Yes, you can use lighttpd to do this.
In fact, LuCI is configured to run as CGI. See /etc/lighttpd/conf.d/luci.conf
However, note that your CGI program will run as the same user as the lighttpd web server, which is running as root on Turris Omnia. To run your tool(s) as an alternate user, you can use mod_fastcgi or mod_scgi or mod_proxy to connect to a daemon running as a different user.
I want to run it as root. I want just hint for hello world, to be able to continue myself. I tried to copy the luci settings and change it for my purpose, but with no success (yes, I restarted lighttpd after change). Now, I have /tools/test.sh file with echo ‘hello’ inside. When I try to access it (http://192.168.1.1/tools/test.sh), it says 404. But more, I need is to receive the parameters somehow if possible (?name=tool-A).
# lighttpd include file for TOOLS
## Set CGI paths
cgi.assign += (
"/tools/test.sh" => ""
## Set aliases to LuCI install directory
alias.url += (
"/tools/" => "/www/tools/"
For start, I would just like to have URL (192.168.1.1/whatever/script.sh) where would be bash script (script.sh) on server, executed by lighttpd and result returned to the browser. So if echo “hello” would be in the script.sh, I would expect to see “hello” when entering the URL in browser.
Never heard of. I will read about it and try. I already found out, that it works under cgi-bin, but I would like to be able to assign another folder. And I still dont know how to read query string (?param=value) from url.
So, I tried it again and I tried to do it as simple as possible to mitigate all possible mistakes. I edited luci.conf to make /www/api dir a CGI dir and I put the same script inside. Now, the results are these:
So, now I know, how CGI works and I set lighttpd to listen on one more port just to point in into my tools folder, to keep it separated from the rest (luci). But, I cannot call it without cgi-bin in URL. Whatever else I set in alias.url, it says 404. Any idea why is that and how to solve it? I would like to call 192.168.1.1:81/somescript.py (for example).
No error in error log (just server started / stopped). I think its a feature for CGI on lighttpd to be able to run just under cgi-bin. Maybe some securoty feature. I don’t have any other explanation.
Since you don’t have any explanation, you probably should refrain from making such unsubstantiated statements, and not only because they are absolutely wrong, and not only because you did not know what CGI was when you first started this post. It reflects poorly on you that you blame the software when you are unable to get something to work, especially when that something is new to you.
As one of the lighttpd developers, I can authoritatively tell you that in a stand-alone config, mod_alias and mod_cgi work as I have described. I say stand-alone config because /etc/lighttpd/conf.d/luci.conf contributes only one part of the lighttpd config running on your Turris.
Running the following will show you what lighttpd sees as your entire config (after all include files have been read and evaluated): /usr/sbin/lighttpd -p -f /etc/lighttpd/lighttpd.conf | less
After doing that you might find that your issue is the generated config from foris (/etc/lighttpd/conf.d/foris), which intercepts everything not explicitly excluded. You’ll have to edit /usr/share/foris/lighttpd-dynamic-conf to carve out any customizations you want.
Aside: Personally, I am not a fan of that foris config and will probably submit some patches to CZ-NIC making foris run as a CGI program, instead of as a fastcgi server. However, Foris running as a CGI is much slower and takes almost 4 seconds to return pages, instead of about 1 second, but I don’t run Foris that frequently, and prefer LuCI, anyway. Also, foris + nuci (not LuCI) are using over 25 MB memory and the bottle server is waking up every 1/2 second from select(). All for something almost never used after initial configuration.
Good to know, that it’s not a feature. I tried to find some intercepting command / setting, but I couldn’t find any. I assume it’s because of me, so I ask you, if you could point me in the result of the command you wrote. I expected something what would overwrite the cgi.assign variable (=) instead of adding (+=), but I don’t see it. What I care about now is the “$SERVER[“socket”] == “:81” {” block. I tried to separate my settings from the original by assigning it to another port, which is better for my purpose anyway. As you can see, I tried to alias the same path by two different aliases. But only “cgi-bin” works. Could you please tell me, what I don’t see? Where could I find the foris intercepting settings? Thank you for being patient with me
If I read it correctly it will capture anything that doesn’t have static, cgi-bin, luci-static or plugins in the request path in the first or second segment.
That’s because foris takes all requests except those specified here. I want to access my scripts on 192.168.1.1/api/, so I add “api”.
Edit /etc/lighttpd/lighttpd.conf
Add this block somewhere after the :80 settings:
$SERVER["socket"] == ":81" {
server.document-root = "/www-api/"
## Set CGI paths
cgi.assign += (
".sh" => "/bin/bash",
".lua" => "/usr/bin/lua",
".py" => "/usr/bin/python"
## Set aliases to API directory
alias.url += (
"/api/" => "/www-api/"
That way I set lighttpd to listen on port 81, with document root in /www-api/, running bash, lua and python scripts and with alias /api pointed into /www-api dir.
The real use for this is to be able to access certain information from host on lxc container. Therefore the port on host on which the webserver listens is accessible only on local network and only from certain IP (the lxc container).
