dbonnes
1
Could someone execute the following command on their Turris & paste the output here:
lxc-checkconfig
I am particularly interested in a router that has not has any reconfiguration of its kernel, or its modules.
Thanks
FWIW, here is mine (but yours will likely be different):
root@sr-router:~# lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup v1 mount points:
/sys/fs/cgroup
/sys/fs/cgroup/systemd
Cgroup v2 mount points:
Cgroup v1 freezer controller: missing
Cgroup v1 clone_children flag: enabled
Cgroup device: enabled
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup memory controller: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, loaded
Macvlan: enabled, loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, not loaded
CONFIG_NF_NAT_IPV4: enabled, loaded
CONFIG_NF_NAT_IPV6: missing
CONFIG_IP_NF_TARGET_MASQUERADE: enabled, loaded
CONFIG_IP6_NF_TARGET_MASQUERADE: missing
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: missing
CONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, loaded
FUSE (for use with lxcfs): enabled, loaded
--- Checkpoint/Restore ---
checkpoint restore: enabled
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: enabled
CONFIG_INET_DIAG: enabled
CONFIG_PACKET_DIAG: enabled
CONFIG_NETLINK_DIAG: enabled
File capabilities:
Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
dbonnes
2
Also, there might be a few bugs in lxc-checkconfig
, and if so, you might want to have a look at:
if ! grep -iq ZX /usr/bin/lxc-checkconfig; then
sed -i '/SETCOLOR_FAILURE/ s/\"\$SET/\$SET/' /usr/bin/lxc-checkconfig
sed -i '/SETCOLOR_FAILURE/ s/ILURE\"/ILURE/' /usr/bin/lxc-checkconfig
sed -i '/xt_CHECKSUM$/a echo' /usr/bin/lxc-checkconfig
sed -i '/E_INSTANCES$/a echo' /usr/bin/lxc-checkconfig
sed -i '/ROUP_NS yes$/a echo' /usr/bin/lxc-checkconfig
sed -i '/CAPABILITIES/ s/ES )/ES; echo \)/' /usr/bin/lxc-checkconfig
echo "### ZX: Formatting fixes applied" >> /usr/bin/lxc-checkconfig
fi
Sure:
# lxc-checkconfig
--- Namespaces ---
Namespaces: enabled
Multiple /dev/pts instances: enabled
Cgroup: enabled
Cgroup clone_children flag: enabled
--- Misc ---
Macvlan: enabled
Vlan: enabled
Bridges: enabled
CONFIG_NF_NAT_IPV6: enabled
CONFIG_IP6_NF_TARGET_MASQUERADE: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: missing
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities: enabled
