_PCM=m
# Texas Instruments DAI support for:
# CONFIG_SND_SOC_DAVINCI_MCASP is not set
# CONFIG_SND_SOC_OMAP_MCBSP is not set
# Audio support for boards with Texas Instruments SoCs
CONFIG_SND_SOC_OMAP_HDMI=m
# end of Audio support for Texas Instruments SoCs
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
CONFIG_SND_SOC_XTFPGA_I2S=m
CONFIG_SND_SOC_I2C_AND_SPI=m
# CODEC drivers
CONFIG_SND_SOC_WM_HUBS=m
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1372_I2C is not set
# CONFIG_SND_SOC_ADAU1372_SPI is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
CONFIG_SND_SOC_ADAU7002=m
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
CONFIG_SND_SOC_AK4458=m
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
CONFIG_SND_SOC_AK5558=m
# CONFIG_SND_SOC_ALC5623 is not set
CONFIG_SND_SOC_BD28623=m
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4234 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
CONFIG_SND_SOC_CS42XX8=m
CONFIG_SND_SOC_CS42XX8_I2C=m
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DA7213 is not set
# CONFIG_SND_SOC_DMIC is not set
CONFIG_SND_SOC_HDMI_CODEC=m
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
CONFIG_SND_SOC_ES8328=m
CONFIG_SND_SOC_ES8328_I2C=m
CONFIG_SND_SOC_ES8328_SPI=m
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_ICS43432 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
CONFIG_SND_SOC_MAX98090=m
CONFIG_SND_SOC_MAX98357A=m
# CONFIG_SND_SOC_MAX98504 is not set
CONFIG_SND_SOC_MAX9867=m
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
# CONFIG_SND_SOC_MAX98390 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_ANALOG is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
CONFIG_SND_SOC_PCM1789=m
CONFIG_SND_SOC_PCM1789_I2C=m
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
CONFIG_SND_SOC_PCM186X=m
CONFIG_SND_SOC_PCM186X_I2C=m
CONFIG_SND_SOC_PCM186X_SPI=m
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM5102A is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RK817 is not set
CONFIG_SND_SOC_RL6231=m
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5640 is not set
CONFIG_SND_SOC_RT5645=m
# CONFIG_SND_SOC_RT5659 is not set
CONFIG_SND_SOC_SGTL5000=m
CONFIG_SND_SOC_SIMPLE_AMPLIFIER=m
# CONFIG_SND_SOC_SIMPLE_MUX is not set
CONFIG_SND_SOC_SPDIF=m
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2518 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2764 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
CONFIG_SND_SOC_TAS6424=m
CONFIG_SND_SOC_TDA7419=m
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TFA989X is not set
CONFIG_SND_SOC_TLV320AIC23=m
CONFIG_SND_SOC_TLV320AIC23_I2C=m
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
CONFIG_SND_SOC_TLV320AIC32X4=m
CONFIG_SND_SOC_TLV320AIC32X4_I2C=m
CONFIG_SND_SOC_TLV320AIC32X4_SPI=m
# CONFIG_SND_SOC_TLV320AIC3X_I2C is not set
# CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
# CONFIG_SND_SOC_TLV320ADCX140 is not set
# CONFIG_SND_SOC_TS3A227E is not set
CONFIG_SND_SOC_TSCS42XX=m
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
CONFIG_SND_SOC_WM8960=m
CONFIG_SND_SOC_WM8962=m
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
CONFIG_SND_SOC_WM8994=m
# CONFIG_SND_SOC_ZL38060 is not set
CONFIG_SND_SOC_MAX9759=m
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_MT6660 is not set
# CONFIG_SND_SOC_NAU8315 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
CONFIG_SND_SOC_NAU8822=m
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# CONFIG_SND_SOC_LPASS_WSA_MACRO is not set
# CONFIG_SND_SOC_LPASS_VA_MACRO is not set
# CONFIG_SND_SOC_LPASS_RX_MACRO is not set
# CONFIG_SND_SOC_LPASS_TX_MACRO is not set
# end of CODEC drivers
CONFIG_SND_SIMPLE_CARD_UTILS=m
CONFIG_SND_SIMPLE_CARD=m
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
CONFIG_SND_VIRTIO=m
CONFIG_AC97_BUS=m
# HID support
CONFIG_HID=m
CONFIG_HID_BATTERY_STRENGTH=y
CONFIG_HIDRAW=y
CONFIG_UHID=m
CONFIG_HID_GENERIC=m
# Special HID drivers
# CONFIG_HID_A4TECH is not set
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=m
# CONFIG_HID_APPLEIR is not set
CONFIG_HID_ASUS=m
# CONFIG_HID_AUREAL is not set
# CONFIG_HID_BELKIN is not set
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_BIGBEN_FF is not set
# CONFIG_HID_CHERRY is not set
# CONFIG_HID_CHICONY is not set
# CONFIG_HID_CORSAIR is not set
CONFIG_HID_COUGAR=m
# CONFIG_HID_MACALLY is not set
CONFIG_HID_PRODIKEYS=m
CONFIG_HID_CMEDIA=m
# CONFIG_HID_CP2112 is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
# CONFIG_HID_CYPRESS is not set
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
CONFIG_HID_ELAN=m
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
# CONFIG_HID_EZKEY is not set
# CONFIG_HID_FT260 is not set
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_GLORIOUS is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_VIVALDI is not set
CONFIG_HID_GT683R=m
CONFIG_HID_KEYTOUCH=m
# CONFIG_HID_KYE is not set
CONFIG_HID_UCLOGIC=m
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
CONFIG_HID_ICADE=m
# CONFIG_HID_ITE is not set
CONFIG_HID_JABRA=m
# CONFIG_HID_TWINHAN is not set
# CONFIG_HID_KENSINGTON is not set
CONFIG_HID_LCPOWER=m
CONFIG_HID_LED=m
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=m
CONFIG_HID_LOGITECH_DJ=m
CONFIG_HID_LOGITECH_HIDPP=m
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_LOGIG940_FF=y
CONFIG_LOGIWHEELS_FF=y
CONFIG_HID_MAGICMOUSE=m
# CONFIG_HID_MALTRON is not set
CONFIG_HID_MAYFLASH=m
# CONFIG_HID_REDRAGON is not set
CONFIG_HID_MICROSOFT=m
# CONFIG_HID_MONTEREY is not set
CONFIG_HID_MULTITOUCH=m
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
CONFIG_HID_ORTEK=m
# CONFIG_HID_PANTHERLORD is not set
CONFIG_HID_PENMOUNT=m
# CONFIG_HID_PETALYNX is not set
CONFIG_HID_PICOLCD=m
CONFIG_HID_PICOLCD_FB=y
CONFIG_HID_PICOLCD_BACKLIGHT=y
CONFIG_HID_PICOLCD_LCD=y
CONFIG_HID_PICOLCD_LEDS=y
CONFIG_HID_PICOLCD_CIR=y
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PLAYSTATION is not set
CONFIG_HID_PRIMAX=m
# CONFIG_HID_RETRODE is not set
CONFIG_HID_ROCCAT=m
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
CONFIG_HID_SEMITEK=m
CONFIG_HID_SONY=m
CONFIG_SONY_FF=y
CONFIG_HID_SPEEDLINK=m
CONFIG_HID_STEAM=m
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
CONFIG_HID_RMI=m
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
CONFIG_HID_THINGM=m
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_U2FZERO is not set
CONFIG_HID_WACOM=m
CONFIG_HID_WIIMOTE=m
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
CONFIG_HID_ZYDACRON=m
CONFIG_HID_SENSOR_HUB=m
# CONFIG_HID_SENSOR_CUSTOM_SENSOR is not set
CONFIG_HID_ALPS=m
# CONFIG_HID_MCP2221 is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=m
# CONFIG_HID_PID is not set
CONFIG_USB_HIDDEV=y
# USB HID Boot Protocol drivers
# CONFIG_USB_KBD is not set
# CONFIG_USB_MOUSE is not set
# end of USB HID Boot Protocol drivers
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID_OF is not set
# CONFIG_I2C_HID_OF_GOODIX is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=m
CONFIG_USB_LED_TRIG=y
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_USB_CONN_GPIO is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=m
CONFIG_USB_PCI=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_FEW_INIT_RETRIES is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_OTG=y
# CONFIG_USB_OTG_PRODUCTLIST is not set
# CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set
# CONFIG_USB_OTG_FSM is not set
CONFIG_USB_LEDS_TRIGGER_USBPORT=m
CONFIG_USB_AUTOSUSPEND_DELAY=2
CONFIG_USB_MON=m
# USB Host Controller Drivers
CONFIG_USB_C67X00_HCD=m
CONFIG_USB_XHCI_HCD=m
# CONFIG_USB_XHCI_DBGCAP is not set
CONFIG_USB_XHCI_PCI=m
# CONFIG_USB_XHCI_PCI_RENESAS is not set
CONFIG_USB_XHCI_PLATFORM=m
CONFIG_USB_XHCI_MVEBU=m
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_PCI=m
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_OMAP=m
CONFIG_USB_EHCI_HCD_ORION=m
# CONFIG_USB_EHCI_TEGRA is not set
CONFIG_USB_EHCI_EXYNOS=m
CONFIG_USB_EHCI_HCD_PLATFORM=m
CONFIG_USB_OXU210HP_HCD=m
CONFIG_USB_ISP116X_HCD=m
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_HCD_PCI=m
# CONFIG_USB_OHCI_HCD_SSB is not set
CONFIG_USB_OHCI_EXYNOS=m
CONFIG_USB_OHCI_HCD_PLATFORM=m
# CONFIG_USB_UHCI_HCD is not set
CONFIG_USB_U132_HCD=m
CONFIG_USB_SL811_HCD=m
CONFIG_USB_SL811_HCD_ISO=y
CONFIG_USB_R8A66597_HCD=m
# CONFIG_USB_HCD_BCMA is not set
CONFIG_USB_HCD_SSB=m
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_TMC=m
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_REALTEK=m
CONFIG_REALTEK_AUTOPM=y
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_STORAGE_ENE_UB6250=m
CONFIG_USB_UAS=m
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
CONFIG_USBIP_CORE=m
CONFIG_USBIP_VHCI_HCD=m
CONFIG_USBIP_VHCI_HC_PORTS=8
CONFIG_USBIP_VHCI_NR_HCS=1
CONFIG_USBIP_HOST=m
# CONFIG_USBIP_VUDC is not set
# CONFIG_USBIP_DEBUG is not set
# CONFIG_USB_CDNS_SUPPORT is not set
CONFIG_USB_MUSB_HDRC=m
CONFIG_USB_MUSB_HOST=y
# CONFIG_USB_MUSB_GADGET is not set
# CONFIG_USB_MUSB_DUAL_ROLE is not set
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=m
# CONFIG_USB_MUSB_TUSB6010 is not set
# CONFIG_USB_MUSB_OMAP2PLUS is not set
# CONFIG_USB_MUSB_AM35X is not set
CONFIG_USB_MUSB_DSPS=m
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
CONFIG_USB_TI_CPPI41_DMA=y
# CONFIG_USB_DWC3 is not set
CONFIG_USB_DWC2=m
# CONFIG_USB_DWC2_HOST is not set
# Gadget/Dual-role mode requires USB Gadget support to be enabled
# CONFIG_USB_DWC2_PERIPHERAL is not set
CONFIG_USB_DWC2_DUAL_ROLE=y
# CONFIG_USB_DWC2_PCI is not set
# CONFIG_USB_DWC2_DEBUG is not set
# CONFIG_USB_DWC2_TRACK_MISSED_SOFS is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_SIMPLE is not set
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
# CONFIG_USB_SERIAL_F81232 is not set
# CONFIG_USB_SERIAL_F8153X is not set
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
# CONFIG_USB_SERIAL_METRO is not set
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7840=m
# CONFIG_USB_SERIAL_MXUPORT is not set
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QCAUX=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_SAFE=m
CONFIG_USB_SERIAL_SAFE_PADDED=y
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_WWAN=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_XSENS_MT=m
# CONFIG_USB_SERIAL_WISHBONE is not set
# CONFIG_USB_SERIAL_SSU100 is not set
CONFIG_USB_SERIAL_QT2=m
# CONFIG_USB_SERIAL_UPD78F0730 is not set
CONFIG_USB_SERIAL_XR=m
CONFIG_USB_SERIAL_DEBUG=m
# USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_ADUTUX=m
CONFIG_USB_SEVSEG=m
# CONFIG_USB_LEGOTOWER is not set
CONFIG_USB_LCD=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_FTDI_ELAN=m
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_APPLE_MFI_FASTCHARGE is not set
CONFIG_USB_SISUSBVGA=m
CONFIG_USB_LD=m
# CONFIG_USB_TRANCEVIBRATOR is not set
CONFIG_USB_IOWARRIOR=m
CONFIG_USB_TEST=m
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
CONFIG_USB_ISIGHTFW=m
# CONFIG_USB_YUREX is not set
CONFIG_USB_EZUSB_FX2=m
# CONFIG_USB_HUB_USB251XB is not set
CONFIG_USB_HSIC_USB3503=m
CONFIG_USB_HSIC_USB4604=m
# CONFIG_USB_LINK_LAYER_TEST is not set
# CONFIG_USB_CHAOSKEY is not set
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=m
CONFIG_AM335X_CONTROL_USB=m
CONFIG_AM335X_PHY_USB=m
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_MXS_PHY is not set
# CONFIG_USB_TEGRA_PHY is not set
# CONFIG_USB_ULPI is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=m
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_AMD5536UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_NET2280 is not set
# CONFIG_USB_GOKU is not set
# CONFIG_USB_EG20T is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_MAX3420_UDC is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
# CONFIG_USB_CONFIGFS is not set
# USB Gadget precomposed configurations
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_GADGET_TARGET is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_NOKIA is not set
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# CONFIG_USB_RAW_GADGET is not set
# end of USB Gadget precomposed configurations
CONFIG_TYPEC=m
# CONFIG_TYPEC_TCPM is not set
# CONFIG_TYPEC_UCSI is not set
CONFIG_TYPEC_TPS6598X=m
# CONFIG_TYPEC_HD3SS3220 is not set
# CONFIG_TYPEC_STUSB160X is not set
# CONFIG_TYPEC_QCOM_PMIC is not set
# USB Type-C Multiplexer/DeMultiplexer Switch support
CONFIG_TYPEC_MUX_PI3USB30532=m
# end of USB Type-C Multiplexer/DeMultiplexer Switch support
# USB Type-C Alternate Mode drivers
CONFIG_TYPEC_DP_ALTMODE=m
# CONFIG_TYPEC_NVIDIA_ALTMODE is not set
# end of USB Type-C Alternate Mode drivers
CONFIG_USB_ROLE_SWITCH=m
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
# CONFIG_PWRSEQ_SD8787 is not set
# CONFIG_PWRSEQ_SIMPLE is not set
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
CONFIG_SDIO_UART=m
CONFIG_MMC_TEST=m
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
CONFIG_MMC_ARMMMCI=m
CONFIG_MMC_QCOM_DML=y
CONFIG_MMC_STM32_SDMMC=y
CONFIG_MMC_SDHCI=y
CONFIG_MMC_SDHCI_IO_ACCESSORS=y
# CONFIG_MMC_SDHCI_PCI is not set
CONFIG_MMC_SDHCI_PLTFM=y
CONFIG_MMC_SDHCI_OF_ARASAN=m
# CONFIG_MMC_SDHCI_OF_ASPEED is not set
CONFIG_MMC_SDHCI_OF_AT91=m
CONFIG_MMC_SDHCI_OF_ESDHC=m
# CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
# CONFIG_MMC_SDHCI_CADENCE is not set
CONFIG_MMC_SDHCI_ESDHC_IMX=m
# CONFIG_MMC_SDHCI_TEGRA is not set
CONFIG_MMC_SDHCI_S3C=m
CONFIG_MMC_SDHCI_PXAV3=y
CONFIG_MMC_SDHCI_S3C_DMA=y
CONFIG_MMC_SDHCI_F_SDH30=m
# CONFIG_MMC_SDHCI_MILBEAUT is not set
# CONFIG_MMC_SDHCI_IPROC is not set
# CONFIG_MMC_OMAP is not set
CONFIG_MMC_OMAP_HS=m
CONFIG_MMC_SDHCI_MSM=m
CONFIG_MMC_MXC=m
# CONFIG_MMC_TIFM_SD is not set
CONFIG_MMC_MVSDIO=y
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_CB710 is not set
# CONFIG_MMC_VIA_SDMMC is not set
CONFIG_MMC_DW=m
CONFIG_MMC_DW_PLTFM=m
# CONFIG_MMC_DW_BLUEFIELD is not set
CONFIG_MMC_DW_EXYNOS=m
# CONFIG_MMC_DW_HI3798CV200 is not set
# CONFIG_MMC_DW_K3 is not set
# CONFIG_MMC_DW_PCI is not set
CONFIG_MMC_VUB300=m
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_REALTEK_USB=m
CONFIG_MMC_SUNXI=m
CONFIG_MMC_CQHCI=m
# CONFIG_MMC_HSQ is not set
# CONFIG_MMC_TOSHIBA_PCI is not set
# CONFIG_MMC_BCM2835 is not set
CONFIG_MMC_MTK=m
# CONFIG_MMC_SDHCI_XENON is not set
CONFIG_MMC_SDHCI_OMAP=m
# CONFIG_MMC_SDHCI_AM654 is not set
CONFIG_MMC_SDHCI_EXTERNAL_DMA=y
CONFIG_MEMSTICK=m
# CONFIG_MEMSTICK_DEBUG is not set
# MemoryStick drivers
# CONFIG_MEMSTICK_UNSAFE_RESUME is not set
CONFIG_MSPRO_BLOCK=m
# CONFIG_MS_BLOCK is not set
# MemoryStick Host Controller Drivers
# CONFIG_MEMSTICK_TIFM_MS is not set
# CONFIG_MEMSTICK_JMICRON_38X is not set
# CONFIG_MEMSTICK_R592 is not set
CONFIG_MEMSTICK_REALTEK_USB=m
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
CONFIG_LEDS_CLASS_FLASH=m
CONFIG_LEDS_CLASS_MULTICOLOR=m
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_AW2013 is not set
CONFIG_LEDS_BCM6328=m
CONFIG_LEDS_BCM6358=m
CONFIG_LEDS_CR0014114=m
# CONFIG_LEDS_EL15203000 is not set
CONFIG_LEDS_TURRIS_OMNIA=m
CONFIG_LEDS_LM3530=m
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
CONFIG_LEDS_LM3692X=m
CONFIG_LEDS_PCA9532=m
# CONFIG_LEDS_PCA9532_GPIO is not set
CONFIG_LEDS_GPIO=m
CONFIG_LEDS_LP3944=m
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP50XX is not set
# CONFIG_LEDS_LP55XX_COMMON is not set
# CONFIG_LEDS_LP8860 is not set
CONFIG_LEDS_PCA955X=m
# CONFIG_LEDS_PCA955X_GPIO is not set
# CONFIG_LEDS_PCA963X is not set
CONFIG_LEDS_DAC124S085=m
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
CONFIG_LEDS_BD2802=m
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_MC13783 is not set
# CONFIG_LEDS_TCA6507 is not set
CONFIG_LEDS_TLC591XX=m
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
CONFIG_LEDS_BLINKM=m
CONFIG_LEDS_SYSCON=y
CONFIG_LEDS_PM8058=m
CONFIG_LEDS_MLXREG=m
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# Flash and Torch LED drivers
CONFIG_LEDS_AAT1290=m
# CONFIG_LEDS_AS3645A is not set
# CONFIG_LEDS_KTD2692 is not set
CONFIG_LEDS_LM3601X=m
# CONFIG_LEDS_RT4505 is not set
# CONFIG_LEDS_RT8515 is not set
# CONFIG_LEDS_SGM3140 is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
CONFIG_LEDS_TRIGGER_TIMER=m
CONFIG_LEDS_TRIGGER_ONESHOT=m
CONFIG_LEDS_TRIGGER_DISK=y
CONFIG_LEDS_TRIGGER_MTD=y
CONFIG_LEDS_TRIGGER_HEARTBEAT=m
CONFIG_LEDS_TRIGGER_BACKLIGHT=m
CONFIG_LEDS_TRIGGER_CPU=y
CONFIG_LEDS_TRIGGER_ACTIVITY=m
CONFIG_LEDS_TRIGGER_GPIO=m
CONFIG_LEDS_TRIGGER_DEFAULT_ON=m
# iptables trigger is under Netfilter config (LED target)
CONFIG_LEDS_TRIGGER_TRANSIENT=m
# CONFIG_LEDS_TRIGGER_CAMERA is not set
CONFIG_LEDS_TRIGGER_PANIC=y
CONFIG_LEDS_TRIGGER_NETDEV=m
# CONFIG_LEDS_TRIGGER_PATTERN is not set
CONFIG_LEDS_TRIGGER_AUDIO=m
# CONFIG_LEDS_TRIGGER_TTY is not set
CONFIG_ACCESSIBILITY=y
# CONFIG_A11Y_BRAILLE_CONSOLE is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# end of Speakup console speech
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
# CONFIG_EDAC is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_MC146818_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
CONFIG_RTC_INTF_DEV_UIE_EMUL=y
CONFIG_RTC_DRV_TEST=m
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
CONFIG_RTC_DRV_AC100=m
CONFIG_RTC_DRV_DS1307=m
# CONFIG_RTC_DRV_DS1307_CENTURY is not set
CONFIG_RTC_DRV_DS1374=m
# CONFIG_RTC_DRV_DS1374_WDT is not set
CONFIG_RTC_DRV_DS1672=m
# CONFIG_RTC_DRV_HYM8563 is not set
CONFIG_RTC_DRV_MAX6900=m
CONFIG_RTC_DRV_MAX77686=m
CONFIG_RTC_DRV_RK808=m
CONFIG_RTC_DRV_RS5C372=m
CONFIG_RTC_DRV_ISL1208=m
# CONFIG_RTC_DRV_ISL12022 is not set
CONFIG_RTC_DRV_ISL12026=m
CONFIG_RTC_DRV_X1205=m
CONFIG_RTC_DRV_PCF8523=m
CONFIG_RTC_DRV_PCF85063=m
# CONFIG_RTC_DRV_PCF85363 is not set
CONFIG_RTC_DRV_PCF8563=m
CONFIG_RTC_DRV_PCF8583=m
CONFIG_RTC_DRV_M41T80=m
CONFIG_RTC_DRV_M41T80_WDT=y
CONFIG_RTC_DRV_BQ32K=m
CONFIG_RTC_DRV_S35390A=m
CONFIG_RTC_DRV_FM3130=m
CONFIG_RTC_DRV_RX8010=m
CONFIG_RTC_DRV_RX8581=m
CONFIG_RTC_DRV_RX8025=m
CONFIG_RTC_DRV_EM3027=m
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV3032 is not set
CONFIG_RTC_DRV_RV8803=m
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
CONFIG_RTC_DRV_M41T93=m
CONFIG_RTC_DRV_M41T94=m
# CONFIG_RTC_DRV_DS1302 is not set
CONFIG_RTC_DRV_DS1305=m
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
CONFIG_RTC_DRV_DS1390=m
CONFIG_RTC_DRV_MAX6916=m
CONFIG_RTC_DRV_R9701=m
CONFIG_RTC_DRV_RX4581=m
CONFIG_RTC_DRV_RS5C348=m
CONFIG_RTC_DRV_MAX6902=m
CONFIG_RTC_DRV_PCF2123=m
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
CONFIG_RTC_DRV_RV3029C2=m
CONFIG_RTC_DRV_RV3029_HWMON=y
# CONFIG_RTC_DRV_RX6110 is not set
# Platform RTC drivers
CONFIG_RTC_DRV_CMOS=y
CONFIG_RTC_DRV_DS1286=m
CONFIG_RTC_DRV_DS1511=m
CONFIG_RTC_DRV_DS1553=m
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
CONFIG_RTC_DRV_DS1742=m
CONFIG_RTC_DRV_DS2404=m
# CONFIG_RTC_DRV_EFI is not set
CONFIG_RTC_DRV_STK17TA8=m
CONFIG_RTC_DRV_M48T86=m
CONFIG_RTC_DRV_M48T35=m
CONFIG_RTC_DRV_M48T59=m
CONFIG_RTC_DRV_MSM6242=m
CONFIG_RTC_DRV_BQ4802=m
CONFIG_RTC_DRV_RP5C01=m
CONFIG_RTC_DRV_V3020=m
CONFIG_RTC_DRV_PCF50633=m
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_IMXDI=m
# CONFIG_RTC_DRV_OMAP is not set
CONFIG_HAVE_S3C_RTC=y
CONFIG_RTC_DRV_S3C=m
CONFIG_RTC_DRV_PL030=m
CONFIG_RTC_DRV_PL031=m
CONFIG_RTC_DRV_SUN6I=y
CONFIG_RTC_DRV_SUNXI=m
# CONFIG_RTC_DRV_MV is not set
CONFIG_RTC_DRV_ARMADA38X=y
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_MC13XXX is not set
CONFIG_RTC_DRV_PM8XXX=m
# CONFIG_RTC_DRV_TEGRA is not set
CONFIG_RTC_DRV_MXC=m
CONFIG_RTC_DRV_MXC_V2=m
CONFIG_RTC_DRV_SNVS=m
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
# CONFIG_RTC_DRV_GOLDFISH is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_ASYNC_TX_ENABLE_CHANNEL_SWITCH=y
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
# CONFIG_AMBA_PL08X is not set
# CONFIG_AXI_DMAC is not set
# CONFIG_DMA_BCM2835 is not set
CONFIG_DMA_SUN4I=m
# CONFIG_DMA_SUN6I is not set
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
CONFIG_IMX_DMA=m
CONFIG_IMX_SDMA=m
# CONFIG_INTEL_IDMA64 is not set
CONFIG_MV_XOR=y
# CONFIG_MXS_DMA is not set
CONFIG_MX3_IPU=y
CONFIG_MX3_IPU_IRQS=4
# CONFIG_NBPFAXI_DMA is not set
CONFIG_PL330_DMA=m
# CONFIG_PLX_DMA is not set
# CONFIG_TEGRA20_APB_DMA is not set
# CONFIG_XILINX_DMA is not set
# CONFIG_XILINX_ZYNQMP_DMA is not set
# CONFIG_XILINX_ZYNQMP_DPDMA is not set
# CONFIG_QCOM_ADM is not set
CONFIG_QCOM_BAM_DMA=m
# CONFIG_QCOM_GPI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_DW_DMAC_PCI is not set
# CONFIG_DW_EDMA is not set
# CONFIG_DW_EDMA_PCIE is not set
# CONFIG_SF_PDMA is not set
CONFIG_TI_CPPI41=m
CONFIG_TI_EDMA=y
CONFIG_DMA_OMAP=y
CONFIG_TI_DMA_CROSSBAR=y
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
CONFIG_DMATEST=m
CONFIG_DMA_ENGINE_RAID=y
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_MOVE_NOTIFY is not set
# CONFIG_DMABUF_DEBUG is not set
# CONFIG_DMABUF_SELFTESTS is not set
# CONFIG_DMABUF_HEAPS is not set
# CONFIG_DMABUF_SYSFS_STATS is not set
# end of DMABUF options
CONFIG_AUXDISPLAY=y
# CONFIG_HD44780 is not set
# CONFIG_IMG_ASCII_LCD is not set
# CONFIG_HT16K33 is not set
# CONFIG_LCD2S is not set
# CONFIG_ARM_CHARLCD is not set
# CONFIG_CHARLCD_BL_OFF is not set
# CONFIG_CHARLCD_BL_ON is not set
CONFIG_CHARLCD_BL_FLASH=y
CONFIG_UIO=m
# CONFIG_UIO_CIF is not set
CONFIG_UIO_PDRV_GENIRQ=m
# CONFIG_UIO_DMEM_GENIRQ is not set
# CONFIG_UIO_AEC is not set
# CONFIG_UIO_SERCOS3 is not set
# CONFIG_UIO_PCI_GENERIC is not set
# CONFIG_UIO_NETX is not set
# CONFIG_UIO_PRUSS is not set
# CONFIG_UIO_MF624 is not set
CONFIG_VFIO=m
CONFIG_VFIO_IOMMU_TYPE1=m
CONFIG_VFIO_VIRQFD=m
# CONFIG_VFIO_NOIOMMU is not set
CONFIG_VFIO_PCI_MMAP=y
CONFIG_VFIO_PCI_INTX=y
# CONFIG_VFIO_PCI is not set
CONFIG_VFIO_PLATFORM=m
CONFIG_VFIO_AMBA=m
# CONFIG_VFIO_PLATFORM_CALXEDAXGMAC_RESET is not set
# CONFIG_VFIO_PLATFORM_AMDXGBE_RESET is not set
# CONFIG_VFIO_MDEV is not set
CONFIG_VIRT_DRIVERS=y
CONFIG_VIRTIO=m
CONFIG_VIRTIO_PCI_LIB=m
CONFIG_VIRTIO_MENU=y
CONFIG_VIRTIO_PCI=m
CONFIG_VIRTIO_PCI_LEGACY=y
CONFIG_VIRTIO_BALLOON=m
# CONFIG_VIRTIO_INPUT is not set
CONFIG_VIRTIO_MMIO=m
# CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
CONFIG_VIRTIO_DMA_SHARED_BUFFER=m
# CONFIG_VDPA is not set
# CONFIG_VHOST_MENU is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
# CONFIG_COMEDI is not set
CONFIG_STAGING=y
# CONFIG_PRISM2_USB is not set
# CONFIG_RTL8192U is not set
CONFIG_RTLLIB=m
CONFIG_RTLLIB_CRYPTO_CCMP=m
CONFIG_RTLLIB_CRYPTO_TKIP=m
CONFIG_RTLLIB_CRYPTO_WEP=m
# CONFIG_RTL8192E is not set
# CONFIG_RTL8723BS is not set
# CONFIG_R8712U is not set
CONFIG_R8188EU=m
CONFIG_88EU_AP_MODE=y
# CONFIG_RTS5208 is not set
# CONFIG_VT6655 is not set
# CONFIG_VT6656 is not set
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16240 is not set
# end of Accelerometers
# Analog to digital converters
# CONFIG_AD7816 is not set
# CONFIG_AD7280 is not set
# end of Analog to digital converters
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# end of Analog digital bi-direction converters
# Capacitance to digital converters
# CONFIG_AD7746 is not set
# end of Capacitance to digital converters
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# end of Direct Digital Synthesis
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# end of Network Analyzer, Impedance Converters
# Active energy metering IC
# CONFIG_ADE7854 is not set
# end of Active energy metering IC
# Resolver to digital converters
# CONFIG_AD2S1210 is not set
# end of Resolver to digital converters
# end of IIO staging drivers
# CONFIG_FB_SM750 is not set
# CONFIG_MFD_NVEC is not set
# CONFIG_STAGING_MEDIA is not set
# Android
CONFIG_ASHMEM=y
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
CONFIG_GS_FPGABOOT=m
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
# CONFIG_FB_TFT is not set
# CONFIG_KS7010 is not set
# CONFIG_PI433 is not set
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_QLGE is not set
# CONFIG_WFX is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
CONFIG_MELLANOX_PLATFORM=y
CONFIG_MLXREG_HOTPLUG=m
CONFIG_MLXREG_IO=m
CONFIG_HAVE_CLK=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Clock driver for ARM Reference designs
CONFIG_ICST=y
# CONFIG_CLK_SP810 is not set
CONFIG_CLK_VEXPRESS_OSC=y
# end of Clock driver for ARM Reference designs
# CONFIG_LMK04832 is not set
CONFIG_COMMON_CLK_MAX77686=m
# CONFIG_COMMON_CLK_MAX9485 is not set
CONFIG_COMMON_CLK_RK808=m
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
CONFIG_COMMON_CLK_SI544=m
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_COMMON_CLK_AXI_CLKGEN is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_BCM2711_DVP=m
CONFIG_CLK_BCM2835=y
CONFIG_MXC_CLK=y
CONFIG_CLK_IMX5=y
CONFIG_CLK_IMX6Q=y
CONFIG_CLK_IMX6SL=y
CONFIG_CLK_IMX6SX=y
CONFIG_CLK_IMX6UL=y
CONFIG_CLK_IMX7D=y
# CONFIG_CLK_IMX8MM is not set
# CONFIG_CLK_IMX8MN is not set
# CONFIG_CLK_IMX8MP is not set
# CONFIG_CLK_IMX8MQ is not set
CONFIG_MVEBU_CLK_COMMON=y
CONFIG_MVEBU_CLK_COREDIV=y
CONFIG_ARMADA_38X_CLK=y
# CONFIG_COMMON_CLK_QCOM is not set
CONFIG_COMMON_CLK_SAMSUNG=y
CONFIG_EXYNOS_4_COMMON_CLK=y
CONFIG_EXYNOS_5250_COMMON_CLK=y
CONFIG_EXYNOS_5260_COMMON_CLK=y
CONFIG_EXYNOS_5410_COMMON_CLK=y
CONFIG_EXYNOS_5420_COMMON_CLK=y
CONFIG_EXYNOS_AUDSS_CLK_CON=y
CONFIG_EXYNOS_CLKOUT=y
CONFIG_CLK_SUNXI=y
CONFIG_CLK_SUNXI_CLOCKS=y
CONFIG_CLK_SUNXI_PRCM_SUN6I=y
CONFIG_CLK_SUNXI_PRCM_SUN8I=y
CONFIG_CLK_SUNXI_PRCM_SUN9I=y
CONFIG_SUNXI_CCU=y
CONFIG_SUN4I_A10_CCU=y
CONFIG_SUN5I_CCU=y
# CONFIG_SUN6I_A31_CCU is not set
# CONFIG_SUN8I_A23_CCU is not set
# CONFIG_SUN8I_A33_CCU is not set
CONFIG_SUN8I_A83T_CCU=y
CONFIG_SUN8I_H3_CCU=y
CONFIG_SUN8I_V3S_CCU=y
# CONFIG_SUN8I_DE2_CCU is not set
CONFIG_SUN8I_R40_CCU=y
CONFIG_SUN9I_A80_CCU=y
CONFIG_SUN8I_R_CCU=y
# CONFIG_COMMON_CLK_TI_ADPLL is not set
CONFIG_XILINX_VCU=m
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_OMAP_DM_TIMER=y
CONFIG_CLKSRC_MMIO=y
CONFIG_BCM2835_TIMER=y
CONFIG_ARMADA_370_XP_TIMER=y
CONFIG_SUN4I_TIMER=y
CONFIG_SUN5I_HSTIMER=y
CONFIG_CADENCE_TTC_TIMER=y
CONFIG_CLKSRC_TI_32K=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
CONFIG_ARM_GLOBAL_TIMER=y
CONFIG_ARM_GT_INITIAL_PRESCALER_VAL=2
CONFIG_ARM_TIMER_SP804=y
CONFIG_CLKSRC_ARM_GLOBAL_TIMER_SCHED_CLOCK=y
CONFIG_CLKSRC_EXYNOS_MCT=y
CONFIG_CLKSRC_SAMSUNG_PWM=y
CONFIG_CLKSRC_QCOM=y
CONFIG_CLKSRC_VERSATILE=y
CONFIG_CLKSRC_IMX_GPT=y
# CONFIG_MICROCHIP_PIT64B is not set
# end of Clock Source drivers
# CONFIG_MAILBOX is not set
CONFIG_IOMMU_IOVA=m
CONFIG_IOMMU_API=y
CONFIG_IOMMU_SUPPORT=y
# Generic IOMMU Pagetable Support
CONFIG_IOMMU_IO_PGTABLE=y
CONFIG_IOMMU_IO_PGTABLE_LPAE=y
# CONFIG_IOMMU_IO_PGTABLE_LPAE_SELFTEST is not set
# CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
# end of Generic IOMMU Pagetable Support
# CONFIG_IOMMU_DEBUGFS is not set
# CONFIG_IOMMU_DEFAULT_DMA_STRICT is not set
CONFIG_IOMMU_DEFAULT_DMA_LAZY=y
# CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
CONFIG_OF_IOMMU=y
# CONFIG_MSM_IOMMU is not set
# CONFIG_OMAP_IOMMU is not set
# CONFIG_SUN50I_IOMMU is not set
# CONFIG_TEGRA_IOMMU_SMMU is not set
# CONFIG_EXYNOS_IOMMU is not set
# CONFIG_ARM_SMMU is not set
# CONFIG_QCOM_IOMMU is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
CONFIG_RPMSG=m
# CONFIG_RPMSG_CHAR is not set
CONFIG_RPMSG_NS=m
CONFIG_RPMSG_VIRTIO=m
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Broadcom SoC drivers
CONFIG_BCM2835_POWER=y
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# CONFIG_QUICC_ENGINE is not set
CONFIG_FSL_GUTS=y
# CONFIG_FSL_RCPM is not set
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
CONFIG_IMX_GPCV2_PM_DOMAINS=y
# CONFIG_SOC_IMX8M is not set
# end of i.MX SoC drivers
# Enable LiteX SoC Builder specific drivers
# CONFIG_LITEX_SOC_CONTROLLER is not set
# end of Enable LiteX SoC Builder specific drivers
# Qualcomm SoC drivers
CONFIG_QCOM_COMMAND_DB=y
# CONFIG_QCOM_CPR is not set
# CONFIG_QCOM_GENI_SE is not set
CONFIG_QCOM_GSBI=m
# CONFIG_QCOM_LLCC is not set
CONFIG_QCOM_MDT_LOADER=m
# CONFIG_QCOM_OCMEM is not set
CONFIG_QCOM_RMTFS_MEM=m
# CONFIG_QCOM_RPMH is not set
# CONFIG_QCOM_RPMPD is not set
CONFIG_QCOM_SMD_RPM=m
CONFIG_QCOM_WCNSS_CTRL=m
# CONFIG_QCOM_APR is not set
# end of Qualcomm SoC drivers
CONFIG_SOC_SAMSUNG=y
CONFIG_EXYNOS_ASV_ARM=y
CONFIG_EXYNOS_CHIPID=y
CONFIG_EXYNOS_PMU=y
CONFIG_EXYNOS_PMU_ARM_DRIVERS=y
CONFIG_EXYNOS_PM_DOMAINS=y
CONFIG_EXYNOS_REGULATOR_COUPLER=y
CONFIG_SUNXI_MBUS=y
CONFIG_SUNXI_SRAM=y
# CONFIG_ARCH_TEGRA_2x_SOC is not set
# CONFIG_ARCH_TEGRA_3x_SOC is not set
# CONFIG_ARCH_TEGRA_114_SOC is not set
# CONFIG_ARCH_TEGRA_124_SOC is not set
CONFIG_SOC_TEGRA_FUSE=y
CONFIG_SOC_TI=y
# CONFIG_TI_PRUSS is not set
# Xilinx SoC drivers
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=m
CONFIG_DEVFREQ_GOV_PERFORMANCE=m
CONFIG_DEVFREQ_GOV_POWERSAVE=m
CONFIG_DEVFREQ_GOV_USERSPACE=m
CONFIG_DEVFREQ_GOV_PASSIVE=m
# DEVFREQ Drivers
CONFIG_ARM_EXYNOS_BUS_DEVFREQ=m
# CONFIG_ARM_IMX_BUS_DEVFREQ is not set
# CONFIG_ARM_IMX8M_DDRC_DEVFREQ is not set
CONFIG_PM_DEVFREQ_EVENT=y
# CONFIG_DEVFREQ_EVENT_EXYNOS_NOCP is not set
CONFIG_DEVFREQ_EVENT_EXYNOS_PPMU=m
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
# CONFIG_EXTCON_FSA9480 is not set
CONFIG_EXTCON_GPIO=m
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_PTN5150 is not set
# CONFIG_EXTCON_QCOM_SPMI_MISC is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_EXTCON_USBC_TUSB320 is not set
CONFIG_MEMORY=y
# CONFIG_ARM_PL172_MPMC is not set
# CONFIG_TI_EMIF is not set
CONFIG_OMAP_GPMC=y
# CONFIG_OMAP_GPMC_DEBUG is not set
# CONFIG_TI_EMIF_SRAM is not set
CONFIG_MVEBU_DEVBUS=y
CONFIG_PL353_SMC=y
CONFIG_SAMSUNG_MC=y
# CONFIG_EXYNOS5422_DMC is not set
CONFIG_EXYNOS_SROM=y
CONFIG_TEGRA_MC=y
CONFIG_IIO=m
CONFIG_IIO_BUFFER=y
# CONFIG_IIO_BUFFER_CB is not set
# CONFIG_IIO_BUFFER_DMA is not set
# CONFIG_IIO_BUFFER_DMAENGINE is not set
# CONFIG_IIO_BUFFER_HW_CONSUMER is not set
CONFIG_IIO_KFIFO_BUF=m
# CONFIG_IIO_TRIGGERED_BUFFER is not set
# CONFIG_IIO_CONFIGFS is not set
# CONFIG_IIO_TRIGGER is not set
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# CONFIG_IIO_TRIGGERED_EVENT is not set
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_ADXL372_SPI is not set
# CONFIG_ADXL372_I2C is not set
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMA400 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_BMI088_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_FXLS8962AF_I2C is not set
# CONFIG_FXLS8962AF_SPI is not set
# CONFIG_HID_SENSOR_ACCEL_3D is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_SCA3300 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7091R5 is not set
# CONFIG_AD7124 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7292 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7606_IFACE_PARALLEL is not set
# CONFIG_AD7606_IFACE_SPI is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7768_1 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD7949 is not set
# CONFIG_AD799X is not set
# CONFIG_ADI_AXI_ADC is not set
CONFIG_AXP20X_ADC=m
# CONFIG_AXP288_ADC is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_DLN2_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
# CONFIG_EXYNOS_ADC is not set
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_IMX7D_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2496 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX1241 is not set
# CONFIG_MAX1363 is not set
# CONFIG_MAX9611 is not set
# CONFIG_MCP320X is not set
# CONFIG_MCP3422 is not set
# CONFIG_MCP3911 is not set
# CONFIG_MEN_Z188_ADC is not set
# CONFIG_NAU7802 is not set
# CONFIG_QCOM_PM8XXX_XOADC is not set
# CONFIG_QCOM_SPMI_IADC is not set
# CONFIG_QCOM_SPMI_VADC is not set
# CONFIG_QCOM_SPMI_ADC5 is not set
# CONFIG_SD_ADC_MODULATOR is not set
# CONFIG_SUN4I_GPADC is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
# CONFIG_TI_ADS1015 is not set
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8344 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_ADS124S08 is not set
# CONFIG_TI_ADS131E08 is not set
CONFIG_TI_AM335X_ADC=m
# CONFIG_TI_TLC4541 is not set
# CONFIG_TI_TSC2046 is not set
# CONFIG_VF610_ADC is not set
# CONFIG_XILINX_XADC is not set
# Analog Front Ends
# CONFIG_IIO_RESCALE is not set
# end of Analog Front Ends
# Amplifiers
# CONFIG_AD8366 is not set
# CONFIG_HMC425 is not set
# end of Amplifiers
# CONFIG_AD7150 is not set
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_ATLAS_EZO_SENSOR is not set
# CONFIG_BME680 is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_SCD30_CORE is not set
# CONFIG_SENSIRION_SGP30 is not set
# CONFIG_SENSIRION_SGP40 is not set
# CONFIG_SPS30_I2C is not set
# CONFIG_VZ89X is not set
# end of Chemical Sensors
# Hid Sensor IIO Common
# CONFIG_HID_SENSOR_IIO_COMMON is not set
# end of Hid Sensor IIO Common
# IIO SCMI Sensors
# end of IIO SCMI Sensors
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# end of SSP Sensor Common
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_AD5686_SPI is not set
# CONFIG_AD5696_I2C is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5758 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5766 is not set
# CONFIG_AD5770R is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_DS4424 is not set
# CONFIG_LTC1660 is not set
# CONFIG_LTC2632 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_TI_DAC082S085 is not set
# CONFIG_TI_DAC5571 is not set
# CONFIG_TI_DAC7311 is not set
# CONFIG_TI_DAC7612 is not set
# CONFIG_VF610_DAC is not set
# end of Digital to analog converters
# IIO dummy driver
# end of IIO dummy driver
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# end of Clock Generator/Distribution
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# CONFIG_ADF4371 is not set
# end of Phase-Locked Loop (PLL) frequency synthesizers
# end of Frequency Synthesizers DDS/PLL
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS290 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_FXAS21002C is not set
# CONFIG_HID_SENSOR_GYRO_3D is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# end of Digital gyroscope sensors
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# end of Heart Rate Monitors
# end of Health Sensors
# Humidity sensors
# CONFIG_AM2315 is not set
# CONFIG_DHT11 is not set
# CONFIG_HDC100X is not set
# CONFIG_HDC2010 is not set
# CONFIG_HID_SENSOR_HUMIDITY is not set
# CONFIG_HTS221 is not set
# CONFIG_HTU21 is not set
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# end of Humidity sensors
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16460 is not set
# CONFIG_ADIS16475 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_FXOS8700_I2C is not set
# CONFIG_FXOS8700_SPI is not set
# CONFIG_KMX61 is not set
# CONFIG_INV_ICM42600_I2C is not set
# CONFIG_INV_ICM42600_SPI is not set
# CONFIG_INV_MPU6050_I2C is not set
# CONFIG_INV_MPU6050_SPI is not set
# CONFIG_IIO_ST_LSM6DSX is not set
# CONFIG_IIO_ST_LSM9DS0 is not set
# end of Inertial measurement units
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_ADUX1020 is not set
# CONFIG_AL3010 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_AS73211 is not set
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
# CONFIG_CM36651 is not set
# CONFIG_GP2AP002 is not set
# CONFIG_GP2AP020A00F is not set
# CONFIG_SENSORS_ISL29018 is not set
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_HID_SENSOR_ALS is not set
# CONFIG_HID_SENSOR_PROX is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_LV0104CS is not set
# CONFIG_MAX44000 is not set
# CONFIG_MAX44009 is not set
# CONFIG_NOA1305 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1133 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_ST_UVIS25 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL2591 is not set
# CONFIG_TSL2772 is not set
# CONFIG_TSL4531 is not set
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
# CONFIG_VCNL4035 is not set
# CONFIG_VEML6030 is not set
# CONFIG_VEML6070 is not set
# CONFIG_VL6180 is not set
# CONFIG_ZOPT2201 is not set
# end of Light sensors
# Magnetometer sensors
# CONFIG_AK8974 is not set
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_HID_SENSOR_MAGNETOMETER_3D is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# CONFIG_SENSORS_RM3100_I2C is not set
# CONFIG_SENSORS_RM3100_SPI is not set
# CONFIG_YAMAHA_YAS530 is not set
# end of Magnetometer sensors
# Multiplexers
# CONFIG_IIO_MUX is not set
# end of Multiplexers
# Inclinometer sensors
# CONFIG_HID_SENSOR_INCLINOMETER_3D is not set
# CONFIG_HID_SENSOR_DEVICE_ROTATION is not set
# end of Inclinometer sensors
# Linear and angular position sensors
# CONFIG_HID_SENSOR_CUSTOM_INTEL_HINGE is not set
# end of Linear and angular position sensors
# Digital potentiometers
# CONFIG_AD5110 is not set
# CONFIG_AD5272 is not set
# CONFIG_DS1803 is not set
# CONFIG_MAX5432 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4018 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_MCP41010 is not set
# CONFIG_TPL0102 is not set
# end of Digital potentiometers
# Digital potentiostats
# CONFIG_LMP91000 is not set
# end of Digital potentiostats
# Pressure sensors
# CONFIG_ABP060MG is not set
# CONFIG_BMP280 is not set
# CONFIG_DLHL60D is not set
# CONFIG_DPS310 is not set
# CONFIG_HID_SENSOR_PRESS is not set
# CONFIG_HP03 is not set
# CONFIG_ICP10100 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# end of Pressure sensors
# Lightning sensors
# CONFIG_AS3935 is not set
# end of Lightning sensors
# Proximity and distance sensors
# CONFIG_ISL29501 is not set
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_MB1232 is not set
# CONFIG_PING is not set
# CONFIG_RFD77402 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9310 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# CONFIG_VCNL3020 is not set
# CONFIG_VL53L0X_I2C is not set
# end of Proximity and distance sensors
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1200 is not set
# Temperature sensors
# CONFIG_LTC2983 is not set
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_HID_SENSOR_TEMP is not set
# CONFIG_MLX90614 is not set
# CONFIG_MLX90632 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TMP117 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
# CONFIG_MAX31856 is not set
# end of Temperature sensors
# CONFIG_NTB is not set
# CONFIG_VME_BUS is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_DEBUG is not set
# CONFIG_PWM_ATMEL_HLCDC_PWM is not set
# CONFIG_PWM_ATMEL_TCB is not set
# CONFIG_PWM_BCM2835 is not set
# CONFIG_PWM_DWC is not set
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_IMX1 is not set
# CONFIG_PWM_IMX27 is not set
# CONFIG_PWM_IMX_TPM is not set
# CONFIG_PWM_OMAP_DMTIMER is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SAMSUNG=m
CONFIG_PWM_SUN4I=m
# CONFIG_PWM_TEGRA is not set
# CONFIG_PWM_TIECAP is not set
# CONFIG_PWM_TIEHRPWM is not set
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
CONFIG_GIC_NON_BANKED=y
CONFIG_ARMADA_370_XP_IRQ=y
# CONFIG_AL_FIC is not set
CONFIG_BRCMSTB_L2_IRQ=y
CONFIG_OMAP_IRQCHIP=y
# CONFIG_TS4800_IRQ is not set
# CONFIG_XILINX_INTC is not set
CONFIG_IMX_GPCV2=y
CONFIG_QCOM_PDC=y
CONFIG_IMX_IRQSTEER=y
CONFIG_IMX_INTMUX=y
CONFIG_EXYNOS_IRQ_COMBINER=y
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_IMX7=y
# CONFIG_RESET_QCOM_AOSS is not set
# CONFIG_RESET_QCOM_PDC is not set
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
CONFIG_RESET_ZYNQ=y
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_GENERIC_PHY_MIPI_DPHY=y
# CONFIG_PHY_CAN_TRANSCEIVER is not set
CONFIG_PHY_SUN4I_USB=m
CONFIG_PHY_SUN6I_MIPI_DPHY=m
CONFIG_PHY_SUN9I_USB=m
# CONFIG_PHY_SUN50I_USB3 is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_TORRENT is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_CADENCE_SALVO is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
CONFIG_PHY_MVEBU_A3700_COMPHY=y
CONFIG_PHY_MVEBU_A3700_UTMI=y
CONFIG_PHY_MVEBU_A38X_COMPHY=m
# CONFIG_PHY_MVEBU_CP110_COMPHY is not set
# CONFIG_PHY_MVEBU_CP110_UTMI is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
CONFIG_PHY_QCOM_APQ8064_SATA=m
# CONFIG_PHY_QCOM_IPQ4019_USB is not set
CONFIG_PHY_QCOM_IPQ806X_SATA=m
# CONFIG_PHY_QCOM_PCIE2 is not set
# CONFIG_PHY_QCOM_QMP is not set
# CONFIG_PHY_QCOM_QUSB2 is not set
# CONFIG_PHY_QCOM_USB_SNPS_FEMTO_V2 is not set
# CONFIG_PHY_QCOM_USB_HS_28NM is not set
# CONFIG_PHY_QCOM_USB_SS is not set
# CONFIG_PHY_QCOM_IPQ806X_USB is not set
CONFIG_PHY_EXYNOS_DP_VIDEO=y
CONFIG_PHY_EXYNOS_MIPI_VIDEO=m
# CONFIG_PHY_EXYNOS_PCIE is not set
# CONFIG_PHY_SAMSUNG_UFS is not set
CONFIG_PHY_SAMSUNG_USB2=m
CONFIG_PHY_EXYNOS4210_USB2=y
CONFIG_PHY_EXYNOS4X12_USB2=y
CONFIG_PHY_EXYNOS5250_USB2=y
# CONFIG_PHY_EXYNOS5250_SATA is not set
# CONFIG_PHY_TEGRA_XUSB is not set
# CONFIG_PHY_DM816X_USB is not set
# CONFIG_OMAP_CONTROL_PHY is not set
# CONFIG_OMAP_USB2 is not set
# CONFIG_TI_PIPE3 is not set
CONFIG_PHY_TI_GMII_SEL=m
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
CONFIG_MCB=m
# CONFIG_MCB_PCI is not set
# CONFIG_MCB_LPC is not set
# Performance monitor support
CONFIG_ARM_CCI_PMU=y
CONFIG_ARM_CCI400_PMU=y
CONFIG_ARM_CCI5xx_PMU=y
CONFIG_ARM_CCN=y
CONFIG_ARM_PMU=y
# CONFIG_FSL_IMX8_DDR_PMU is not set
# end of Performance monitor support
CONFIG_RAS=y
# CONFIG_USB4 is not set
# Android
CONFIG_ANDROID=y
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
CONFIG_ANDROID_BINDER_IPC_SELFTEST=y
# end of Android
CONFIG_DAX=m
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
# CONFIG_NVMEM_IMX_IIM is not set
CONFIG_NVMEM_IMX_OCOTP=y
CONFIG_QCOM_QFPROM=m
# CONFIG_NVMEM_SPMI_SDAM is not set
CONFIG_NVMEM_SUNXI_SID=m
CONFIG_NVMEM_SNVS_LPGPR=m
CONFIG_NVMEM_RMEM=m
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
CONFIG_INTERCONNECT=y
# CONFIG_INTERCONNECT_IMX is not set
# CONFIG_INTERCONNECT_QCOM is not set
# CONFIG_INTERCONNECT_SAMSUNG is not set
# CONFIG_COUNTER is not set
# CONFIG_MOST is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
CONFIG_EXT2_FS=m
CONFIG_EXT2_FS_XATTR=y
CONFIG_EXT2_FS_POSIX_ACL=y
CONFIG_EXT2_FS_SECURITY=y
CONFIG_EXT3_FS=m
CONFIG_EXT3_FS_POSIX_ACL=y
CONFIG_EXT3_FS_SECURITY=y
CONFIG_EXT4_FS=m
CONFIG_EXT4_FS_POSIX_ACL=y
CONFIG_EXT4_FS_SECURITY=y
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=m
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=m
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
CONFIG_REISERFS_PROC_INFO=y
CONFIG_REISERFS_FS_XATTR=y
CONFIG_REISERFS_FS_POSIX_ACL=y
# CONFIG_REISERFS_FS_SECURITY is not set
CONFIG_JFS_FS=m
CONFIG_JFS_POSIX_ACL=y
CONFIG_JFS_SECURITY=y
# CONFIG_JFS_DEBUG is not set
CONFIG_JFS_STATISTICS=y
CONFIG_XFS_FS=m
CONFIG_XFS_SUPPORT_V4=y
CONFIG_XFS_QUOTA=y
CONFIG_XFS_POSIX_ACL=y
CONFIG_XFS_RT=y
CONFIG_XFS_ONLINE_SCRUB=y
# CONFIG_XFS_ONLINE_REPAIR is not set
# CONFIG_XFS_WARN is not set
# CONFIG_XFS_DEBUG is not set
CONFIG_GFS2_FS=m
CONFIG_GFS2_FS_LOCKING_DLM=y
CONFIG_OCFS2_FS=m
CONFIG_OCFS2_FS_O2CB=m
CONFIG_OCFS2_FS_USERSPACE_CLUSTER=m
# CONFIG_OCFS2_FS_STATS is not set
CONFIG_OCFS2_DEBUG_MASKLOG=y
# CONFIG_OCFS2_DEBUG_FS is not set
# CONFIG_BTRFS_FS is not set
CONFIG_NILFS2_FS=m
CONFIG_F2FS_FS=m
# CONFIG_F2FS_STAT_FS is not set
CONFIG_F2FS_FS_XATTR=y
CONFIG_F2FS_FS_POSIX_ACL=y
# CONFIG_F2FS_FS_SECURITY is not set
# CONFIG_F2FS_CHECK_FS is not set
# CONFIG_F2FS_FAULT_INJECTION is not set
CONFIG_F2FS_FS_COMPRESSION=y
CONFIG_F2FS_FS_LZO=y
CONFIG_F2FS_FS_LZORLE=y
CONFIG_F2FS_FS_LZ4=y
CONFIG_F2FS_FS_LZ4HC=y
CONFIG_F2FS_FS_ZSTD=y
CONFIG_F2FS_IOSTAT=y
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
CONFIG_EXPORTFS_BLOCK_OPS=y
CONFIG_FILE_LOCKING=y
CONFIG_FS_ENCRYPTION=y
CONFIG_FS_ENCRYPTION_ALGS=m
CONFIG_FS_VERITY=y
# CONFIG_FS_VERITY_DEBUG is not set
CONFIG_FS_VERITY_BUILTIN_SIGNATURES=y
CONFIG_FSNOTIFY=y
# CONFIG_DNOTIFY is not set
CONFIG_INOTIFY_USER=y
CONFIG_FANOTIFY=y
CONFIG_FANOTIFY_ACCESS_PERMISSIONS=y
CONFIG_QUOTA=y
CONFIG_QUOTA_NETLINK_INTERFACE=y
# CONFIG_PRINT_QUOTA_WARNING is not set
# CONFIG_QUOTA_DEBUG is not set
CONFIG_QUOTA_TREE=m
# CONFIG_QFMT_V1 is not set
CONFIG_QFMT_V2=m
CONFIG_QUOTACTL=y
CONFIG_AUTOFS4_FS=m
CONFIG_AUTOFS_FS=m
CONFIG_FUSE_FS=m
# CONFIG_CUSE is not set
CONFIG_VIRTIO_FS=m
CONFIG_OVERLAY_FS=m
# CONFIG_OVERLAY_FS_REDIRECT_DIR is not set
# CONFIG_OVERLAY_FS_REDIRECT_ALWAYS_FOLLOW is not set
# CONFIG_OVERLAY_FS_INDEX is not set
# CONFIG_OVERLAY_FS_METACOPY is not set
# Caches
CONFIG_NETFS_SUPPORT=m
CONFIG_NETFS_STATS=y
CONFIG_FSCACHE=m
CONFIG_FSCACHE_STATS=y
# CONFIG_FSCACHE_DEBUG is not set
CONFIG_CACHEFILES=m
# CONFIG_CACHEFILES_DEBUG is not set
# end of Caches
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
CONFIG_ZISOFS=y
CONFIG_UDF_FS=m
# end of CD-ROM/DVD Filesystems
# DOS/FAT/EXFAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="utf8"
# CONFIG_FAT_DEFAULT_UTF8 is not set
CONFIG_EXFAT_FS=m
CONFIG_EXFAT_DEFAULT_IOCHARSET="utf8"
CONFIG_NTFS_FS=m
# CONFIG_NTFS_DEBUG is not set
CONFIG_NTFS_RW=y
CONFIG_NTFS3_FS=m
CONFIG_NTFS3_LZX_XPRESS=y
CONFIG_NTFS3_FS_POSIX_ACL=y
# end of DOS/FAT/EXFAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_PROC_CHILDREN=y
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
CONFIG_TMPFS_POSIX_ACL=y
CONFIG_TMPFS_XATTR=y
CONFIG_MEMFD_CREATE=y
CONFIG_CONFIGFS_FS=m
CONFIG_EFIVAR_FS=m
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
CONFIG_ORANGEFS_FS=m
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_ECRYPT_FS=m
# CONFIG_ECRYPT_FS_MESSAGING is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
CONFIG_EFS_FS=m
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
CONFIG_JFFS2_SUMMARY=y
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_FS_POSIX_ACL=y
CONFIG_JFFS2_FS_SECURITY=y
CONFIG_JFFS2_COMPRESSION_OPTIONS=y
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_LZO=y
CONFIG_JFFS2_RTIME=y
CONFIG_JFFS2_RUBIN=y
# CONFIG_JFFS2_CMODE_NONE is not set
CONFIG_JFFS2_CMODE_PRIORITY=y
# CONFIG_JFFS2_CMODE_SIZE is not set
# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
CONFIG_UBIFS_FS=m
# CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
CONFIG_UBIFS_FS_LZO=y
CONFIG_UBIFS_FS_ZLIB=y
CONFIG_UBIFS_FS_ZSTD=y
# CONFIG_UBIFS_ATIME_SUPPORT is not set
CONFIG_UBIFS_FS_XATTR=y
CONFIG_UBIFS_FS_SECURITY=y
# CONFIG_UBIFS_FS_AUTHENTICATION is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=m
# CONFIG_SQUASHFS_FILE_CACHE is not set
CONFIG_SQUASHFS_FILE_DIRECT=y
# CONFIG_SQUASHFS_DECOMP_SINGLE is not set
# CONFIG_SQUASHFS_DECOMP_MULTI is not set
CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU=y
CONFIG_SQUASHFS_XATTR=y
CONFIG_SQUASHFS_ZLIB=y
CONFIG_SQUASHFS_LZ4=y
CONFIG_SQUASHFS_LZO=y
CONFIG_SQUASHFS_XZ=y
CONFIG_SQUASHFS_ZSTD=y
CONFIG_SQUASHFS_4K_DEVBLK_SIZE=y
# CONFIG_SQUASHFS_EMBEDDED is not set
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
CONFIG_MINIX_FS=m
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
CONFIG_ROMFS_FS=m
CONFIG_ROMFS_BACKED_BY_BLOCK=y
# CONFIG_ROMFS_BACKED_BY_MTD is not set
# CONFIG_ROMFS_BACKED_BY_BOTH is not set
CONFIG_ROMFS_ON_BLOCK=y
CONFIG_PSTORE=y
CONFIG_PSTORE_DEFAULT_KMSG_BYTES=10240
CONFIG_PSTORE_DEFLATE_COMPRESS=m
# CONFIG_PSTORE_LZO_COMPRESS is not set
# CONFIG_PSTORE_LZ4_COMPRESS is not set
# CONFIG_PSTORE_LZ4HC_COMPRESS is not set
# CONFIG_PSTORE_842_COMPRESS is not set
CONFIG_PSTORE_ZSTD_COMPRESS=y
CONFIG_PSTORE_COMPRESS=y
# CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT is not set
CONFIG_PSTORE_ZSTD_COMPRESS_DEFAULT=y
CONFIG_PSTORE_COMPRESS_DEFAULT="zstd"
# CONFIG_PSTORE_CONSOLE is not set
# CONFIG_PSTORE_PMSG is not set
# CONFIG_PSTORE_FTRACE is not set
CONFIG_PSTORE_RAM=m
# CONFIG_PSTORE_BLK is not set
# CONFIG_SYSV_FS is not set
CONFIG_UFS_FS=m
CONFIG_UFS_FS_WRITE=y
# CONFIG_UFS_DEBUG is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=m
CONFIG_NFS_V2=m
CONFIG_NFS_V3=m
# CONFIG_NFS_V3_ACL is not set
CONFIG_NFS_V4=m
# CONFIG_NFS_SWAP is not set
CONFIG_NFS_V4_1=y
CONFIG_NFS_V4_2=y
CONFIG_PNFS_FILE_LAYOUT=m
CONFIG_PNFS_BLOCK=m
CONFIG_PNFS_FLEXFILE_LAYOUT=m
CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
# CONFIG_NFS_V4_1_MIGRATION is not set
CONFIG_NFS_V4_SECURITY_LABEL=y
CONFIG_NFS_FSCACHE=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
# CONFIG_NFS_V4_2_READ_PLUS is not set
CONFIG_NFSD=m
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
CONFIG_NFSD_V4=y
CONFIG_NFSD_PNFS=y
CONFIG_NFSD_BLOCKLAYOUT=y
CONFIG_NFSD_SCSILAYOUT=y
CONFIG_NFSD_FLEXFILELAYOUT=y
# CONFIG_NFSD_V4_2_INTER_SSC is not set
# CONFIG_NFSD_V4_SECURITY_LABEL is not set
CONFIG_GRACE_PERIOD=m
CONFIG_LOCKD=m
CONFIG_LOCKD_V4=y
CONFIG_NFS_COMMON=y
CONFIG_NFS_V4_2_SSC_HELPER=y
CONFIG_SUNRPC=m
CONFIG_SUNRPC_GSS=m
CONFIG_SUNRPC_BACKCHANNEL=y
CONFIG_RPCSEC_GSS_KRB5=m
# CONFIG_SUNRPC_DISABLE_INSECURE_ENCTYPES is not set
# CONFIG_SUNRPC_DEBUG is not set
CONFIG_CEPH_FS=m
CONFIG_CEPH_FSCACHE=y
CONFIG_CEPH_FS_POSIX_ACL=y
# CONFIG_CEPH_FS_SECURITY_LABEL is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS2 is not set
CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
CONFIG_CIFS_UPCALL=y
CONFIG_CIFS_XATTR=y
CONFIG_CIFS_POSIX=y
CONFIG_CIFS_DEBUG=y
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
CONFIG_CIFS_DFS_UPCALL=y
CONFIG_CIFS_SWN_UPCALL=y
CONFIG_CIFS_FSCACHE=y
CONFIG_SMB_SERVER=m
CONFIG_SMB_SERVER_CHECK_CAP_NET_ADMIN=y
# CONFIG_SMB_SERVER_KERBEROS5 is not set
CONFIG_SMBFS_COMMON=m
CONFIG_CODA_FS=m
# CONFIG_AFS_FS is not set
CONFIG_9P_FS=m
CONFIG_9P_FSCACHE=y
CONFIG_9P_FS_POSIX_ACL=y
# CONFIG_9P_FS_SECURITY is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=m
CONFIG_NLS_CODEPAGE_737=m
CONFIG_NLS_CODEPAGE_775=m
CONFIG_NLS_CODEPAGE_850=m
CONFIG_NLS_CODEPAGE_852=m
CONFIG_NLS_CODEPAGE_855=m
CONFIG_NLS_CODEPAGE_857=m
CONFIG_NLS_CODEPAGE_860=m
CONFIG_NLS_CODEPAGE_861=m
CONFIG_NLS_CODEPAGE_862=m
CONFIG_NLS_CODEPAGE_863=m
CONFIG_NLS_CODEPAGE_864=m
CONFIG_NLS_CODEPAGE_865=m
CONFIG_NLS_CODEPAGE_866=m
CONFIG_NLS_CODEPAGE_869=m
CONFIG_NLS_CODEPAGE_936=m
CONFIG_NLS_CODEPAGE_950=m
CONFIG_NLS_CODEPAGE_932=m
CONFIG_NLS_CODEPAGE_949=m
CONFIG_NLS_CODEPAGE_874=m
CONFIG_NLS_ISO8859_8=m
CONFIG_NLS_CODEPAGE_1250=m
CONFIG_NLS_CODEPAGE_1251=m
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=m
CONFIG_NLS_ISO8859_2=m
CONFIG_NLS_ISO8859_3=m
CONFIG_NLS_ISO8859_4=m
CONFIG_NLS_ISO8859_5=m
CONFIG_NLS_ISO8859_6=m
CONFIG_NLS_ISO8859_7=m
CONFIG_NLS_ISO8859_9=m
CONFIG_NLS_ISO8859_13=m
CONFIG_NLS_ISO8859_14=m
CONFIG_NLS_ISO8859_15=m
CONFIG_NLS_KOI8_R=m
CONFIG_NLS_KOI8_U=m
CONFIG_NLS_MAC_ROMAN=m
CONFIG_NLS_MAC_CELTIC=m
CONFIG_NLS_MAC_CENTEURO=m
CONFIG_NLS_MAC_CROATIAN=m
CONFIG_NLS_MAC_CYRILLIC=m
CONFIG_NLS_MAC_GAELIC=m
CONFIG_NLS_MAC_GREEK=m
CONFIG_NLS_MAC_ICELAND=m
CONFIG_NLS_MAC_INUIT=m
CONFIG_NLS_MAC_ROMANIAN=m
CONFIG_NLS_MAC_TURKISH=m
CONFIG_NLS_UTF8=m
CONFIG_DLM=m
# CONFIG_DLM_DEBUG is not set
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
CONFIG_KEYS_REQUEST_CACHE=y
# CONFIG_PERSISTENT_KEYRINGS is not set
CONFIG_TRUSTED_KEYS=m
CONFIG_ENCRYPTED_KEYS=m
CONFIG_KEY_DH_OPERATIONS=y
CONFIG_SECURITY_DMESG_RESTRICT=y
CONFIG_SECURITY=y
CONFIG_SECURITYFS=y
CONFIG_SECURITY_NETWORK=y
# CONFIG_SECURITY_NETWORK_XFRM is not set
CONFIG_SECURITY_PATH=y
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
CONFIG_HARDENED_USERCOPY=y
CONFIG_HARDENED_USERCOPY_FALLBACK=y
# CONFIG_HARDENED_USERCOPY_PAGESPAN is not set
CONFIG_FORTIFY_SOURCE=y
# CONFIG_STATIC_USERMODEHELPER is not set
# CONFIG_SECURITY_SELINUX is not set
# CONFIG_SECURITY_SMACK is not set
# CONFIG_SECURITY_TOMOYO is not set
CONFIG_SECURITY_APPARMOR=y
CONFIG_SECURITY_APPARMOR_HASH=y
CONFIG_SECURITY_APPARMOR_HASH_DEFAULT=y
# CONFIG_SECURITY_APPARMOR_DEBUG is not set
# CONFIG_SECURITY_LOADPIN is not set
CONFIG_SECURITY_YAMA=y
# CONFIG_SECURITY_SAFESETID is not set
# CONFIG_SECURITY_LOCKDOWN_LSM is not set
CONFIG_SECURITY_LANDLOCK=y
# CONFIG_INTEGRITY is not set
# CONFIG_DEFAULT_SECURITY_APPARMOR is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
CONFIG_INIT_ON_ALLOC_DEFAULT_ON=y
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_XOR_BLOCKS=m
CONFIG_ASYNC_CORE=m
CONFIG_ASYNC_MEMCPY=m
CONFIG_ASYNC_XOR=m
CONFIG_ASYNC_PQ=m
CONFIG_ASYNC_RAID6_RECOV=m
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=m
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=m
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=m
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_AKCIPHER=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_KPP=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_USER=m
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_NULL2=y
CONFIG_CRYPTO_PCRYPT=m
CONFIG_CRYPTO_CRYPTD=m
CONFIG_CRYPTO_AUTHENC=m
CONFIG_CRYPTO_TEST=m
CONFIG_CRYPTO_SIMD=m
CONFIG_CRYPTO_ENGINE=m
# Public-key cryptography
CONFIG_CRYPTO_RSA=y
CONFIG_CRYPTO_DH=y
CONFIG_CRYPTO_ECC=m
CONFIG_CRYPTO_ECDH=m
CONFIG_CRYPTO_ECDSA=m
# CONFIG_CRYPTO_ECRDSA is not set
CONFIG_CRYPTO_SM2=m
CONFIG_CRYPTO_CURVE25519=m
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_CHACHA20POLY1305=m
CONFIG_CRYPTO_AEGIS128=m
CONFIG_CRYPTO_AEGIS128_SIMD=y
CONFIG_CRYPTO_SEQIV=m
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CFB=m
CONFIG_CRYPTO_CTR=m
CONFIG_CRYPTO_CTS=y
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_LRW=m
# CONFIG_CRYPTO_OFB is not set
CONFIG_CRYPTO_PCBC=m
CONFIG_CRYPTO_XTS=y
CONFIG_CRYPTO_KEYWRAP=m
CONFIG_CRYPTO_NHPOLY1305=m
CONFIG_CRYPTO_ADIANTUM=m
CONFIG_CRYPTO_ESSIV=m
# Hash modes
CONFIG_CRYPTO_CMAC=m
CONFIG_CRYPTO_HMAC=y
CONFIG_CRYPTO_XCBC=m
CONFIG_CRYPTO_VMAC=m
# Digest
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_CRC32=m
# CONFIG_CRYPTO_XXHASH is not set
CONFIG_CRYPTO_BLAKE2B=m
CONFIG_CRYPTO_CRCT10DIF=y
CONFIG_CRYPTO_GHASH=m
CONFIG_CRYPTO_POLY1305=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
CONFIG_CRYPTO_SHA512=y
CONFIG_CRYPTO_SHA3=m
CONFIG_CRYPTO_SM3=m
# CONFIG_CRYPTO_STREEBOG is not set
CONFIG_CRYPTO_WP512=m
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_BLOWFISH_COMMON=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST_COMMON=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_DES=m
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_CHACHA20=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_SM4=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
# Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_LZO=y
# CONFIG_CRYPTO_842 is not set
CONFIG_CRYPTO_LZ4=m
CONFIG_CRYPTO_LZ4HC=m
CONFIG_CRYPTO_ZSTD=y
# Random Number Generation
CONFIG_CRYPTO_ANSI_CPRNG=m
CONFIG_CRYPTO_DRBG_MENU=m
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=m
CONFIG_CRYPTO_JITTERENTROPY=m
CONFIG_CRYPTO_USER_API=m
CONFIG_CRYPTO_USER_API_HASH=m
CONFIG_CRYPTO_USER_API_SKCIPHER=m
CONFIG_CRYPTO_USER_API_RNG=m
# CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
CONFIG_CRYPTO_USER_API_AEAD=m
# CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE is not set
# CONFIG_CRYPTO_STATS is not set
CONFIG_CRYPTO_HASH_INFO=y
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_ALLWINNER=y
CONFIG_CRYPTO_DEV_SUN4I_SS=m
# CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN4I_SS_DEBUG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE is not set
# CONFIG_CRYPTO_DEV_SUN8I_SS is not set
# CONFIG_CRYPTO_DEV_HIFN_795X is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_COMMON=m
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC=m
CONFIG_CRYPTO_DEV_FSL_CAAM_AHASH_API_DESC=m
CONFIG_CRYPTO_DEV_FSL_CAAM=m
# CONFIG_CRYPTO_DEV_FSL_CAAM_DEBUG is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_JR=m
CONFIG_CRYPTO_DEV_FSL_CAAM_RINGSIZE=9
# CONFIG_CRYPTO_DEV_FSL_CAAM_INTC is not set
CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_AHASH_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_PKC_API=y
CONFIG_CRYPTO_DEV_FSL_CAAM_RNG_API=y
# CONFIG_CRYPTO_DEV_OMAP is not set
# CONFIG_CRYPTO_DEV_SAHARA is not set
CONFIG_CRYPTO_DEV_EXYNOS_RNG=m
# CONFIG_CRYPTO_DEV_S5P is not set
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
CONFIG_CRYPTO_DEV_MXS_DCP=m
CONFIG_CRYPTO_DEV_MARVELL=m
CONFIG_CRYPTO_DEV_MARVELL_CESA=m
CONFIG_CRYPTO_DEV_QCE=m
CONFIG_CRYPTO_DEV_QCE_SKCIPHER=y
CONFIG_CRYPTO_DEV_QCE_SHA=y
CONFIG_CRYPTO_DEV_QCE_AEAD=y
CONFIG_CRYPTO_DEV_QCE_ENABLE_ALL=y
# CONFIG_CRYPTO_DEV_QCE_ENABLE_SKCIPHER is not set
# CONFIG_CRYPTO_DEV_QCE_ENABLE_SHA is not set
# CONFIG_CRYPTO_DEV_QCE_ENABLE_AEAD is not set
CONFIG_CRYPTO_DEV_QCE_SW_MAX_LEN=512
CONFIG_CRYPTO_DEV_QCOM_RNG=m
CONFIG_CRYPTO_DEV_VIRTIO=m
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
CONFIG_ASYMMETRIC_KEY_TYPE=y
CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
# CONFIG_ASYMMETRIC_TPM_KEY_SUBTYPE is not set
CONFIG_X509_CERTIFICATE_PARSER=y
# CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
CONFIG_PKCS7_MESSAGE_PARSER=y
# CONFIG_PKCS7_TEST_KEY is not set
CONFIG_SIGNED_PE_FILE_VERIFICATION=y
# Certificates for signature checking
CONFIG_SYSTEM_TRUSTED_KEYRING=y
CONFIG_SYSTEM_TRUSTED_KEYS=""
# CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
CONFIG_SECONDARY_TRUSTED_KEYRING=y
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
CONFIG_BINARY_PRINTF=y
# Library routines
CONFIG_RAID6_PQ=m
CONFIG_RAID6_PQ_BENCHMARK=y
CONFIG_LINEAR_RANGES=y
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_CORDIC=m
# CONFIG_PRIME_NUMBERS is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_STMP_DEVICE=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
# Crypto library routines
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_LIB_ARC4=m
CONFIG_CRYPTO_ARCH_HAVE_LIB_BLAKE2S=y
CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
CONFIG_CRYPTO_LIB_CHACHA_GENERIC=m
CONFIG_CRYPTO_LIB_CHACHA=m
CONFIG_CRYPTO_ARCH_HAVE_LIB_CURVE25519=m
CONFIG_CRYPTO_LIB_CURVE25519_GENERIC=m
CONFIG_CRYPTO_LIB_CURVE25519=m
CONFIG_CRYPTO_LIB_DES=m
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
CONFIG_CRYPTO_ARCH_HAVE_LIB_POLY1305=m
CONFIG_CRYPTO_LIB_POLY1305_GENERIC=m
CONFIG_CRYPTO_LIB_POLY1305=m
CONFIG_CRYPTO_LIB_CHACHA20POLY1305=m
CONFIG_CRYPTO_LIB_SHA256=y
CONFIG_CRYPTO_LIB_SM4=m
# end of Crypto library routines
CONFIG_LIB_MEMNEQ=y
CONFIG_CRC_CCITT=m
CONFIG_CRC16=m
CONFIG_CRC_T10DIF=y
CONFIG_CRC_ITU_T=m
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
CONFIG_CRC64=m
# CONFIG_CRC4 is not set
CONFIG_CRC7=m
CONFIG_LIBCRC32C=m
CONFIG_CRC8=m
CONFIG_XXHASH=y
CONFIG_AUDIT_GENERIC=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_COMPRESS=m
CONFIG_LZ4HC_COMPRESS=m
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_COMPRESS=y
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_DECOMPRESS_ZSTD=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_REED_SOLOMON=m
CONFIG_REED_SOLOMON_ENC8=y
CONFIG_REED_SOLOMON_DEC8=y
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_DMA=y
CONFIG_DMA_OPS=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_REMAP=y
CONFIG_DMA_CMA=y
# CONFIG_DMA_PERNUMA_CMA is not set
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=48
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_DMA_MAP_BENCHMARK is not set
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
CONFIG_LRU_CACHE=m
CONFIG_CLZ_TAB=y
CONFIG_IRQ_POLL=y
CONFIG_MPILIB=y
CONFIG_DIMLIB=y
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_UCS2_STRING=y
CONFIG_HAVE_GENERIC_VDSO=y
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_GENERIC_VDSO_32=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# end of Library routines
CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
CONFIG_ASN1_ENCODER=m
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
# CONFIG_STACKTRACE_BUILD_ID is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=3
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DYNAMIC_DEBUG_CORE is not set
CONFIG_SYMBOLIC_ERRNAME=y
# CONFIG_DEBUG_BUGVERBOSE is not set
# end of printk and dmesg options
CONFIG_AS_HAS_NON_CONST_LEB128=y
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
CONFIG_ARCH_WANT_FRAME_POINTERS=y
CONFIG_FRAME_POINTER=y
# CONFIG_VMLINUX_MAP is not set
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
CONFIG_MAGIC_SYSRQ=y
CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
CONFIG_MAGIC_SYSRQ_SERIAL=y
CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
# CONFIG_DEBUG_FS_ALLOW_NONE is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_UBSAN is not set
# end of Generic Kernel Debugging Instruments
CONFIG_DEBUG_KERNEL=y
CONFIG_DEBUG_MISC=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_PAGE_OWNER is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_PAGE_REF is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_WX is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
CONFIG_DEBUG_KMEMLEAK=y
CONFIG_DEBUG_KMEMLEAK_MEM_POOL_SIZE=16000
# CONFIG_DEBUG_KMEMLEAK_TEST is not set
CONFIG_DEBUG_KMEMLEAK_DEFAULT_OFF=y
CONFIG_DEBUG_KMEMLEAK_AUTO_SCAN=y
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_PER_CPU_MAPS is not set
# CONFIG_DEBUG_KMAP_LOCAL is not set
# CONFIG_DEBUG_HIGHMEM is not set
CONFIG_HAVE_ARCH_KASAN=y
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
# CONFIG_KASAN is not set
# end of Memory Debugging
CONFIG_DEBUG_SHIRQ=y
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
CONFIG_SCHED_DEBUG=y
CONFIG_SCHED_INFO=y
CONFIG_SCHEDSTATS=y
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_RWSEMS is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# CONFIG_SCF_TORTURE_TEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_IRQFLAGS is not set
CONFIG_STACKTRACE=y
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
# Debug kernel data structures
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PLIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Debug kernel data structures
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_RCU_SCALE_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_REF_SCALE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=60
# CONFIG_RCU_TRACE is not set
# CONFIG_RCU_EQS_DEBUG is not set
# end of RCU Debugging
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
CONFIG_LATENCYTOP=y
CONFIG_NOP_TRACER=y
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_RING_BUFFER=y
CONFIG_EVENT_TRACING=y
CONFIG_CONTEXT_SWITCH_TRACER=y
CONFIG_TRACING=y
CONFIG_GENERIC_TRACER=y
CONFIG_TRACING_SUPPORT=y
CONFIG_FTRACE=y
# CONFIG_BOOTTIME_TRACING is not set
CONFIG_FUNCTION_TRACER=y
CONFIG_FUNCTION_GRAPH_TRACER=y
CONFIG_DYNAMIC_FTRACE=y
CONFIG_DYNAMIC_FTRACE_WITH_REGS=y
# CONFIG_FUNCTION_PROFILER is not set
# CONFIG_STACK_TRACER is not set
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_HWLAT_TRACER is not set
# CONFIG_OSNOISE_TRACER is not set
# CONFIG_TIMERLAT_TRACER is not set
CONFIG_FTRACE_SYSCALLS=y
# CONFIG_TRACER_SNAPSHOT is not set
CONFIG_BRANCH_PROFILE_NONE=y
# CONFIG_PROFILE_ANNOTATED_BRANCHES is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
CONFIG_KPROBE_EVENTS=y
# CONFIG_KPROBE_EVENTS_ON_NOTRACE is not set
CONFIG_UPROBE_EVENTS=y
CONFIG_BPF_EVENTS=y
CONFIG_DYNAMIC_EVENTS=y
CONFIG_PROBE_EVENTS=y
CONFIG_FTRACE_MCOUNT_RECORD=y
CONFIG_FTRACE_MCOUNT_USE_CC=y
# CONFIG_SYNTH_EVENTS is not set
# CONFIG_HIST_TRIGGERS is not set
# CONFIG_TRACE_EVENT_INJECT is not set
# CONFIG_TRACEPOINT_BENCHMARK is not set
# CONFIG_RING_BUFFER_BENCHMARK is not set
# CONFIG_TRACE_EVAL_MAP_FILE is not set
# CONFIG_FTRACE_RECORD_RECURSION is not set
# CONFIG_FTRACE_STARTUP_TEST is not set
# CONFIG_RING_BUFFER_STARTUP_TEST is not set
# CONFIG_RING_BUFFER_VALIDATE_TIME_DELTAS is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
# CONFIG_KPROBE_EVENT_GEN_TEST is not set
# CONFIG_SAMPLES is not set
CONFIG_STRICT_DEVMEM=y
CONFIG_IO_STRICT_DEVMEM=y
# arm Debugging
# CONFIG_ARM_PTDUMP_DEBUGFS is not set
CONFIG_UNWINDER_FRAME_POINTER=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_ARM_KPROBES_TEST is not set
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# end of arm Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
# CONFIG_RUNTIME_TESTING_MENU is not set
CONFIG_ARCH_USE_MEMTEST=y
# CONFIG_MEMTEST is not set
# end of Kernel Testing and Coverage
# end of Kernel hacking
