Hi, I downloaded the latest medkit to reset a Turris Omnia (original model with 1 GiB of RAM) which I hadn’t used in a while. Configured all the basics through the web interface then.
After that I attempted opkg update
and was immediately met with errors:
root@turris:~# opkg update
Downloading https://repo.turris.cz/hbl/omnia/packages/core/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_core
Downloading https://repo.turris.cz/hbl/omnia/packages/core/Packages.sig
Signature check failed.
Remove wrong Signature file.
Downloading https://repo.turris.cz/hbl/omnia/packages/base/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_base
Downloading https://repo.turris.cz/hbl/omnia/packages/base/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/cesnet/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_cesnet
Downloading https://repo.turris.cz/hbl/omnia/packages/cesnet/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_luci
Downloading https://repo.turris.cz/hbl/omnia/packages/luci/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/node/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_node
Downloading https://repo.turris.cz/hbl/omnia/packages/node/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_packages
Downloading https://repo.turris.cz/hbl/omnia/packages/packages/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_routing
Downloading https://repo.turris.cz/hbl/omnia/packages/routing/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_telephony
Downloading https://repo.turris.cz/hbl/omnia/packages/telephony/Packages.sig
Downloading https://repo.turris.cz/hbl/omnia/packages/turrispackages/Packages.gz
Updated list of available packages in /var/opkg-lists/turrisos_turrispackages
Downloading https://repo.turris.cz/hbl/omnia/packages/turrispackages/Packages.sig
Upon further investigation and finding a script (and unfortunately also removing wget-ssl
based on advice in the OpenWRT forum), I was able to investigate this a little further.
I manually downloaded the following two files into /tmp
wget https://repo.turris.cz/hbl/omnia/packages/turrispackages/Packages.{gz,sig}
… and attempted the steps evident from said script, after unpacking Packages
from Packages.gz
The result was the following error:
# usign -V -P /etc/opkg/keys -m /tmp/Packages
Cannot open file '/etc/opkg/keys/b4140d4dba7ec90e' for reading
which to me suggests that there should be a key with that fingerprint/ID (i.e. b4140d4dba7ec90e
) which isn’t present on my system.
Where does this key come from? What’s the procedure to establish trust with previously not known keys?
Anyway, I think it suggests that there is an issue with the image flashed by the medkit, since it’s at least unusual that a mere opkg update
should fail right after a fresh installation.
I reckon the following is also relevant:
# cat /etc/os-release
NAME="TurrisOS"
VERSION="7.0.0"
ID="turrisos"
ID_LIKE="lede openwrt"
PRETTY_NAME="TurrisOS 7.0.0"
VERSION_ID="7.0.0"
HOME_URL="https://www.turris.cz/"
BUG_URL="https://gitlab.nic.cz/groups/turris/-/issues/"
SUPPORT_URL="https://www.turris.cz/support/"
BUILD_ID="r20300+124-3547565f24"
OPENWRT_BOARD="mvebu/cortexa9"
OPENWRT_ARCH="arm_cortex-a9_vfpv3-d16"
OPENWRT_TAINTS="busybox"
OPENWRT_DEVICE_MANUFACTURER="CZ.NIC"
OPENWRT_DEVICE_MANUFACTURER_URL="https://www.turris.cz/"
OPENWRT_DEVICE_PRODUCT="Turris Omnia"
OPENWRT_DEVICE_REVISION="v0"
OPENWRT_RELEASE="TurrisOS 7.0.0 3547565f245479dc1643ea66828fb55635d49051"
